List of budget subwoofers ($300 and less) - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 552Likes
post #2791 of 3084 Old 01-25-2018, 07:25 AM
abhaskare's Avatar
Originally Posted by JimWilson View Post
Total freedom? There's something you don't see every day...
Is there one primary location for the listeners or will they be scattered about? What level of Audyssey (2EQ, XT, XT32)? They go from a no-frills version to one with all the bells and whistles. Depending upon which your receive has determines whether or not it's able to independently tune the subwoofers.
Thanks...its being built so wide choice! It will be in a theater room (18'x17'x9') with a 2 seating area in back center.
Another related Q is should I go with 10" or 12" sub? excess hum is something that I dont like, favor more of punchy beats.
I currently own an ancient Sony 12" sub that seems to be ok but nothing great.
The receiver has Audessey MultiEQ XT32, below is from the specs:
Equipped with the full Audyssey Platinum suite of advanced DSP algorithms, the AVR-X4300H features Audyssey MultEQ XT32 automatic room acoustic correction. With the supplied measurement microphone, MultEQ XT32 analyzes each speaker's output (including the subwoofers) at up to 8 measurement locations and generates precision digital filters that optimize each channel for the correct frequency and time domain response.
Audyssey Dynamic Volume smoothes out annoying jumps in volume (such as TV commercials), letting you listen at lower levels and still enjoy clear dialog, music and sound effects. Audyssey Dynamic EQ provides precision tonal tailoring for full range clarity at any listening level. Audyssey Low Frequency Containment uses advanced psychoacoustic algorithms to deliver a full range tonal balance, including deep bass, but without disturbing close-by neighbors or family members in other rooms, and features a multi-step adjustment that lets you dial in the amount of containment to your preference.
Audyssey Sub EQ HT provides individual DSP tailoring of each subwoofer in a dual subwoofer setup, for deeper bass with improved definition, compared to a single subwoofer configuration.
abhaskare is offline
post #2792 of 3084 Old 01-25-2018, 01:12 PM - Thread Starter
Writer & Reviewer
JimWilson's Avatar
Quoted: 2532 Post(s)
Liked: 4092
Sub EQ, muy bueno. That means if you have more than one subwoofer each of them gets its own EQ curve.
No bueno. Seats against a wall - especially the back wall - wreak havoc on the bass, Sub EQ or not. If possible, you should pull them out a few feet.
You're in for a treat; the subwoofers available today will be quite a bit better than that old Sony.
If you only have two seats, and they are close in proximity, there's a good argument for a single nice subwoofer instead of a pair of average subs. What are you after; depth, volume, precision, something else perhaps? Those are not mutually exclusive, but the more qualities you add the more the cost goes up.
alwaller likes this.
If you take yourself too seriously expect me to do the exact opposite.
BTW, did you really need to quote the entire post?
JimWilson is offline
post #2793 of 3084 Old 01-25-2018, 01:40 PM
abhaskare's Avatar
Yes, will be having the prime seating 3-4 feet from the rear wall. Allow me to tell you more on what I am looking for:
I recently got new speakers - Focal Aria 926. These have two 6" woofers and good bass.
https://www.focal.com/en/home-audio/...akers/aria-926
The next one up was Focal Aria 946 with dual 8" woofers but for $1500/- more so I decided to then invest in a good subwoofer.
Not really sure if a sub complements to fill that gap ..but that is what I am looking for. So I can go higher in budget.
To get deep bass that I am missing from dual 8". Smooth Jazz/instrumental is my primary listening preference.
post #2794 of 3084 Old 01-25-2018, 02:04 PM - Thread Starter
Writer & Reviewer
JimWilson's Avatar
Liked: 4092
Well, with that in mind... you're in the wrong thread I'm afraid. The last thing you want to do is saddle those Focal's with a budget subwoofer. That would drag the whole experience down. Your subwoofer(s) should compliment the speakers, not insult them. About the least costly sub I can think of that might work is the RSL SpeedWoofer 10S, which is $400.
alwaller, abhaskare and Lp85253 like this.
post #2795 of 3084 Old 01-25-2018, 02:28 PM
abhaskare's Avatar
Thanks a lot, JimWilson.
Yes, I need to look for something in line with Focals rather than a budget subwoofer. Great help, will keep researching in appropriate thread.
Appreciate very much all of your detailed and quick responses!
post #2796 of 3084 Old 01-28-2018, 08:04 AM
Quoted: 23 Post(s)
Liked: 7
Fry's has the Klipsch sub-12hg on sale again for $197 with free shipping.
I know Klipsch doesn't get much love here but most of the disdain seems directed at the 10SW and 12SW.
I have seen some feedback on the Sub 12HG and it was positive so I thought I would ask for opinions . At $200 the sub is right in the middle of budget subs. Is the quality of construction and overall sound comparable to the BIC PL-200 or the polk505 ? There was another $200 sub that was popular as well but I forget the name.
