Official Rythmik Audio Subwoofer thread - Page 1277 - AVS Forum | Home Theater Discussions And Reviews
 12182Likes
post #38281 of 39158 Old 05-11-2019, 02:56 PM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
Originally Posted by enricoclaudio View Post
Not sure if these recommendations would fly with your wife but here we go:
1.- Move those bookcases out of the front wall. You are limiting your sound stage having those bookcases on the front wall.
2.- Move each front speaker 1.5 ft - 2 ft to the outside. That would give you a much better sound stage as they would be about 8 ft to 10 ft apart. Right now they are like like 4 ft which with the center between and your seating position at more than 15 ft, what you have is literally a big mono speaker up front.
3.- Place the FV25HP on the right corner like 1 ft from the side wall and 8" from back wall. That would give you enough corner load gain which you need in such a big room.
4.- If you can, move the sofa up front so the distance from the front wall to the sofa is equal to the distance between the main speakers. If the speakers are 10 ft apart, the sofa should be no more than 12 ft from the front wall.
5.- Run calibration and listen again.
Okay I did everything but one quick question, the calibration keeps saying my sub is 33 ft away, do I keep it that way?
Sent from my SM-G975U using Tapatalk
tuner1129 is offline
post #38282 of 39158 Old 05-11-2019, 03:10 PM
enricoclaudio's Avatar
Quoted: 3619 Post(s)
Liked: 4338
The only explanation for that is that you are using LINE IN and the delay/phase knob is all the way up. That would add 16ms which is like 16 ft. Make sure you are using LFE IN or if you are using LINE IN set the delay/phase knob at 0 and crossover on the subwoofer all the way up.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #38283 of 39158 Old 05-11-2019, 03:16 PM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
Ok double checked and just to make sure my eyes are good I took a picture to show if I didn't miss anything?
post #38284 of 39158 Old 05-11-2019, 03:34 PM
Liked: 4338
It looks good. What receiver do you have and what is the physical distance from the mic to the subwoofer measured with a measuring tape?
post #38285 of 39158 Old 05-11-2019, 03:36 PM
torii's Avatar
Quoted: 3205 Post(s)
Liked: 1810
I would put the sub in a corner like I have mine.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #38286 of 39158 Old 05-11-2019, 03:37 PM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
I have Yamaha Aventage 760, I also have a denon 4400 but it's at denon for service. It measure 10.4.
post #38287 of 39158 Old 05-11-2019, 03:38 PM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
I'll try that right now.
post #38288 of 39158 Old 05-11-2019, 03:43 PM
Liked: 4338
Something is not right with your receiver as the distance should be very close to 10 ft. Our amps have no DSP so there is not added delay. Are you by any chance using a wireless subwoofer adapter to send the signal to the subwoofer?
post #38289 of 39158 Old 05-11-2019, 03:49 PM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
No its connected straight into the receiver using the LFE and Sub out 1. I changed the distance to 10.4 as it should be. Here's a picture of the moved set up I use tape measure to distance all speakers equally.
Matt2026 and dinamigym like this.
post #38290 of 39158 Old 05-11-2019, 04:09 PM
Rise & Grind
dinamigym's Avatar
Quoted: 273 Post(s)
Liked: 244
It may not sound good yet but it sure looks good!
iceatola and tuner1129 like this.
dinamigym is online now
post #38291 of 39158 Old 05-11-2019, 06:36 PM
darthray's Avatar
Quoted: 2049 Post(s)
Liked: 2899
Ok forsure yes I only places it there for right now since I was leaving but I had it by the windows on the left side. Tomorrow I'll make alot of the changes and move.
Keep us posted.
Looking forward to see how it turn out
Darth
tuner1129 likes this.
darthray is offline
post #38292 of 39158 Old 05-11-2019, 07:59 PM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
Okay, quick update. This sub is amazing lol. Made all the appropriate changes suggested by enrico helped alot, I still have some nulls but way better now. Also helped that chucky7 Charlie came by and ran the REW to see what we are working with. I forgot to take a picture but I'm getting a mic and mini dsp next week. So far this is a beast, definitely loving it. Nothing but smiles as everything shakes in my house everyone here thank you for your advice and help. I do appreciate it. I hope to get my mic next week so I can make this sound even better with my new speakers.
chucky7, Alan P, LennS and 8 others like this.
