Official Rythmik Audio Subwoofer thread - Page 1289 - AVS Forum | Home Theater Discussions And Reviews
 13563Likes
post #38641 of 40468 Old 05-22-2019, 07:14 PM
darthray's Avatar
Quoted: 2257 Post(s)
Liked: 3278
Originally Posted by JimWilson View Post
MDF is actually the most common cabinet material for speakers and subwoofers. It's compatible with a wide variety of finishes, including paint, and is rather inert so it makes a good choice for speakers and subwoofers. When you think about the fact it's essentially sawdust and glue fused together with heat and pressure it does make you wonder about some of its properties, but the stuff seems to work well.
+1
Originally Posted by Schrodinger23 View Post
Okay. Thanks. I guess I was just a little confused when reading Jim’s review of the G25HP, where he said there were finish options in, “...black oak veneer, matte black vinyl and a high gloss 'piano' finish.” I understood what he was talking about with the black matte vinyl finish, where it is just vinyl applied directly to the MDF. But, I was assuming that the other two finishes where veneer’s with either a high gloss paint applied for piano black or a stain for the black oak. I’m only asking, since I have very little understanding of woodworking. I didn’t know that MDF could be sanded very smooth and painted directly.
Just for your woodworking education
Actually MDF is very smooth, and very heavy. The one of the reason many quality manufacturer use this as there prefer cabinet material.
Another material that is often use in other quality cabinets, is Birch Marine Plywood. Very heavy and very expensive, between the two. I prefer MDF for it's ease of use, if you built your cabinets.
I once ask why they do not use hard wood or other fancy materials.
The answer was very simple. Speakers and subs re-produce sound, and should not produce sound like an instrument.
Therefor MDF or Birch Marine Wood been the choices, of quality manufacturers.
Since they are very inert, and do not produce there own sound like an instrument.
Darth
darthray is offline
post #38642 of 40468 Old 05-22-2019, 07:30 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1629
Originally Posted by darthray View Post
+1
The answer was very simple. Speakers and subs reproduce sound, and not produce sound like an instrument.
Plywood can be great if used properly:
darthray and tuner1129 like this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #38643 of 40468 Old 05-22-2019, 07:31 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1629
While I do some key words to find the "Harman mode calculator".
Do you have a direct link to provide me, in case I cannot find-it?
https://www.harman.com/room-mode-calculator
darthray likes this.
post #38644 of 40468 Old 05-22-2019, 07:32 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
Originally Posted by Soulburner View Post
Plywood can be great if used properly: https://www.youtube.com/watch?v=EEh01PX-q9I
Crazy that I been watching these type of videos including the one you linked. Since I cant find towers I like i am pursuing making own with custom crossovers and drivers.
Sent from my SM-G975U using Tapatalk
Soulburner likes this.
tuner1129 is offline
post #38645 of 40468 Old 05-22-2019, 07:48 PM
darthray's Avatar
Liked: 3278
Of course, the reason I mention Birch Marine Plywood.
Unfortunately, this video is way too long for my small time on the computer.
That said, working with MDF. Is very dusty to cut and round out the edges, when working as DIY
Did add your link to my favorites, but look it will take me a while to install-it and figure out hoe to install-it properly.
When there is a will, there is a way to figure your personal restriction (computer programs for me)
Thanks!!!
Darth
darthray is offline
post #38646 of 40468 Old 05-22-2019, 08:10 PM
darthray's Avatar
Liked: 3278
You can try those guys;
https://www.madisoundspeakerstore.com/
In my DIY days (late 90'), after I figure what drivers to get for my budget.
They figure the volume of my cabinets require, how far the Tweeter/mids should be from each other within the cabinet.
And even had pre-made cabinets, to test in an sound test room chamber (acoustic chamber).
For DIY, these threads are great place to start;
https://www.avsforum.com/forum/155-diy-speakers-subs/
Darth
darthray is offline
post #38647 of 40468 Old 05-23-2019, 02:39 AM
bear123's Avatar
Quoted: 2655 Post(s)
Liked: 4150
So after lots of testing, I still haven't filled my nulls. So fortunately I'll be getting another fv25hp to fill in the nulls my space is less then 800 sqft and somehow 1 is not enough for me. 2 should fix my nulls and OCD with my right side being different from my left. Can never have too much bass, that's my problem
If you place them symmetrically for aesthetics as if they were speakers for imaging, it may not improve your response. Be willing to put them where they need to go if you want a good response. You might get lucky and symmetrical placement on the front stage might do it, but often does not.
bear123 is online now
post #38648 of 40468 Old 05-23-2019, 05:07 AM
jsc79's Avatar
Quoted: 423 Post(s)
Liked: 502
Yes, duals symmetrical placed in the front does not give me an even response. It cleaned up everything except a null at 45hz for me.
