Official Rythmik Audio Subwoofer thread - Page 1282 - AVS Forum | Home Theater Discussions And Reviews
 12126Likes
post #38431 of 39076 Old 05-14-2019, 06:12 PM
Rise & Grind
dinamigym's Avatar
Quoted: 270 Post(s)
Liked: 241
Originally Posted by darthray View Post
Nice room
The new lay out look great, and looking forward for your end results and impressions.
Ray
Thanks Ray!
Trinnov Altitude 16, Magico A3, Magico ACC, Magico A1s, Dual Rythmik FV25HP
Amps- ATI AT523NC, AT524NC, AT528NC
Kaleidescape Terra Server/Strato, Oppo UDP-203, Apple TV4k, XFinity X1
Sony VPL-VW5000, 136" 2.35:1 Stewart Studiotek 100 screen, Lumagen Pro 4242
dinamigym is online now
post #38432 of 39076 Old 05-14-2019, 06:18 PM
darthray's Avatar
Quoted: 2035 Post(s)
Liked: 2885
Originally Posted by dinamigym View Post
Thanks a ton! I’m running Dirac as we speak!
Thanks Ray!
Now time to put that phone down for replying, and to concentrate on your calibration
Darth
darthray is offline
post #38433 of 39076 Old 05-14-2019, 06:23 PM
enricoclaudio's Avatar
Quoted: 3595 Post(s)
Liked: 4282
Now to run Dirac. Thanks again for the suggestion turned out to be a great layout on many levels!
Now my OCD tells me that for the sake of symmetry you need a third FV25HP to place on the left side of the room mirroring the one you have on the right side
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #38434 of 39076 Old 05-14-2019, 06:33 PM
Rise & Grind
dinamigym's Avatar
Quoted: 270 Post(s)
Liked: 241
Ha! How did you know my weakness is symmetry!
post #38435 of 39076 Old 05-14-2019, 06:37 PM
Liked: 4282
I speak OCDish very fluently my friend Just finished installing this Yamaha TF3 in a small venue at church. All cables labelled and hide out if sight. It took me 3 hours just to hide and label the cables but when I see it I feel great
ID:	2566910   Click image for larger version
post #38436 of 39076 Old 05-14-2019, 06:41 PM
Rise & Grind
dinamigym's Avatar
Quoted: 270 Post(s)
Liked: 241
It’s a curse I know well...thanks again Enrico! The subs are beyond belief. You guys make a tremendous product and back it up with even better service!
JOSOSA likes this.
post #38437 of 39076 Old 05-14-2019, 07:11 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2121 Post(s)
Liked: 3142
See, I told you Enrico was OCD. The first step to a cure is admitting it...
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #38438 of 39076 Old 05-14-2019, 07:26 PM
Gary Bechtold's Avatar
Quoted: 141 Post(s)
Liked: 194
Home Theater 5.1 Setup: Marantz AV8805, Sunfire TGA-7401, Monitor Audio Gold GX300 Front/Rear, Monitor Audio Gold GXC 350 Center, Rythmik Audio G25HP, Oppo UDP-203, Samsung PN64F8500
PC Audio 5.1 Setup: Denon AVR-X3300W, Monitor Audio Gold GX100 Front/Rear, Monitor Audio Gold GXC 150 Center, Rythmik Audio F12SE
Gary Bechtold is online now
post #38439 of 39076 Old 05-14-2019, 08:16 PM
darthray's Avatar
Liked: 2885
And then, 11 to go
Unless you always, deny-it
Darth
audiofan1 and JimWilson like this.
darthray is offline
post #38440 of 39076 Old 05-14-2019, 09:00 PM
Bluecow003's Avatar
Quoted: 314 Post(s)
Liked: 295
Originally Posted by Soulburner View Post
Say you have the non-4K Blu-ray of some of these - is the audio track the same?
For the newer ones, the regular blu-ray might have the same Dolby Atmos soundtrack as the UHD disc, but that's not always the case. What you want is the Dolby Atmos mix for the UHD movies I listed. Master and Commander plus Tron Legacy is only available on regular blu-ray, so you're fine with regular blu-ray for those. For the others, they definitely benefit from the Atmos soundtracks.
With my F12s on low-extension and high-damping, plus low-bass EQ, whether it be from Dynamic EQ or from Dirac Live, and combined with my small-room gain, I don't really have a "roll off" of my subs at normal frequencies. It doesn't happen until somewhere below 10Hz...below the point I normally measure. It's nice not seeing any drop all the way to the left edge of the graph
I've run it this way for so long that it's how I've come to expect it to sound.