post #38293 of 39158 Old 05-11-2019, 08:15 PM
David Charles's Avatar
Quoted: 1104 Post(s)
Liked: 1844
So I had like 2 hrs to play with the fv25hp. I'm at a lost for word of this things shakes my house. The only thing is the blackhole I have in my house seems to suck the frequency. I spend 1 hour moving it inch by inch to multiple places (thank you pads provided by Rythmik) and yet I have awesome sound and then nothing like nothing lol I have no idea maybe my living is cursed or something but I ask if anyone has a idea or something to try I will. Thanks ahead sincerely a noob
. And , please
David Charles is offline
post #38294 of 39158 Old 05-11-2019, 08:33 PM
muscles's Avatar
Quoted: 574 Post(s)
Liked: 766
Man that's awesome! Chucky came by and helped out too! He really knows his stuff, if he can't make it work pretty much no one can. What an awesome community this is. Chucky doesn't even have a Rythmik and he came through.
Greg
chucky7, LennS, darrob104 and 4 others like this.
Subwoofers: Dual Rythmik F18SEs - SB13 Ultra
Speakers: Martin Logan Expressions - Martin Logan ESL-C - SVS Ultra Surrounds - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's- McIntosh MT5 - McIntosh MP100 - Oppo UDP-205 - Panamax M5300PMx2 - Apple TV 4k - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is offline
post #38295 of 39158 Old 05-11-2019, 08:40 PM
chucky7's Avatar
Quoted: 3372 Post(s)
Liked: 4077
Greg
I don't think I have been to your place. I believe it's Marc that came by your place...
Speakers: L/C/R: JTR Neosis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #38296 of 39158 Old 05-11-2019, 08:41 PM
muscles's Avatar
Quoted: 574 Post(s)
Liked: 766
Sorry, I forgot to quote the original post. Did you not go to the inland empire and help that guy with his FV25HP? I went to your house, how could I forget the ULF4000?
Greg
chucky7 likes this.
muscles is offline
post #38297 of 39158 Old 05-11-2019, 09:12 PM
chucky7's Avatar
Liked: 4077
Greg
Yes, I just got back from tuner1129's place.
muscles and tuner1129 like this.
post #38298 of 39158 Old 05-11-2019, 09:17 PM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
Greg
Yes awesome community and he definitely knows his stuff, great guy too. Next weekend I'll be hearing the ULF 4000
chucky7, bulls and muscles like this.
post #38299 of 39158 Old 05-11-2019, 09:36 PM
imureh's Avatar
Quoted: 2633 Post(s)
Liked: 3080
Props Chucky!
chucky7 and audiofan1 like this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #38300 of 39158 Old 05-12-2019, 01:02 AM
Quoted: 24 Post(s)
Liked: 45
For those who own the fv25hp, is it normal for the amp to be warm in standby? I'm moving all the stuff right bow to see if I can eliminate my bulls and voids.
Yes the amp plate is warm for me too. I moved my FV25HP all around the room to find a sweet spot and ended at the left side in front of left speaker. I use "quick mesure" feature with Anthem ARC genesis ( AVM60 ) you can measure the response at each position.
Found 2 similar positions for the room response at MLP. One in the corner (graph was OK) but I felt nothing at MLP. And the second on the left side, where I have accurate and strong bass but still a little dip at 30 Hz.
I told you to be patient because the first times I was upset to see that the sweet spots for my former sub were not ok for the FV25HP. The behavior is very different for each sub.
QUICK measure is a very good thing to check the position of every speaker and for the sub of course. You can use REW too.
With this kind of sub, it's mandatory
I promise you will be very very happy, I tried a lot of subs and YES this one is PITA to move and setup for the first time. Yes it seems to lose some tightness when you're still tweaking, but once it's done, MAN ! it's unbelievable and unrivalled. Trust me, I have Greg's disease. My name is Joseph, and I have a problem . I'm bass addict
Soulburner and tuner1129 like this.
B&W 802 D3 Classe CTM600 ANTHEM AVM60 Rythmik FV25HP
JOSOSA is offline
post #38301 of 39158 Old 05-12-2019, 01:02 AM
Quoted: 24 Post(s)
Liked: 45
Lightbulb
JOSOSA is offline
post #38302 of 39158 Old 05-12-2019, 01:22 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1159
Distance settings in the AVR have little correlation to actual distance. In other words, they usually will not match, and that is okay.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is online now
post #38303 of 39158 Old 05-12-2019, 06:44 AM
BluesDaddy56's Avatar
Quoted: 537 Post(s)
Liked: 724
Originally Posted by Matt2026 View Post
The possibility of a device that produces frequency that causes vibration of the eyeballs—and therefore distortion of vision—was suggested by paranormal researcher Vic Tandy[1][2] in the 1990s while attempting to demystify a "haunting" in his laboratory in Coventry. This "spook" was characterised by a feeling of unease and vague glimpses of a grey apparition. Some detective work implicated a newly installed extractor fan that, Tandy found, was generating infrasound of 18.9 Hz, 0.3 Hz, and 9 Hz."
