Official Rythmik Audio Subwoofer thread - Page 1092 - AVS Forum | Home Theater Discussions And Reviews
 14790Likes
post #32731 of 41391 Old 01-30-2018, 05:21 PM
Hootowls's Avatar
Quoted: 14 Post(s)
Liked: 34
Originally Posted by Jim1290 View Post
Question; is it normal the amp stays a bit warm all the time?
I have followed advise to leave the sub on all the time, but the amp on FV25HP always a bit warm even without play for more than 24 hours. Thank you for your time!
I don't know if this directly answers your question but I found heat information on the website at the following link.
http://www.rythmikaudio.com/faq.html...inktemperature
Jim1290 likes this.
Hootowls is offline
post #32732 of 41391 Old 01-30-2018, 10:09 PM
DonH50's Avatar
Quoted: 3341 Post(s)
Liked: 3489
@Jim1290 : I don't leave mine on, and the FV25HP uses a higher-wattage amp than my F12's, but I think the idle power is in the 4-5 W range, about the same as a nightlight. So I'd expect they would be a little warm to the touch.
@enricoclaudio -- Could you ask Brian why the higher standby power for the class D amps vs. the AB/H amps? Curious... I know class D is least efficient at lowest power so that may have something to do with it.
Originally Posted by Pelly_NV View Post
Did you know Rythmik makes subwoofers? ;D
Yeah, I heard that somewhere, and I think Enrico (who posted in the same vein right above me) thinks so too. Did you have a subwoofer question?
gwsat and Jim1290 like this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #32733 of 41391 Old 01-30-2018, 10:18 PM
Quoted: 852 Post(s)
Liked: 948
@Jim1290
i just went down and checked mine with a heat sensor and all 3 are showing about ~73F (cool to the touch). that's the warmest spot on each, the rest of the amp is in the mid to high 60s. all of mine are set to auto.
PlasmaPZ80U and Jim1290 like this.
serith is offline
post #32734 of 41391 Old 01-31-2018, 01:40 AM
Quoted: 199 Post(s)
Liked: 105
Thank you very much! I have found the above link the other day.
Thank you very much Don, as always. I think that must be the reason.
Originally Posted by serith View Post
@Jim1290
@serith thank you very much for your time! Yes, when on Auto ON it's not warm at all, it's only a bit warm when ON. Thanks again!
serith likes this.
Jim1290 is offline
post #32735 of 41391 Old 01-31-2018, 07:33 AM
Zcars's Avatar
Quoted: 166 Post(s)
Liked: 106
Originally Posted by enricoclaudio View Post
Well when I was married I remember getting my new electronics with a Gucci, Luis Vuitton or Mario Hernandez bag attached to them so the wife didn't complaint. At the end I was buying Onkyo, Marantz and Denon at Trinnov and Lindorff prices but at least the wife was happy
It is give and take, isn't it? My wife just got another new designer bag (that she apparently just HAD to have, because it was somehow so different from the others she has), so I do have some bargaining room. On the LVX12, I measured the footprint and I am a bit concerned that it will be too big for my space. My tv is wall-mounted in a corner facing the main seating area in the opposite corner, with few options for placing a 2 ft sub. Ideally I would get a sealed model but this would cheat myself of the additional benefits for HT use. It may have to go along the wall by the tv but the front will not be facing the MLP if that makes a difference. I realise subs are non-directional but it may affect the results. Also, not sure if it matters what speakers I have, but I only have KEF Q100s as the LR fronts with the Q200c centre.
Zcars is online now
post #32736 of 41391 Old 01-31-2018, 11:42 AM
Quoted: 852 Post(s)
Liked: 948
there is actually some really detailed information a few people were sharing a page or two back with regard to where it makes most sense to place your subwoofer(s) (in a square/rectangle room anyway). most that have them flanking their l/r speakers do it for aesthetics, not because it sounds best there. all else fails do the sub crawl.
serith is offline
post #32737 of 41391 Old 01-31-2018, 01:05 PM
DonH50's Avatar
Liked: 3489
We can't tell where the sound is coming from, but sub placement does make a difference in how the sub interacts with the room, so placement does matter and is audible. It changes the magnitude of peaks and valleys in the frequency response.
