Official Rythmik Audio Subwoofer thread - Page 1203 - AVS Forum | Home Theater Discussions And Reviews
 13784Likes
post #36061 of 40630 Old 11-18-2018, 07:17 AM
PlasmaPZ80U's Avatar
Quoted: 2853 Post(s)
Liked: 1044
I've found on models with the compact amp like LV12R and L12, Line In sounds best but I do leave crossover knob at max and 12dB LPF slope. Reducing the crossover knob and/or using 24dB LPF slope makes the mid to upper bass too thin and weak.
Also, using a 100Hz global crossover in the AVR is a lot more seamless with the L12 than the LV12R.
(My speakers can handle a 80Hz crossover easily but the in room response has big dips/nulls under 100Hz or so... therefore the higher than normal crossover is very helpful.)
Another thing is my AVR (Yamaha 2070) has separate crossovers for each speaker pair and the center but I find the bass coming from the sub is more uniform for speaker to speaker with a single global crossover. My ears are particularly sensitive to that.
Samsung 55" MU8000
Yamaha RX-A2070
KEF Q150 Bookshelf x 5
Rythmik L12 Sealed Subwoofer
PlasmaPZ80U is offline
post #36062 of 40630 Old 11-18-2018, 10:39 AM
Rythmik's Avatar
Quoted: 439 Post(s)
Liked: 727
Originally Posted by Stro3579 View Post
I got my sub working really well for HT use. Now I have to figure out how to get good music out of it.
I am glad HT is working well. I agree with plasma80Z in trying out the Line-in. There are some discussions on this forum about double filtering etc. But in reality, SUB out from AVR is only digitally filtered. Depending on brands, some noise can leak into SUB out. In this case, a gradual filtering in LINE-in (with XOVER knob to max and LPF at AVR/12) can fix the problem. Sub level is another consideration. In HT a couple of db hot is good. But for music, one may want to reduce the boost a little bit.
Rythmik is offline
post #36063 of 40630 Old 11-18-2018, 10:58 AM
Quoted: 91 Post(s)
I feel like even in HT there 120hz LFE that the audyssey sets is a little to high (denon-avr-x8500h-receiver). Not sure. But I will change to line out today. What changes do I need to try in avr and amp on sub? I am gonna take a pict of my current settings for just in case. Also in avr, what sub level db is everyone running? Are you using the volume know on back of sub to fine tune output volume during listening? Or in avr?
I would prefer to make adjustments on sub, due to avr being in closet. Havent purchased a rf universal remote yet.
Just a fyi, I'm not knowledgeable on terms, but have a great ear for music. So excuse me if I dont understand tech slang. Please keep it as basic as possible for me.
Stro3579 is offline
post #36064 of 40630 Old 11-18-2018, 11:13 AM
DonH50's Avatar
Quoted: 3311 Post(s)
Liked: 3416
The LFE setting is not in general the same as the sub/mains crossovers. Some AVRs send LFE energy over the crossover into the other speakers and some do not (my old Pioneer did not). The Low Frequency Effects channel is a separate effects channel for movies like the left, right or surround channels. Bass management sends energy from the main channels (typically the L/R channels, some sum from all channels) that is below the crossover to the subwoofer.
I would try setting the crossover to 12 dB/AVR and 80 Hz on the sub for starters. Opinions vary about level; I would adjust the AVR's sub level control so the trim level is perhaps -3 dB then adjust the sub to taste after that by turning up the volume (or down) as desired (without rerunning Audyssey).
You may need to move the sub or listening position a bit for optimal performance.
Madmax67 likes this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #36065 of 40630 Old 11-18-2018, 03:14 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2235 Post(s)
Liked: 3399
My G25HP review was just posted. For anyone who might be interested in reading the article click this link.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #36066 of 40630 Old 11-18-2018, 03:30 PM
Quoted: 91 Post(s)
So you want me to turn the volume on the avr sub level to 12db? Should I still use the line vs lfe input?
Stro3579 is offline
post #36067 of 40630 Old 11-18-2018, 04:06 PM
woster402's Avatar
Quoted: 52 Post(s)
Liked: 44
Great review Jim.
B T C likes this.
__________________________________________________ __________________________________
HT Set-up: Yamaha RX-A2060; Sierra 2 LCR; Luna surrounds; Dual Rythmik F12s plus a L12
Desktop Set-up: Yamaha RX-1040; Ascend Luna's; Polk TL1 Center; Rythmik LV12R
woster402 is offline
post #36068 of 40630 Old 11-18-2018, 07:06 PM
DonH50's Avatar
Liked: 3416
No, the lowpass selector to AVR/12. Check the installation guide. It may be worthwhile emailing or calling Rythmik to have them walk you through the procedure.
