Official Rythmik Audio Subwoofer thread - Page 1256 - AVS Forum | Home Theater Discussions And Reviews
 13771Likes
post #37651 of 40624 Old 03-26-2019, 08:21 AM
Rythmik's Avatar
Quoted: 439 Post(s)
Liked: 727
Originally Posted by Eric HA View Post
Excellent info Brian, I'm glad that I asked. I have no intention of removing my F18's for a room full of F8's, but your insight does give some credence to the long held belief (by some) that smaller drivers are more accurate.
The driver in F18 is a very good one with controlled inductance. There are manufactures don't even care about and the crossover between mass capacitor and voice coil inductance can happen as low as 60hz. Then they use DSP to cover it up. That does not put the problem away.
audiofan1 likes this.
Rythmik is offline
post #37652 of 40624 Old 03-26-2019, 11:47 AM
audiofan1's Avatar
Quoted: 2356 Post(s)
Liked: 2957
Originally Posted by logan456 View Post
I have F18, I have the extension filter set to 12 mid, sounds pretty good when I watch movies. just curious what everybody else sets theirs to when watching movies?Just curious what the differences are between 12 mid and 18 low and so forth.
I run my F18's on high damping/12hz extension for everything. I suppose clicking to mid damping may provide a little more oomph for movies, but I'm very satisfied with their output and sq.
I'm running 12hz / high damping for everything as well as this provides excellent bass articulation while providing good headroom. I'm also nearing my conclusion on the spikes for the F18 and so far its all favorable
audiofan1 is online now
post #37653 of 40624 Old 03-26-2019, 12:37 PM
torii's Avatar
Quoted: 3626 Post(s)
Liked: 2061
I found my response curves using rew were best at high damping and 12hz.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #37654 of 40624 Old 03-26-2019, 12:46 PM
tvuong's Avatar
Quoted: 2692 Post(s)
Liked: 2490
Originally Posted by jedi1982 View Post
Quick and relatively easy solution for The Force Theater
Love your ‘The Force Theater’. Look clean and beautiful with excellent gears. I bet it sounds amazing there.
jedi1982 likes this.
tvuong is offline
post #37655 of 40624 Old 03-26-2019, 02:13 PM
jedi1982's Avatar
Quoted: 244 Post(s)
Liked: 517
Appreciate it! Yes, thankfully was in a position to be able to build this during our new house build over a year ago and am grateful to have connected with several folks active on this forum that were able to help along the way
The Rythmik's do sound absolutely fantastic along with the other gear in the room
Matt2026 likes this.
jedi1982 is offline
post #37656 of 40624 Old 03-26-2019, 09:53 PM
tvuong's Avatar
Liked: 2490
Originally Posted by Rythmik View Post
Yes. They do. Larger diameter drivers do sound like they have higher inertia. F8 is our smallest sub with lightest weight cone. What I can describe is it has planner speaker characteristic in the bass department. All of these is a comparison I do while all of them have the almost exactly same bass extension contours.
The conclusion is driver inertia is audible. Larger diameter drivers tend to sound more authoritative. But it is even more important to have sufficient cone control to prevent it from getting boomy.
Brian, in the same token, two 15” drivers sub has larger diameter than one 18” driver sub. So does two 15” sub sound more authoritative than one 18” sub assuming both subs use the SAME amp power?
tvuong is offline
post #37657 of 40624 Old 03-26-2019, 10:31 PM
DonH50's Avatar
Quoted: 3309 Post(s)
Liked: 3415
Magnepan uses low-order crossovers and panels with lots of overlap in the frequency range. That provides a more seamless transition among drivers than many conventional speakers, leading to better imaging with no funny "wiggles" in the response through the critical voice range (~300 Hz to 3 kHz). Too many speakers have little discontinuities in the vocal band as the sound moves between (among) drivers to my ears. It's hard to describe but easy to hear; images "snap" into position and there is no change in the sound as voices and instruments slide up and down the (musical) scale. I have since changed to Revel speakers and find they share similar characteristics.