I just spent some time on the REW room simulator and I think I found the perfect spot for a really nice frequency response, will need to run sweeps to verify. Only problem is, I just tried to negotiate it with the wife and she said absolutely not. That’s now in the dining area she said. lol.
She said if anything goes there it will be a small wine fridge. I said I could get something made to make the sub look like a small fridge. Win win!
She is leaving for a long weekend in a couple of weeks. Might have to surprise her when she comes back. Lol
If I am reading the room simulator right, this is a pretty good frequency response right? Most other placement have a big null at 45hz. This placement puts it right in this little nook between my dining area and living area, right where that plant thing is.. I think it would look nice myself.
Name:	spot in room.jpg
ID:	2570584   Click image for larger version
Name:	REW Room Simulator.jpg
darthray, darrob104 and Matt2026 like this.
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2EX - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #38649 of 40468 Old 05-23-2019, 06:44 AM
David Charles's Avatar
Quoted: 1106 Post(s)
Liked: 1846
A push/pull non-vibration sealed sub that is also a wine rack. Now there you go!!!
jsc79 likes this.
David Charles is offline
post #38650 of 40468 Old 05-23-2019, 07:53 AM
Schrodinger23's Avatar
Quoted: 213 Post(s)
Liked: 83
+1
Darth
I think that I finally understand now. Since the MDF is naturally very smooth, then it can be painted with either a high gloss paint for "piano black" or a flat black paint for the "matte black" finish. For those that want the appearance of wood grain, they can get the "black oak grain" finish which would be a vinyl wrap applied to the MDF. Obviously this would be the only way to get the appearance of grain, since MDF doesn't have any grain to it. Is that right?
Schrodinger23 is offline
post #38651 of 40468 Old 05-23-2019, 08:00 AM
BluesDaddy56's Avatar
Quoted: 567 Post(s)
Liked: 790
Or you apply a wood veneer. Just to note, MDF is smooth and hard, but also quite porous. It soaks up a finish if not properly prepped. Google "diy piano black finish" and you'll get lots of info on what it takes to get this finish.
darthray and Schrodinger23 like this.
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR; Center: Selah Audio BMR-CC; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is online now
post #38652 of 40468 Old 05-23-2019, 10:08 AM
Quoted: 213 Post(s)
Liked: 83
Enrico said that all finishes were directly over MDF, when I asked about any wood veneer options. This is why I'm thinking that the wood grain finish is the vinyl wrap. Unless I was misunderstanding him before.
Interesting. It makes sense when you say this, where one might miss this the first time trying to finish it. I have no such plans. I'll just pay for it to be finished well.
post #38653 of 40468 Old 05-23-2019, 10:23 AM
Quoted: 567 Post(s)
Liked: 790
My comment was in general, not what Rythmik does.
post #38654 of 40468 Old 05-23-2019, 11:48 AM
Quoted: 338 Post(s)
Liked: 222
Primarily due to WAF, but also due to a touch of OCD, I too have had to contend with making the best of two subs on the front wall. Placing them exactly symmetrical exaggerated a dip around 55 htz that I had with sub one. I did experiment with placing the 2nd sub unsymmetrically left of my left speaker, as I had about 4ft of spare space available. While I'm sure extensive experimentation could have led to better results, the Mrs shot that placement down the second she saw it without bothering to allow me much chance to experiment with EQ/PEQ and fine tuning the placement.
So I went back to an almost symmetrical placement and experimented with pulling sub2 out from the front wall. Turned out, just pulling sub2 out about 8" from the front wall further than sub 1, led to pulling my 55htz dip from; ~7.5dB +/- with one sub, to +/-10dB with two perfectly symmetrical, to ~3.5-4db+/- with sub2 about 8" further out from the front wall. Very much a noticeable difference in SQ. And they are symmetrical left to right, so no other average OCD people notice this. I have one OCD friend that understands bass reflections, nulls/peaks etc and he inquired about the off set placement relative to the front wall. No one else has ever noticed. Ever.