DonH50 is offline
post #36069 of 40630 Old 11-18-2018, 07:17 PM
Writer & Reviewer
JimWilson's Avatar
Liked: 3399
Originally Posted by woster402 View Post
Great review Jim.
Thank you. I hope you were able to find something of value in it.
post #36070 of 40630 Old 11-18-2018, 07:20 PM
Quoted: 91 Post(s)
miss understood you, its already on 12
Stro3579 is offline
post #36071 of 40630 Old 11-19-2018, 07:21 PM
tvuong's Avatar
Quoted: 2698 Post(s)
Liked: 2502
As usual, excellent write up, Jim. Thanks for your time and contribution.
JimWilson likes this.
tvuong is online now
post #36072 of 40630 Old 11-20-2018, 10:58 AM
MordredKLB's Avatar
Quoted: 84 Post(s)
Liked: 27
Just discovered I work literally 10 minutes away from Rhythmik Audio's offices. Anybody know if they do demos there?
MordredKLB is offline
post #36073 of 40630 Old 11-20-2018, 11:00 AM
imureh's Avatar
Quoted: 2962 Post(s)
Liked: 3781
They don’t really have a set up to demo stuff as it’s a warehouse. You contact them and see.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #36074 of 40630 Old 11-20-2018, 11:13 AM
millerrh's Avatar
I am in the same boat and was able to work out an arrangement several years ago. I'd contact them to see what they can do for you.
millerrh is offline
post #36075 of 40630 Old 11-20-2018, 11:40 AM
MordredKLB's Avatar
Quoted: 84 Post(s)
Liked: 27
Thanks. I'm still probably about 4 months away from buying anything so I'll contact them a little closer to that time. Was hoping I could pop in over lunch or something to satisfying my curiosity, but I don't want to waste anybodies time right now.
post #36076 of 40630 Old 11-20-2018, 11:43 AM
enricoclaudio's Avatar
Quoted: 3872 Post(s)
Liked: 4758
We don't have demo room in our location. It's a warehouse with an office. But if you are local, you can for sure come by, look at the subwoofers and get the subwoofer you like, bring it to your home and demo it. You have 45 days to try it. If you don't like it, just bring it back for a full refund. Easy peasy
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #36077 of 40630 Old 11-20-2018, 11:48 AM
millerrh's Avatar
Yep, this is exactly what I did. Couldn't remember if that was an official policy or if you were just letting me do it, so glad to hear this is an official policy. I actually ended up taking both a ported and sealed sub to try out so I could compare them both, ended up returning the ported and getting a second sealed. Love them!
jamiebosco and Soulburner like this.
millerrh is offline
post #36078 of 40630 Old 11-20-2018, 12:11 PM
kdaq's Avatar
Quoted: 18 Post(s)
An LV12R has served me exceedingly well for four and a half years, but the time has come...
kdaq is offline
post #36079 of 40630 Old 11-20-2018, 12:42 PM
Liked: 1044
given my experience from the LV12R for 3 years to the L12 recently, you are in for a real treat... going to the F18 is quite the upgrade
kdaq likes this.
Samsung 55" MU8000
Yamaha RX-A2070
post #36080 of 40630 Old 11-20-2018, 01:21 PM
atomicron's Avatar
Quoted: 62 Post(s)
Liked: 87
Looking for a technical explanation why dual G25HP’s have a fuller, deeper, richer bass response across the spectrum and especially at lower volumes (52-55db) and have less wall penetrating bass vs my previous subs both the PB16’s and the SB16’s.
I’ve noticed I can run the bass louder AND have less of the bass escaping the sealed room while maintainer clarity like I’ve never experienced.
I know the TR discussion is ever current here but this is just an observation, a statement, and a question. I’m practically in awe at the bass I hear at very comfortable listening levels, and pleasantly surprised I can hear more of it without my wife texting me to turn it down in the late hours which used to happen.. always. I’m in awe because of how loud I can listen without it disturbing others in the house.
So what is the magic on why I can get a highly improved bass response in every way (cleaner, deeper, more output) compared to similar depth and output with much more wall penetrating bass? I much prefer the contained bass as it lets me enjoy it without disrupting the family.