The room is 20x20x8with half of one wall open to a second room. 50/50 music and movies. I know I will need 2 to fill that space. Hence the deal hunting
CL-350 is offline
post #2797 of 3084 Old 02-04-2018, 04:17 PM
Quoted: 44 Post(s)
Liked: 3
12x18 room
looking at the emotive basx 8 at $200.
is 28hz good enough if I like movies with explosions etc.
its another $100 for the 10 and only get 27hz on that one
or maybe a bic f12?
50/50 movies/music in stereo mode, mains with sub
johndoe1 is offline
post #2798 of 3084 Old 02-04-2018, 05:41 PM
MIX_MASTER_ICE's Avatar
Quoted: 2678 Post(s)
Liked: 2493
Originally Posted by johndoe1 View Post
12x18 room
or maybe a bic f12?
Klipsch sub-12hg is $198 @fry s.com this week with promo code. That's the best bang for the buck going right now under $200.
Subs>RBH I-12e. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB72,XB32. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. JBL PartyBox100(x2), Xtreme2,Charge4,Link300. Sivga SV004. LG FH6,RK8,RK7,PK7,PK5. HK Onyx Studio4(x2)
MIX_MASTER_ICE is offline
post #2799 of 3084 Old 02-05-2018, 08:03 AM
Quoted: 965 Post(s)
Liked: 482
the the sub12 was highly regarded at the 200 price range a couple of years ago, i have one
fills my room nicely
14x18x9, 1 door to kitchen, slab on grade
MIX_MASTER_ICE likes this.
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #2800 of 3084 Old 02-05-2018, 05:25 PM
Quoted: 44 Post(s)
Liked: 3
is that the same klipsch sub frys uses in their demo room?
it does a pretty damn good job when i play music there
ill check this weekend. hopefully its still on sale
johndoe1 is offline
post #2801 of 3084 Old 02-08-2018, 01:02 AM
Quoted: 23 Post(s)
Liked: 7
Yesterday Fry's had a 1 day promo code with free shipping on it so I went ahead and ordered one. I think the weekly promo code is for instore only. The sales change constantly, a person really needs to keep watch.
I know it is a much older design but I am letting budget control my purchases (for once) and from what i have read, it should perform well for being a $198 sub. Once I get it and then once I get home and can set it up I will post my thoughts (as uninformed as they may be).
M
CL-350 is offline
post #2802 of 3084 Old 02-08-2018, 01:28 AM
Liked: 2493
M
The Sunday code, which is good for the entire week, does indeed work for shipping the Klipsch sub-12 for $198. The sub-12 has long been a go to selection under 200 bones. It's been available many times for under $200 the past few years and I'm surprised they are still pumping these out, as it was supposedly discontinued quite a while back. Hope you enjoy it.
post #2803 of 3084 Old 02-08-2018, 09:04 PM
Quoted: 44 Post(s)
Liked: 3
i looked at specs between the sub hg12 at $200 on sale at frys and the ssw12
why does the cheaper hg12 go lower than the ssw12? the ssw12 is much more expensive
johndoe1 is offline
post #2804 of 3084 Old 02-09-2018, 12:03 AM
Liked: 2493
I'm not familiar with the Klipsch SSW12. Did you possibly mean the R12SW? The sub-12hg is from the cheaper "Synergy" line. The build quality isn't exactly high end. It's like back in the day, buying a muscle car for the engine, with it having roll up windows and no AC.
post #2805 of 3084 Old 02-10-2018, 05:55 PM
Quoted: 44 Post(s)
Liked: 3
I think I meant the sw12. I went to frys today. the sub they use in the demo room is the sw10. I like it. pretty awesome for music at least how they have it set up there.
johndoe1 is offline
post #2806 of 3084 Old 02-12-2018, 11:09 AM
Quoted: 24 Post(s)
Liked: 9
it's a punchy little sub, i heard one at best buy. However for the price ($250 on sale?) I feel like there are better choices. Mostly because for $180-$200 you can get a Bic RTR Ev-1200 or a Bic F12 (basically the same sub) or for less money you can get a dayton sub 1000, sub 1200, or a bic v1020.
VegetarianEater is offline
post #2807 of 3084 Old 02-12-2018, 06:05 PM
DavidML3's Avatar
Quoted: 211 Post(s)
Liked: 90
I can't believe I missed out on the svs sub deal. I bought an svs sub back in 2007 and its still going strong.
I need another for my theater room. Im looking for two subs this time. So is bic the best behind svs?
What about wireless subs? Less wires the better. I really want this room looking clean.
DavidML3 is offline
post #2808 of 3084 Old 02-12-2018, 11:17 PM
Liked: 2493
What SVS deal are you referring to? If it's the PB12-NSD, it's still available from Electronics Expo, World Wide Stereo and Listen Up for $499.99.
post #2809 of 3084 Old 02-13-2018, 05:43 AM
DavidML3's Avatar
Quoted: 211 Post(s)
Liked: 90
I may just settle for a klipsch. I wanted two subs and needed to keep the budget under 500 for both combined
DavidML3 is offline
post #2810 of 3084 Old 02-13-2018, 01:22 PM
Liked: 2493
Kinda like two bologna sandwiches or one steak sandwich.
post #2811 of 3084 Old 02-22-2018, 02:53 PM
Liked: 0
Thank you for making this great list!
jvr14 is offline
post #2812 of 3084 Old 03-01-2018, 07:05 AM
Leon!'s Avatar
Quoted: 297 Post(s)
Liked: 152
Klipsch SW115 and the jamo s626 towers, bookshelves center package for $900 at frys. Shipping as of now, otherwise in store only (no hold for p/u
Leon! is offline
post #2813 of 3084 Old 03-09-2018, 06:58 AM
Liked: 8
I have the HG 12 Klipsch . I am very happy with this subwoofer!!
