Official Rythmik Audio Subwoofer thread - Page 1320 - AVS Forum | Home Theater Discussions And Reviews
 13554Likes
post #39571 of 40443 Old 08-07-2019, 12:50 AM
holco's Avatar
Quoted: 18 Post(s)
Liked: 70
Yesterday I received my Rythmik F18 subwoofer in the Netherlands
Today is the day that I will set it up correctly in my stereo and AV setup, after a first try with the settings (MiniDSP 88A + BM) of my DIY Dual Opposed 15 "subwoofer it looks very promising
There are still some things to solve out with Rythmik, but that's another story.
Greetings, Mario
Nick V, kemac, darthray and 6 others like this.
Stereo: MagnaHifi Mano-Ultra Music streamer > Audio-GD R8 DAC >
Audio-GD Master 1 PreAmp > MiniDSP DDRC-88A + BM Dirac Live >
Audio-GD Master 3 PowerAmp > Thiel CS 2.4 loudspeakers + Rythmik F18 subwoofer
AV: Marantz SR7010 - IOTAVX AVXP1 - 7x Klipsch surround speakers
holco is offline
post #39572 of 40443 Old 08-07-2019, 09:27 AM
PretzelFisch's Avatar
Quoted: 485 Post(s)
Liked: 296
Originally Posted by dpc716 View Post
Most of us don't know what we're doing either, so you're in good company.
What's your budget, and in each room do you listen to mostly movies, music, or a mix?
I am looking to spend under 1k. the bedroom is 80% movies 20% music. the family room is about 90% movie and 10% music.
I was kind of hoping rhythmic still carried the 15 inch down firing so I wouldn't have to worry about the little one touching the cone when in the family room.
PretzelFisch is offline
post #39573 of 40443 Old 08-07-2019, 12:47 PM
dpc716's Avatar
Quoted: 167 Post(s)
Liked: 238
I would vote for the FVX15 if you can stretch a bit, otherwise go down to the 12. I would put the new sub wherever you listen most, probably the family room.
If you feel strongly about down firing, talk to the Rythmik folks. They can probably make it happen, if not directly they can most likely coordinate a cabinet built for you using their components.
dpc716 is offline
post #39574 of 40443 Old 08-07-2019, 11:39 PM
holco's Avatar
Quoted: 18 Post(s)
Liked: 70
The F18 is setup now, what a beast!! Extremely tight with inordinate low details
holco is offline
post #39575 of 40443 Old 08-08-2019, 01:23 PM
holco's Avatar
Quoted: 18 Post(s)
Liked: 70
Hahaha, my brother wanted to pose on my F18, what the heck why not
holco is offline
post #39576 of 40443 Old 08-08-2019, 04:07 PM
tvuong's Avatar
Quoted: 2617 Post(s)
Liked: 2375
^^ wheel legs? Congrats on the sub! The F18 is just a super nice sounding sub.
spyboy, audiofan1 and holco like this.
tvuong is offline
post #39577 of 40443 Old 08-09-2019, 12:13 AM
holco's Avatar
Quoted: 18 Post(s)
Liked: 70
That sub just can't be moved without wheels
spyboy likes this.
holco is offline
post #39578 of 40443 Old 08-09-2019, 06:19 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1622
^ does that cannon recoil when she fires?
Soulburner is offline
post #39579 of 40443 Old 08-09-2019, 08:05 AM
tuner1129's Avatar
Quoted: 197 Post(s)
Liked: 186
This is one heck of a smart idea with the wheels
Sent from my SM-G975U using Tapatalk
holco likes this.
tuner1129 is offline
post #39580 of 40443 Old 08-09-2019, 08:41 AM
Quoted: 12 Post(s)
Liked: 0
Hello,
I have a LVX12 sitting on an isolation pad and I got some rattling when MV is high, would it better if I use spikes ? (wooden floor)
Thank you
cyriltra is offline
post #39581 of 40443 Old 08-09-2019, 08:59 AM
Mactavish's Avatar
Quoted: 140 Post(s)
Liked: 140
Originally Posted by cyriltra View Post
Hello,
Thank you
Others will chime in, but from what I’ve read “spikes” are for carpet floors. I have a Rythmik F12G, on a Aurelex platform, on wooden floor, no issues. Perhaps it’s the low frequencies themselves causing issue, you didn’t specify what was rattling.