Regarding the Mrs being out of town, I would definitely capitalize on that for experimentation. Mine hates, absolutely hates hearing Audyssey & REW sweeps, so her absence alone is reason enough to experiment for me, but I've discovered that after the experimentation, in the end, she always endorses the SQ improvements.
It has been a hard fought battle, but she really appreciates the SQ and after some listening time has been willing to compromise on aesthetic considerations. After time, I don't think she would be willing to go backwards. So much so, I'm considering a new battle for Rythmik's big boys. Probably not FV25HP's, but possibly two G25HP's, or maybe two F18's. Maybe even ported two FV18's?
I state all this to say: capitalize on her absence, better to ask for forgiveness than for permission!
I'm willing to bet a small amount she will grow to appreciate the SQ.
And you can always put the plant on top.
darthray, darrob104, jsc79 and 1 others like this.
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is online now
post #38655 of 40468 Old 05-23-2019, 11:50 AM
Quoted: 34 Post(s)
Originally Posted by notpierce View Post
hi all
have a few qs about my fairly recently acquired Rythmik LV12R sub which i was hoping y'all could help me with.
1) played "war of the worlds" scene (where the aliens come out of the ground) to try out the sub & saw the led light at the back of the Rythmik LV12R subwoofer blinking few times. the subwoofer gain was at 5 notches above 12 o'clock (approx 1 o'clock) & the avr's volume at around 14 (have run audyssey with the sub at 12 o'clock which returned a trim for the sub of -5). playing around with the gain and avr volume find that the blinking in that scene starts occuring at about 3 notches above 12 o'clock & avr volume at 15+. if i turned down the gain/avr volume a little then it only blinked once (when the first ray is shot). I've read here that it's a sign of the limiter kicking in, but what does that mean? that the sub could get damaged? should i turn down the gain? what are the possible effects of keeping the gain at such a level that it clips occasionally as such demanding scenes are few.
2) in my setup i found that there's a big difference in the sub being at 12 o'clock where it sounds ok but like a regular sub & at say 2 o'clock where you really feel & enjoy it. is that ok or indicative of any issue? would it be ok to keep it at 2 o'clock if there is no audible distortion?
3) is it ok to flip the Bass extension switch/LPF slope setting while the sub is on & media is playing?
4) sometimes when i skip scenes in a movie there is a slight pop sound from the sub. i also have a klipsch rw12 sub connected & there is no such pop from it. what could that be due to?
5) in one of the pleasant (& unexpected) effects of having the LV12 - the aforementioned klipsch sub before the rythmik came in would rumble & make some creaking sounds in demanding scenes but now when i have both the subs on the klipsch has stopped making those noises. how does the rythmik stop another sub from doing that?
6) is it better to run audyssey with just the LV12R running or both subs on?
7) if i read the quick guide right, for movies Bass extension switch should be LOW & LPF to 12db & for music it should be HIGH-24db? so for what media should the Bass extension switch be on MID?
TIA
anyone?
notpierce is offline
post #38656 of 40468 Old 05-23-2019, 01:23 PM
Quoted: 338 Post(s)
Liked: 222
anyone?
I'm sure others will chime in with their take, but from my perspective high damping is the only way to go. Now I'm a music first guy and willing to compromise with movies/tv. I suspect mid damping is a good compromise for those that dont prioritize music over movie LFE, but want the middle of the road for both and are not willing to get up and change the switch when converting from movies to music. For me, music is priority 1, so I just leave the switch to high and take what I get for movies/tv. You might be the opposite or somewhere in between. The somewhere inbetweener's that don't want to make adjustments from source to source might prefer the mid damping.YMMV.
post #38657 of 40468 Old 05-23-2019, 01:57 PM
enricoclaudio's Avatar
Quoted: 3835 Post(s)
Liked: 4704
I said "body shop" kinda paint finish. You cannot apply topcoat (piano black) directly on the MDF without prepping the surface. The whole process is made by hand and involve around 7 steeps:
1.- Fill with filler any marks, dents or screws.
2.- The whole cabinet is sanded.
3.- Primer is applied. Usually takes 2 or 3 coats of primer.
4.- The whole cabinet is re-sanded and wiped down with thinner.
5.- The topcoat of paint is applied. Same as the primer, 3 - 4 coats maybe necessary. Before the final coat, the whole cabinet is re-sanded with ultra fine sandpaper and clean with a rag.
