Official Rythmik Audio Subwoofer thread - Page 1304 - AVS Forum | Home Theater Discussions And Reviews
 12460Likes
post #39091 of 39462 Old 06-19-2019, 06:55 PM
darthray's Avatar
Quoted: 2098 Post(s)
Liked: 2990
Originally Posted by enricoclaudio View Post
We uses M-10 for 15" and 18" subwoofers and M-6 for 12" subwoofers.
Thanks for the info
While I will get two FV18 eventually, it is nice to know!
Darth
darthray is offline
post #39092 of 39462 Old 06-19-2019, 07:02 PM
darthray's Avatar
Liked: 2990
Originally Posted by serith View Post
nothing. yet
Wow, you are one brave man. But it must suck to have no Bass at all, for the time been
Darth
darthray is offline
post #39093 of 39462 Old 06-20-2019, 05:41 PM
Rythmik's Avatar
Quoted: 426 Post(s)
Liked: 700
Originally Posted by DonH50 View Post
^^^ But I believe the power LED turns red when the limiter's threshold is reached...(?) If your amp has the limiter (the old base A370 did not IIRC, only the newer A370PEQ2 and A370PEQ3 models).
It should not turn red. The behavior of A370 and H600 analog amps is when protection circuit kicks in, the light will go out. Most customers think it is power issue and proceed to unplug the power. In fact, sliding the power switch to OFF resets the protection. This method of code reset also applies to HX series amps.
Matt2026 likes this.
Rythmik is offline
post #39094 of 39462 Old 06-20-2019, 06:16 PM
DonH50's Avatar
Quoted: 3152 Post(s)
Liked: 3101
Oops, thanks Brian. Obviously I have not had to deal with it since my initial testing all those years ago, and have not had to get behind them because they just sit there doing their job without fuss.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #39095 of 39462 Old 06-21-2019, 02:16 PM
tjcinnamon's Avatar
Quoted: 1799 Post(s)
Liked: 483
What is the tuning for the 1P-HT and 2P-HT settings of the LVX 12?
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #39096 of 39462 Old 06-22-2019, 10:32 AM
tjcinnamon's Avatar
Liked: 483
Found it, I think:
Frequency Response 14 - 200 Hz (-2 dB @ 18 Hz, [email protected]) with LFE input 14 - 90 Hz (-2 dB @ 18 Hz, [email protected]) with LINE IN input Multi-tune 20hz (2 ports) and 14hz (1 port)
post #39097 of 39462 Old 06-22-2019, 11:34 AM
qguy's Avatar
Quoted: 180 Post(s)
Liked: 104
Would I gain extended life/improved performance from the plate amp, if I remove it from the sub enclosure ?
qguy is offline
post #39098 of 39462 Old 06-22-2019, 01:43 PM
pink soda's Avatar
Quoted: 44 Post(s)
Liked: 52
m-10
Is the pitch 1.5? Thanks.
Originally Posted by darthray View Post
m10, sound like a standard size
I believe m-10 is a standard size for speaker treads. From the reply you got, from @enricoclaudio.
Here's a link, where I got my Custom Made Outriggers;
https://soundocity.com/product-category/tips/
The man is on retirement, and do custom work as a side hobby and small business.
His craftsmanship is Outstanding, and many choices to choose from.
For the tips, I went with two different colors. One color for the Tip, one other one for the main body of the brass cone (see my Theater page, attach to my signature. For pictures).
And since all is work, is custom made. You can request a m-10 tread.
Darth
Thanks, these look like a good value. I'm probably set on Mapleshade Heavyfeet because those did wonders for my towers, but these look like a great alternative. It'll be a while before I actually buy the feet so I have plenty of time to decide. Will be enjoying the Rythmiks with stock feet in the meantime.
darthray likes this.
