Official Rythmik Audio Subwoofer thread - Page 1294 - AVS Forum | Home Theater Discussions And Reviews
 12450Likes
post #38791 of 39455 Old 05-29-2019, 07:01 PM
darthray's Avatar
Quoted: 2098 Post(s)
Liked: 2987
Originally Posted by BadJRT View Post
I know absolutely nothing about digital room correction software/hardware. In fact after just now reading your post I did a search and saw the Dirac Live website but haven't had a chance to look it over. Is this something I can just download to a pc or phone? Do I have to buy mics and other hardware?
PS, does anyone know why my avatar isn't showing up? I put one on there quite a while ago and it shows up when I look up my own info, but it's never beside my name in the threads/posts.
Not a computer expert, and struggle with computer stuff
That said, it could be as simple as this.
Click on your user name, then "Tools". Follow by "user CP" than "Edit Avatar"
The following should show-up;
"Avatars are small graphics that are displayed under your username whenever you post.
Do not use an avatar (there will be a circle, the left side of this sentence)
Note: if you have a custom avatar selecting this option will delete it."
Make sure, you did not click on that circle. If you did my mistake, click on-it again so the circle is blank.
Hopefully this work for you, if not it could be a case where the end user need so many post before using this option.
Darth
BadJRT likes this.
darthray is offline
post #38792 of 39455 Old 05-29-2019, 07:05 PM
nonstopdoc1's Avatar
Quoted: 521 Post(s)
Liked: 113
One of the threaded inserts (in which the feet screw in) in my sub is freely rotating inside the MDF cabinet. Any ideas on how to fix it? Will gorilla glue work?
My Build Thread
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | Denon AVR | QSC DPA 4.2 | ATI AT528NC | Procella P8/P5V | Revel C763L | Rythmik FV15HP x2
Living Room - LG OLED 65" | Yamaha 2060 | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia CC | Polk Surrounds | Monolith 12" Subs x 2
nonstopdoc1 is offline
post #38793 of 39455 Old 05-29-2019, 07:17 PM
darthray's Avatar
Liked: 2987
Not an uncommon problem.
First you need to remove the threaded insert, could be difficult.
Using a small needle plyer, to put pressure inside and going counter wise to pull up. Work many time with some patience.
If things get stuck, but do have little space to insert a small flat screwdriver. You might be able to work it out.
Those process require lots of patience, since you do not want to damage the MDF on the cabinet.
Once out, inspect the inside. To make sure your Philips crew driver still have a good bit, to re-insert.
If not, go to your local Hardware store, and buy a matching one (very cheap to get).
Once ready to re-insert, normal wood working glue will work just fine.
If the hole is too loose, use the glue and insert a/or few tooth wood pick-it. Push in, and break the top part.
Or fill the hole with some wood filler, insert back the threaded insert. Using pressure and crewing-it until flush. Clean the wood filler that came out.
Let the glue/wood filler cure 24 Hours, even if it say 4 hours.
And should be good as new.
Darth
darthray is offline
post #38794 of 39455 Old 05-29-2019, 08:08 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Quick update if I may: Last Friday I acquired my 2nd fv25hp from Greg, which by the way got to see and hear his set up and oh man is that some sweet equipment I personally loved the sealed sub with the Martin Logan's they had absolutely no distortion. Thanks Greg! You ruined how my speakers sound forever jk lol need to get those speakers. So after moving and using the REW I came to a conclusion, data can only fix so much. My ears are the true and final test and going against the grain I used my ears to set my gains and position. I fixed about 90 percent of my nulls by doing so. I spent more time with the REW mic/software then I had anticipated and couldnt find a solution my ears fixed. These subwoofers are the best damn mini fridges I've ever heard. There my taste and I'm happy with my choices sticking with Rythmik. To everyone here who has helped me I thank you, I ain't going no where cause I am building a dedicated HT and will most likely by a 3rd fv25hp lol Yes I am that crazy about bass. Will definitely have alot of questions that I hope I can get inside from you guys. Also yes I know my center is tiny lol
Sent from my SM-G975U using Tapatalk
chucky7, serith, audiofan1 and 8 others like this.
tuner1129 is offline
post #38795 of 39455 Old 05-29-2019, 08:30 PM
Quoted: 155 Post(s)
Liked: 48
Man, I ALMOST bought that one from him...but it came to down me having shared walls in a duplex. I have decided to go sealed to not anger the neighbors. So, REALLY, I am the one who is owed a big thanks! haha, enjoy man, I bet your system thumps
muscles and tuner1129 like this.