DonH50 is offline
post #32738 of 41391 Old 01-31-2018, 02:14 PM
Zcars's Avatar
Quoted: 166 Post(s)
Liked: 106
Thanks DonH50 and serith. As I said, options are limited, so I will play a bit with my current sub to find the best spot then determine if the large LVX12 will work. I think I am leaning towards the LV12R again at the expense of some tactile extension.
Zcars is online now
post #32739 of 41391 Old 01-31-2018, 02:29 PM
AlexanderDelarg's Avatar
Quoted: 223 Post(s)
Liked: 272
Love my LV12R in my HT. Give it a try....
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | Hulu | Roku Ultra | Monoprice 12AWG |
AlexanderDelarg is offline
post #32740 of 41391 Old 01-31-2018, 04:14 PM
Zcars's Avatar
Quoted: 166 Post(s)
Liked: 106
Thanks for the endorsement, I likely will. Since you have one, what is your experience with this sub? I am looking to hear and feel the subtle low frequencies in shows and movies without the muddiness that says "I'm a subwoofer!". I understand a lot of this will occur above 20 Hz and the Rythmik will be very good at providing clean bass. Anything you are aware of missing?
Zcars is online now
post #32741 of 41391 Old 01-31-2018, 10:57 PM
panasonicst60's Avatar
Quoted: 223 Post(s)
Liked: 121
The G25HP box is the same as the G25. If I recall I posted the G25 dimensions a few months back when we were selling the G25 demo unit. Dimensions are 18"(W) x 25" (D) x 24"(H). Amplifiers knobs add extra 1"(W). Brian is assembling one G25HP this week to test it and take some measurements. We won't be able to send it to Josh until mid Summer due to Josh busy schedule, though. That's all the info I have to share.
Are these dimensions including grille and heatsink?
panasonicst60 is offline
post #32742 of 41391 Old 02-01-2018, 06:33 AM
kdaq's Avatar
Quoted: 18 Post(s)
I've had a LV12R for a few years now myself. It's very capable. If you integrate it into your system properly, it will completely disappear, and simply make your main speakers sound better. I've never heard a sub like it before. On the right material, you feel it without it announcing itself, if you know what I mean.
Room modes are definitely a concern though, as with any subwoofer. I have a few problem spots in my room. Using Audyssey XT32 helps, and the primary listening spot I calibrated sounds perfectly balanced in the sub's range.
kdaq is offline
post #32743 of 41391 Old 02-01-2018, 07:35 AM
Bass and Hi-Fi Enthusiast
citsur86's Avatar
Quoted: 1992 Post(s)
Liked: 987
My first entry into "real" subwoofers was an LV12R. I remember when I got it re-watching movie after movie and realizing that I had been missing an entire (and important) part of the audio track. There were sound effects, tactile slam (I had it nearfield), and more generally a full or more complete sound than with my previous HTIB dinky sub. Good luck and if you decide to purchase, please let us know your feedback. Most of us love hearing impressions, good or bad. If bad, there are many here who will step in to help you dial it in correctly.
| 7.2.4 Photos (Updated Photos 1/5) | Frequency Response | Visual: LG 65” B7A OLED | Elite VMAX-2 Electric 120" | Optoma GT1080 Proj |
| AVR/Amps: Marantz SR-6011 9C | Audio Source AMP-100VS | iNuke 1000DSP; TTs: 4x AuraSound Pro |
| Center: B&W CM Center 2 S2 Ed | Fronts: 2x B&W 684 S1s | Side Surrounds: 2x B&W 685 S1 |
| Front/Rear Heights: 4x Polk T15 | In-Ceiling: 2x Micca M-8C | Subs: 2x Rythmik FV15HP |
citsur86 is offline
post #32744 of 41391 Old 02-01-2018, 07:47 AM
Zcars's Avatar
Quoted: 166 Post(s)
Liked: 106
Thanks, my room is definitely a challenge. I have a Denon x2200w with Audyssey MultiEQ XT and I focus the setup in the opposite corner where the sectional is as MLP. Where the current sub is located seems to work, but a Rythmik will offer more for sure and hopefully blend in better than the BIC.
