Official Chase Home Theater Owners Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 882 Old 03-24-2011, 04:40 PM
floridapoolboy's Avatar
Originally Posted by eljaycanuck View Post
They're wood, sanded and painted/finished. I put some felt pads on the feet and stood the subs upright. This is one of the only two pics I have, taken when I was unboxing the subs. (The other one looks pretty much the same.)
Well, the feet certainly are an improvement, looks like some spikes would mount up easy enough. My subs use spikes, helps keep the sound and the sub anchored. http://www.parts-express.com/pe/show...number=240-715
floridapoolboy is offline
post #62 of 882 Old 03-24-2011, 04:45 PM
eljaycanuck's Avatar
Quoted: 1865 Post(s)
Liked: 2615
Originally Posted by floridapoolboy View Post
... looks like some spikes would mount up easy enough. ... http://www.parts-express.com/pe/show...number=240-715
Those spikes look pretty sharp. (No pun intended. ) And, yeah, I think they'd screw into the SS-18.T's feet pretty easily. Hmmm...
eljaycanuck is offline
post #63 of 882 Old 03-24-2011, 04:55 PM - Thread Starter
Matman1970's Avatar
Liked: 27
I like the look of those. It says they are adjustable, do you know how tall you can make them?
__________________________
Originally Posted by jagzjagz
Holy smokes. A simple question turned into a buck wild display of thoughts, gazillion graphs, multiple interpretations, philosophies, and overall mayhem!!
Matman1970 is offline
post #64 of 882 Old 03-24-2011, 08:26 PM
Lurkerage's Avatar
It would be cool if I could get square black feet that screw in for my 18.1 Im gonna have to see how to do that exactly, that way they will look similar to these newer ones, although I am very happy with the finish on this one it's smoother and cleaner than the original 18.1 was.
Lurkerage is offline
post #65 of 882 Old 03-24-2011, 08:26 PM
No, I don't own these particular ones, they just caught my eye in the catalog.
post #66 of 882 Old 03-25-2011, 12:52 AM
tesseract67's Avatar
Sharp enough to gouge the heck out of your floor! Also, coupling spikes are in direct opposition to the concept of de-coupling your sub from the room, such as an Auralex Gramma would do.
I use vinyl bump on feet for my front mounted subs. I do like Lurkerage's idea of screw in rubber feet, I might try that on my Series 2's
"Women and cats will do as they please, and men and dogs should relax and get used to the idea." -Robert A. Heinlein
tesseract67 is offline
post #67 of 882 Old 03-25-2011, 07:15 AM
Pure-Evil's Avatar
Liked: 153
oh I dunno...those original round feet peg things were so sexy....and unique. i'll be they cost extra to do that kind of workmanship too :-) just sayin
Pure-Evil is offline
post #68 of 882 Old 03-25-2011, 07:33 AM - Thread Starter
Matman1970's Avatar
Liked: 27
I have already renamed the 18.T Series 2 the 18.T Vintage 1954 Leg Edition and I plan to be on Antiques Roadshow around 2025 and getting offered $50,000.00....meanwhile PE will be watching this on TV and splashing raindrop tears all over his little red riding hood sub while shaking his fists and cursing the fates.... :-) just sayin
I kid...I kid....PE your sub does look sweet from the picts I saw and I am glad you are enjoying it.
post #69 of 882 Old 03-25-2011, 07:46 AM
http://media.photobucket.com/image/c...ANKLES.jpg?o=3
post #70 of 882 Old 03-25-2011, 08:23 AM
Moderator
rboster's Avatar
Quoted: 1600 Post(s)
Liked: 2178
I have two sets of those that I never used on my DIY sub project. They very nice spikes.
rboster is offline
post #71 of 882 Old 03-25-2011, 09:54 AM
edgebsl's Avatar
Quoted: 666 Post(s)
Liked: 1183
Matt, that is too funny! lmao!
"1954"!
You know, believe it or not, most either liked the woodgrain the way it was or opted to just use the front firing setup. Changing the feet to black was an option and certainly the easiest fix..but most preferred to keep them as-is or remove them. Go figure!
As far as Spikes go, if it is a carpeted floor then I wouldn't see a problem using them but I agree with Tesseract that the ideal is to "de-couple" the sub from the floor. So I would not use them on a wood floor or hard surface.
Jeremy
Reaction Audio Subwoofers
edgebsl is offline
post #72 of 882 Old 03-25-2011, 02:02 PM
LOL, High five, Matt! "splashing raindrop tears". I see fpb is linking pics of his personal conquests.
I am still deciding on whether or not I want to front fire with metal grills or down fire. While I like the brute force look of the front fire, I also like the hidden driven/mystery/ominous black cube look, too. Massive bass out of seemingly nowhere. They can also be stacked for an outrageous Monolith look. It is great to have options!
post #73 of 882 Old 03-25-2011, 03:29 PM
HuskerOmaha's Avatar
Quoted: 68 Post(s)
Liked: 60
Originally Posted by tesseract67 View Post
LOL! High five, Matt. "splashing raindrop tears"
I did front firing for a while but seem to get a better sound and power down-firing.
Am I imagining this?
HuskerOmaha is offline
post #74 of 882 Old 03-25-2011, 03:53 PM
It is hard to say without measurements to qualify. You may very well be getting more boundary reinforcement. If you like the way they look and sound...
I am liking the way these look with the drivers hidden. Now that they are broken in, I am starting to experiment more with placement.
