The New Master List of BASS in Movies with Frequency Charts - Page 287 - AVS Forum | Home Theater Discussions And Reviews
 7237Likes
post #8581 of 27592 Old 06-10-2013, 03:29 PM
nube's Avatar
Quoted: 77 Post(s)
Liked: 447
Originally Posted by obxdiver View Post
Well I have been missing quite the debate.
Just got home and got a chance to read everyone's input.
To put the DIY debate to rest, I do not plan to build my own sub.
I will buy one.
I like the sound of the Cap S2 with 2x 18", but some folks have said I should get 2 of those???
Meaning 4x 18" subs and 2 cabinets?
I don't think I need this much, plus, that would make it $6000...or do not understand something?
Is this because I am currently running 2 subs?
I would think (and hoping) that 1x Cap S2 or similar could replace both of my current subs.
Or, I can still run my Velodyne HGS 18 with the CAP S2 and turn it down a bit so it does not "pop" which only happens on the most aggressive of movies.
That would make 3x 18" subs in the room.
It was a long day at work, so I have not done much research yet.
This decision will take some time.
Multiple subs are helpful to smooth out room modes, or peaks and dips in the frequency response of the subs based on the dimensions of the room, and reflections/absorption by its walls, furniture and accoutrements.
It's likely true that a single S2 will significantly outperform your existing setup. However, with your budget and very large room, your best bet is dual Captivator S2. You can go cheaper, but won't get the output or value from any of the other available options. The difference in output compared to your current setup will be night and day. I would not recommend using your existing subs in conjunction with whatever you buy. There's just little to no point. Get some money back by selling them. smile.gif
Plus, after talking with Jeff recently, I'm fairly certain that lead time on the JTR subs is minimal at the current time. You'd want to call to make sure, though.
nube is offline
post #8582 of 27592 Old 06-10-2013, 03:53 PM
popalock's Avatar
Quoted: 1495 Post(s)
Liked: 2096
Correct me if I'm wrong here guys, but a single OS has about the same output as dual S2's at horn load, right?
S2's dig deeper, but the OS would give you more in the fq range that "most people" want.
Wish I could point obx to D-B to let him draw his own conclusions, but none of the mentioned ID recommendations have been put through the Ricci ringer.
Regardless of what you end up going with, I'm sure it will be such a massive improvement, you will be happy for a long time!
popalock is offline
post #8583 of 27592 Old 06-10-2013, 04:29 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
$295.00 ep4000 probably a better deal for DIY. 4 of those in 4 ohm bridged gives you 6400 measured REAL RMS WATTS of power.
Then it's like 200 for mdf
50 for duratex
100 for minidsp
and you have 1400 bucks for drivers, which would get you six 18" drivers
6400 watts and six 18" drivers vs 4000 watts and two 18" drivers. Not really even comparable IMO.
JWagstaff is offline
post #8584 of 27592 Old 06-10-2013, 04:57 PM
nube's Avatar
Quoted: 77 Post(s)
Liked: 447
popalock, obxdiver doesn't want what "most people" want, though. He said real specifically that he wants the lowest octaves, or the "deepest" subs. And, now that I look again, he said his budget is only $3-4k. I mistakenly thought it was $6k for some reason. I guess a single S2 will prolly have to suffice!
50 for duratex
100 for minidsp
Your numbers are a bit light for the construction of the boxes and the actual price of the MiniDSP. But, if it was apples-to-apples, you'd be looking at a 1-1.5dB improvement with the 6 drivers due to the power limitations. However, that's still not a super realistic comparison, because driver parameters and box size result in different real world performance. This or a similar conversation has been had before in the DIY section, and a cheapie 18" driver (if they can even be had) isn't nearly the same as the custom manufactured, high xmax, high power capacity drivers in the S2.
nube is offline
post #8585 of 27592 Old 06-10-2013, 06:22 PM
MKtheater's Avatar
Quoted: 2444 Post(s)
Liked: 2466
Well to be fair some of those cheaply drivers measured very well under real conditions and the CapS2 has not yet. We are assuming they are much better based on specs. There are cheaper drivers with better specs that did measure well too!
Nothing right now
MKtheater is online now
post #8586 of 27592 Old 06-11-2013, 10:19 AM
Imageless83's Avatar
Originally Posted by Toe View Post
As far as commercially available subs go, is there anything better than the S2 at its 3k price point? That seems like the best to me overall, but there might be something I am missing. If I ever upgrade from what I have now and go with another bought sub, that S2 (duals) is top of my list. Having said that, I hope I can muster up the courage to take on a DIY project since that seems to be where the real bang/buck factor is highest.
