Antimode 8033 - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #631 of 646 Old 05-14-2018, 05:30 AM
Ovation's Avatar
Quoted: 188 Post(s)
Liked: 170
Originally Posted by moleman74 View Post
my RX-A3050 has build in subwoofer eq so I am worried that when running YPAO afterward it will mess up the antimode settings with its own eq
It shouldn’t mess anything up. YPAO should just interpret a well placed sub and have less work to do. When YPAO runs a signal to the sub and its mic “hears” it, the sub will be playing an already improved sound. It’s the same idea as what Anthem recommends to those who own a Paradigm sub with a Perfect Bass Kit (essentially ARC for just the sub). They say run PBK first and run the receiver’s ARC with the corrected sub.
Ovation is offline
post #632 of 646 Old 05-14-2018, 05:55 AM
moleman74's Avatar
Quoted: 32 Post(s)
Liked: 3
nice thank you. I think I now have confidence to by the antimode. Are there a specific setting/lift for movies or does it depends on room and subwoofer brand?
moleman74 is offline
post #633 of 646 Old 05-14-2018, 06:04 AM
Ovation's Avatar
Quoted: 188 Post(s)
Liked: 170
I leave it flat, as my SVS goes below 20hz with authority in my small room and the Antimode is primarily taming a significant hump around 20-25 hertz anyway. I tried the lift settings with my older, less capable sub but preferred flat as well.
Ovation is offline
post #634 of 646 Old 05-14-2018, 06:09 AM
moleman74's Avatar
Quoted: 32 Post(s)
Liked: 3
my mksound x10 has Frequency Response: 20-200 Hz (+/- 2 dB in band tolerance) so I guess its flat here as well
post #635 of 646 Old 05-14-2018, 06:21 AM
Ovation's Avatar
Quoted: 188 Post(s)
Liked: 170
I like my bass to be clean and articulate, while many like to run their subs a bit “hot”, especially for movies. The Antimode lift settings are easy enough to try (no need to recalibrate) but you might want to try them before running YPAO. Otherwise, you’ll be changing the sub response after EQ has been applied. Just FYI.
Ovation is offline
post #636 of 646 Old 06-10-2018, 11:47 AM
moleman74's Avatar
Quoted: 32 Post(s)
Liked: 3
i have bought a used antimode cinema and i think its working ok. but i am a bit confused to what the diference between flat and subsonic only is. On the lifting modes it says that it will engage a infrasonic filter that cuts of from 10Hz to protect ported subs. Is the subsonic filter doing the same ??
post #637 of 646 Old 06-15-2018, 12:34 AM
moleman74's Avatar
Quoted: 32 Post(s)
Liked: 3
after have used the antimode cinema on few more movies I must say that I am very disappointed.
In my room with the antimode connected running on flat setting the bass is very boomy and overall to much. If I turn the level down the bass is not near as good as the Yamaha EQ.
I have placed the antimode mic on a tripod in my mlp facing towards center of the room and I ran the sweep 6 times I think.
post #638 of 646 Old 01-27-2019, 03:01 AM
Tobias Secker's Avatar
Quoted: 33 Post(s)
Question Subwoofer
How does this graph look guys? Will I benefit from an Antimode?
Name:	Sub, Audyssey On & Off.jpg
Tobias Secker is offline
post #639 of 646 Old 01-27-2019, 07:33 AM
muad'dib's Avatar
Quoted: 421 Post(s)
Liked: 118
I'm no expert... But since Antimode does not try to fix nulls and only lowers peaks unlike audyssey, I would think the end result would be flatter with Antimode at you have lots of peaks...
I have had Antimode, audyssey xt32, anthrm ARC and PBK..
The winner has always been Antimode...
Something special about this magic box...
muad'dib is offline
post #640 of 646 Old 01-27-2019, 08:19 AM
Quoted: 33 Post(s)
It's looking that way!
post #641 of 646 Old 02-03-2019, 03:00 PM
dondino's Avatar
Hi gang, I had an 8033S that was subsequently sent in and upgraded to an 8033S-II. That was about 6 years ago. Does anyone know if there have been any further improvements/upgrades etc to the 8033S-II since then? Thanks.
ala Yoda...
"Tweeters". Heh! "Treble". Heh! A basshead craves not these things! ...
dondino is offline
post #642 of 646 Old 12-01-2019, 12:43 PM
MATA7's Avatar
Quoted: 77 Post(s)
Liked: 68
hi guys, i have the 8033S-II and i been using it for like 3 years with one sub SVS PB-13 Ultra and love it don't think i can live without it, now i brought a second PB16-Ultra so i will have 2 Sub, my yamaha CX-A5100 have 2 independent Sub Outputs, what would be the best way to connect and setup the 8033S-II with this 2 subs
thanks in advanced
Sony XBR-75X940E | Yamaha CX-A5100 | Anthem MCA 50| Sunfire TGA-7201 | SVS PB16-Ultra Subwoofer, SVS PB13-Ultra, Antimode 8033S-II | 7.1.4 Klipsch RP-450C - RP-260F - RP-240S - RP-160M - 4 In-Ceiling MartinLogan | Nvidia Shield TV | Xbox One | AppleTV 4K
English Is Not My First Language
MATA7 is offline
post #643 of 646 Old 12-01-2019, 04:28 PM
Kal Rubinson's Avatar
Quoted: 1383 Post(s)
Liked: 1322
1. Bass EQ in the Yamaha is awful, so using the 8033 is a good idea.
2. The 8033 accepts only one input but, iirc, it has 2 outputs. Those output are, iirc, of inverted polarity so you have to switch the polarity on one of the subs.
3. So, take only one sub output from the Yamaha, feed it to the 8033 and, after connecting both subs, handle them as one.
However, you need to figure out some way to configure level and phase for each sub independently before all this. I don't know what tools you have for this.
You should also consult SVS for suggestions.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #644 of 646 Old 12-01-2019, 10:35 PM
MATA7's Avatar
Quoted: 77 Post(s)
Liked: 68
thanks kal, my 13 ultra just broke so now i have to deal with that first, again thanks
MATA7 is offline
post #645 of 646 Old 12-02-2019, 08:26 PM
xb243's Avatar
Quoted: 66 Post(s)
Liked: 1
Hi, I'm using the Anti-Mode Cinema with my yamaha avr...just want to know after I've calibrated my subwoofer with the anti-mode, which one should I select before running the YPAO/AVR calibration?
Sub-Sonic or Flat?
xb243 is online now
post #646 of 646 Old 12-06-2019, 09:48 PM
muad'dib's Avatar
Quoted: 421 Post(s)
Liked: 118
Sub-Sonic or Flat?
I use flat...
xb243 likes this.
muad'dib is offline