Ethos4Lyfe is offline
post #38796 of 39455 Old 05-29-2019, 08:42 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
hey man sorry you couldnt have it but I am sure enjoying it lol so far my water tank heater somehow broke but not sure if I can pin it to the subs. These hurricane proof front window I am kinda worried about lol sucks I cant upload a video of things going crazy here. Thankfully my neighbors know me as the Oh it's that time the day for him lol sealed are awesome!
Ethos4Lyfe likes this.
post #38797 of 39455 Old 05-29-2019, 10:06 PM
Quoted: 155 Post(s)
Liked: 48
haha so cool! im gonna go w/ a g25hp i think! god speed to you, your neighbors, your water heater, your windows, etc...
Geronimo.USMC and tuner1129 like this.
post #38798 of 39455 Old 05-29-2019, 10:51 PM
serith's Avatar
Quoted: 776 Post(s)
Liked: 805
we must be related...
7.0.6 / 1700 ft³ / PSA MTM-210T³ / Epson HC 2150 / 147" AT 2.39:1 Spandex Screen / Seatcraft Rialto³ / Velvet Everywhere / Chasing LFE
serith is offline
post #38799 of 39455 Old 05-30-2019, 05:02 AM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2155 Post(s)
Liked: 3238
For sure, your LCR setup now has to match what the subs can do.
dinamigym likes this.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #38800 of 39455 Old 05-30-2019, 07:52 AM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Lol yes it would appear we are! Mam they look awesome in this photo
post #38801 of 39455 Old 05-30-2019, 07:53 AM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Totally agree and working on custom speakers, for now the rp 600 will have to do and I have the center klipsch but cant mount it on the wall.
post #38802 of 39455 Old 05-30-2019, 01:35 PM
BadJRT's Avatar
Quoted: 32 Post(s)
Darth
Thanks, got it! I'm so excited about getting my first Rythmik... I can't wait!!
darthray, Matt2026, drh3b and 1 others like this.
BadJRT is offline
post #38803 of 39455 Old 05-30-2019, 02:54 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Here's a question. Is it normal for a woofer to be this color? My other one is fine, I even switch them thinking it was a reflection but I'm stumped?
post #38804 of 39455 Old 05-30-2019, 02:55 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Here's the picture sorry
post #38805 of 39455 Old 05-30-2019, 05:05 PM
Geronimo.USMC's Avatar
Quoted: 302 Post(s)
Liked: 178
Just ordered my 1st piano gloss G25HP. Thanks Brian, and Enrico.
I had dual SVS SB16, and sold them a couple months ago to try Rythmik.
My plan: Buy one G25HP, add another one later.
I was lucky enough that I was able to buy a Rythmik L22. I really like it. Very nice sound quality. I probably will sell it down the line to help fund my 2nd G25HP.
In the meantime, who here is mixing different Rythmik subwoofers?
I'm probably going to use both the L22, and G25 together. I hope the L22 will not affect the sound quality of the G25HP.
audiofan1 likes this.
- AUDIO: (7.2.4 Atmos) EMOTIVA RMC-1 | McIntosh MC-8207 + CROWN XLS 2502, 1502 | KEF LS50, SVS Prime Elevations, RYTHMIK G25HP + L22
- VIDEO: SONY OLED 65A1E | Panasonic UB820 | 44TB Synology DS1815+ | Dune Solo 4K | XBOX ONE X SCORPIO | PS4 PRO | Apple TV 4K | HTPC/Gaming Rig (Ryzen 3700X, GIGABYTE X570 I AORUS PRO WIFI, 16GB, STRIX OC 1080TI, Auzen HDMI XFi)
Geronimo.USMC is offline
post #38806 of 39455 Old 05-30-2019, 05:18 PM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 660 Post(s)
Liked: 299
I'm envious of the G25HP performance, but I think the F18 is a nicer looking sub, at least in terms of the gloss black variants. That may not be fair to say considering I've only seen pics of the G25HP.
B T C is offline
post #38807 of 39455 Old 05-30-2019, 05:27 PM
darthray's Avatar
Liked: 2987
I now see you Avatar, glad my small computer knowledge did work for you
And enjoy your new toy, I believe the one you settle on. Was the E15HP2, am I correct?
And don't forget to find a good location for it, to maximize it's potential.
Darth
darthray is offline
post #38808 of 39455 Old 05-30-2019, 05:39 PM
darthray's Avatar
Liked: 2987
Is it the picture, or the woofer do look like kind of purple?
And also find odd, that both woofer have the same color. Not just one
It should not affect the performance, but if having your sub without a grill in a bright room.
I can see why you are asking.
