Proper format choice - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Leeliemix
post #1 of 9 Old 06-12-2020, 11:14 AM - Thread Starter
mlknez's Avatar
Quoted: 663 Post(s)
Liked: 222
Let's say that I have a 7.1 audio system. I buy a disk that has 3 audio tracks. They are:
Auro-3D 9.1
Atmos
DTS-HD MA 5.1
If my processor can do Auro, Atmos and DTS-HD MA, which is the best track to choose that will maximize the quality of the audio?
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is offline
post #2 of 9 Old 06-12-2020, 11:22 AM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 304
Auro-3D 9.1
Atmos
DTS-HD MA 5.1
Each of those sound processes has varying speaker setups, so it would be dependent on your speaker positions, i.e. Atmos above the head, Auro requires Front overhead channels, etc., DTS is probably the more flexible of the three, IMHO. Hope this helps, I'm sure others will chime in.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX-7/DaLite 125" 2:35:1 Scope Screen; Paladin DCR
Azekecse is online now
post #3 of 9 Old 06-12-2020, 11:24 AM - Thread Starter
mlknez's Avatar
Quoted: 663 Post(s)
Liked: 222
Azeke
It is a standard 7.1 horizontal plane layout... Left front, Center, Right Front, Subwoofer, Left Surround, Right Surround, Left Rear surround, Right Rear Surround.
If i choose the 5.1 track, the rear surrounds will not be used at all of course. So the question is, are the Atmos and Auro down-mixers worthwhile and trustworthy enough to make good use of the rear surrounds without muddying the original quality and intent of the creator. While less enveloping, will the 5.1 mix sound better because the imaging is not left to a down-mixer?
mlknez is offline
post #4 of 9 Old 06-12-2020, 11:27 AM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 304
Then DTS would probably be the best option, just make sure your audio is properly calibrated. You could always test each one and see which sounds better to you, but again proper speaker calibration is important, prior to evaluation.
Azeke
post #5 of 9 Old 06-12-2020, 11:44 AM
Quoted: 593 Post(s)
Liked: 299
The Atmos track should decode basically as a normal dolby trueHD track which are usually 7.1. There is no downmixing as such, it just doesnt decode the extra atmos information without atmos speakers.
Atmos can be dolby digital+ based but thats mostly for streaming, not common on bluray.
captainbrent likes this.
Leeliemix is online now
post #6 of 9 Old 06-12-2020, 11:52 AM - Thread Starter
mlknez's Avatar
Quoted: 663 Post(s)
Liked: 222
So, am I missing some of the audio if I choose the Atmos track? This is an audio only disk.
Sent from my LG-H931 using Tapatalk
mlknez is offline
post #7 of 9 Old 06-12-2020, 12:01 PM
Quoted: 593 Post(s)
Liked: 299
No you wont miss anything. What they do for the last full atmos is more or less move sounds to the upper/top layer. All sounds are in the dolby trueHD track you will hear.
But try them all, all mixes are not created equal so might be one of the others sound better to you on that disc. It may be different on another disc.
post #8 of 9 Old 06-12-2020, 12:32 PM
sworth's Avatar
Quoted: 674 Post(s)
Liked: 485
They will adapt to fit your speaker configuration, each one in a different way. Listen to all of them and decide what you like best.
sworth is offline
post #9 of 9 Old 06-14-2020, 09:18 PM
kokishin's Avatar
Quoted: 1463 Post(s)
Liked: 1607
Auro-3D 9.1
Atmos
DTS-HD MA 5.1
I'm not as familiar with Auro but Atmos and I believe Auro require height speakers. You have a traditional 7.1 floor level speaker configuration. If you try to play the Atmos soundtrack, you will get Dolby TrueHD 7.1.
DTS-HD MA 5.1 will replicate the Side Surround channels to the Rear Surround speakers. So you end up using all your speakers.
Not sure what Auro will do
I expect Dolby TrueHD would be the preferred soundtrack.
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon FTV Stick 4K, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is offline
Reply Surround Music Formats