In the interest of maintaining that smooth sound passing through the various drivers and crossovers, it is helpful to have a subwoofer that can handle frequencies well above the crossover. Remember the crossover is not a brick wall dropping to zero on either side; a typical 12 dB/octave AVR crossover means the sub is about half as loud as the mains nearly an octave above the crossover, and the mains are about half as loud an octave below the crossover. Having a sub with a higher frequency response like the F8 helps provide that seamless transition and sense of "air" Brian described. In my case, decades ago I discovered servo subs by inventing my own design, interestingly similar to Brian's. The servo helps provide the equivalent of a much more power amplifier with much lower output impedance to better control the sub's driver. That in combination with a higher-order crossover design enabled me to produce a subwoofer that mated well with my Maggies. Thus, nearly 30 years later, Rythmik was an obvious choice, and one I have been very happy with. As I've said before, I was vexed to discover that subs I felt worthy of my Maggies were in the $3k to $5k range until trying Rythmik. The rest is history.
Oh, the Revels take the opposite approach -- multiple drivers, high-order crossovers, very professionally (scientifically) tweaked to provide a smooth transition from driver-to-driver, not only in frequency response but also in radiation pattern (much more critical in conventional speakers).
Finally, keeping the sub low enough that the energy is pretty much inaudible before reaching that critical voice band is the usual approach, and leads to the 80 Hz crossover often cited. Below the frequency most of us cannot localize the speaker, meaning the sound does not mess up the mains, and allow us to place them for smoothest in-room frequency response without compromising the stereo (or multichannel) image. That means a sub that plays cleanly with low distortion above and below the crossover point. At 80 Hz, a high second harmonic distortion term is at 160 Hz, readily heard and localized. You don't want that, or at least I don't, and another reason I like servo subs (a crossover doesn't matter if the sub's distortion is the source of the higher-frequency sound).
ESLs are tricky -- the panels are essentially big capacitors and so drop very low in impedance at high frequency. However, the vast majority use a transformer to step up the amplifier's voltage to drive the panels, so there's a big inductor in the circuit. Their HF impedance is low because of the big capacitor that is the panel, but looking into the speaker it is not necessarily capacitive. But the wide frequency range and corresponding need for a very clean sub is the same as for planar magnetics (Magnepan) or ribbons (Apogee and speakers with ribbons mid/tweeter drivers).
Sorry for all the babble, HTH - Don
Alan P, Rythmik, audiofan1 and 1 others like this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #37658 of 40624 Old 03-26-2019, 11:51 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1778
This is a good question, but wouldn't you want amp power to be adjusted so that it's at an appropriate level to achieve the same SPL on either system? Then you do the comparison.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #37659 of 40624 Old 03-27-2019, 07:16 AM
Rythmik's Avatar
Quoted: 439 Post(s)
Liked: 727
In this particular case that Tony mentioned, the difference between two 15" and 18" drivers is small. The more obvious case will be 18"/15" vs 12" or even 8".
In all the comparison I have done, the level of the subwoofer is kept the same via SPL meter measurement @40hz. I can further adjust 1db or 2db up and down to compare.
Rythmik is offline
post #37660 of 40624 Old 03-27-2019, 08:55 AM
Liked: 0
Can sub pre out be given to L&R of Rythmik subwoofer
rajeshmahrn is offline
post #37661 of 40624 Old 03-27-2019, 09:55 AM
iamsabit313's Avatar
Originally Posted by chucky7 View Post
Ummm... not according to Data-bass though...
FV18 'only' averaged 0.5dB more from 16~80Hz. $300 is a lot for 0.5dB more, wouldn't you say? [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]
This is where a ranking system may not deliver fair comparison. The FV18 uses 2 ports to provide 12hz tuning vs FV15HP of 1 port. The extra relief below 20hz will give you extra headroom for signals above 20hz. In addition, we now have paper cone version FV18 which increases the output above 50hz even more.
