Official Rythmik Audio Subwoofer thread - Page 1293 - AVS Forum | Home Theater Discussions And Reviews
 13555Likes
post #38761 of 40443 Old 05-28-2019, 08:51 AM
imureh's Avatar
Quoted: 2860 Post(s)
Liked: 3587
Originally Posted by dinamigym View Post
I know there is an 11% rule when gain matching a pair of subs. However, what would be proper mic placement for gain matching the FV25HPs? In between the two cones if laying on side and, if so, how far away? Thanks Much! - Paul
It’s important to have the subs in the exact same location with the same mic position when doing this. One at a time.
darthray and dinamigym like this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #38762 of 40443 Old 05-28-2019, 08:54 AM
enricoclaudio's Avatar
Quoted: 3827 Post(s)
Liked: 4701
Between the two cones would be if you are gain matching a FV25HP with a different model, like the FV15HP or FV18. If you are gain matching a pair of FV25HPs, then the bottom driver would be my choice as it's closer to the ports. In fact, because they are identical subwoofers, whatever spot you pick, do it for both subwoofers and you should be fine.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #38763 of 40443 Old 05-28-2019, 09:11 AM
Liked: 4701
As explained by AustinJerry, this is not necessary if you place the mic near field (2" to 3" from the cone or 11% rule which is the 11% of cone radius). This is to remove room gain interaction in the measurements. Doing this way you can have the subwoofers in their final location when gain matching.
darthray, darrob104 and dinamigym like this.
post #38764 of 40443 Old 05-28-2019, 09:13 AM
imureh's Avatar
Liked: 3587
Originally Posted by enricoclaudio View Post
As explained by AustinJerry, this is not necessary if you place the mic near field (2" to 3" from the cone or 11% rule which the 11% of cone radius). This is to remove room gain interaction in the measurements. Doing this way you can have the subwoofers in their final location when gain matching.
Looks like I need to revisit how I have my FV18s set up
imureh is offline
post #38765 of 40443 Old 05-28-2019, 09:26 AM
Rise & Grind
dinamigym's Avatar
Quoted: 324 Post(s)
Liked: 292
Thanks a ton guys!
Trinnov Altitude 16, Magico A3, Magico ACC, Magico A1s, Dual Rythmik FV25HP
Amps- ATI AT523NC, AT524NC, AT528NC
Kaleidescape Terra Server/Strato, Oppo UDP-203, Apple TV4k, XFinity X1
Sony VPL-VW5000, 136" 2.35:1 Stewart Studiotek 100 screen, Lumagen Pro 4242
dinamigym is offline
post #38766 of 40443 Old 05-28-2019, 12:42 PM
gwsat's Avatar
Quoted: 4471 Post(s)
Liked: 5819
When I got my FV18s a couple of years ago, I set them up equidistant from the MLP and ran REW. After I got everything so it sounded good to me, I posted my measurements in the REW thread. My betters there, the Wise Men regulars, said the measurements looked just fine and I have been very pleased with my setup ever since. Once again, thanks to Austin Jerry and the others who helped me.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB and Terra Server 24 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+; Apple TV 4K
gwsat is offline
post #38767 of 40443 Old 05-28-2019, 03:57 PM
BadJRT's Avatar
Quoted: 32 Post(s)
Originally Posted by MattiasG View Post
Oh so recognisable. I started looking out for a sub (don't have one) almost a year ago.
Went from wanting the L12, to F12, to E15, to E15HP2. Now I'm fixed on the F18 but I feel that G25HP somewhere in the back of my mind
Considering the spot and our current situation with moving to another house being in our very near future (hopefully very very near!) I wouldn't go with a bigger sub, even if my wife suggested I did so. This house we're in is nice but so very small that this E15HP2 is going to look like a refrigerator sitting next to my little couch. My wife is going to have a brief WTF moment but will be ok with it after a little while. But I know how you feel. I've been bouncing all over the place on what type/brand subs I'm getting as soon as we find a house. I know for sure I'm getting the hardest hitting dual sealed sub setup I can find for under or somewhere around $5K. That's one reason I'm going to give this Rythmik a shot, as it may give me some insight into what I end up with when I start building my main system from scratch. I've looked very hard at the Seaton Submersive HP and HP slave setup and still consider it possibly my top choice when it comes time. Those Rythmik G25HP's look promising but I have no idea what type of output they're capable of when comparing to Submersives or even a set of PSA S3611's. This Rythmik I'm about to place an order for has the same amp as the F18 and the G25HP has basically the same amp but with two 900 watt output modules - one for each 15" driver. Speaking of which, does anyone know how the G25HP driver differs from the E15HP2's driver? Is there a difference? I just hope this Rythimk really impresses me, as it'll set the tone for a future setup I can't wait to get started on.
