Official Rythmik Audio Subwoofer thread - Page 1302 - AVS Forum | Home Theater Discussions And Reviews
 12419Likes
post #39031 of 39430 Old 06-12-2019, 05:16 AM
PlasmaPZ80U's Avatar
Quoted: 2790 Post(s)
Liked: 971
Originally Posted by nonstopdoc1 View Post
Originally Posted by PlasmaPZ80U View Post
One port plugged allows you to lower port tune to 12Hz and turn rumble filter to 1 port/Off. Combined with extension set to 14Hz and damping to High, you can get a sealed sub like sound and ample extension, output, and tactile response.
Leaving both ports open requires rumble filter to be set to 2 port/On and increases port tune to 18Hz. You can still set extension and damping to your preference, but you don't really gain much more headroom at frequencies 18Hz and up. You just end sacrificing extension and get increased ringing/boominess from the rumble filter and higher port tune. Some also report is less 3D/more flat sound due to the missing extension under 18Hz.
The main advantage of 2 ports open is it is less likely for port chugging to occur at very high SPL and content with very deep and strong bass. Using low damping can also help in such usage, though at the expense of added ringing/boominess.
Most here use 1 port plugged, rumble filter off, 14Hz extension and high damping (you can also try mid or low for movies).
Hope this helps...
Thanks. I have both open on mine. I will try 1 port open option.
What is "sealed sub like sound" if both ports are plugged? I am sure the Sub cannot go any lower in frequency than whats reported and it will decrease output also. So whats the advantage of plugging both?
Only one port can be plugged, never both. Sealed sub like sound means that the one port plugged with rumble filter off and 14Hz/high damping produces a very clean, deep, and tight bass response that is similar to a sealed sub. The Rythmik ported subs are designed to sound more like sealed one, except for the added output and tactile response port(s) provide.
Samsung 55" MU8000
Yamaha RX-A2070
KEF Q150 Bookshelf x 5
Rythmik L12 Sealed Subwoofer
PlasmaPZ80U is offline
post #39032 of 39430 Old 06-12-2019, 08:45 AM
Quoted: 24 Post(s)
Liked: 45
Lightbulb
Originally Posted by muscles View Post
Working on that now. It is going to be hard though because of the uncertainty of the housing market. I am only 2 miles from the beach and my business is right here. The further away I have to move (and I would have to because this townhome is about 900k) the harder it is on my business. Everything is squared away for now, I can really let the stereo fly and it doesn't bother anyone and the AMG GTs has a pretty muted exhaust. Things could be a lot worse, and when the time is right, I will eventually move.
The Superman colors really sold me
Greg
Greg, with your superman color car, you need the super hero interconnects and cables https://www.nbspeakercables.com.au/c...he-superhero-1
muscles likes this.
B&W 802 D3 Classe CTM600 ANTHEM AVM60 Rythmik FV25HP
JOSOSA is offline
post #39033 of 39430 Old 06-12-2019, 10:34 AM
dschulz's Avatar
Quoted: 816 Post(s)
Liked: 578
Recommended number of circuits?
Speccing a new build, with an opportunity to get things right from the start. If planning on using 4 F18s, how many dedicated circuits should I plan for the subs? 1 circuit for all 4 amps? 2? Or 4, with a dedicated circuit for each? This will be a fairly large room (3 rows of seating) and although discotheque volume levels are not needed we do want to be able to play motion pictures comfortably at reference level.
dschulz is offline
post #39034 of 39430 Old 06-12-2019, 10:41 AM
Rise & Grind
dinamigym's Avatar
Quoted: 294 Post(s)
Liked: 275
I can tell you I currently run a pair of FV25HPs on one 15a circuit without any issues so far. It is a dedicated circuit to the subs though so no other loads on it.
Hope this helps,
Paul
darthray, dschulz and tuner1129 like this.
Trinnov Altitude 16, Magico A3, Magico ACC, Magico A1s, Dual Rythmik FV25HP
Amps- ATI AT523NC, AT524NC, AT528NC
Kaleidescape Terra Server/Strato, Oppo UDP-203, Apple TV4k, XFinity X1
Sony VPL-VW5000, 136" 2.35:1 Stewart Studiotek 100 screen, Lumagen Pro 4242
dinamigym is online now
post #39035 of 39430 Old 06-12-2019, 10:57 AM
flyers10's Avatar
Quoted: 113 Post(s)
Liked: 59
I'm more for having extra to be on safe side mentality. Since are building out I'd do a few dedicated 20amp runs. 2 for your 4 subs. And 1 for your receiver/amps and other items. You never know what more demanding upgrades you'll do in the future. Much cheaper to run it now. I wish I had added a couple dedicated runs when my house was built.
flyers10 is offline
post #39036 of 39430 Old 06-12-2019, 11:09 AM
jsc79's Avatar
Quoted: 364 Post(s)
Liked: 425
I didn’t plan on having the system I now own when we built our house. I have everything in my signature running of a single 15a circuit. Haven’t tripped a breaker yet, but I might not be as crazy as others on the volume knob?
dschulz likes this.
