Official Rythmik Audio Subwoofer thread - Page 1315 - AVS Forum | Home Theater Discussions And Reviews
 13576Likes
post #39421 of 40480 Old 07-13-2019, 07:44 PM
tvuong's Avatar
Quoted: 2621 Post(s)
Liked: 2377
@gadgtfreek , how do you like your current Klipsch speakers? IIRC, you had the rf7ii, then the psa 210. How are your current RPs compared to those you had? The RPs are much cheaper right? I can feel how your single fv15 pressurizes your tiny room. Nice and clean set up.
gadgtfreek likes this.
tvuong is online now
post #39422 of 40480 Old 07-13-2019, 08:40 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6052
Originally Posted by darthray View Post
Nice room, with a nice little bar with lots of options
But where is the beer fridge
Darth
LOL. A bar is getting built for the adjoining room, wont be a far walk.
Originally Posted by PretzelFisch View Post
I did you try stacking them first?
I did not.
XBR65A9G / XBR65A8F / 55R615
DP-UB420 / ATV4K (3) / PS Vue
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is online now
post #39423 of 40480 Old 07-13-2019, 08:42 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6052
Originally Posted by Soulburner View Post
No doubt, I really enjoy having my system in a room that's not the living room. Have you done any measurements yet? You may have a convenient peak at a certain frequency due to corner loading. If you get used to it, you'll be chasing it forever in the next setup...it will sound odd with music, though.
I have not. Next time Chad B comes into cal both my OLEDs, I will have him use REW and see what is going on.
post #39424 of 40480 Old 07-13-2019, 08:45 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6052
Yeah, when I went from the 7II's and 64II to the PSA monitors, it was because the horns were starting to get to me. I guess old age. The PSA's are so much more warm, I loved them. When I wanted to setup this 5.1, the PSA 210C is too large, so I went with the new Reference Premiere line, reading that they were mellow. I can say for a fact they are 180 degrees from harsh, and sound great. Real happy with the choice, plus now I have a true 5.1 system.
post #39425 of 40480 Old 07-14-2019, 12:08 AM
Matt2026's Avatar
Quoted: 909 Post(s)
Liked: 25834
Originally Posted by jsc79 View Post
You could also just build a frame around the center out of some sort of 3/4” or thicker plywood as fancy grade as you wanted. That could be the load bearing surface. Could paint it black, duratex, stain.... probably make it blend right in.
That's what I did to get my Center Ultra up off the bottom shelf closer to the LR speaker height. The height was set to just raise the bottom of the TV enough to be even with the top of the Center speaker. The distance between the end legs is wide enough to allow the Center to slid back close to the TV and about even with the front edge of the stand.
After I had it assembled I decided to add an angle on the inside edges to somewhat resemble the angle on the Ultra speakers. I used 3/4 oak and black spray paint.
It can be a bit difficult to see with all the black on black. If I wasn't so lazy I'd set up some better lighting for a clearer picture
Name:	Dry fit bottom view.jpg
ID:	2590540   Click image for larger version
ID:	2590542   Click image for larger version
Name:	Riser on Stand 2.jpg
ID:	2590544   Click image for larger version
Name:	Mini-HT - Surround listening Room (3).jpg
chucky7, serith, darthray and 9 others like this.
Regards, Ken (Retired)
7.1.2) Denon 4520CI; Aircom T-8, Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Denon 300F/Ortofon 2M Bronze;
Matt2026 is online now
post #39426 of 40480 Old 07-14-2019, 12:17 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1630
Nice woodworking - I wish I could do that, but I would not use a closed back. Now you have a mild version of the "cupping your hands around your mouth while talking" effect. It's like putting a speaker in a cabinet or bookshelf.
I think just some bracing along the frame would be enough, and would keep it "open".