Die Hard 5 on blu can be had for $10 starting today at Target for those who do not know once you take off the $3.00 coupon which you can get for signing up for their text coupons (it is on sale starting today for $13). I am tempted on a blind buy at that price looking at the charts even with the generally bad word of mouth on the film itself. I enjoyed LFoDH quite a bit (watched it last night again) so as long as this one is not to far behind I think I would get a few watches out of it. cool.gif
Thanks for looking out, picked up Die Hard 5 for $10.60 last night.
Imageless83 is offline
post #8587 of 27592 Old 06-11-2013, 12:54 PM
Toe
Toe's Avatar
Quoted: 2665 Post(s)
Liked: 3418
Cool! Glad it worked out. smile.gif I still need to get over there.
Toe is online now
post #8588 of 27592 Old 06-11-2013, 01:54 PM
Blu_One's Avatar
Liked: 62
65" Panasonic ST60 | Onkyo 809 | Oppo 103 | Apple TV4 | Darbee Darblet | 5.2 system - 5x Arx A2 + 2x SVS SB12-NSD
Blu_One is offline
post #8589 of 27592 Old 06-11-2013, 03:16 PM
eljaycanuck's Avatar
Quoted: 1867 Post(s)
Liked: 2621
eljaycanuck is offline
post #8590 of 27592 Old 06-11-2013, 04:04 PM
Ray77085's Avatar
Quoted: 178 Post(s)
Liked: 174
Any deep LFE or good surround sound in this movie ? Please post up before i buy it.
http://www.blu-ray.com/movies/Hansel-and-Gretel-Witch-Hunters-Blu-ray/65146/
MY 5.4.4 SET UP (Dolby Atmos)
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs. 4 ea Over head in ceiling 8" speakers.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000. Samsung BD-8500 Blu-Player
Ray77085 is offline
post #8591 of 27592 Old 06-11-2013, 06:49 PM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 312
Absolutely not. Zero bass, horrible movie.
wth718 is offline
post #8592 of 27592 Old 06-12-2013, 03:59 AM
Ray77085's Avatar
Quoted: 178 Post(s)
Liked: 174
WOW !!!
Thanks for the info and saving my dime !!!
Ray77085 is offline
post #8593 of 27592 Old 06-12-2013, 06:18 AM
Cowboys's Avatar
Liked: 107
Originally Posted by Brian Fineberg View Post
I say AGDTDH is easily a 5 star. Holy hell!
AGDTDH? Huh?
Cowboys is offline
post #8594 of 27592 Old 06-12-2013, 06:36 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Originally Posted by Cowboys View Post
AGDTDH? Huh?
a good day to die hard
post #8595 of 27592 Old 06-12-2013, 06:43 AM
KJSmitty's Avatar
Liked: 34
I think we are going to need a sticky at the start of this thread listing all of the movie acronyms for those stopping by.. 😄 I know I had to go looking several times
Love DIY
KJSmitty is offline
post #8596 of 27592 Old 06-12-2013, 06:47 AM
MKtheater's Avatar
Liked: 2466
Or people can search, I mean it was mentioned for 2 recent pages.
Nothing right now
post #8597 of 27592 Old 06-12-2013, 04:02 PM
KJSmitty's Avatar
Liked: 34
Well yes, there is always that....😏
I work in a world of acronyms.. Many newcomers don't always comprehend them or immediatly apply them to a phrase, word or title. It's always good to have a gouge or cross reference.
Cheers
Love DIY
KJSmitty is offline
post #8598 of 27592 Old 06-12-2013, 05:11 PM
LastButNotLeast's Avatar
Quoted: 2408 Post(s)
Liked: 2053
Originally Posted by Steve544 View Post
So, what, in peoples opinions, is the very best all around Blu Ray that you would use as a DEMO disc? There are many great ones available and many that aren't worth a thing, but, other than animated cartoon stuff, what would be your choice as the best demo disc?
If you (still) want a demo disc, the best thing is a demo disc. I hope these have been mentioned somewhere here already, as they are each worthy of attention:
ScubaSteve's
http://www.mediafire.com/?ryv68qxb68s8nt4
Superleo's 1
https://www.avsforum.com/t/1391873/reference-blu-ray-demo-disc-bd9-dvd-dl-media-bd50
Superleo's 2
https://www.avsforum.com/t/1469192/reference-2-blu-ray-demo-disc-bd9s-bd50
Jindrak's
https://www.avsforum.com/t/1412846/the-ultimate-bass-demo-disc
MemX likes this.