6.- Apply a coat of lacquer. The same steps as applying the primer and topcoat are used with 1-2 coats usually being used.
7.- Buffing.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #38658 of 40468 Old 05-23-2019, 02:02 PM
PlasmaPZ80U's Avatar
Quoted: 2840 Post(s)
Liked: 1025
hi all
TIA
1) limiter kicks in when the sub is expected to play louder than it can and that is based on the combined effect of the master volume, sw level in AVR, and sub gain knob position. The conventional advice is to set the sw level in AVR at -6dB or lower after adding whatever boost you want and they add more via gain knob if necessary.
(However, you would want to start with a sub gain knob position that results in Audyssey setting the sub level around -10dB to -11dB or so, to allow you to turn up the sw level without exceeding -6dB or so. Then add via gain knob if you need more bass.)
Of course, because the sub can only play so loud, especially the smallest ported Rythmik, scenes with strong bass especially under 30Hz can trip the limiter if you are adding too much bass boost and/or simply have master volume too high. I would find a balance of MV, sw level and gain knob that results in the limiter not engaging at all or only slightly on the most demanding scenes. That will help protect the sub from amp clipping and driver over-excursion.
Brian has mentioned turning things down even just 1-2dB can stop the limiter from kicking in.
2) This is normal, especially with well designed subs like Rythmiks... they only draw attention to themselves when needed. If you want to know the sub is playing at all times you will likely be running things quite hot (ample bass boost).
However, you should respect the limits of the sub (or get more/bigger subs and/or more optimal placement, integration, EQ, etc.)
That means limiter should rarely if ever kick in and the sub amp should not get hot to the touch during long, intense listening sessions. You want to make sure that there is some headroom above your listening levels so that the sub is not constantly being pushed to its limits or beyond.
3) I would switch off the sub before adjusting LPF slope otherwise a loud pop occurs. Adjusting Bass Extension/Damping can be done with sub on, but I would pause or mute audio to be safe. I think if using Line In, crossover knob at max and 12dB LPF slope should be ideal for music and movies. Mid bass extension/damping on the LV12R is the best compromise IMO. High gives up too extension and Low is too boomy for best music SQ to me.
For the rest)
Running duals (properly gain matched and time/polarity aligned) will put less stress on each sub vs. single sub... however, I would use 2 of the same sub for best results and run both through Audyssey.
darthray, darrob104 and notpierce like this.
Samsung 55" MU8000
Yamaha RX-A2070
KEF Q150 Bookshelf x 5
Rythmik L12 Sealed Subwoofer
PlasmaPZ80U is offline
post #38659 of 40468 Old 05-23-2019, 02:09 PM
BadJRT's Avatar
Quoted: 32 Post(s)
Originally Posted by enricoclaudio View Post
In terms of output, the real competition for the SB3000 would be the L22, not the F12. The L22 would have more output and lower extension than the SB3000 at a lower price.
I'm confused.... So your saying the $539 L22 hits harder than your $980 F12?
BadJRT is offline
post #38660 of 40468 Old 05-23-2019, 02:11 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1629
F12 has more controls and deeper extension. L22 has fewer controls and less extension, but more output above 20Hz.
post #38661 of 40468 Old 05-23-2019, 02:16 PM
Liked: 1025
The F12 has 1dB more output at 20Hz than the L12. The L22 is basically 2 L12's with a single enclosure and set of amp controls/connections.
The L12/L22 are considered entry level vs. the F12, which has more amp controls/connections, available aluminum cone, and available high gloss piano black finish.
It also has 14Hz extension vs. 18Hz on the L12/L22... however, with room gain in smaller rooms the L models can still play flat to 10Hz or lower.
Samsung 55" MU8000
Yamaha RX-A2070
post #38662 of 40468 Old 05-23-2019, 02:27 PM
Matt2026's Avatar
Quoted: 909 Post(s)
Liked: 25825
Put it there and put the plant on top of the sub
Your wife might not even notice it
darthray and darrob104 like this.
Regards, Ken (Retired)
7.1.2) Denon 4520CI; Aircom T-8, Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #38663 of 40468 Old 05-23-2019, 02:43 PM
Karami's Avatar
Quoted: 74 Post(s)
Liked: 75
do you tint the primer the same colour as the topcoat?