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is online now
post #39427 of 40480 Old 07-14-2019, 02:49 PM
DonH50's Avatar
Quoted: 3275 Post(s)
Liked: 3362
Not a problem with a closed-back speaker (is it?) and front flush.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #39428 of 40480 Old 07-14-2019, 05:37 PM
Matt2026's Avatar
Quoted: 909 Post(s)
Liked: 25834
There is a 1.7" port behind each woofer. From the back of the speaker it is about 8" to the riser. There is open vertical space in front of and behind the screen so is not sitting in a tight box.The gap on either side of the speaker is ~4" to the riser legs. The gap from the back edge of the speaker is ~3" to the center of the curved TV screen. The front is even with the edge of the stand but 2" higher on angled foam wedges, points right at my head.
It sounds just fine to me
post #39429 of 40480 Old 07-14-2019, 10:14 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1630
Speakers emanate sound in all directions - and there are reflections abound, just like standing and yelling at the mouth of a cave. He does have the face in the clear, which isn't as bad as center speakers put at the back of a cabinet.
post #39430 of 40480 Old 07-15-2019, 04:40 AM
DonH50's Avatar
Liked: 3362
Their dispersion pattern moves to point sources at lower frequencies, but as you move higher driver directivity comes to play, along with baffle effects and all that jazz, so they radiate more and more to the front. But "emit" is debatable; again, a rear port is an emitter, but otherwise the back of the cabinet is not (or should not be) a direct emitter.
DonH50 is offline
post #39431 of 40480 Old 07-18-2019, 10:08 AM
darrob104's Avatar
Quoted: 62 Post(s)
Liked: 40
Looking for some guidance...
1 year ago I installed a new home theater system included 2x FV18's... I've always had issues with the bass in this room, so I went with the dual FV18's to 'fix the bass issues'... initially, movies were awesome, but I was underwhelmed with the sound for music... I spent a lot of time learning how to use Audyssey and manually adjust the FV18's and made a lot of improvements, but still, I feel like there's room for a lot of improvement... so, after much research and daily reading here in the forums, I decided to learn how to use REW and purchased a MiniDSP 2x4 HD... I've been making notes and collecting links regarding using REW & MiniDSP to calibrate the subs & my system.
Unfortunately, we had a drain pipe leak into that room so I've had that room torn up since April ... I just got the room put back together last night, and am ready to calibrate the subs & system.
I've spent the last hour sorting through my notes and links and am having a hard time trying to figure out how best to go about doing this... I'd like to start by gain matching my subs, but really don't know where to start... the link I saved talked about moving each sub to the middle of the room and using the MIC to gain match them... I also have a note that says the subs can be gain matched in position, without moving them to the center of the room... but... how exactly do I do that? I'm now realizing that as a newb, I'm not sure how to do the simple things that I should already know...
Enrico has a great document in his signature that covers most of the basics... but, with regards to Gain Matching the subs, the link he includes isn't helping me... or I'm not finding the right posts... Does anyone have a link to a document or post that steps through the process (in beginner terms) of how to gain-match subs?
Thanks in advance for your help!!!
Home Theater: RBH Signature Reference Speakers 7.1.4 Dolby Atmos | Rythmik FV-18 Subs (x2)
LG 65" OLED C7 | Marantz AV7703 | Outlaw 7700 & 5000 | OPPO UPD-203 | XBOX One X
Front Room: RBH 61-SE/r | RBH SX-1010/r Sub | Vizio M602i-B3 | Marantz SR7009 | Denon DVD-1930CI
darrob104 is offline
post #39432 of 40480 Old 07-18-2019, 10:41 AM
enricoclaudio's Avatar
Quoted: 3836 Post(s)
Liked: 4706
Check on Page 4 of "Using MiniDSP 2x4 to Time-Align Multiple Subs on One Channel before Room Correction" Guide.
https://www.dropbox.com/s/w7jmpozner...%20Version.pdf
darrob104 likes this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #39433 of 40480 Old 07-18-2019, 11:38 AM
darrob104's Avatar
Quoted: 62 Post(s)
Liked: 40
This document states it's for multiple subs on the same channel... I have my subs on separate channels (Marantz AV7703), so do I need to put them on the same channel? Skip the gain-mayching step? Or is there a different set of instructions?
