Official Rythmik Audio Subwoofer thread - Page 1307 - AVS Forum | Home Theater Discussions And Reviews
 13551Likes
post #39181 of 40436 Old 06-27-2019, 06:56 PM
Geronimo.USMC's Avatar
Quoted: 316 Post(s)
Liked: 188
Maggies:
Sensitivity 86dB / 500Hz / 2.83v
4 Ohm
FOCAL:
Sensitivity (2.83V / 1m)92.5dB
Nominal impedance 8 Ohms
Minimum impedance 2.5 Ohms
- AUDIO: (7.2.4 Atmos) EMOTIVA RMC-1 | McIntosh MC-8207 + CROWN XLS 2502, 1502 | KEF LS50, SVS Prime Elevations, RYTHMIK G25HP + L22
- VIDEO: SONY OLED 65A9G | Panasonic UB820 | 44TB Synology DS1815+ | Dune Solo 4K | XBOX ONE X SCORPIO | PS4 PRO | Apple TV 4K | HTPC/Gaming Rig (Ryzen 3700X, GIGABYTE X570 I AORUS PRO WIFI, 16GB, STRIX OC 1080TI, Auzen HDMI XFi)
Geronimo.USMC is offline
post #39182 of 40436 Old 06-27-2019, 06:57 PM
torii's Avatar
Quoted: 3589 Post(s)
Liked: 2023
Originally Posted by Geronimo.USMC View Post
I believe speaker efficiency is one of the things that dictates how loud a speaker can get with the same ammount of watts. Maggies are also harder to drive than most speakers, but I don't know in regards to your Focals.
my focals a good 8-10db louder when switched with maggies and no changes...just thought the subs would play the same level and make me adjust between speaker output.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #39183 of 40436 Old 06-27-2019, 07:03 PM
Quoted: 316 Post(s)
Liked: 188
See above.
I'm afraid not,.....Unless your AV/PROCESSOR source has PRESETS that you can edit and, or save
post #39184 of 40436 Old 06-27-2019, 07:06 PM
torii's Avatar
Liked: 2023
See above.
good to know. just figured if my subs can do 120 db, why cant they independent of whether maggies or focal. learn something new.
torii is online now
post #39185 of 40436 Old 06-27-2019, 07:34 PM
mattburk's Avatar
THD numbers
Originally Posted by enricoclaudio View Post
Assuming the G25HP behaves like the F18, then the result would be very very close to this:
I am interested in either the F18 or G25HP. Do you have any THD numbers at the above outputs at lets say 10,15,25 and 40? If I had to pick one I would like to see how they look at 15.
mattburk is offline
post #39186 of 40436 Old 06-27-2019, 09:41 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
I have a quick questions on dual fv25hp. I have 2 more months to enjoy these at their loudest form possible even if I have cracked some drywall that will need repair in the future. 1) Has anyone who has dual ported ever tried to have one port facing up and the other one down? 2) For those who listen so music on ported subs only, is it better to use LFE or RCA IN? Thank you in advance.
Sent from my SM-G975U using Tapatalk
tuner1129 is offline
post #39187 of 40436 Old 06-27-2019, 10:02 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1622
I am failing to picture how this even works.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #39188 of 40436 Old 06-27-2019, 10:13 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
opps now that I read it I see what you mean lol what I meant to say is basically flipping one upside down and keeping the other how it should go.
post #39189 of 40436 Old 06-27-2019, 10:21 PM
torii's Avatar
Liked: 2023
I spent so many hrs with rew and audyssey to get lfe in(x2) working....not bothering with line in...I did try it, just didnt need it.
tuner1129 likes this.
torii is online now
post #39190 of 40436 Old 06-27-2019, 10:26 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
That's the answer I needed! Thank you.
post #39191 of 40436 Old 06-27-2019, 10:54 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1622
Sorry, I missed that question. I've posted this graph before. Here is the difference:
Name:	Slope Testing.png
The quickest rolloff was what sounded best to me. The light blue was LFE in and the 12Hz slope setting, as "default". I could hear the 200-300Hz sounds and it wasn't clean.
post #39192 of 40436 Old 06-27-2019, 11:41 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
Attachment 2585170
Maybe is why I finding it hard to dial it in with music. Movies is it's fine I love the sound but music seems to have slow drop off and it lingers. I have tried every combination but still same outlook. I think I'll need separate sealed subs for music. All using the LFE, I sent back my mic for the 2nd time because the REW was telling me I have huge dips on 17, 40, 60 and 65. I really wish I would remember to save these things to share. Mind you this is with 2 subs and with 1 only I only have dips on the 40, 50. It really has me scratching my head
post #39193 of 40436 Old 06-27-2019, 11:44 PM
torii's Avatar
Liked: 2023
just fyi, I have problem at my xover of 80hz...so lfe was best choice for me. obviously try all the tools in your toolbag.
torii is online now
post #39194 of 40436 Old 06-28-2019, 06:04 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1622
You can run up to 100Hz XO with Line In, I've done it for years. I believe those tests were done with the AVR set to 80, but I didn't write it down. Just make sure your mains can pick up the slack in the midbass. Not a problem for most of us.
post #39195 of 40436 Old 06-28-2019, 06:20 AM
jsc79's Avatar
Quoted: 422 Post(s)
Liked: 500
Data bass has numbers on the F18. I’m sure the G25HP would also have really low THD.