Zcars is online now
post #32745 of 41391 Old 02-01-2018, 07:55 AM
Zcars's Avatar
Quoted: 166 Post(s)
Liked: 106
Yes, it is the "didn't know those sounds were there!" that I am trying to get at. I went straight to an SVS SB-2000 for my living room 2.1 music setup and it does sound good, which is why I notice the shortcomings of the BIC in the HT. I am going to put the SVS in the HT this weekend and play a variety of media. Although it is sealed, it does go down to 19 Hz so it should give me a rough idea of how a better sub could sound and where it can be placed. I am wavering on going with a sealed Rythmik purely for aesthetics and footprint, but I know I will lose out on some LFE benefits. At least I get to play with my toys this weekend in the name of research . Now if only the CDN dollar would improve!
Zcars is online now
post #32746 of 41391 Old 02-01-2018, 10:50 AM
Quoted: 223 Post(s)
Liked: 272
My room is a dedicated HT room that is completely enclosed with no ambient light. 20ft long by 14 ft wide. 9 foot ceilings. Sound panels on the walls. The sub does a great job and with speakers set to small and 80hz handles the rumbles without being localized. I was looking to spend $500 on a sub and after all of my research this is the sub that stood out and I am very happy with it. If money was no problem, then I would have gotten two 15" Rythmik subs. I will add a second LV12R at some point as two subs are always better than one....
gwsat likes this.
post #32747 of 41391 Old 02-01-2018, 11:12 AM
Zcars's Avatar
Quoted: 166 Post(s)
Liked: 106
Thanks for the feedback. If I had a somewhat normally shaped room it would be a no-brainer, and I may even opt for the LVX12, but the opposite corner layout and large opening at one end make it challenging. Duals would be even more challenging, although I am starting to think about how I could get 2 in the tv/speaker corner. I like the LV12R for the price. I am also wondering about the F12 sealed based on specs and size, although it is a lot more money. I want to do it right this time so doing my homework.
AlexanderDelarg likes this.
Zcars is online now
post #32748 of 41391 Old 02-01-2018, 11:23 AM
qguy's Avatar
Quoted: 232 Post(s)
Liked: 112
I am going through a difficult PHASE right now.
I have one subwoofer, F15 and trying to connect two systems to it. (2 channel audio and 2 channel HT) Both system do not have any digital processing. One connects Via RCA and the other via speaker level connection.
The Audio system connects via RCA, Phase is at 180, The HT system connects via Speaker level and phase is at 0. Can I reverse the speaker wire connections to make both in-sync without damaging the sub ?
qguy is online now
post #32749 of 41391 Old 02-01-2018, 12:52 PM
DonH50's Avatar
Liked: 3489
Yes, if you mean swapping the speaker-level input wires at the sub, but I'd probably buy a line-level switch box and do it that way if both have preamp outputs. There may be interaction between the two inputs.
DonH50 is offline
post #32750 of 41391 Old 02-01-2018, 01:04 PM
qguy's Avatar
Quoted: 232 Post(s)
Liked: 112
Will a line level switchbox solve my phase problem ?
qguy is online now
post #32751 of 41391 Old 02-01-2018, 01:21 PM
DonH50's Avatar
Liked: 3489
No, forgot about that, not if one component inverts phase with respect to the other and you have no other way to fix it through a setting in one of the systems.
DonH50 is offline
post #32752 of 41391 Old 02-01-2018, 02:34 PM
Eric HA's Avatar
Quoted: 137 Post(s)
Liked: 232
Well I made it to February, but am chomping at the bit for those F18 kits! I probably need to start building cabinets too. Enrico, do you have an estimated date when the container with the 18" drivers will arrive?
Eric HA is offline
post #32753 of 41391 Old 02-01-2018, 03:03 PM
enricoclaudio's Avatar
Quoted: 4075 Post(s)
Liked: 5093
Why the HT system connects via speaker level inputs? Does your receiver has subwoofer out?