Speakers: Ascend Acoustics Sierra RAAL Towers & Horizon w/ Mapleshade 4" Maple Platforms & Brass Heavyfeet ・ Ascend Sierra Luna satellitesRythmik FV18 subwoofer x2 ・ JBL GX-1200 subwoofer x5 direct mounted to seats
Components: Anthem MRX 720 ・ miniDSP DDRC-88BM with Dirac Live ・ Outlaw Audio 7140Sony VPL-HW45ES
pink soda is offline
post #39099 of 39462 Old 06-24-2019, 06:30 AM
jsc79's Avatar
Quoted: 370 Post(s)
Liked: 431
How many in here running crossovers higher than 80hz? I bumped mine up to 90hz this past weekend and ran some sweeps. Just had to add a couple ft to the sub distance and it cleaned it up nice around the crossover point. Didnt notice a ton of difference, but thought it would take a little more workload off my LCR. Probably more beneficial to my Sierra 2's than anything.
I was thinking about trying 100hz or higher next time I get an inkling to bust out the umik. I don’t think I have to worry about localization as all my gear is along the front wall by the L/C/R. Just would like to prevent deep voices from getting routed to the subs. Not sure what frequency that typically would be.
I use the lfe input on the subs.
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2 - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #39100 of 39462 Old 06-24-2019, 06:38 AM
imureh's Avatar
Quoted: 2681 Post(s)
Liked: 3227
I am using 100hz for LCR, 110hz for surrounds and 120hz for Atmos. Sounds great
JT78681 and jsc79 like this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #39101 of 39462 Old 06-24-2019, 06:42 AM
jsc79's Avatar
Quoted: 370 Post(s)
Liked: 431
Sweet, I will bump it up a bit more. Bad thing is my avr only has a global crossover.
I tried getting in on a Denon 4400 from Frys for 599, but it’s a difficult thing to do with that place when it comes to getting one shipped.
jsc79 is online now
post #39102 of 39462 Old 06-24-2019, 07:13 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1265
Going from 80 to 90 is very subtle; going to 100 is a little more noticeable. Whatever it takes to fill in a dip in that region.
If you're worried about the sub affecting voices, flip the switch on the amp to 80/24. It will start to roll off close to 90 but it will be fine and will cut a lot of >200Hz sounds from the sub. Don't forget to recalibrate with that setting. If it's still an issue, use the Line-In instead of LFE, if you have it. I tend to benefit when my XO is 100 and those running higher may as well.
jsc79 likes this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #39103 of 39462 Old 06-24-2019, 08:25 AM
JT78681's Avatar
Quoted: 1510 Post(s)
Liked: 1059
I am using a 100hz crossover with no localization whatsoever. The MLP is roughly 9-10 ft from the subs (FV15HP's).
jsc79 likes this.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #39104 of 39462 Old 06-24-2019, 08:30 AM
jsc79's Avatar
Quoted: 370 Post(s)
Liked: 431
Excellent! I think I will bump it up to 100hz and run a sweep to see how it looks and adjust the sub distance as necessary.
I did some minor eq adjustments on my minidsp and need to recheck my sub level anyways and make sure it is still at 75db. Might as well knock out both things at the same time while everything is hooked up.
After this I am packing up the umik and REW for a while and just start listening to my system instead of tweaking it all the time. Famous last words. lol
darrob104 and audiofan1 like this.
jsc79 is online now
post #39105 of 39462 Old 06-24-2019, 09:43 AM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2155 Post(s)
Liked: 3238
The amplifier was designed for internal use so it's highly unlikely there would be any additional lifecycle if it were external instead. Performance variation would be zero; it's designed to supply X number of watts, something unchanged by it's physical mounting location.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #39106 of 39462 Old 06-24-2019, 05:00 PM
torii's Avatar
Quoted: 3325 Post(s)
Liked: 1877
I have tried 90 and 100 xover but had localization issues.
jsc79 likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #39107 of 39462 Old 06-24-2019, 05:12 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1265
This is hard to avoid if the subs are near-ish, but you can mitigate a lot of it by using the Line-In and/or the 80/24 slope switch. Best results are obtained if your speakers can pick up the slack in the midbass.
post #39108 of 39462 Old 06-24-2019, 06:31 PM
darthray's Avatar
Liked: 2990
+1
All depend how low the speaker can play, more on my reply to the OP.