$300 price difference also includes shipping difference: FV18 is shipped via freight and FV15HP is shipped via UPS small package. After you subtract that, the real price difference is $150. It is a bargain for FV18, wouldn't you say?
PS: I have a Houston customer iamsabit313 upgrading from FV15HP to FV18 alu cone. I did help him roll FV18 via a narrow stairway to 2nd floor . That is quite a lot of effort for both of us. He can easily tell the difference that FV18 adds to TR. In short, if size and manageability is key, go with FV15HP. Otherwise, FV18 alu and paper cone both will have an edge over FV15HP.
😂 that was quite an workout Brian-San! Apologize about my tiny staircase opening. You should have stayed for the lunch, food was terrific.
Well, about the difference between FV15HP and FV18 ALC, FV15HP was absolutely terrific but it lacked the ability to replicate the BR2049 experience I had at an IMAX theater in Singapore. Call me crazy, but I’m a huge blade runner fan and I upgraded only because of the opening sequence of BR2049. I also tried PB16Ultra, PSA, HSU and all other id subs that people consider usually. They are all great choices but FV25HP and FV18 were the only two subs that were successful at replicating the aural experience I had watching this movie in the theater. I would go for the FV25 but as Brian San mentioned my upstairs staircase opening is very slim. So it’s quite literally impossible to take such big and heavy things upstairs unless you hire a moving company.
But FV18 exceeded my expectations and in my room and there is a night and day difference in TR and sound quality, ok yeah the last part is subjective but yes, to my ears FV18 has better definitions in instrumental soundtracks, plenty of headroom and ability to scare you in an LFE heavy movie. I was running FV15HP volume at 3 o’clock but on the FV18 I can’t get past 10 o’clock.
Hope that helps.
Rythmik, darrob104 and toddct like this.
iamsabit313 is offline
post #37662 of 40624 Old 03-27-2019, 10:18 AM
enricoclaudio's Avatar
Quoted: 3870 Post(s)
Liked: 4758
Hope that helps.
Funny that you are mentioning BR2049 opening scene as I mentioned to @tvuong , @toddct and @imureh about that scene and they said it's not that impressive. I was watching it last night while testing my new ATMOS speakers with a recently installed Denon X6500H and that scene is one of the best scenes to test subwoofers/ATMOS systems. It is scary as hell and the soundtrack is just AMAZING.
gwsat, darrob104, Eric HA and 6 others like this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #37663 of 40624 Old 03-27-2019, 10:44 AM
imureh's Avatar
Quoted: 2960 Post(s)
Liked: 3779
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #37664 of 40624 Old 03-27-2019, 10:50 AM
toddct's Avatar
Quoted: 284 Post(s)
Liked: 822
On the contrary my good man, me likey that scene! That whole movie is a feast for the ears and the eyes! It's best if you watch it and the original together.
If I did say I didn't think it was impressive, it was probably the margaritas talking.
Todd
BluesDaddy56 likes this.
“People say nothing is impossible, but I do nothing every day.”― A.A. Milne, Winnie-the-Pooh
toddct is offline
post #37665 of 40624 Old 03-27-2019, 11:34 AM
Funny that you are mentioning BR2049 opening scene as I mentioned to @tvuong , @toddct and @imureh about that scene and they said it's not that impressive. I was watching it last night while testing my new ATMOS speakers with a recently installed Denon X6500H and that scene is one of the best scenes to test subwoofers/ATMOS systems. It is scary as hell and the soundtrack is just AMAZING.[/QUOTE]
Yep! Also Joe VS Luv fight scene in the last act is also outstanding in sound design and atmos implementation.
I will come by one day to check out the atmos setup.