I have mine in the corners facing the side walls, this would kind of be like down firing. I am definitely feeling more ULF, I am confident that measuring will bear this out. I am on my way to measure them right now. I can "only" measure down to 16hz, though.
post #75 of 882 Old 03-25-2011, 04:28 PM
GSDTrainer's Avatar
Measurements are good and all but I hope you are plotting on a computer graph so we can all over ANALyze and say you faked this or that
GSDTrainer is offline
post #76 of 882 Old 03-25-2011, 04:37 PM
Weird, each sub has been moved almost 2 feet over towards the side walls. I gained 3db at 16hz, but everything at 20hz and above mirrors exactly what I was getting before.
Maybe your subjective experience is correct, Husker. My impressions were borne out in measurement, more ULF.
My subjective feelings are now, that the subs are lagging behind the mains, as they are sitting behind the plane of the mains. Got a central air duct in the way, I can't pull the left sub forward without covering it. I don't want to heat my sub! The upside is that my B&W's now have more room to breathe and they sound better.
Another thing I am starting to play with is the PEQ. This thing is awesome, I may be able to get by without any bass management at all.
post #77 of 882 Old 03-25-2011, 04:44 PM
HA! I hear you.
I am using a Rat Shack meter, test tones CD, pen and paper. Trying to optimize the sound in my room, FTW.
I don't have Excel. I am trying Open Office (thanks Desertdome), but my computer isn't cooperating.
This does make me want a Velo SMS-1, though. Maybe someday.
post #78 of 882 Old 03-26-2011, 08:12 AM
chashint's Avatar
Quoted: 20 Post(s)
Liked: 56
LOL, the only way to find that pic would be knowing where to look
Charlie
chashint is offline
post #79 of 882 Old 03-26-2011, 12:30 PM
Pure-Evil's Avatar
Liked: 153
um...don't they just look like black spray painted boxes?
post #80 of 882 Old 03-26-2011, 04:09 PM - Thread Starter
Matman1970's Avatar
Liked: 27
...... I can "only" measure down to 16hz, though.
Did I miss an "in" joke or is there a reason you stopped at 16hz.
post #81 of 882 Old 03-26-2011, 04:24 PM
No joke, that is as far down as my R-DES test disc goes. Or rather, where it begins.
post #82 of 882 Old 03-27-2011, 12:52 PM
tooskinny's Avatar
I'm using the same disc. Made a graph of my readings, but really don't know what to do next as for as using the Eq.
tooskinny is offline
post #83 of 882 Old 03-27-2011, 05:05 PM
I found the biggest changes come from room positioning. Are you satisfied with the sub placement? If so, you are ready to dial your parameters in.
You have choices with the EQ. One is a fixed solution, the bass boost, another is the variable PEQ. You can also use the crossover point as a form of EQ, either the Dayton's or a receiver's.
The phase control can help you dial the subs back in time if they are sitting closer to you than the mains are. It cannot compensate for the mains being closer than the sub, it cannot dial the subs ahead in time, so set it to "0" if this is the case. If you have a receiver handling distance, set the phase to "0".
I picked out the most problematic room peak, around 40-60hz for me, and then pulled this down with the PEQ set right around 50hz, about a 3db cut. Bandwidth is set at .5 to reach neighboring problem FR. The bass boost switch helps lift the textbook sealed enclosure roll off down low.
Take a look at your graph and play around with your parameters a bit. Rather than run through all the test tones again, just rerun the problem frequencies and see what your new readings are, that will speed up the process. Rinse, wash, repeat until you like what you see and hear.
And as always, have fun.
post #84 of 882 Old 03-28-2011, 08:47 AM
edgebsl's Avatar
Quoted: 666 Post(s)
Liked: 1183
I have not tried any of theses yet, so a work of caution there.
But there are a lot of sine wave tones and sweeps on this website:
http://www.realmofexcursion.com/downloads.htm
Jeremy
edgebsl is offline
post #85 of 882 Old 03-28-2011, 08:55 AM
MKtheater's Avatar
Quoted: 2374 Post(s)
Liked: 2329
I am running distortion tests with my sub system and I am testing just one sub. I want to find out what the limit is at 10hz and 10% distortion. So far I am at 108 db's at 10hz and 1.77% distortion from 14 feet away. My room gain is about 18db's at 10hz. I am posting all the info at CHT and my dual dts-10 and CS 18.2 thread. It will give me a good idea what a single is capable of with sine waves. Program material would be much easier to reproduce.
Audio Design Associates/Outlaw
Speakerpower SP1-4000
subs-Re audio XXX 18 IB(LT).
DIY speakers-mktheater-S10/S12s
MKtheater is online now
post #86 of 882 Old 03-28-2011, 11:13 AM
Thanks. I've tried these, HTS downloads, Real Traps... my computer isn't letting me burn them. I have some troubleshooting to do here.
I'm not terribly concerned about anything below 16hz right now. All I have to measure with is a Rat Shack meter, so I wouldn't expect a lot of accuracy that low.
Hoping for an SMS-1 sometime in the future, although that doesn't get down real low either. I figure if I am flat at 15-16hz, I am good.
post #87 of 882 Old 03-28-2011, 02:40 PM
tooskinny's Avatar
Craig helped me out with the settings after I sent him my graph. I have the series 1 sub with plate amp, so I don't have some of the settings you have.
Thanks for the reply.
post #88 of 882 Old 03-28-2011, 04:46 PM
You are welcome, tooskinny.
post #89 of 882 Old 03-29-2011, 12:14 PM
cneely8's Avatar
download the realtraps tones - they start at 10 Hz.
cneely8 is offline
post #90 of 882 Old 03-29-2011, 12:44 PM
Lurkerage's Avatar
Ahh Realm of Excursion I remember seeing that site, and I have burned test tones off of it before to see the performance of my car subs. They have all kinds of tones like pink noise and stuff too if I remember correctly, definitely handy if you are testing and adjusting.