TV: LG OLED 65inch C7 | Bluray Player: OPPO UDP-203
A/V Receiver: Yamaha RX-V2085 | Surge Protector: THOR PS10
Speakers - Front: Klipsch RP-160M | Center: Klipsch RP-450C | Side and Rear Surrounds: Klipsch RP-250S | Subs: Dual PSA S3600i
Karami is offline
post #38664 of 40468 Old 05-23-2019, 02:53 PM
jsc79's Avatar
Quoted: 423 Post(s)
Liked: 502
Agreed!
jsc79 is online now
post #38665 of 40468 Old 05-23-2019, 03:38 PM
LIKEAUDIO's Avatar
Quoted: 54 Post(s)
Liked: 32
RYTHMIK Sub
I have separates components Pre amp, amp and my speakers have 8" woofers.
Room Open floor priority Music, TV Music videos smart tv use, TV Sports, Movies
20'x20' open floor plan hard floors surface high 12' ceilings
Best Bang for my $ Subwoofer option
LIKEAUDIO is offline
post #38666 of 40468 Old 05-23-2019, 03:42 PM
BadJRT's Avatar
Quoted: 32 Post(s)
[/QUOTE]PlasmaPZ80U;58090104]The F12 has 1dB more output at 20Hz than the L12. The L22 is basically 2 L12's with a single enclosure and set of amp controls/connections.
It also has 14Hz extension vs. 18Hz on the L12/L22... however, with room gain in smaller rooms the L models can still play flat to 10Hz or lower.[/QUOTE]
enricoclaudio In terms of output, the real competition for the SB3000 would be the L22, not the F12. The L22 would have more output and lower extension than the SB3000 at a lower price.
I apologize as I had myself confused on the Rythmik models. I quoted the L12 price for the L22 Enrico suggested for me. But I'd like to get back to my original question. I've recently had opportunities to hear the SVS SB 3000 on several occasions with music playing and it's basically my only frame of reference in the just under $1000 range. I have been doing a lot of reading about Rythmik, PSA and SVS but have been definitely leaning towards the Servo controlled articulation and tightness I keep reading about. Now I realize power isn't everything and I'm looking for the absolute highest output of a sub at the cost of tightness and control, but I also don't want to spend $1000 expecting to hear something close to the SB3000 and then find out the output isn't even close. I don't want the stacked driver configuration of the L22 but I would consider dual opposed drivers for similar price. The SVS is rated at 800 watts RMS and gets great reviews for music, and the PSA S1510 is 960 watts RMS. Now I realize the PSA is a 15" driver and does slightly eclipse the $1000 threshold I was trying to stay under, but that power difference is not something I can just ignore, especially coming from a very reputable company like PSA and SVS. With all that being said, I really want to decide on the Rythmik based on all I've read, but I would like to just make sense of all this.
PS, I'm loving the G25HP and can see where that model probably slams with the best of them and does it even better, but the 300 watt range concerns me with some of the smaller Rythmiks. Maybe you guys can help me? Thanks.
This was my original question that Enrico was replying to in case you guys didn't see it.
BadJRT I only want to know about how hard it will hit compared to the SVS with say rock music that's loaded with double kick drum sequences.
I've all but decided to go with Rythmik but don't want to be disappointed with how hard it can hit, because I'm already assuming it's extremely accurate and
sounds great, but will it slam as hard as the SB3000 is my question. Rythmik uses class D higher power for the G25HP (which is highest on my list of subs for
main system I'm starting soon) yet a lessor power class A/B for this F12 and it concerns me in regards to shear output abilities.
BadJRT is offline
post #38667 of 40468 Old 05-23-2019, 04:31 PM
Quoted: 567 Post(s)
Liked: 790
The L22 is $899 not $539. I think you're looking at the L12.
Madmax67 likes this.
post #38668 of 40468 Old 05-23-2019, 04:33 PM
BadJRT's Avatar
Quoted: 32 Post(s)
You are correct. I posted about that and elaborated on my questions but I don't know what happened to my post. I'm not seeing it anywhere.
BadJRT is offline
post #38669 of 40468 Old 05-23-2019, 04:37 PM
BadJRT's Avatar
Quoted: 32 Post(s)
BadJRT is offline
post #38670 of 40468 Old 05-23-2019, 04:40 PM
BadJRT's Avatar
Quoted: 32 Post(s)
I meant to say I'm NOT looking for the absolute highest power output. I'm having trouble with this site. Sorry I'm new here.
BadJRT is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
