Official REL Subwoofer thread... - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #1171 of 1179 Old 05-19-2020, 10:58 AM
blackspider's Avatar
Quoted: 419 Post(s)
Liked: 51
Originally Posted by C J View Post
Question for REL owners. Looking to replace my two Klipsch RP-120s. Not sure which model between the Ti5/7/9 I should be looking at. Room size is 18x18x8 (with one side that opens into the kitchen and dining room), front L/R are sonus faber concerto domus. 50/50 split on HT/Music. The REL website suggested the Ti7 x 2 but I'm worried about dropping from a 12 inch to 8 inch speaker. Will I lose the bottom end of my Home Theater? Will the eights be able to pressurize the room. Like the finish in white
TIA
Start with a T9i & you can always add another one later if you find the need too.
Cheers..
jonctk and C J like this.
55" LG B6 - Nad T758 V3- Anthem MCA 225- B&W 600 s2 speaker series - Stereo Rel S2
blackspider is online now
post #1172 of 1179 Old 05-19-2020, 11:26 AM
C J
Quoted: 27 Post(s)
Cheers..
best place to purchase?
C J is offline
post #1173 of 1179 Old 05-19-2020, 11:49 PM
Quoted: 176 Post(s)
Liked: 45
Cheers..
I would get it directly from the rel official website because of the no risk in home trial offer.
C J likes this.
Do it all or don't do it at all.
Dynaudio Contour 20, REL T/5i's, Bluesound Node 2i, Anthem MCA 225, Musical Fidelity M2si, Wireworld and Analysis Plus cables
yodog is offline
post #1174 of 1179 Old 05-20-2020, 11:09 AM
Liked: 2
REL T1 owner here just checking in....it may be entry-level REL stuff but daaaaang call it the little sub that could!
I'm fascinated with the hookups and can't believe how accurate the high level hookup is with so much xmax. Best part? I picked it up for $140 from a guy who found it for $15 at a thrift shop
C J likes this.
BenjiboyZ28 is offline
post #1175 of 1179 Old 05-20-2020, 12:51 PM
C J
Quoted: 27 Post(s)
Cheers..
Going to order aa single from REL and see how it goes. T9i it is. Thanks again
blackspider likes this.
C J is offline
post #1176 of 1179 Old 05-25-2020, 05:44 AM
jonctk's Avatar
Hi. Anyone tried the REL Subwoofer Hight Cable
by Analysis Plus? I am looking a higher quality one to replace my stock Rel neutrik speakon. Any recommendations?
jonctk is offline
post #1177 of 1179 Old Today, 01:13 AM
Quoted: 136 Post(s)
I haven't tried it but can you try it with your sub or at least demo at a shop?
Philips752 is online now
post #1178 of 1179 Old Today, 11:15 AM
neo_2009's Avatar
Quoted: 384 Post(s)
Liked: 296
What are you trying to achieve with the change? It would unusual for a Company to provide a cable that would degrade their own equipment ...
neo_2009 is offline
post #1179 of 1179 Old Today, 09:16 PM
RPNYC's Avatar
I have the T7i and T9i for in-home demo right now. My dealer gave me a bunch of different cables to try out for myself. I’m not a cable tweaker so I didn’t expect much, but I will be buying the REL Bassline cable regardless of which REL I use. It was definitely better for me than the cable that comes with the subs. The bass was tighter and more defined to my ears, with more weight to it as well. It’s expensive, but I couldn’t unhear it. REL markets it for their higher-end subs, but it sounded great when I tried it with the T9i.
After hearing the Bassline I read about another brand called Signal Cable that makes cables to improve the REL high level connection performance as well. Their website shows them being a lot less expensive than the REL cable.
Also, if you’re looking for a line level cable, I found the Audioquest Boxer cable to sound great with the REL subs in my setup.
RPNYC is online now
Rel , Subwoofers