BadJRT is offline
post #38768 of 40443 Old 05-28-2019, 04:06 PM
Liked: 4701
The E15HP2 has the same driver as the FV25HP and G25HP subwoofers, the DS1520 driver.
post #38769 of 40443 Old 05-28-2019, 04:14 PM
BadJRT's Avatar
Quoted: 32 Post(s)
Thanks, and how does the DS1520 differ from the DS1510 that's in the E15HP or the F15HP?
BadJRT is offline
post #38770 of 40443 Old 05-29-2019, 01:16 AM
Madmax67's Avatar
Quoted: 2224 Post(s)
Liked: 2516
See post #35775 .
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #38771 of 40443 Old 05-29-2019, 07:23 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1627
See post #35775 .
Link doesn't work on mobile.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is online now
post #38772 of 40443 Old 05-29-2019, 08:24 AM
Quoted: 192 Post(s)
Liked: 211
Doesn't work on desktop either.
Monitor Audio RX2 & SVS PB-1000
DEQ (15dB RLO) | Subwoofer Gain: 25/40
Creator of https://freeaudioconverter.net
Ferrari_1996 is offline
post #38773 of 40443 Old 05-29-2019, 01:17 PM
BadJRT's Avatar
Quoted: 32 Post(s)
"DS1510 is 3ohms and DS1520 is 2ohms." That is all it says on the post link 35775. I don't know if there are other differences or that is the only difference. Doesn't really tell me much. I'm still waiting on a more definitive answer from enricoclaudio.
BadJRT is offline
post #38774 of 40443 Old 05-29-2019, 01:25 PM
jamiebosco's Avatar
Quoted: 757 Post(s)
Liked: 1869
Why? That post was by Enrico, it sounds like the difference between them IS the impedance
TV: Panasonic P65ST60 AVR: Denon X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is online now
post #38775 of 40443 Old 05-29-2019, 01:38 PM
Liked: 4701
That is correct my friend Jamie. The only difference is impedance. DS1510 is 3ohms and DS1520 is 2ohms. We had to lower impedance to 2ohms on DS1520 for it to handle up to 1100 watts RMS. DS1510 can handle up to 800 watts RMS.
jamiebosco likes this.
post #38776 of 40443 Old 05-29-2019, 01:38 PM
BadJRT's Avatar
Quoted: 32 Post(s)
I don't know what was asked that Enrico was answering. Maybe the question was specifically about impedance and that's exactly what he answered. What if there's also a difference in linear excursion or driver depth? My point is I'm about to buy one of these and I want an answer that simply says impedance is the only difference, if that is indeed that case.
BadJRT is offline
post #38777 of 40443 Old 05-29-2019, 01:39 PM
BadJRT's Avatar
Quoted: 32 Post(s)
Thank you Enrico.
BadJRT is offline
post #38778 of 40443 Old 05-29-2019, 01:45 PM
Liked: 4701
Container Update!!
The container with FV25HPs and G25HPs and other subwoofers on backorder is scheduled to arrive at our warehouse this Friday, May 31st. We should be able to start shipping next Monday, June 3rd all pending orders and new orders as soon we catch up with all pending orders. Thanks for you patience!!
tuner1129 likes this.
post #38779 of 40443 Old 05-29-2019, 01:56 PM
Madmax67's Avatar
Liked: 2516
It's not a link. It just shows up like that when numbers are placed beside the # sign. I should have copy/ pasted the post itself as well. My bad.
Madmax67 is offline
post #38780 of 40443 Old 05-29-2019, 02:00 PM
Madmax67's Avatar
Liked: 2516
That answer was from Enricoclaudio. Can't get much more definitive than that.
EDIT: Sorry, missed jamiebosco's post before mine. Not a pile on. Main thing is you get the correct information you need to make an educated buying decision.