It seems all of the Rythmik subs are clean low distortion subs. I love my FV18’s.
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2 - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #39196 of 40436 Old 06-28-2019, 10:56 AM
BluesDaddy56's Avatar
Quoted: 566 Post(s)
Liked: 789
I'm not sure what I'm getting myself in for (well, I'm a little bit sure), but I just ordered a Cross Spectrum calibrated Umik-1 mic.
Geronimo.USMC likes this.
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR; Center: Selah Audio BMR-CC; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is offline
post #39197 of 40436 Old 06-28-2019, 10:59 AM
enricoclaudio's Avatar
Quoted: 3818 Post(s)
Liked: 4691
You better start saving for the miniDSP 2x4 HD as you may don't like what would you see after taking initial measurements
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #39198 of 40436 Old 06-28-2019, 11:26 AM
Quoted: 566 Post(s)
Liked: 789
Well, I don't need to save. The bass in my room sounds pretty good to me, but we'll see.
post #39199 of 40436 Old 06-28-2019, 11:40 AM
jsc79's Avatar
Quoted: 422 Post(s)
Liked: 500
I thought mine sounded awesome too. Then I saw what was going on and made it even better.
I also recommend the WI-DG with the MiniDSP 2x4HD.
jsc79 is online now
post #39200 of 40436 Old 06-28-2019, 12:45 PM
Quoted: 566 Post(s)
Liked: 789
Understood. Does the WI-DG get you anything OTHER than wi-fi access to the MiniDSP? My internet switch is essentially on the same wall as my system equipment and all my network hookups are via ethernet and not wi-fi, so it's not a problem adding one more if I wind up getting one.
post #39201 of 40436 Old 06-28-2019, 12:48 PM
jsc79's Avatar
Quoted: 422 Post(s)
Liked: 500
Nope, just wireless access to the MiniDSP. I do the beq thing so it’s pretty convenient for that. Eliminates having to hook up a cable but in reality not that big of deal.
BluesDaddy56 likes this.
jsc79 is online now
post #39202 of 40436 Old 06-28-2019, 09:16 PM
Quoted: 316 Post(s)
Liked: 188
I just sent back my UMIK-1 back to Cross Spectrum Labs today to get it checked out. I have that dip at exactly 15Hz from both my G25HP, and L22 by playing them separately, and both together. Each sub is at a different location in the room....
This is my latest results using line in, and a miniDSP 2x4 HD.
Subs Only, No Smoothing
G25HP = RED
L22 = GREEN
BOTH = BLUE
MINIDSP 2X4 HD = ORANGE
post #39203 of 40436 Old 06-28-2019, 09:45 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
G25HP = RED
L22 = GREEN
BOTH = BLUE
That mini DSP really works magic, well not 100% ofcourse but alot better. I'm not fully sure if the mics have issues or just my homes layout just super messed up I really thought having 2 fv25hp would fix the nulls but kinda got more I'm sure its user error but now waiting on my 3rd mic and hopefully this will tell me its either the mics or I have Interstellars black hole and it's in my house
post #39204 of 40436 Old 06-28-2019, 09:54 PM
Quoted: 316 Post(s)
Liked: 188
I'm right there with you. I hope it was a bad mic, or I might have to get another Rythmik sub later on if it would help plug those other small nulls and bring up that 15Hz valley/slope
post #39205 of 40436 Old 06-28-2019, 09:56 PM
Quoted: 316 Post(s)
Liked: 188
Make sure you time align those subs though, if you haven't yet.
post #39206 of 40436 Old 06-28-2019, 10:02 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
Yes, or maybe I should of gone with dual g25hp. I always wonder if a sealed would help me in the mid bass since my rf8000f cant keep up with my music loudness. But then I'll probably need another mini dsp.
post #39207 of 40436 Old 06-28-2019, 10:04 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
Yes I saw a bunch of videos on YouTube and that helped alot to time align them.
post #39208 of 40436 Old 06-29-2019, 12:04 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1622
Sealed won't have more midbass, but it will perceptually have more midbass because the curve is more round.
post #39209 of 40436 Old 06-29-2019, 07:21 AM
PlasmaPZ80U's Avatar
Quoted: 2831 Post(s)
Liked: 1017
I just wanted to say what I really love about the L12 over the LV12R and all the ported subs I've had over the years is how quickly the woofer can snap back into the rest position during quick transients. It's like you can hear how quickly the woofer gets sucked backwards into the enclosure after a loud and quick bass note or sound effect. Kinda like a pulled punch with a nice snap to it.
With slower bass notes and rumbles, it is less noticeable but still the sound is super clean and controlled.
Samsung 55" MU8000
Yamaha RX-A2070
KEF Q150 Bookshelf x 5
Rythmik L12 Sealed Subwoofer
PlasmaPZ80U is offline
post #39210 of 40436 Old 06-29-2019, 02:15 PM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
Makes sense, I guess I'm having a hard time matching these new subs to match the low end to mid bass.
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