Just took a look at the specifications of your speaker;
46Hz - 38kHz ± 3dB
While the crossover is not a brick, and lower frequencies will still be played. But at a lesser loudness, setting your crossover higher. Normally yield better results for your midbass, at higher volume of play. That said, while my towers can play a little lower. I set them to 80Hz, and think you should also be fine with Sierra 2 to be also set at 80Hz. Since a good sub, will take of the rest and do what it is design for. If your lower frequencies were higher (like 60-70Hz), a higher crossover point would be required. Not case for your speakers
Darth
jsc79 likes this.
darthray is offline
post #39109 of 39462 Old 06-24-2019, 06:48 PM
torii's Avatar
Liked: 1877
for me an dozens of rew, it was all about xover freq smoothness...90 and 100 gave better results but I didnt like sub location sound....this led to countless attempts with different front speaker toe in angles which finally resulted in best at 80hz. pointbeing fronts determine alot.
torii is online now
post #39110 of 39462 Old 06-24-2019, 07:10 PM
jsc79's Avatar
Quoted: 370 Post(s)
Liked: 431
Here is a crappy pic of my laptop, I’m not on my laptop right now to get a proper pic. Snapped this one last week when I was tinkering.
This is with a 90hz crossover. I am in a 10k + cubic foot open floor plan with a big open staircase on one side of the room, hallway, dining room, kitchen, office, etc. I’m ok with the one null as I’m limited with placement options, WAF.
Blue line is pretty flat with 3 filters from REW imported into my MiniDSP. The other is with +6 dB boost via the sub trim in my avr. I run the subs in 12 hz tune, 12hz extension and mid damping right now. These subs rock this big space, big time. Loud and alot of TR.
jsc79 is online now
post #39111 of 39462 Old 06-24-2019, 09:13 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1265
Exactly - you tune your crossover for your overall frequency response. If that means raising the crossover frequency, then go for it. But if that brings in upper frequencies that don't sound good, try one of the tweaks I mentioned. Fixed it for me by bringing down the top end of the sub from 300Hz to about 200Hz. No problem with 100Hz crossover and rear sub is 4 feet behind my head. Sticking with LFE-in and the standard 12Hz slope did not sound good with a 100Hz crossover even with subs further away. YMMV.
post #39112 of 39462 Old 06-25-2019, 08:02 AM
Quoted: 188 Post(s)
Liked: 93
The family and I had a lovely trip to Australia in April.
However, a couple things displeased me a bit lately...
First, Ferrari is not doing well in F1, and every time I look at my old Testarossa I like Mercedes less
Well, they did better job than Ferrari over the past few years, and Seb is no Schumi!
Second, lately my FV25 behaved different, since about 4 to 5 months, the green light will flash/blink twice, sometime after watched a film, and sometimes even without use it for a few days (I was just checking it from time to time since I experienced green light flash/blink). Why it happened?
Thank you very much for your time, should someone can educate me on the matter!
As I was ready to get another FV25 or two FV18, and now I am thinking something local in Europe.
Thank you all.
Jim1290 is offline
post #39113 of 39462 Old 06-25-2019, 09:00 AM
Quoted: 24 Post(s)
Liked: 45
Just tried 100 Hz crossover and it sounds much better. But I do not know what does it change on subwoofer position on AVR. I think I have to add a couple of feet for phase adjustment at crossover frequency.
Do someone know a definitive way to fix phase with the distance trick on AVR ? When are you sure the setting is good ? I tried by ear ...
With 80 Hz sub is set at 11 feet (real distance) at 100 Hz sub seem to sound better at 12 feet ...
Enrico and Brian do you have a method for phase with AVR ? Just by ear or do you have something more "scientific" ?