Thanks again!
post #39434 of 40480 Old 07-18-2019, 11:50 AM
Liked: 4706
Thanks again!
If you are using SubEQ HT and the subwoofers are at the same distance from main listening position, then do level matching and let Audyssey set the levels during calibration. If the subwoofers are at different distance from main listening position then gain match them. You can still use the two subwoofer outs from the 7703. Just turn ON only the subwoofer you are measuring, set the level on the subwoofer volume to whatever dB value you want, then turn it off and measure the second subwoofer adjusting the volume on the subwoofer volume knob to the same dB value of the first subwoofer. that would be gain matching in layman terms. Then you can run Audyssey again.
post #39435 of 40480 Old 07-18-2019, 12:00 PM
Liked: 4706
Oh wait, sorry. I just saw that you have a miniDSP 2x4 HD. Forget about using both subwoofer outs on the 7703. Use only one subwoofer output on the 7703, gain match the subwoofers and time align the subwoofers using the miniDSP 2x4 HD. Then show the two subwoofers to Audyssey as one. Basically follow the miniDSP guide I posted above.
post #39436 of 40480 Old 07-18-2019, 07:43 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1630
That's basically what Audyssey does. It level matches each sub individually, before continuing.
darthray likes this.
post #39437 of 40480 Old 07-19-2019, 06:53 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1630
Had a dream that I got a pair of FV18s. Then I woke up, sans FV18s, and I had to get ready for work.
darrob104, Matt2026 and drh3b like this.
post #39438 of 40480 Old 07-19-2019, 07:13 AM
jsc79's Avatar
Quoted: 423 Post(s)
Liked: 504
Bummer dude. There is always tomorrow!
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2EX - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #39439 of 40480 Old 07-19-2019, 12:57 PM
serith's Avatar
Quoted: 819 Post(s)
Liked: 867
someone is selling a pair here on the classified section for $1800, 1 alone for $1k. they're down in florida though, would love to have one for my living room setup which i've been using a lot more these days.
7.0.6 / 1700 ft³ / PSA MTM-210T³ / Epson HC 2150 / 147" AT 2.39:1 Spandex Screen / Seatcraft Rialto³ / Velvet Everywhere / Chasing LFE
serith is offline
post #39440 of 40480 Old 07-19-2019, 01:10 PM
torii's Avatar
Quoted: 3592 Post(s)
Liked: 2027
you blown up your theater? it was too nice to be w/out subs this long....
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #39441 of 40480 Old 07-19-2019, 02:09 PM
serith's Avatar
Quoted: 819 Post(s)
Liked: 867
haha, no. have just been watching a lot of tv shows lately and that's more suited for tv & comfy sectional seating upstairs, plus can eat food & multi-task. the room downstairs is a little too hardcore for that, really purpose built for consuming films only. plus with the lack of subwooferage currently it feels like i murdered the room
djreef and torii like this.
serith is offline
post #39442 of 40480 Old 07-19-2019, 02:16 PM
torii's Avatar
Liked: 2027
I hear ya, I have a full basement thats just storage/nephew living quarters cause honestly I hate steps and like someone living for free in my space.
torii is offline
post #39443 of 40480 Old 07-19-2019, 02:35 PM
Liked: 4706
This is definitely a great idea but because I'm too OCD, I ended up ordering today a Salamander Synergy Twin 30 Core Module with Center Speaker custom made opening (12" high) with maple sides, maple drawers and heavy duty casters to match my current Salamander Synergy AV Rack. It should be delivered in about 2 weeks.