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2 - Center - Ascend Acoustics Horizon w/RAAL - Surrounds: Sonance VP62R SST/SUR
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #39037 of 39430 Old 06-12-2019, 11:14 AM
tuner1129's Avatar
Quoted: 174 Post(s)
Liked: 165
I have the fv25hp both on 15 amps and I do crank them up pretty high and I dont even get flinching lights let alone tripped a breaker. I have 2 dedicated 20 amps next to them but haven't needed to change to them. Hope that helps.
Sent from my SM-G975U using Tapatalk
dschulz likes this.
tuner1129 is online now
post #39038 of 39430 Old 06-12-2019, 01:44 PM
Bluecow003's Avatar
Quoted: 318 Post(s)
Liked: 301
I have my two F25 subs on a single 15 amp circuit (only a couple LED lights on the circuit otherwise), then I have 2 dedicated 20 amp circuits near my equipment rack (1 just for my two amps and 1 covers all of the other electronics like processor, blu-ray player, display, misc.). If you wanted to be extra safe, do two circuits for your 4 subs (two subs on each circuit). Probably doesn't matter if they are 15 or 20 amp, but it probably won't cost you anything extra to do 20 amp if the runs are short.
darthray, dschulz and dinamigym like this.
7.2.4 Setup | Display: LG 77" C8 OLED | Blu-ray: Oppo UDP-203 | Processor: Anthem AVM60 | Amps: Outlaw 7700, Emotiva XPA-5 Gen 2 | Speakers: Paradigm Prestige (2) 95F's, 55C, (4) 15B's, (4) CI-Elite E65-R (Atmos) | Subs: (2) Rythmik F25's
Bluecow003 is offline
post #39039 of 39430 Old 06-12-2019, 05:19 PM
darthray's Avatar
Quoted: 2092 Post(s)
Liked: 2973
We have a pretty close way to do-it. I got a dedicated 20 amp circuit, for my two subs. One more dedicated 20 amp circuit, for my Outlaw 7700. Then a dedicated 15 amp circuit, for my second Amp Outlaw 5000. And one more dedicated 15 amp circuit, for all the electronics.
While I know, it is way overkill. I know for sure, that the power will always be there if required
Darth
darthray is offline
post #39040 of 39430 Old 06-12-2019, 06:55 PM
Quoted: 53 Post(s)
Liked: 26
Using some quick math:
If all four subs are taken to the max output of their amplifier (900w each), you'd require 3600 watts, or about 30 amps of current at 120 volts. Allowing a ballpark of 25% for inefficiencies of the amp will bring total power needs to ~4500 watts. Each dedicated 20 amp line will give you about 2400 watts, give or take. So, two 20 amp lines would in reality be more than enough, if you max out your sub amps.
Most people who are only going to reference sound levels or less are unlikely to need to max out their 900w sub amps...particularly with four subs and room gain.
Looking at your situation from a slightly different view, if we need to use 3 dB less of power output per sub to achieve the desired SPL, that would cut the max amplifier draw to half, or about 450 watts/sub for 1800 watts total (2250 watts if using 25% amp inefficiencies). If 6 dB less of power output per sub is needed or used, then we are looking at roughly 225 watts/sub or 900 watts total (1125w). If 9 dB less, we are at ~450 watts total (~565 watts w/inefficiencies).
Basically, this is about how loud you want to play and what type of margins you'd like to include. If you want to play it safe, give yourself lots of headroom, maybe considering to go down the BEQ route, then two 20 amp lines. Otherwise, one 15 amp or 20 amp line could be all you'll need.
FWIW.
AudioFan810 is offline
post #39041 of 39430 Old 06-12-2019, 09:09 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1237
And taking into consideration Mark's earlier reply, that momentary spikes won't trip a breaker, it's usually not a problem.
darthray and dschulz like this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #39042 of 39430 Old 06-13-2019, 09:15 AM
dschulz's Avatar
Quoted: 816 Post(s)
Liked: 578
Thanks everyone! Not gonna quote-tweet every reply, but this was a most helpful dialogue, with a converging opinion (my favorite scenario).
dschulz is offline
post #39043 of 39430 Old 06-13-2019, 04:52 PM
darthray's Avatar
Liked: 2973
While I did admit, I like to overkill. And more likely, always will
I do remember that post, and look for-it for 30 minutes or so. But came back empty hand.