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #32754 of 41391 Old 02-01-2018, 03:35 PM
Quoted: 852 Post(s)
Liked: 948
probably not the best place to ask but figure worth a shot. does anyone have any recommendations for either a quality soundbar or self-powered in-wall speakers (not even sure they exist)? i like watching my guilty pleasure tv shows in the living room and the built-in speakers on the tv are abysmal. i don't want speakers protruding from the wall though or have to buy another receiver because space is limited. i know i could use the multi-zone feature on my denon to power a pair but i'd have to walk downstairs to turn it on nevermind controlling it. i do have the tv hooked up to my home theater pc in the basement though which is pretty cool. i have a wireless keyboard that i created a hotkey for to switch the display between the projector & the tv. now i just need some better sound.
i was going to get these even though they stick out a little but then cancelled the order because i noticed they are ported on the rear and they'd be right up against the wall which isn't going to work.. https://www.amazon.com/Micca-PB42X-P...wered+speakers
serith is offline
post #32755 of 41391 Old 02-01-2018, 03:42 PM
torii's Avatar
Quoted: 3725 Post(s)
Liked: 2121
i have this soundbar in my bedroom and like it...https://www.accessories4less.com/mak...eceiver/1.html
i bought mine from gramophone so not advertising for a4l...
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #32756 of 41391 Old 02-01-2018, 04:06 PM
Liked: 5093
Before having a full receiver and 5.1 system in my bedroom, I had a Denon mini stereo system, D-M39S and it sounded amazing. The New model is the D-M41. It comes with speakers and the stereo receiver has subwoofer out. It sounds much better than a sound bar.
https://usa.denon.com/us/product/hifi/mini/dm41
https://www.amazon.com/Denon-System-...keywords=d-m41
MrGrey likes this.
post #32757 of 41391 Old 02-01-2018, 05:31 PM
Liked: 5093
The container is arriving in about 12 days. I would say that by mid-February we should be able to start selling the DS1820 CI Kit.
Blorton likes this.
post #32758 of 41391 Old 02-01-2018, 07:17 PM
qguy's Avatar
Quoted: 232 Post(s)
Liked: 112
The RCA in is being used by the AUDIO System.
qguy is online now
post #32759 of 41391 Old 02-01-2018, 08:21 PM
Quoted: 223 Post(s)
Liked: 121
I finally got my nad 777 in today and I finally got a chance to dialed in the f18. Damn this sub blows away my old SB13 by a mile. I also modify my svs isolation feets to fit on the f18. I am blown away, pun intended. Wow! Now I got to save up for a second one next year .
TV: OLED65C8P - Receiver: Anthem MRX 710 - Blu-ray: Panasonic UB820 - Cd transport: Cambridge Audio CXC - Amp: Parasound A31 - LCR Speakers: Ascend Towers & Luna Duo - Surround: Noble Fidelity L-65mkII - Sub: Rythmik F18 - Power Distribution: PS Juice Bar II, Signal Cable Magicstrip - Power Cable: PS AC5, PS SC, Shunyata Venom 14 - Speaker Cable: Kimber 8tc, BJC 10 - RCA Cable: AQ Silver - Probe: i1 Display Pro OEM Rev.B - Software: Lightspace HTL, Calman Enthusiast - Bias Lighting - MediaLight
post #32760 of 41391 Old 02-01-2018, 08:35 PM
tvuong's Avatar
Quoted: 2773 Post(s)
Liked: 2617
Originally Posted by panasonicst60 View Post
After kinda setting up my f18 I was slightly disappointed with performance so far to be honest. Coming from a SB13 and this being an 18 incher I was expecting a little more output. Sounds very clean but again I was expecting more output. Not sure if all my settings are correct, maybe someone can tell me the best setting on the amp for more oomph. I do have a new receiver with dirac so I'm still experiencing with a lot of setting that I need to dial in.
Look like you got it all figured out. I like happy ending story
gwsat and audiofan1 like this.
tvuong is online now
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