B&W 802 D3 Classe CTM600 ANTHEM AVM60 Rythmik FV25HP
JOSOSA is offline
post #39114 of 39462 Old 06-25-2019, 09:40 AM
mitchlampert's Avatar
Quoted: 118 Post(s)
Liked: 42
This is how I integrated my subs: https://www.avsforum.com/forum/155-d...ow-thread.html
darrob104, jsc79 and JOSOSA like this.
mitchlampert is offline
post #39115 of 39462 Old 06-25-2019, 10:30 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1265
If your AVR has something like Audyssey, it will usually handle phase/distance well, as long as you started calibration with the knob on your sub at zero.
If you want the "scientific" method, you would use a MiniDSP UMIK-1, optionally calibrated by Cross Spectrum Labs for increased accuracy, and software like Room EQ Wizard to adjust sub distance to smooth out speaker/sub integration (after room correction).
darrob104 and jsc79 like this.
post #39116 of 39462 Old 06-25-2019, 11:45 AM
Geronimo.USMC's Avatar
Quoted: 302 Post(s)
Liked: 178
Funny you guys bring 100hz crossover up.
Ever since I got my G25HP blending with my L22, I was also experimenting with the crossover point on my KEF LS50 's.
Weeks and many hours of using REW, a Spectrum Labs calibrated UMIK-1, a MINIDSP HD, I got the smoothest frequency response at 100Hz, and 12dB/Octave crossover slope within my AV processor this yesterday.
I'm using the LFE inputs on both the G25HP, and L22 so far. I haven't tried the line in.
I really wanted an 80Hz crossover, but using REW showed me that was not the way to go in my living room.
I'm actually contemplating using the line in inputs on the subs to see if I can get the subs response smoother, but since I have a MINIDSP HD, I think the LFE input is the way to go. What experience do you guys have blending RYTHMIK subs with a MINIDSP HD, and line in vs LFE?
- AUDIO: (7.2.4 Atmos) EMOTIVA RMC-1 | McIntosh MC-8207 + CROWN XLS 2502, 1502 | KEF LS50, SVS Prime Elevations, RYTHMIK G25HP + L22
- VIDEO: SONY OLED 65A1E | Panasonic UB820 | 44TB Synology DS1815+ | Dune Solo 4K | XBOX ONE X SCORPIO | PS4 PRO | Apple TV 4K | HTPC/Gaming Rig (Ryzen 3700X, GIGABYTE X570 I AORUS PRO WIFI, 16GB, STRIX OC 1080TI, Auzen HDMI XFi)
Geronimo.USMC is offline
post #39117 of 39462 Old 06-25-2019, 11:48 AM
jsc79's Avatar
Quoted: 370 Post(s)
Liked: 431
Weeks and many hours of using REW, a Spectrum Labs calibrated UMIK-1, a MINIDSP HD, I got the smoothest frequency response at 100Hz, and 12dB/Octave crossover slope within my AV processor.
I'm actually contemplating using the line in inputs on the subs, but since I have a MINIDSP HD, I think the LFE input is the way to go. What experience do you guys have blending RYTHMIK subs with a MINIDSP HD, and line in vs LFE?
Can you post a rew graph? I want to see what your crossover region looks like. Curious is all. Mine is kinda up and down but not a sharp cliff like I’ve seen before.
jsc79 is online now
post #39118 of 39462 Old 06-25-2019, 11:52 AM
Quoted: 302 Post(s)
Liked: 178
Sure, what exactly should I measure? I can post up after I come back home.
post #39119 of 39462 Old 06-25-2019, 11:56 AM
jsc79's Avatar
Quoted: 370 Post(s)
Liked: 431
Just the standard channel 3 sweep (center plus sub), or whatever speaker(s) you are blending in at the crossover.
Just curious how smooth it is.
Geronimo.USMC likes this.
jsc79 is online now
post #39120 of 39462 Old 06-25-2019, 11:57 AM
Quoted: 24 Post(s)
Liked: 45
LINE IN / Anthem ARC /
JOSOSA is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