Matt2026 likes this.
HDTV: Panasonic P55VT50 Plasma
AVR: Denon X3500H
SPEAKERS: Ohm (mains), Chane 2.4 (center), Rythmik F12G (sub), DefTech ProMonitor 80 (sats)
MEDIA PLAYER: Oppo BD83
Mactavish is offline
post #39582 of 40443 Old 08-09-2019, 10:36 AM
dpc716's Avatar
Quoted: 167 Post(s)
Liked: 238
Hello,
Thank you
Rattling can be caused by mechanical coupling or sound waves. Going from a pad to spikes would increase coupling if anything, so that would make the issue worse if that was the cause.
However I would assume sound waves are the cause and your best bet would be to find what's rattling and remove or better secure those objects. Pads can be attached to the backs of things hanging on walls to reduce noise.
Madmax67 likes this.
dpc716 is offline
post #39583 of 40443 Old 08-09-2019, 01:46 PM
Matt2026's Avatar
Quoted: 907 Post(s)
Liked: 25733
I had several doors rattling and put a couple of inches of insulation rubber strip along the door jam. I have a bit left over, about 10 life times worth
[Edit] Added picture. Foam piece about 2" long.
Name:	Door Rattle Fix.jpg
darthray, dpc716 and tuner1129 like this.
Regards, Ken (Retired)
7.1.2) Denon 4520CI; Aircom T-8, Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #39584 of 40443 Old 08-09-2019, 02:06 PM
holco's Avatar
Quoted: 18 Post(s)
Liked: 70
Hahahaha, no movement at all 😉
holco is offline
post #39585 of 40443 Old 08-09-2019, 03:57 PM
Mickeyboy's Avatar
Quoted: 18 Post(s)
Originally Posted by enricoclaudio View Post
Like Don mentioned, no issues mixing paper cone with aluminum cone. The L12 and F12 match very well. Same for L22 and E15HP.
Now that is interesting. Were I to do this, the L12 and the F12 would be driven by the single sub out channel of the NAD T758 connected by an RCA splitter. They could be placed the same distance from the listening position.
Mickeyboy is offline
post #39586 of 40443 Old 08-09-2019, 04:54 PM
darthray's Avatar
Quoted: 2246 Post(s)
Liked: 3252
Your brother need to be off the sub, before trying to move-it. It will be much easier
Darth
darthray is offline
post #39587 of 40443 Old 08-09-2019, 05:05 PM
darthray's Avatar
Liked: 3252
Actually spikes are for hard surface, to decouple the speaker/sub from the floor and do nothing on carpet. Vibration from a cabinet, is like water/electricity or an explosion. It will take the path of the lowest resistance, from the biggest area to the point of the spike/outrigger. An Aurelex platform, work as a good thick carpet. While my three front speakers are on spikes/outrigger on carpet, it is more for a look thing.
For the rattling, it can be cause by many things within the room. Since many different lower frequencies, can have an exciting mode that will make a wall/ceiling and any object nearby to rattles. I have spend many hours, chasing those objects. And where my walls/ceiling, needed extra drywall screws to fix mine.
Darth
Mactavish likes this.
darthray is offline
post #39588 of 40443 Old 08-09-2019, 05:30 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1622
^ spikes are to go through carpet to the hard floor below.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
post #39589 of 40443 Old 08-09-2019, 05:59 PM
darthray's Avatar
Liked: 3252
Not really, most spikes come with a small plate to be put on a hard floor and can be use also use on carpet (but never do). And when going through carpet, it take many years to settle at the bottom of the floor. Unless you have a really thin carpet.
Darth
darthray is offline
post #39590 of 40443 Old 08-09-2019, 06:05 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1622
Spikes are for carpet.
They will dig into your hard floor. That is what the little plates are for.