Also, I need a sealed unit for the bedroom. Hmm, options and options!
post #37666 of 40624 Old 03-27-2019, 02:58 PM
BluesDaddy56's Avatar
Quoted: 572 Post(s)
Liked: 798
Todd
Agreed. When it came out I took the opportunity to upgrade my copy of the original to 4k Blu ray. Watching both back to back is, well, exhilarating. Extraordinary movie making.
Eric HA, toddct and audiofan1 like this.
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR; Center: Selah Audio BMR-CC; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is offline
post #37667 of 40624 Old 03-27-2019, 07:16 PM
elusiveis's Avatar
Quoted: 30 Post(s)
Thinking about joining the Rythmik family. Need input... for my space (see attached pic), (2) 12's now or (1) 15 now and another one down the road? I currently have a budget 10" subwoofer and it does an ok job. I've installed doors in between basement and storage area. So basement area is somewhat isolated. Thanks in advance.
elusiveis is offline
post #37668 of 40624 Old 03-27-2019, 07:38 PM
banyar's Avatar
Quoted: 223 Post(s)
Liked: 88
(2) FV18s PC 🙂
drh3b likes this.
banyar is offline
post #37669 of 40624 Old 03-27-2019, 07:39 PM
Liked: 0
Those of you with f18s, what frequency are you crossing them over with your speakers? Mine is getting delivered on Friday but I've never used a subwoofer with my speakers before so I'm not really sure how to integrate everything.
aa aw is offline
post #37670 of 40624 Old 03-27-2019, 07:56 PM
bkeeler10's Avatar
Quoted: 461 Post(s)
Liked: 310
Crossover selection is highly dependent on main speaker capability and in-room response of subs and mains. But 80 Hz is a good starting point. If you have the tools to measure (ie REW and a miniDSP UMIK-1 or similar), you would be able to hone in on the most optimal crossover and phase matching.
Sent from my SM-N910V using Tapatalk
Soulburner, audiofan1 and drh3b like this.
System
Transducers: Revel Concerta2 F36 (3), M16 (4); Tannoy AMS 6DC (4); Rythmik F18 (2)
Front end: NAD T758 v3; Outlaw Model 7125
Sources: Panasonic UB820; Oppo BDP-103; Toshiba HD-A2
Projection: JVC DLA-RS440; Seymour CenterStage UF retractable 110" 2.35:1
bkeeler10 is offline
post #37671 of 40624 Old 03-27-2019, 08:40 PM
drh3b's Avatar
Quoted: 2079 Post(s)
Liked: 4205
It depends how deep you want to go into the weeds, and your system. If you are running an AVR like I'm guessing most of us are, you just run Audyssey, or whatever your room correction is, set all your speakers as small, and your crossover to 80 Hz after room correction. Good starting point for everyone, and final point for a lot of us. Also, check out the guide in Enrico's sig for more specific details on Rythmik setup, and the guide in Mike's sig if you want more understanding and details of subwoofer setup.
Laulau's guide in Enrico's sig.
https://www.avsforum.com/forum/113-s...l#post25314641
Mike's Guide:
https://www.avsforum.com/forum/113-s...l#post55725252
toddct, mthomas47 and audiofan1 like this.
My World Beating System!
Spoiler!
drh3b is offline
post #37672 of 40624 Old 03-27-2019, 09:51 PM
DonH50's Avatar
Liked: 3415
It would be great if you could add a door at the stairs as well to seal the room.
It is not large, sans the open stairs, so a pair of 12's would probably do the trick. Especially if your current 10" is "ok". If you may move to a larger space later then a 15" may be a better choice.
IMO -- most here fall into the "anything worth doing is worth overdoing" camp but I need to save for retirement - Don
Soulburner and Matt2026 like this.