And it was a good education on breakers, for tripping them.
Darth
darthray is offline
post #39044 of 39430 Old 06-13-2019, 05:08 PM
darthray's Avatar
Liked: 2973
Originally Posted by Mark Seaton View Post
Typical usage will easily allow operation of 4 SubMersive HP units on a single, dedicated 20A breaker. By this I mean a system with 2xHP+ amplified units with each driving an HP-Slave unit; 4 cabinets total, 8 x 15" woofers, and actually a rather common configuration our customers arrive at directly or through a couple upgrades.
Circuit breakers have a duration related behavior. This is rather useful in homes as it might otherwise be tricky to get garbage disposals to initially turn on, or toasters to not trip breakers when turned on. Ultimately the intended job of a circuit breaker is to keep over current conditions from overheating wires in the power system, and to interrupt fault conditions (ie hot shorted to neutral or other). Wires don't heat up instantly, so immediate, brick wall protection has no benefit.
Standard household breakers can pass 1.5-10x their trip current for short a duration. The shorter the duration, the more it can pass. Considering it's dissipated power which heats things up, this makes sense, as power requires duration, as a Voltage burst 2x longer but the same intensity results in 2x the power dissipated.
Common figures used for power requirements use 1/3rd to 1/6th draw from rated audio power, particularly if we exclude subwoofers. If we were only powering signals above 1kHz in an active system, we might load up to 1/6-1/20th the power draw from the rated audio power. For subwoofers that can range from 1/4 to as much as 1/2 rated power if pushed hard into limiters, other protections, or hard clipping.
Of course the amplifier type has to be considered, as class AB amplifiers are much less efficient, and plenty of class D amplifiers are 70-80% efficient, while the 4000W amplifier I use is closer to 90% efficiency. As an example, a 2000W amplifier that is 50% efficient could draw a maximum of 4000W, while an 80% efficient equivalent could draw a maximum of 2500W, while a 90% efficient amplifier could draw a maximum of ~2220W.
Darth
Edit: found-it, now in the first quote.
Did had to quote myself, to include the one from Mark.
Soulburner likes this.
darthray is offline
post #39045 of 39430 Old 06-13-2019, 05:08 PM
Matt2026's Avatar
Quoted: 832 Post(s)
Liked: 24233
Darth
Is this the one? If not it may be in the general area...
darthray likes this.
Regards, Ken (Retired)
9.1.) Denon 4520CI; Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Aircom T-8, Denon 300F/Ortofon 2M Bronze;
Matt2026 is online now
post #39046 of 39430 Old 06-13-2019, 05:10 PM
darthray's Avatar
Liked: 2973
Thanks Matt for the suggestion and did found-it a minute ago, it was in this thread.
That said, if I would have not find that post a minute or two before your post.
It would have save me lot's of time, with your link
Darth
Matt2026 likes this.
darthray is offline
post #39047 of 39430 Old 06-14-2019, 05:56 AM
Liked: 971
So, I've been experimenting with low shelf filters in the MiniDSP 2x4 HD (both the basic option in the 2x4 HD plug-in and the versions in REW that can be imported into the plug-in (LS, LS 6dB, and LS 12dB).
Using a gain of 3dB (sub not running hot or any other bass boosts), and a frequency of 40Hz, I was able to make my room shake with Netflix movies around -35MV on my Yamaha AVR.
Yet when I simply run the sub 3dB hot without a house curve, it doesn't sound nearly as strong.
Why is this?
Samsung 55" MU8000
Yamaha RX-A2070
post #39048 of 39430 Old 06-14-2019, 03:22 PM
nonstopdoc1's Avatar
Quoted: 519 Post(s)
Liked: 112
Is anyone here using SVS soundpath feet with their Rythmik subs? It seems that the included screws with SVS soundpath are not compatible with FV15HPs.
How thick are the standard feet? Also, how many feet does FV15HP has? 4 or 6? My subs are behind the baffle wall. I thought I would just ask on forum rather than removing the screen to check.
My Build Thread
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | Denon AVR | QSC DPA 4.2 | ATI AT528NC | Procella P8/P5V | Revel C763L | Rythmik FV15HP x2
Living Room - LG OLED 65" | Yamaha 2060 | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia CC | Polk Surrounds | Monolith 12" Subs x 2
nonstopdoc1 is offline
post #39049 of 39430 Old 06-14-2019, 03:35 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1237
Why is this?