Name:	Screen Shot 2019-07-19 at 4.31.47 PM.png
ID:	2592608   Click image for larger version
Name:	Screen Shot 2019-07-19 at 4.33.06 PM.png
audiofan1 and Matt2026 like this.
post #39444 of 40480 Old 07-19-2019, 02:36 PM
Quoted: 166 Post(s)
Liked: 151
Do you ever listen to music down there? Seems like a good place to hang out in the dark with some chill bass heavy tracks. Maybe while drunk/high?
ianrozzano is offline
post #39445 of 40480 Old 07-19-2019, 02:48 PM
torii's Avatar
Liked: 2027
I never really paid attention to salamander av storage til I scored a cabinet. its built like a tank, real wood, heavy as heck, and been a happy purchase. I got my piece off amazon at closeout price/free shipping....so just overall happy a few yrs later
think attached pic shows cherry finish halfway ok. old model...
djreef and Matt2026 like this.
torii is offline
post #39446 of 40480 Old 07-19-2019, 03:12 PM
serith's Avatar
Quoted: 819 Post(s)
Liked: 867
very rarely. honestly the psa speakers just aren't that great for music playback (my opinion of course). the best analogy i can give you to help explain what they sound like is, would you sit in a movie theater and listen to music there? probably not, there's just a "cinema sound" that comes with horn speakers and while they excel for watching movies (especially the center channel with dialogue) they're not that enjoyable for 2 channel music consumption. of course i play around with them sometimes though--more so when i had the fv25's in the room, but it was more to mess around with the subs than it was for any audiophile jam-session. both the in-wall micca m-8's i use in my living room & my (very old) logitech z5500's i use in my home office sound better for music than the psa speakers. the psa's are clear, sharp, and extremely efficient. i just prefer a warmer sound signature for music i guess. however for their given application the psa's are perfect (for me).
speaking of the sub-less room...
for anyone following what's going on with my setup (either from here or if you watch my youtube videos), i was pretty underwhelmed by the diy creation that i borrowed from dad recently. it was nice to hear & feel the room pressurized again but there was just an emptiness that's hard to explain what's missing exactly. i didn't use rew but i did use an old-school physical equalizer with it & crossed the sub over similarly to what i had the rythmik's at. i'm glad i tried it though, was good fun.
for anyone curious the cabinet dimension was similar to an fv25 or jtr2400ulf, but a little larger. single 18" dayton, tuned somewhere into the teens with ~1000 watts of power. i was thinking of trying the new tv36 but anyone following the psa sub thread knows where that ended up (also not a fan of the ports not facing the same direction as the driver--i like to feel the port wind!). if only there were other subwoofers that challenge the cap4000 to consider
here are a couple of pictures of the single vented 18 dad built that i tried the other week:
djreef, MaxTemp and torii like this.
serith is offline
post #39447 of 40480 Old 07-19-2019, 03:42 PM
Quoted: 166 Post(s)
Liked: 151
Have you considered a couple of DSS Mariana 24s?
femi likes this.
post #39448 of 40480 Old 07-19-2019, 05:44 PM
darthray's Avatar
Quoted: 2257 Post(s)
Liked: 3280
As @Soulburner said, there is no need to do that with the Audyssey.
+1
Thanks again!
With your AV7703, using the two sub outputs will do the following during the Audyssey calibration. On the first run, it will send separated measurement for each sub. To adjust the time delay and volume of each sub. Then do the calibration as one sub, and sending one signal to both subs. Since there is only one bass channel on any recording. This result both subs work as one unit, but are adjust to the proper level and delay for each other.
Once Audyssey is done, you can use your miniDSP 2x4 HD for tweaking.
Darth
darthray is offline
post #39449 of 40480 Old 07-19-2019, 05:47 PM
djreef's Avatar
Quoted: 211 Post(s)
Liked: 269
I love the Lab photobomb. LOL!
2kW fully active, fully balanced 2 channel Vaders
Overkill IS my middle name.
djreef is offline
post #39450 of 40480 Old 07-19-2019, 05:56 PM
darrob104's Avatar
Quoted: 62 Post(s)
Liked: 40
Update...
I've installed the MiniDSP, wi-DG wireless adapter and the app on my laptop and am working through the documentation... Unfortunately, I have zero bass output when I go into my Marantz and send test tones to each channel...
I'll get back into it Sunday to see where I may have a setup issue... I just need the family to leave for a couple days so I can focus on this?!?!?? 🙂
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