No issues with my spiked speaker stands, they went right through my average home carpet.
post #39591 of 40443 Old 08-09-2019, 06:22 PM
darthray's Avatar
Liked: 3252
I also had no issues at all with my outriggers. And had some for last 20 years or so.
Sound wise, I found they made a difference on hard floor with those little plate.
Night and day, No very subtle. Just removing some vibrations from the cabinet, been couple to the floor.
On a carpet, I find the speaker/sub made no difference at all.
Darth
darthray is offline
post #39592 of 40443 Old 08-09-2019, 07:01 PM
Bluescale's Avatar
Quoted: 816 Post(s)
Liked: 408
~7 years ago I purchased a D15SE. Unsurprisingly, I have some issues with uneven bass response in my room. I've been kicking myself for years for not buying a second one before they stopped selling them. I don't really care about the difference in appearance. However, the subs sold today have a different driver, and a higher power amp. If I were to buy a F15HP, how hard would it be to integrate into my HT? And if I'm already buying a different sub, is there any reason not to buy something like the F18? All hypothetical, of course.
Bluescale is offline
post #39593 of 40443 Old 08-09-2019, 08:11 PM
muscles's Avatar
Quoted: 705 Post(s)
Liked: 911
I think this is one of the easiest subs to move around. I pick them up and reposition them all the time. I also carried an FV25HP solo up 2 flights of stairs lol
The F18 isn't much over 100lbs right? Practically a featherweight sub
Greg
Subwoofers: Dual Rythmik F18SEs - SB13 Ultra
Speakers: Martin Logan Expressions - Martin Logan ESL-C - SVS Ultra Surrounds - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's- McIntosh MT5 - McIntosh MP100 - Oppo UDP-205 - Panamax M5300PMx2 - Apple TV 4k - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is offline
post #39594 of 40443 Old 08-09-2019, 09:24 PM
Mactavish's Avatar
Quoted: 140 Post(s)
Liked: 140
Greg
OK, your forum name now makes sense!
AVR: Denon X3500H
post #39595 of 40443 Old 08-09-2019, 11:12 PM
holco's Avatar
Quoted: 18 Post(s)
Liked: 70
Trying to understand what the settings really do
All combinations (close range measurements) with the low cutoff's and MF bass extension filters (limiter / rumble in off position)
Think I go for the 12Hz medium setting, red line 4th from top.
Click on the picture twice to get a higher resolution.
holco is offline
post #39596 of 40443 Old 08-10-2019, 12:36 AM
holco's Avatar
Quoted: 18 Post(s)
Liked: 70
Decided to continue with the 12Hz / MF Medium setting, following is the differences between the Limiter and Rumble filters.
holco is offline
post #39597 of 40443 Old 08-10-2019, 12:38 AM
holco's Avatar
Quoted: 18 Post(s)
Liked: 70
We do not live independently, so we continue with the Rumble and Limiter filter on, which looks like this.
holco is offline
post #39598 of 40443 Old 08-10-2019, 05:00 PM
darthray's Avatar
Liked: 3252
Greg
Hi Greg, if you are built like your Avatar picture. I can see that
But some of us look more like this
That said, at 128lb. I was able to move my two PB13-Ultra around, by sliding one corner at the time. With the subs weighting 150lb
When I get my two FV18. I may use my hand truck, or go back to old slide system on my carpet.
Darth
muscles and Matt2026 like this.
darthray is offline
post #39599 of 40443 Old 08-10-2019, 06:44 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
Darth
Flat cardboard also useful as a slider. One in front of the other....
darthray likes this.
Rysa4 is offline
post #39600 of 40443 Old 08-11-2019, 08:58 AM
gwsat's Avatar
Quoted: 4471 Post(s)
Liked: 5819
You may remember me having posted about this before but I hired a moving company to uncrate my FV18s and put them where I wanted them In my family room. It was the best money I ever spent. I weigh 164 pounds but it is a decidedly aging 164, so I decided to hire out the stoop labor.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB and Terra Server 24 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+; Apple TV 4K
gwsat is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
