Official Rythmik Audio Subwoofer thread - Page 536 - AVS Forum | Home Theater Discussions And Reviews
 12471Likes
post #16051 of 39476 Old 06-23-2014, 08:56 AM
Bond 007's Avatar
Quoted: 3218 Post(s)
Liked: 2532
Originally Posted by enricoclaudio View Post
The F12SE is the only subwoofer that comes with black spike feet for free. These are not the same spike feet we sell for the 15" subwoofers.
Interesting. Why is that? Is there something about the F12SE that makes spike feet necessary?
Bond 007 is offline
post #16052 of 39476 Old 06-23-2014, 10:04 AM
enricoclaudio's Avatar
Quoted: 3657 Post(s)
Liked: 4395
Feet are not necessary for the F12 / F12SE, they are just part of the upgrade to SE (Signature Edition).
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #16053 of 39476 Old 06-23-2014, 10:16 AM
Bond 007's Avatar
Liked: 2532
Bond 007 is offline
post #16054 of 39476 Old 06-23-2014, 10:48 AM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
Purchase or DIY subwoofer riser are a consideration if you want the sub off the carpet. Some people believe the risers result in better sound quality by changing the interaction with axial room modes. I use risers with caster because they make moving the subs around much easier. Most of this stuff with spike feet, $1000 speaker wire, ect is equal to snake oil. I am in the snake oil business and sell it for only $25.00 a can.
derrickdj1 is offline
post #16055 of 39476 Old 06-23-2014, 11:07 AM
basshead81's Avatar
Quoted: 316 Post(s)
Liked: 8865
Any chance that the D15 will be offered in the HP version at some point and possible ported(DV15HP)? That was the only thing that kept me from going rythmik back when I was sub shopping. For some reason I just love a downfiring sub because there are no grills or drivers exposed. The D15se would make for some beautiful end tables, Just wish they were offered with the 1510 driver and 600watt amp.
basshead81 is offline
post #16056 of 39476 Old 06-23-2014, 11:17 AM
JT78681's Avatar
Quoted: 1510 Post(s)
Liked: 1059
Bass it seems like he could simply take the DIY kit that comes with the 600 watt amp and 1510 driver and stuff it in the D15 enclosure. I could very well be wrong and there could be more to it then that.
basshead81 likes this.
JT78681 is offline
post #16057 of 39476 Old 06-23-2014, 11:28 AM
JT78681's Avatar
Liked: 1059
^^^ All speculation on my part of course. We need Brian to chime in on this one.
JT78681 is offline
post #16058 of 39476 Old 06-23-2014, 11:38 AM
DonH50's Avatar
Quoted: 3152 Post(s)
Liked: 3102
Have to redesign the cabinet...
My F12's sit on the carpet. That is a feature; if you move the subs around to clean behind them, or rescue a lost toy, it is easy to see exactly where to put them back. That is much harder with spikes.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #16059 of 39476 Old 06-23-2014, 11:43 AM
JT78681's Avatar
Liked: 1059
For ported yes, but you think sealed as well?
JT78681 is offline
post #16060 of 39476 Old 06-23-2014, 11:50 AM
Bond 007's Avatar
Liked: 2532
rescue a lost toy
lol
Bond 007 is offline
post #16061 of 39476 Old 06-23-2014, 11:52 AM
Bond 007's Avatar
Liked: 2532
You dont understand. Its nothing to do with the port. Spikes dont leave an indentation in the carpet.
Bond 007 is offline
post #16062 of 39476 Old 06-23-2014, 12:01 PM
JT78681's Avatar
Liked: 1059
Weird I think he might have posted and edited real quick. My response was only to him saying "Have to redesign the cabinet..." and not what was below that.
JT78681 is offline
post #16063 of 39476 Old 06-23-2014, 12:16 PM
DonH50's Avatar
Liked: 3102
If the driver parameters change, and I assume they would going to a higher capacity driver, the optimal cabinet size will probably change. It might not be significant. However, higher power/output usually means more displacement and that often entails a cabinet change. As others said, Brian can say for sure.
Don't think I edited that post...
DonH50 is offline
post #16064 of 39476 Old 06-23-2014, 12:28 PM
JT78681's Avatar
Liked: 1059
Makes sense, but I was just curious if it could be done with the current cabinet.
JT78681 is offline
post #16065 of 39476 Old 06-23-2014, 12:31 PM
basshead81's Avatar
Quoted: 316 Post(s)
Liked: 8865
I do not see why not...the F15 and F15HP are the same size cab.
post #16066 of 39476 Old 06-23-2014, 01:19 PM
dbmcelroy's Avatar
Wink lv12 availability
Originally Posted by Rythmik View Post
L12 is an entry levelsealed sub. It is not meant to replace F12. The amp is similar to the amp used in LV12R (which is 300WRMS)so that we can keep the cost on par with LV12R. L12 is also smaller than F12 which means it is less efficient. We have adjusted the T/S parameters so that it can come as close to the output of F12 at 20hz. But output above 20hz will be slightly lesst han that of F12. I will keep a reasonable damping value of the lowest extension music mode so that customers can still enjoy deeper than 20hz extension. A rumble filter is included for HT mode. If some has more than one L12, he can even use low extension music mode for HT use. The third extension mode is high extension (maybe 24hz or 28hz 3rd order roll-off). I need confirmation from F12 customers that they seldom use 28hz extension setting.
I have hinted there will be derivative productsof L12 which include a possibility of E12 (aluminum cone driver using HX400 400WRMS amp for sealed configuration), or L22 (two drivers with HX580 amp). My thinking is F15 is no longer as price-wise competitive. We have to find a good replacement model and L22 seems to make sense.