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #8599 of 27592 Old 06-12-2013, 06:33 PM
Blu_One's Avatar
Liked: 62
ScubaSteve's
Superleo's 1
Superleo's 2
Jindrak's
Blu_One is offline
post #8600 of 27592 Old 06-12-2013, 06:39 PM
newc33's Avatar
Quoted: 1173 Post(s)
Liked: 1779
Anyone see trailer to pacific rim? Looks like an awsomr movie visually and if it had quality sound and lfe it would be a pretty kick ass I bet
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s rear surround
Quad PSA T18s!!!!!!
Funk audio 12.2 HP mains powered by/funk audio 6x500 watt amp
newc33 is offline
post #8601 of 27592 Old 06-13-2013, 02:50 PM
newc33's Avatar
Liked: 1779
Whatched oz the great and powerful yesterday.. when I went to audio options it had the option for dts 7.1 nearfeild mix. What does the nearfeild mix mean? Either way it sounded very good
denon x4100
Quad PSA T18s!!!!!!
newc33 is offline
post #8602 of 27592 Old 06-13-2013, 03:58 PM
quattroatl's Avatar
Quoted: 13 Post(s)
Liked: 37
Originally Posted by nube View Post
Was not impressed by A Good Day To Die Hard. Compared to the heavy hitters, it has only a couple of scenes, and only one of those is sustained. 4 stars for bass by my ears. Plus, it's an absolutely terrible movie. Much worse than the last one. Total waste of time.
I have to disagree wholeheartedly because AGDTDH along with Oz the Great and Powerful are both stellar in demonstrating demo worthy scenes.
Bass fanatics are lucky to have these 2 movies along with Looper and Judge Dredd in the past 12 months.
Say what you will about the quality of the movies, but the bass scenes are all top notch.
quattroatl is offline
post #8603 of 27592 Old 06-13-2013, 05:50 PM
HeffeMusic's Avatar
Quoted: 460 Post(s)
Liked: 194
Hello I watched the OZ movie and I have to say there were a few very nice LFE moments. I have to say I would like
To see some graphs on the end of the movie. Near field means the mix was mixed specifically for smaller rooms. The engineer has the speakers closer to him his head when he makes his mix.
HeffeMusic is offline
post #8604 of 27592 Old 06-13-2013, 05:55 PM
newc33's Avatar
Liked: 1779
Okay I kinda figured something like that. So a large room should choose the Dolby 5.1 instead? As far as lfe the last 20 mins or so were awesome and very realistic. I found the fireworks to be my favorite quality wise. When they went off u could feel the percussion as if it were real. I was impressed by the movies lfe all together but everything after the fireworks seemed a step up output wise
denon x4100
Quad PSA T18s!!!!!!
newc33 is offline
post #8605 of 27592 Old 06-13-2013, 08:16 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Has some decent bass in it, but AGTDH has more. Not a very good movie though, but somewhat OK for mindless popcorn entertainment.
Max
djbluemax1 is offline
post #8606 of 27592 Old 06-13-2013, 08:24 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Originally Posted by Roger Dressler View Post
Jeff, thanks for the link. A treasure trove of info for me to wade into.
What I am looking for are plots of LFE alone with a bandwidth somewhat larger than 120 Hz, so as to see where the content rolls off. Are there such plots a DB? The ones I've seen all stop at 120 Hz.
Roger, curious as to what you're looking to find about the LFE bandwidth? Are you looking to see how many studios adhere to or deviate from the generic standards? Perhaps we could introduce this discussion on the other site where there are quite a few folks interested in the technical aspects of things.
BTW, did you ever manage to find out anything from your contacts about The Hobbit's mix/LFE?
Max
post #8607 of 27592 Old 06-13-2013, 08:28 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
I'm expecting good things from smaug in the hobbit part 2.
post #8608 of 27592 Old 06-13-2013, 08:58 PM
MKtheater's Avatar
Liked: 2466
Why? They filtered out all the bass before so why expect some next time?
Nothing right now
post #8609 of 27592 Old 06-13-2013, 09:18 PM
Reddig's Avatar
Quoted: 505 Post(s)
Liked: 1001
Right Hobbit 1 was such a dissapointment in that area.
JBL Pro Cinema/JTR/JVC/Denon/Oppo/Roku Ultra/Elite Screens/Furman/Seatcraft/Acoustimac/AudioQuest
Reddig is offline
post #8610 of 27592 Old 06-13-2013, 10:13 PM
holt7153's Avatar
Quoted: 140 Post(s)
Liked: 222
A disappointment in many areas.
Flageborg likes this.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