Definitely sounds like what I experience with an 18.5 hz sine wave generated through my system.
Matt2026 likes this.
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR, Center: Emotiva Airmotiv C2; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is online now
post #38304 of 39158 Old 05-12-2019, 08:32 AM
Rise & Grind
dinamigym's Avatar
Quoted: 273 Post(s)
Liked: 244
So my subs are arriving tomorrow. Although I have a dedicated media room, due to the size of the FV25s I only really have two location options...
1. One is laying on their sides in between the Left & Right Front speakers and center (pic 1):
2. Two is laying on side or standing upright in back of room where Wisdom STS is currently at (pic 2):
From reading obviously it would be ideal to move them around and take measurements but the aisle up the left side is pretty tight so that would be very difficult to do.
Any suggestions on where to best try first...front or back?
Also, since both subs are in identical and will be equidistant from the MPL in either location would a Minidsp 2x4 still be recommended?
PS Due to the size of the STS I only had one option with that so there was no thought or measurement as to where that is currently located.
Thanks Much - Paul
ID:	2565762   Click image for larger version
jsc79 and tuner1129 like this.
post #38305 of 39158 Old 05-12-2019, 08:44 AM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2135 Post(s)
Liked: 3197
Originally Posted by dinamigym View Post
Hi Ralph, I’m breaking every audiophile rule currently! Lol I’m running Magico A3s FR/L, Revel C208 center, SVS Ulta Bookshelf sides and rears, & 6X Goldenear Invisa 7000 for atmos and the Wisdom STS sub.
Actually I would love to hear that system. Conventional wisdom suggests there's no way you would be able to correctly balance and integrate such disparate equipment so I'd be very interested to hear what you have wrung out of it. I imagine that was quite a challenge.
dinamigym and AudioFan810 like this.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #38306 of 39158 Old 05-12-2019, 08:54 AM
Rise & Grind
dinamigym's Avatar
Quoted: 273 Post(s)
Liked: 244
Hi Jim,
LOL! Maybe I just am a very poor judge of sound quality, which is totally possible, but after playing around with my Dirac Live calibrations a bit I think it sounds pretty darn good. Definitely a challenge...I will say I could never get a good result when I tried using Audyssey but Dirac seems to allow me the flexibility to play with it enough to where I'm pretty happy (or at least can live) with the mess until I can get the speakers all on the same page !
Paul
post #38307 of 39158 Old 05-12-2019, 09:29 AM
tvuong's Avatar
Quoted: 2538 Post(s)
Liked: 2172
Thanks Much - Paul
First, congrats on scoring an FV25 pair, second, wow, what a beautiful room. I would go with option 3) one in front laying down and one in back but wait, I also have an OCD problem, so I would go with option 3a) add another FV25 so you will have 2 upfront laying down and one in the back . That should do it for both look and sound
Alan P, mthomas47 and dinamigym like this.
tvuong is online now
post #38308 of 39158 Old 05-12-2019, 09:37 AM
Rise & Grind
dinamigym's Avatar
Quoted: 273 Post(s)
Liked: 244
Thanks for that...very kind! I don't vacation/travel so thats my escape room. Funny thing is I thought about listing your recommendation as option 3 but I was afraid that would be the winner. Ha I'm right there with you in the OCD camp!. If I tried front and back before option 3A ....would you recommend centered on front and back wall or one side center speaker and one side of where STS currently is?
Thanks Again
post #38309 of 39158 Old 05-12-2019, 10:43 AM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
Thanks Much - Paul
That's a awesome room!! I tried them flat and standing both gave me little difference but also its because of my weird room. Try both its definitely going to take time to get it in the sweet spot by well worth it.
dinamigym likes this.
post #38310 of 39158 Old 05-12-2019, 10:47 AM
tuner1129's Avatar
Quoted: 110 Post(s)
Liked: 130
I'll be a copy to that addiction lol but I completely understand I know I have way more to play with and I am fine with it. This is what is fun for me I can spent hours hearing and moving lol I thought I was alone in pursuing and getting certain bass out subs which Rythmik delivered on
dinamigym and JOSOSA like this.
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