Originally I don't want to discuss too much on future products. But I guess too many of you want to understand what we have in mind.
Brian, I am interested in a sub for music with the Tekton m-lore high efficiency speakers and the Jolida 1501r amp, Emotiva dac1 dac input. The LV12r interested me for price and also many users commented on it's musicality inspite of it listed as a HT sub in the company's web site. I was glad to read that you are planning a sealed sub in the same price range. I assume this new unit would be an even better match for 95% music and 5% games. Is this correct?
If so, could you give an approximation of when you anticipate this sealed unit would be available? Won't hold you to it as things change, but I am looking to decide should I wait for that or jump in to the LV12r if the time will be long.
Thanks for your reply and advice.
David McElroy
dbmcelroy is offline
post #16067 of 39476 Old 06-23-2014, 01:53 PM
Bruce Watson's Avatar
Quoted: 173 Post(s)
Liked: 262
Anyway, we are going to have more models between LV12R and FV15HP, customers certainly will have more choices.
And that's what I'm waiting for.
Bruce Watson is offline
post #16068 of 39476 Old 06-23-2014, 05:14 PM
Eldiablos's Avatar
I can't wait for a F25HP and or a ported version :O
Panasonic TC-P60GT30, Oppo UDP-203, Marantz AV8802a, Emotiva XPA-6 Gen 3, Emotiva XPA-5 Gen 3
Paradigm Signature S8v3, C5v3, S2v3, Studio 20v5, SIG-1.5Rv3(x4), and Rythmik FV15HP
Eldiablos is offline
post #16069 of 39476 Old 06-23-2014, 05:47 PM
qguy's Avatar
Quoted: 180 Post(s)
Liked: 104
Ported version of the F25HP .... that would be insanely huge Imagine 2 FV15HP on top of one another
qguy is offline
post #16070 of 39476 Old 06-23-2014, 06:31 PM
JT78681's Avatar
Liked: 1059
People would buy it, but Brian might have trouble shipping it.
JT78681 is offline
post #16071 of 39476 Old 06-23-2014, 06:36 PM
JT78681's Avatar
Liked: 1059
The porting might be a bit challenging. I wonder if he could do a slot port. Perhaps that's more challenging or not feasible without being able to successfully implement the servo technology.
JT78681 is offline
post #16072 of 39476 Old 06-23-2014, 06:51 PM
basshead81's Avatar
Quoted: 316 Post(s)
Liked: 8865
Agreed. That is why I think they should focus on offering a upgraded D15 model. I think it would sell more. Honestly for the marginal price difference, Rythmik should drop all the Non HP model 15" subs. Another thing that would help is to post some cea2010 data for each sub. The 20hz comparison is pretty vague..sure the LV12 might be within 2db @ 20hz of the non hp models, but above and below the tuning point it has to be down several db. If folks were to see this when navigating the website it might help them get a better idea of the subs capability that interests them. Jmo
post #16073 of 39476 Old 06-23-2014, 10:53 PM
Eldiablos's Avatar
Yes we would!
post #16074 of 39476 Old 06-23-2014, 11:04 PM
tvuong's Avatar
Quoted: 2541 Post(s)
Liked: 2186
Brian already mentioned a page or two back that he won't make fridge size sub, so there's no hope for the FV25hp.
tvuong is online now
post #16075 of 39476 Old 06-23-2014, 11:22 PM
steveting99's Avatar
Quoted: 1847 Post(s)
Liked: 651
^ tvuong,
A little OT, but your avatar tells me you you're a fan of the world cup. Does the Rythmik sub(s) keep up with the tension in a soccer match? Not sure there's much low frequencies in the game.
NFL is a bit different, especially when the titans collide.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #16076 of 39476 Old 06-23-2014, 11:30 PM
tvuong's Avatar
Liked: 2186
^^ I am a huge NFL fan, Cowboys fan to be exact. To me, there's nothing better than football (NFL and college). I used to play soccer (when I was younger and thinner ). It's just not popular in the states but I do enjoy and watch the every four years World cup. Team US is playing well, I just want to show my support. And no, I just watch the World Cup in my main living room with just TV sound or at a sport bar.
post #16077 of 39476 Old 06-23-2014, 11:37 PM
bear123's Avatar
Quoted: 2505 Post(s)
Liked: 3917
I think the reason most of the moderate sized ID subs do not use slot ports is because the mdf takes up too much internal volume, as much as 10%, whereas the material of tubular ports takes up almost no internal volume. Giant cabs like the Captivators(which are tiny by DIY standards), it does not matter so much because people build the cabs as huge as they need to.
bear123 is offline
post #16078 of 39476 Old 06-24-2014, 08:17 AM
Blacklightning's Avatar
Quoted: 998 Post(s)
Liked: 853
I never understood the use of Max SPL, If I'm running my system flat. If my MAX @ 20hz is 95db my MAX @ 40hz should be 95db because I'm not going to run my system into compression. I understand headroom but I figured most people want a flat response. I would be more interested to know how loud 16hz is when 64hz is @ 95db's.
Eg. This Rythmik F12 kit to me has a MAX SPL of 92-93db's overall with 10hz @ 83db's (or 10hz at +/- 5 dbs)
Blacklightning is offline
post #16079 of 39476 Old 06-24-2014, 08:30 AM
basshead81's Avatar
Quoted: 316 Post(s)
Liked: 8865
Because cea2010 offers a way to compare performance on a even playing field. It's nice to know a subs capability before purchasing.
post #16080 of 39476 Old 06-24-2014, 02:20 PM
qguy's Avatar
Quoted: 180 Post(s)
Liked: 104
Maybe an F18HP or FV18HP .... imagine the output of that beast
rcohen and enricoclaudio like this.
qguy is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