DonH50 is offline
post #37673 of 40624 Old 03-27-2019, 09:58 PM
drh3b's Avatar
Liked: 4205
Don't you have a Revel Salon 2 setup? Going up a size on subwoofers from what you think you need is a pittance in comparison. Just sayin'.
drh3b is offline
post #37674 of 40624 Old 03-27-2019, 10:05 PM
DonH50's Avatar
Liked: 3415
Don't really have space (though with my current setup could probably fit a couple of 15") and do not need more. My four little F12's are -3 dB at about 7 Hz in my room and put out enough to damage walls, furniture, and ears. Sometimes overkill just means "kill". And I think my current system is killer just as it is, so there!
Soulburner, audiofan1 and Matt2026 like this.
DonH50 is offline
post #37675 of 40624 Old 03-27-2019, 10:09 PM
drh3b's Avatar
Liked: 4205
Oh, I don't disagree that your system is killer, I am totally jealous. I would love the same thing, just substitute f18s for F12 because I DO subscribe to too much isn't enough, which, unfortunately, goes for my music listening levels.
Spoiler!
drh3b is offline
post #37676 of 40624 Old 03-28-2019, 12:59 AM
audiofan1's Avatar
Liked: 2957
Also, I need a sealed unit for the bedroom. Hmm, options and options![/QUOTE]
Ha! I just flat out stop denying and lying to myself after watching it over the weekend that nothing touches BR2049 !
post #37677 of 40624 Old 03-28-2019, 07:46 AM
Eric HA's Avatar
Quoted: 136 Post(s)
Liked: 232
I am crossing my F18's over closer to 60hz, but my main and center speakers have the capability to dig as deep as needed. If you are using smallish speakers, 80hz would be a better starting point.
Eric HA is offline
post #37678 of 40624 Old 03-28-2019, 07:49 AM
Eric HA's Avatar
Quoted: 136 Post(s)
Liked: 232
A single 15" now, with a second one later would be an excellent strategy. Two 12"s would probably be enough in that space, but two 15"s down the road would assuredly get you where you need to be. Were you thinking ported or sealed?
Eric HA is offline
post #37679 of 40624 Old 03-28-2019, 08:07 AM
elusiveis's Avatar
Quoted: 30 Post(s)
Originally Posted by banyar View Post
(2) FV18s PC 🙂
Something to think about.
Top of stairs has a door, does that count? Do I calculate the entire sqft of basement 21x23 or just the listening area 17x13?
This might be the direction I go. I'm going with ported.
post #37680 of 40624 Old 03-28-2019, 01:10 PM
gopala33's Avatar
Quoted: 202 Post(s)
Originally Posted by rajeshmahrn View Post
Recently I brought Rythmik LV12F subwoofer ....
Connected my subwoofer ( from my Denon AVR's subwoofer preout to LFE in subwoofer ) ....
But the output is very low .... (Subwoofer's volume set at 12'o clock )
When my mobile phone is connected to L&R of the subwoofer .... It plays pretty well .... But when connected to AVR it plays with very low output ...
I think the AVR is sending very low signal to pre out ....
Can I connect pre out to an headphone amp to amplify it and send it to subwoofer's line in ie., L & R ?
most avr very low output for music if watch movies will be high output
i think pre out low output if set master volume -20dB will be low output sub for music if set master volume 0dB will be high output sub but front speaker to much crazy loud that problem
so i have Onkyo A-9070 for stereo but i connected L&R of the subwoofer to Pre out port L&R for Onkyo A-9070
subwoofer will be low output i did set master volume 0dB then subwoofer will be high output but front speaker to much loud so i already disconnect Pre out port then connected L&R of the subwoofer to Line out port L&R for Onkyo A-9070 then subwoofer will be high output so i can set master volume -20dB for front speaker sound enough output
so i can adjust gain sub for 1'o clock or 2'o clock or 3'o clock so my sub amp is dayton spa250 250watts for kicker comp 15' car subwoofer so my set gain 1'o clock i did try 2'o clock or 3'o clock but abit distort due amp limit my kicker 15' sub is 8ohm so low watts will be 156watts so i don't have 4ohm sub so can't run 250watts
that why max gain 1'o clock only to get clean loud
gopala33 is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
