Multichannel DSD - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By SeeMoreDigital
  • 1 Post By Peter M
post #1 of 12 Old 04-21-2020, 04:52 AM - Thread Starter
Liked: 0
Multichannel DSD
hi
i have many ISO SACDs , many hybrid with 5.1 channels
My receiver can handle DSD from HDMI
The only way to play it is:
1. extract the ISO to DSF files (up to 500MB per track!!!)
2. store it in the NAS
3. Using pioneer BDP 6700 - stream from the net and send to HDMI
does anyone here have a better way?
any streamer/computer/player that can access the ISO directly and send DSD to HDMI?
thanks
Liran Ben Haim is offline
post #2 of 12 Old 04-21-2020, 07:58 AM
mlknez's Avatar
Quoted: 640 Post(s)
Liked: 215
what receiver do you have?
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is offline
post #3 of 12 Old 04-21-2020, 08:16 AM - Thread Starter
Liked: 0
yamaha RXA3050
the receiver supports DSD 5.1
the problem is finding a good transport
right now i have all duplicated , ISO SACD for the Stereo DAC and DSF files for MCH
post #4 of 12 Old 04-21-2020, 08:29 AM
mlknez's Avatar
Quoted: 640 Post(s)
Liked: 215
Not many choices for your situation. You would have to get a new set up. I went through a lot of time and money figuring out what would work well and be most flexible. It is not cheap. Take a look at my signature for some of the equipment that i have.
Also, if you do REALLY want dsd, make sure that you turn off YPAO while playing.
mlknez is offline
post #5 of 12 Old 04-21-2020, 10:07 AM
rdgrimes's Avatar
Quoted: 4068 Post(s)
Liked: 3387
Originally Posted by Liran Ben Haim View Post
hi
thanks
Your search is much easier of you just convert the 5.1 content to LPCM files at 24/88.
Your Yamaha doesn't do anything special with DSD input, it all gets converted to LPCM somewhere.
rdgrimes is offline
post #6 of 12 Old 04-21-2020, 10:28 AM
SeeMoreDigital's Avatar
Quoted: 1181 Post(s)
Liked: 1028
Or even FLAC at 88.2kHz/24-bit
fullhorn likes this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is online now
post #7 of 12 Old 04-21-2020, 02:19 PM
Bill Mac's Avatar
Quoted: 2341 Post(s)
Liked: 3640
yamaha RXA3050
Are you using YPAO room correction? Found that I much prefer converting 5.1 DSD to PCM with my Oppo player. The reason for this is to be able to use Dirac room correction. The sound quality is much better in my room when using Dirac opposed to 5.1 DSD direct.
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound STP-SE (preamp), SX-500s, ST-500, ST-250, Oppo UDP-205, UDP-203, BDP-105, BDP-103, BDP-93, BDP-83, Panasonic TC-P60GT50, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #8 of 12 Old 04-21-2020, 11:15 PM
Peter M's Avatar
Quoted: 441 Post(s)
Liked: 410
I use dBPoweramp to convert my SACD rips to FLAC, and then JRiver to play them.
Cheers,
Peter M is offline
post #9 of 12 Old 04-22-2020, 01:17 PM
Liked: 1028
Out of interest... When you encode to FLAC, what 'sample rate' and 'bit depth' settings do you use?
post #10 of 12 Old 04-22-2020, 05:47 PM
Peter M's Avatar
Quoted: 441 Post(s)
Liked: 410
96/24
Cheers,
Peter M is offline
post #11 of 12 Old 04-23-2020, 02:41 AM
Liked: 1028
96/24
Cheers,
Not wanting to start a DSD/PCM flame war.... Given that the sample rate of an SACD's DSD audio stream is 64 times that of an CD's PCM audio stream (DSD = 2822.4kHz and PCM = 44.1kHz). It's deemed good practice to use increments of 44.1 kHz.
Which I why, whenever I convert DSD to FLAC I personally use 88.2kHz. Although some people convert using 176.4kHz
captainbrent likes this.
post #12 of 12 Old 04-23-2020, 03:47 PM
Peter M's Avatar
Quoted: 441 Post(s)
Liked: 410
The comparisons I've done between my rips and the original discs have revealed no perceivable difference so I'm happy with my process. YMMV.
Cheers,
Peter M is offline
Reply Surround Music Formats
dsd streaming