And does the measured response before and after show exactly the intended effect, or something else?
post #39050 of 39430 Old 06-14-2019, 10:20 PM
Quoted: 155 Post(s)
Liked: 48
Well....my jaw is dropped
Got my G25HP in this week...and dear god, I have never heard bass like this. Now, I haven't even run REW or correctly calibrated this thing...just two run throughs of Audyssey and phone call w/ Enrico....but I am so blown away I can't even explain. Coming from an SVS PB-4000, I have never heard bass like this. It is so tight and controlled while still digging deep. I enjoyed the SVS, not here to bash - I just wanted something a little better for my room. I have shared walls in a duplex, so I tried going sealed for now. Last night, I did the opening of EOT - never heard it like that. Neighbors didn't feel a thing. Tonight, I watched Don't Breathe (one of the best movies for LFE I have ever seen) and it was at -6 on the trim, and MV at -22. WOW. I text the neighbors and they said they felt it, but nearly as bad as before. So, my hopes came true....I can listen at louder levels without bothering them. I can go down to -8 probably and not affect them, which I couldn't do before. I'm so glad I listened to everybody and tried out Rythmik. I will never try another sub brand, just add more of these haha
gwsat, laulau, darthray and 10 others like this.
Ethos4Lyfe is online now
post #39051 of 39430 Old 06-14-2019, 10:36 PM
tvuong's Avatar
Quoted: 2540 Post(s)
Liked: 2183
Originally Posted by Ethos4Lyfe View Post
Got my G25HP in this week...and dear god, I have never heard bass like this. I will never try another sub brand, just add more of these haha
Welcome to Rythmik club. That was exactly my thought 6-7 years ago when I got my 1st FV15hp. What was better? 2 of them, so here I am rocking 2 Fv15hps for years.
gwsat, darthray, dinamigym and 1 others like this.
tvuong is offline
post #39052 of 39430 Old 06-14-2019, 11:12 PM
torii's Avatar
Quoted: 3319 Post(s)
Liked: 1872
rythmik subs sound great...thats the key.
dinamigym and JOSOSA like this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #39053 of 39430 Old 06-15-2019, 09:23 AM
Quoted: 155 Post(s)
Liked: 48
now i want to get a smaller sub for the bedrom to replace my martin logan dynamo 700 haha
post #39054 of 39430 Old 06-15-2019, 09:32 AM
Rise & Grind
dinamigym's Avatar
Quoted: 294 Post(s)
Liked: 275
Ha Great minds think alike! I'm extremely impressed/enjoying the FV25s in my media room! I'm looking at a sealed sub for each of for my boys bedrooms. All I hear is Dad... need more bass! Would the F12 be a good fit for a bedroom (15' x 13') 2-channel application?
post #39055 of 39430 Old 06-15-2019, 09:42 AM
enricoclaudio's Avatar
Quoted: 3647 Post(s)
Liked: 4376
Yes, the F12 would be a good choice, same as the L22. I have a LVX12 in my bedroom which I use daily for watching TV and a L22 in my home office for editing and mastering. I love both but if you are more into music, then the L22 is the way to go.
dinamigym likes this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #39056 of 39430 Old 06-15-2019, 09:48 AM
Rise & Grind
dinamigym's Avatar
Quoted: 294 Post(s)
Liked: 275
Excellent...as always, thank you for all the help and speedy response!
post #39057 of 39430 Old 06-15-2019, 11:28 AM
DonH50's Avatar
Quoted: 3140 Post(s)
Liked: 3099
So, soon all they'll hear is "boys, turn down the bass!"
Depending upon budget and long-term goals an L12 might be a better choice. Or go for an F12 but have them pay half with the understanding they get to take it when they leave.
Madmax67 and dinamigym like this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #39058 of 39430 Old 06-15-2019, 01:04 PM
Rise & Grind
dinamigym's Avatar
Quoted: 294 Post(s)
Liked: 275
Ha! Thats a fantastic idea and probably keep my wife from strangling them.
post #39059 of 39430 Old 06-15-2019, 07:02 PM
tjcinnamon's Avatar
Quoted: 1798 Post(s)
Liked: 483
On my LVX12’s is the gain knob an attenuator only or past 12 o’clock does it amplify/boost?
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is online now
post #39060 of 39430 Old 06-15-2019, 07:16 PM
darthray's Avatar
Liked: 2973
Your gain on the sub, is only a volume control from the signal receive by your AVR. Meaning, if the signal receive is too weak or too strong. You can adjust there, not too have your AVR volume output set too extreme. Like -10 dB or +5-10 dB, as an example. This is when you tweak, with sub knob to achieve a better number. Post calibration, from your AVR output volume. Once calibration is done, you like to be around -5 dB on the AVR output. This give some room to adjust your bass preference level, from the AVR output up or down by a few dB.
Darth
mthomas47 likes this.
darthray is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