Madmax67 is offline
post #38781 of 40443 Old 05-29-2019, 02:10 PM
Madmax67's Avatar
Liked: 2516
That's my bad. I just thought you would go to that post and read the question preceding it to see the context. That wasn't a link I made. Just the # sign before a number shows up as a link. Least that's how it works on Tapatalk. I don't use the actual AVS website as a daily driver for threads.
Madmax67 is offline
post #38782 of 40443 Old 05-29-2019, 02:13 PM
BadJRT's Avatar
Quoted: 32 Post(s)
No big deal. On the phone with Enrico now. Getting all kinds of good info!!
BadJRT is offline
post #38783 of 40443 Old 05-29-2019, 02:15 PM
Madmax67's Avatar
Liked: 2516
Cool deal. Get all that knowledge you can. Makes writing that check a little less painful.
drh3b likes this.
Madmax67 is offline
post #38784 of 40443 Old 05-29-2019, 02:29 PM
BadJRT's Avatar
Quoted: 32 Post(s)
haha, I'm about to send Brian and Enrico an email for billing info. I'm pulling a WAF sidestep. This E15HP2 is gonna show up on our CC as costing $573.00 and then 900 on grocery store visa's I just bought for cash. She'll be so much happier this way. I'm just wondering how long it'll be until someone who I'm not aware of is at my house and knows a little something about audio and says wow, that sub really hits hard and then my wife blurt out, yeah and it only cost $573 I told him he didn't need to spend over a grand on a sub. She'll be saying...'see honey he thinks that sub sounds great, aren't you glad I talked you out of spending over a grand on a stupid subwoofer. LOL
Matt2026 and drh3b like this.
BadJRT is offline
post #38785 of 40443 Old 05-29-2019, 02:42 PM
Madmax67's Avatar
Liked: 2516
LMAO. That's hilarious. Just know that I saw that particular tactic when I was selling cars and it went both ways as to which signficant other was doing the money moving. One time I got 10 grand in cash coming out from under a hat, both shoes and I stopped physically taking it when he reached for his belt
Forgiveness over permission
[i]No plan survives first contact with the enemy[i]
Hopefully you don't talk in your sleep !
enricoclaudio, drh3b and BadJRT like this.
Madmax67 is offline
post #38786 of 40443 Old 05-29-2019, 04:53 PM
BadJRT's Avatar
Quoted: 32 Post(s)
Enrio, Did you get my email with the three billing instructions? I haven't received anything back and I just want to make sure this process is officially underway. I'm very excited to have finally purchased a sub after well over a year of creeping and stalking sub and audio forums. Another question I forgot to ask you - how can I see photos of the black matte finish? I ordered black oak but would like to make sure that's the finish I want.
Thanks, Brian
BadJRT is offline
post #38787 of 40443 Old 05-29-2019, 05:07 PM
torii's Avatar
Quoted: 3590 Post(s)
Liked: 2024
every setting on rythmik subs and mic position will change your rew results....I can demonstrate almost every possible freq response now after 2+ years of trial and error. if using audyssey make sure sub set to low rumble filter off. once audyssey ran then tweak sub. with all the rythmik settings on amp, everyone should be able to find great sound with rew if they put in time.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #38788 of 40443 Old 05-29-2019, 06:03 PM
BadJRT's Avatar
Quoted: 32 Post(s)
I know absolutely nothing about digital room correction software/hardware. In fact after just now reading your post I did a search and saw the Dirac Live website but haven't had a chance to look it over. Is this something I can just download to a pc or phone? Do I have to buy mics and other hardware?
PS, does anyone know why my avatar isn't showing up? I put one on there quite a while ago and it shows up when I look up my own info, but it's never beside my name in the threads/posts.
BadJRT is offline
post #38789 of 40443 Old 05-29-2019, 06:25 PM
torii's Avatar
Liked: 2024
dirac can be bought with minidsp for 500 dollar license or something....I use audyssey. rew is free and only mic and laptop needed.
darthray and BadJRT like this.
torii is offline
post #38790 of 40443 Old 05-29-2019, 06:45 PM
Liked: 4701
Thanks, Brian
I got your email and forwarded it to Brian asking for the order link. I sent you the photos a few seconds ago.
BadJRT likes this.
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