So the big thing with BassEQ is that although your subs are capable of getting down to 10Hz like mine are as well, most movie soundtracks have low frequency filters that roll off sharply at 20 or even 30 Hz. So for those movies your subs are never playing sounds below 20 or 30 Hz because they have been filtered out by the movie soundtrack. What BassEQ does is people have created custom miniDSP EQ settings specific to each movie that creates huge boosts to the low frequency sounds in soundtracks to bring them back up to similar levels as the other frequencies in the movie. It essentially makes movies full range soundtracks. So you have to load the miniDSP settings for each individual movie when you play it and then take those settings out once the movie is done since the settings are specific to each individual movie. For example, look at Avengers Infinity War below. The dashed line is the movie soundtrack without any alteration is it would normally play. The solid line is after BassEQ settings have been applied. You can see that it significantly increases the frequencies below 20Hz, which really increases the tactile response during the movie. That's only possible with custom EQ curves for each movie plugged into a miniDSP.
Alan P, darrob104 and SuperFist like this.
7.2.4 Setup | Display: LG 77" C8 OLED | Blu-ray: Oppo UDP-203 | Processor: Anthem AVM60 | Amps: Outlaw 7700, Emotiva XPA-5 Gen 2 | Speakers: Paradigm Prestige (2) 95F's, 55C, (4) 15B's, (4) CI-Elite E65-R (Atmos) | Subs: (2) Rythmik F25's
Bluecow003 is offline
post #38441 of 39076 Old 05-14-2019, 09:26 PM
tuner1129's Avatar
Quoted: 109 Post(s)
Liked: 129
How hard would it be to find those custom movie soundtracks? I noticed a noticeable difference between bluray intro in EOT and a downloaded version that Charlie (chucky7) gave me as a reference. Is has more umff to it more wall shaking at the same volume. Thankfully I also just purchased the mini dsp HD but will def be a noob in that region as well.
Sent from my SM-G975U using Tapatalk
tuner1129 is online now
post #38442 of 39076 Old 05-14-2019, 09:37 PM
Bluecow003's Avatar
Quoted: 314 Post(s)
Liked: 295
They are all in the BassEQ thread here:
https://www.avsforum.com/forum/113-s...ed-movies.html
For instructions, scroll down past the list of all of the movies to the first couple of posts in the thread. It goes into great detail explaining how to do everything. It's very simple though once you get it.
Alan P and SuperFist like this.
post #38443 of 39076 Old 05-14-2019, 09:45 PM
tuner1129's Avatar
Quoted: 109 Post(s)
Liked: 129
Thank you very much!
Bluecow003 likes this.
post #38444 of 39076 Old 05-14-2019, 11:16 PM
chucky7's Avatar
Quoted: 3368 Post(s)
Liked: 4044
Actually, the demo clips I gave you are from the avsforum reference bass demo discs, which contain the same high def audio tracks from the source blu-rays.
An easy way to tell is checking out your AVR screen during the clips. You should see DTS-HD Master audio or Dolby TrueHD.
Speakers: L/C/R: JTR Neosis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #38445 of 39076 Old 05-15-2019, 12:39 AM
muscles's Avatar
Quoted: 573 Post(s)
Liked: 762
Unboxed one of the F18SE's tonight and took a look at it. My god, this has to be the best looking sub I have ever seen. The 18" driver looks so badass. My girl came home from work and she said that she "loved" the way it looked, and she doesn't care if it's not as good as the other either. I will unpack the other one and begin the daunting task of integrating it.
Greg
Subwoofers: Dual Rythmik F18SEs - SB13 Ultra
Speakers: Martin Logan Expressions - Martin Logan ESL-C - SVS Ultra Surrounds - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's- McIntosh MT5 - McIntosh MP100 - Oppo UDP-205 - Panamax M5300PMx2 - Apple TV 4k - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is online now
post #38446 of 39076 Old 05-15-2019, 04:23 AM
jsc79's Avatar
Quoted: 310 Post(s)
Liked: 359
Greg
Can’t wait to hear your impressions and how the set up looks. I’m gonna guess the F18 might be your favorite “sound” just a little less on the output side compared to the other 2 models you had.