I got it on CL for $125. I think this is a good sub for movies as it goes pretty deep with some volume.
I would say that it does not have a great punch in the midbass and it sure does not seem like the fastest most accurate bass. As I said before I think this is a pretty fantastic sub for movies for under $200!!
Toddnkaya is offline
post #2814 of 3084 Old 04-02-2018, 06:01 PM
ez1dog's Avatar
Quoted: 31 Post(s)
Liked: 44
Unhappy New Sub
I need some thoughts on the Bic Acoustech Pl-200 series 2 subwoofer. Only one review on You Tube.
ez1dog is offline
post #2815 of 3084 Old 04-02-2018, 06:36 PM - Thread Starter
Writer & Reviewer
JimWilson's Avatar
Liked: 4092
You can check out my review at this link. It might have something to help you with the decision.
post #2816 of 3084 Old 04-02-2018, 08:02 PM
ez1dog's Avatar
Quoted: 31 Post(s)
Liked: 44
Thanks Jim. Now that's a REVIEW! You covered that sub from top to bottom. You answered questions I didn't even have. LOL. Thanks again.
ez1dog is offline
post #2817 of 3084 Old 04-03-2018, 05:52 AM - Thread Starter
Writer & Reviewer
JimWilson's Avatar
Liked: 4092
You're quite welcome. I'm glad my evaluation proved useful.
post #2818 of 3084 Old 04-12-2018, 11:07 AM
Raymond Leggs's Avatar
Quoted: 48 Post(s)
Liked: 37
Rockville APM10W --$144.95 it always sells for this price.
https://www.rockvilleaudio.com/apm10...AaAngmEALw_wcB
Kinyo AW-650
$ 99.99
https://www.ebay.com/i/222015974868?chn=ps&dispItem=1
Rockville RGB12S
$189.95-245.00
https://www.ebay.com/itm/New-Rockvil...MAAOSwFqJWqSE6
Raymond Leggs is offline
post #2819 of 3084 Old 04-12-2018, 05:26 PM - Thread Starter
Writer & Reviewer
JimWilson's Avatar
Liked: 4092
Kinyo AW-650
$ 99.99
Rockville RGB12S
$189.95-245.00
Thanks for the heads up.
The Rockville APM10W seems to fit the bill so I'll add that one. Their RBG12S is a PA subwoofer though, which is a different market then what I'm tracking; this list is for products designed for HT and 2 channel music systems. The Kinyo has a 5.5" driver, which means it isn't really a subwoofer. I have established a minimum driver size of 8" because anything smaller is a mid-bass module more than anything else.
post #2820 of 3084 Old 04-13-2018, 03:00 PM
stonecoldtx's Avatar
Not sure whether this is allowed here or not, but for those of you who have access to a Frys store in your area, they have a Klipsch Synergy Sub-12HG (apparently, a discontinued model) on sale through tomorrow, for $229.00 (plus shipping and tax) . . . this sub has a 12" driver and a 300w RMS/650w Dynamic amp . . . I live about 20 miles from the nearest store, and yesterday, I went online and ordered one, and got FREE SAME DAY DELIVERY!!
To me, that seemed like a SMOKIN' good deal on a sub that normally lists for around $400 and up online . . . I think you can even order it directly from their website and have regular delivery, but of course, shipping charges will apply . . .
EDIT: After I posted this, I did a search in this thread, and saw that Frys has had this sub on sale at times for about $30 less . . . still a good deal, IMVHO . . .
stonecoldtx is offline
Acoustic Audio , Acoustic Audio Psw 8 300 Watt 8 Audiophile Series Powered Subwoofer , Acoustic Audio Rwsub 8 300 Watt 8 Home Theater Series Powered Subwoofer , Aperion Audio , Bic America , Dayton Audio Sub 800 8 80 Watt Powered Subwoofer , Energy Esw C8 8 Inch Subwoofer Black , Energy Esw M8 Na 1200 Watt Subwoofer , Hsu Research , Hsu Research Stf 1 Subwoofer 150 Watt , Infinity Ps 12 Subwoofer , Jamo Sub210 8 Powered Subwoofer , Klipsch , Klipsch Kw 100 120v Subwoofer , Klipsch Sub 12 , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Klipsch Synergy Sub 10 Subwoofer Speaker , Martin Logan , Martinlogan Dynamo 300 Home Theater And Stereo Subwoofer , Polk Audio Psw110 10 Inch Powered Subwoofer Single Cherry , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Polk Audio Tsi500 Black 3 1 Tower Speaker System Free Psw 110 , Polk Psw108 10 100w Psw Series Powered Subwoofer , Scosche Hdw12 Subwoofer 12 , Subwoofers