I know I’m sitting in the best spot I have available which is maximizing what I hear, and maybe that’s all it comes down to compared to my previous subs.. but it just seems like I have “more usable bass” if that makes sense.
muscles, Pradeep2 and Matthew Pool like this.
atomicron is offline
post #36081 of 40630 Old 11-20-2018, 01:41 PM
tvuong's Avatar
Liked: 2502
^^ I think it mostly due to cleaner/tighter less distortion sound from the G25hp’s.
post #36082 of 40630 Old 11-20-2018, 03:50 PM
Alan P's Avatar
Quoted: 6568 Post(s)
Liked: 5920
IME, less "leakage" into other areas of the house means you got the time-alignment right.
Did you do anything different with the new subs in that regard??
basshead81 likes this.
Alan P is offline
post #36083 of 40630 Old 11-20-2018, 03:54 PM
torii's Avatar
Quoted: 3626 Post(s)
Liked: 2061
these rythmik subs can be adjusted just about anyway you want. I can get mine to have actually no ringing, and also be full blown vibrating my house apart. all depends how you like them setup imo.
serith and Soulburner like this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #36084 of 40630 Old 11-20-2018, 04:00 PM
Matthew Pool's Avatar
Quoted: 153 Post(s)
Liked: 44
@Jack1949
I set up my F12SE's using LFE in with Y cable's and do notice an increase in SQ and ease of adjusting bass level (get's louder/more tactile quicker). I still have a ways to go before I'm proficient with all the adjustments when switching between music and movies - especially Rumble Filter and Extension Filter. I'm also getting better with AVR sub levels, trim levels, sub gain and volume.
@atomicron
I'm having the same experience you're having. This is high quality bass.
ID:	2485472   Click image for larger version
KEF R3 L/R | Dual Rythmik F12SE | 2.2 | Yamaha RX-A2080
Matthew Pool is online now
post #36085 of 40630 Old 11-20-2018, 04:08 PM
atomicron's Avatar
Quoted: 62 Post(s)
Liked: 87
I have no doubt this plays a role as well.. the ultra low frequencies are so controlled that it really seems miraculous and I wonder since that is the foundation of these subs if it just makes the whole sound more appealing.
Originally Posted by Alan P View Post
IME, less "leakage" into other areas of the house means you got the time-alignment right. [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]
The placement is different, and I moved my MLP back by 1 foot to accommodate a null zone the new placement caused.
Audyssey XT32 is the only current bass management there is on them. I have them boosted +6db over what Audyssey set them to. I’m on a concreate slab as well.
Here is before and after.
ID:	2485476   Click image for larger version
post #36086 of 40630 Old 11-20-2018, 04:25 PM
Alan P's Avatar
Liked: 5920
Alan P is offline
post #36087 of 40630 Old 11-20-2018, 09:24 PM
Quoted: 76 Post(s)
Liked: 30
Brian/ Enrico
Do you guys have any plans of coming out with a G28 HP? Dual opposed 18s?
rsmt2000 is offline
post #36088 of 40630 Old 11-20-2018, 10:43 PM
Quoted: 847 Post(s)
Liked: 931
Originally Posted by rsmt2000 View Post
Brian/ Enrico
you can have your g28 after i get my fv28.
rsmt2000 likes this.
serith is online now
post #36089 of 40630 Old 11-20-2018, 11:29 PM
Quoted: 166 Post(s)
Liked: 151
Why wait for an FV28 when the Cap 4000 exists now?
ianrozzano is offline
post #36090 of 40630 Old 11-21-2018, 12:07 AM
Quoted: 847 Post(s)
Liked: 931
because it's not remotely the same thing?
my father built himself custom dual vented 18's that are in larger cabinets & fed far more power than the sp1-4000 amp that comes with the jtr cap 4000. however that doesn't directly translate into something i'd like to have though. rythmik subs are extremely tight & accurate and i've come to absolutely love the sound signature--but i just want more. there's really no reason rythmik couldn't make a dual vented 18 if they wanted to as they already have the driver (f18/fv18) and the fv25 is a freight-only option and the fv28 would follow suit. in my opinion they're missing out on a market of sick people like myself that would happily give them more money for such a thing.
the cap4000 sells. the fv28 would too.
dad's subs shown below next to sealed ultimax 15's for reference & a gorgeous pair of paradigm signature s8's. if i just wanted "more" output i would have went the diy route too.
ID:	2485650   Click image for larger version
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