Darth
darthray is offline
post #38809 of 39455 Old 05-30-2019, 05:53 PM
BadJRT's Avatar
Quoted: 32 Post(s)
Darth
Thanks and when I get it maybe you guys can help me with setting it up. I have a lot to learn, but love doing it. As far as location, there's not much I can do there. I have one spot, but keep in mind this house is temporary. We bought this house quick on a move due to work relocation and it having a fenced in yard for the "badJRT" lol and her two sisters. We have two house showings this weekend to go through and see if the family rooms are big enough to accommodate a very nice H/T setup that I'm going to start as soon as we buy another house. I'll post a few pics of how my sub will have to set once I get it. My current house is only 1300 sq/ft and the room has hardwood floors.
....and yes you're correct, I ordered the E15HP2 black oak. I hope this thing impresses me... I have a feeling it will. The only other sub I have is an Axiom EP500 I bought in 2009 for a system that I haven't had since 2012. Lost it in a move and haven't had a system since. I have that sub in my little computer room hooked up to two Edifier desktop/computer speakers. lol
BadJRT is offline
post #38810 of 39455 Old 05-30-2019, 06:02 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Darth
It's not the picture, it's the woofers. I haven't noticed anything bad it's just very noticeable and wondering. I also took a picture of the other one to make sure its bot my eyes and there is nothing purple-ish in front of it? The picture if this fv25hp is the one in the left of it. I put this one in the same place and has no shade of purple.
post #38811 of 39455 Old 05-30-2019, 06:06 PM
darthray's Avatar
Liked: 2987
While it suck to have only one spot available, at the moment. You may either end up lucky or in a very bad spot, or anything in between.
If you want to learn, this is a very good read;
Guide to Subwoofer Calibration and Bass Preferences
While it is long and can be overwhelming with information, reading it a few time do help.
And coming from an Axiom EP500, I am positive you will have a big smile on your face. Once you listen to your new E15HP2.
Darth
darthray is offline
post #38812 of 39455 Old 05-30-2019, 06:17 PM
darthray's Avatar
Liked: 2987
Maybe the subs, were made from a different batch of woofer (same exact woofer, just made at a different time).
I also notice, that you have the grills on the side of the subs.
I would not loose sleep over this small difference in color, since you are using grills.
As I would without grills. Since my room is very dark, even with the light on.
Darth
darthray is offline
post #38813 of 39455 Old 05-30-2019, 06:34 PM
BadJRT's Avatar
Quoted: 32 Post(s)
Congrats!! I will be anxious to hear how you think the G25HP stacks up against the SVS SB16. That's a great comparison for people who don't have access to, or know people with higher end audio systems. I've lived in Southeast PA for almost 2 years and I've never ever run into a single person who has any type of decent audio system. My point is, people like me can always hear a demo of an SVS model at Magnolia or a local HT store if there's one around and use that as a bar or gauge of how another brand stacks up. I did get to hear an SB3000 and an Ultra SB16 this past December. This will be interesting info coming from a guy who owned SB16's and knew them well.
I'll be getting my first Rythmik next week (I'm hoping, I have no date to receive yet) and once my wife and I buy another house, I'll be looking to buy a twin set of subs such as the G25HP.
Geronimo.USMC likes this.
BadJRT is offline
post #38814 of 39455 Old 05-30-2019, 07:08 PM
imureh's Avatar
Quoted: 2680 Post(s)
Liked: 3220
Is the purple one you bought form Greg?
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #38815 of 39455 Old 05-30-2019, 07:41 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Darth
Even with the grills on, in fact a friend confirmed it I thought I was just going crazy lol but doesnt affect the woofer but i wanted to see if this is only my woofers. I leave the grills of I mean I love seeing those things bounce
post #38816 of 39455 Old 05-30-2019, 07:43 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Uhmm yes it's the one I got from him. They dont have any residue or finger prints so I think the manufacturer when the where beign. Hopefully they dont get even more purple I mean it would look pretty nice won't lie but now there mismatched.
post #38817 of 39455 Old 05-30-2019, 08:28 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1258
Is one of you working with Potassium Permanganate
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #38818 of 39455 Old 05-30-2019, 08:32 PM
enricoclaudio's Avatar
Quoted: 3656 Post(s)
Liked: 4385
Here is a picture of Greg's FV25HPs just out of the boxes and they look normal to me. Check also Greg's G25HP. You can see some sort of purple tone but this is due the light he has in the room. If you have LED bulbs with cold light (6500K and up) the black anodized aluminum would look kinda purple. Another cause for this discoloration is if somebody uses solvent to clean the cone.
ID:	2573970   Click image for larger version
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #38819 of 39455 Old 05-30-2019, 08:44 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
Instantly thought of iron man
post #38820 of 39455 Old 05-30-2019, 08:46 PM
tuner1129's Avatar
Quoted: 179 Post(s)
Liked: 175
It's okay I'm not complaining I just thought I would ask lol like I said as long as the woofer is working 100% I'm fine. Is there a way to bring it back to blackish? Like I said if it turns purple I'll just have to match the rest
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