The F18’s are some sweet looking subs no doubt!
audiofan1 likes this.
jsc79 is online now
post #38447 of 39076 Old 05-15-2019, 05:51 AM
JT78681's Avatar
Quoted: 1509 Post(s)
Liked: 1058
Greg
Pictures man! You always gotta include some pictures when you provide a description like that. Just kidding no but for real maybe snap a few when you get them placed.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #38448 of 39076 Old 05-15-2019, 06:11 AM
JT78681's Avatar
Liked: 1058
I'll break the ice!
ID:	2567062   Click image for larger version
ID:	2567064   Click image for larger version
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #38449 of 39076 Old 05-15-2019, 06:24 AM
Quoted: 271 Post(s)
Liked: 163
Greg
Which driver did you choose, standard or silver?
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is online now
post #38450 of 39076 Old 05-15-2019, 06:35 AM
Rise & Grind
dinamigym's Avatar
Quoted: 270 Post(s)
Liked: 241
Originally Posted by JT78681 View Post
I'll break the ice!
Silver looks really sharp!
JT78681 and Matt2026 like this.
post #38451 of 39076 Old 05-15-2019, 06:40 AM
tvuong's Avatar
Quoted: 2526 Post(s)
Liked: 2130
Greg
With Rythmik subs, you know they are going to sound just as good, probably a bit better than the FV25 and as good as the G25.
tvuong is online now
post #38452 of 39076 Old 05-15-2019, 08:05 AM
Keizer's Avatar
Quoted: 42 Post(s)
Liked: 54
I had to laugh the other day. A friend of mine came over and saw the empty box to my FV15HP that I keep out in my shop. He said "Oh, did you get a new clothes dryer"? Funny part was that he was serious.
Keizer is offline
post #38453 of 39076 Old 05-15-2019, 09:43 AM
imureh's Avatar
Quoted: 2599 Post(s)
Liked: 3026
And to top it all is that most of us consider the FV15HP to be a relatively small sub.
darthray, jsc79 and dinamigym like this.
Subwoofers: Dual Rythmik FV18s Rev 2 with Paper cone
Speakers: PSA MTM-210 L/C/R - PSA MT 110sr Surrounds - 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra & Premium, Apple TV, Minidsp 2X4 HD
imureh is online now
post #38454 of 39076 Old 05-15-2019, 11:08 AM
muscles's Avatar
Quoted: 573 Post(s)
Liked: 762
Standard, my OCD wouldn't allow the silver. The cones on my martin logans are black and I would want them to match. It took me an hour to line up my media center to my TV. I like things uniform
Greg
post #38455 of 39076 Old 05-15-2019, 11:17 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1127
Standard, my OCD wouldn't allow the silver. The cones on my martin logans are black and I would want them to match. It took me an hour to line up my media center to my TV. I like things uniform [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
I'm the same way. I prefer the black cone. I guess I shouldn't be surprised that I really like the look of my incoming Buchardt speakers with the big black waveguide.
darthray likes this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #38456 of 39076 Old 05-15-2019, 12:24 PM
muscles's Avatar
Quoted: 573 Post(s)
Liked: 762
Started to work on this late last night and did another hour during my break today. I hope to be up and running at least to try some sweeps tonight. I apologize for the dirty pictures, I will vacuum and such when everything is where it should be.
Greg
Not sure why its uploading sideways, but its right side up on my end. Oh well, you get the idea. When final placement is done I will bust out the big boy camera.
post #38457 of 39076 Old 05-15-2019, 12:39 PM
Rise & Grind
dinamigym's Avatar
Quoted: 270 Post(s)
Liked: 241
Greg
I know in the grand scheme of things it’s meaningless but I love how the the driver fills the whole face...super cool looking!
muscles and derekmoore like this.
post #38458 of 39076 Old 05-15-2019, 12:42 PM
jsc79's Avatar
Quoted: 310 Post(s)
Liked: 359
Those F18’s with some Crowsons for movies would be a really sweet combo.
Speakers: L/R Ascend Acoustics Sierra 2 - Center - Ascend Acoustics Horizon w/RAAL - Surrounds: Sonance VP62R SST/SUR
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #38459 of 39076 Old 05-15-2019, 12:55 PM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 660 Post(s)
Liked: 297
Greg
Interesting. I've been single for a long time. Sounds like me and my two F18SE's might want to consider hosting a Tupperware party.
B T C is offline
post #38460 of 39076 Old 05-15-2019, 12:55 PM
WOKNROX's Avatar
Quoted: 266 Post(s)
Liked: 191
Better yet..some mini Quakes from Earthquake Sound...
WOKNROX is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
