Official Power Sound Audio Subwoofer Thread - Page 1054 - AVS Forum | Home Theater Discussions And Reviews
 66664Likes
post #31591 of 52991 Old 02-15-2017, 08:12 PM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
Originally Posted by thecloneranger View Post
how hot do you guys run your subs. audyssey set mine to -6 i bumped it to -1.5. this should be fine correct?
that is about how hot I run mine...4-6db hot is average. you could even try 0 on the sub trim and run a full 6db hot.
wait so u set your sub gain then ran audyssey. then u raised the gain up some more after. i thought that would mess with audyssesy intergration of your speakers. i always just lowered in the reciever never thought about doing it on the back of the sub
don't do that it's the wrong approach...not every gain dial is exactly the same when you have multiple subs...the way I told you is correct. Level match each sub, run audyssey, -6 after cal is about perfect and nets you 6db of adjustment without going past 0. You want to use the AVR sub trim as it is much more precise then adjusting the amp gain dials after calibration.
ahblaza likes this.
basshead81 is offline
post #31592 of 52991 Old 02-15-2017, 08:18 PM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
Originally Posted by sunPin View Post
Does the averaging that occurs by having dual subs reduce bass ringing? If I'm doing my REW measurement correctly, it looks like I have some pretty long rings.
Yep sure does...the only way to reduce ringing is by smoothing the response without eq. The only way to do that is to change placement and more then likely add more subs. This is why multiple subs are always better then a single when properly setup.
sunPin likes this.
post #31593 of 52991 Old 02-15-2017, 08:23 PM
Hopinater's Avatar
Quoted: 3585 Post(s)
Liked: 11409
i see well everyone is home now so i cant play with it anymore tonight. last thing i did was move the third subwoofer upfront and move my seats back as close against the wall. my current theatre room is small but im gonna have a bigger dedicated room built soon so im getting my electronics out the way now. ill take some pics of my setup and maybe you guys can suggest some places to try for my third woofer. not many places to put the third woofer but let me know any ideas yall have to try. i know i need to get rew but for now just going by ear
Looks good and I really like that Terminator replica you have. That is sweet. Where did you get that?
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
post #31594 of 52991 Old 02-15-2017, 08:27 PM
Hopinater's Avatar
Liked: 11409
Originally Posted by ahblaza View Post
I hear you my friend, either going down this Friday depending on when Jim gets the cabs, they're shipping Thursday but no time guarantee when they'll arrive, could be early morning, mid afternoon or closer to 5 PM. Regardless I will have them by the weekend, more likely Saturday, I think you'll be heading down Jim Saturday as well, correct?
Just a side note, look for two mint low usage hours V1800s in the outlet. I've never had a single issue with these subs, auto on worked every time with no glitches, no scratches or blems and the grill covers have been in storage since I bought them. The feet were never used as I made custom sliders that screwed on the bottom of cab for easy placement positions. Sorry for the rambling, it's like I'm trying to make a sale here
Cheers Jeffrey
You're right Jeff, looks like I'll be heading up there on Saturday. Let me know if you are going on Saturday for certain and maybe we can try and get there around the same time.
ahblaza likes this.
post #31595 of 52991 Old 02-15-2017, 08:30 PM
Hopinater's Avatar
Liked: 11409
That's fine. I run my V3600's 9 dB hot. Audyssey sets the trim at -9.5 and I bumped them up to -0.5.
ahblaza likes this.
post #31596 of 52991 Old 02-15-2017, 08:31 PM
thecloneranger's Avatar
Quoted: 87 Post(s)
Liked: 64
its from sideshow collectibles. i dont see it listed on their website anymore bought it a year ago. but no worries they have a full scale replica for 6 grand!!!
https://www.sideshowtoy.com/collecti...tibles-400060/
Epson 5030ub,Onkyo 818,Samsung bd player,Xbox One,Ibuypower gaming pc
Ascend Acoustics sierra 2s l/r,Ascend Acoustics horizon center w/raal upgrade
Ascend Acoustics cbm 170 x4 surround duty,PSA dual s3000i
thecloneranger is offline
post #31597 of 52991 Old 02-15-2017, 08:46 PM
That's fine. I run my V3600's 9 dB hot. Audyssey sets the trim at -9.5 and I bumped them up to -0.5. [IMG]https://www.avsforum.com//forum/i
mages/smilies/biggrin.gif[/IMG]
So where do you set the sub gain for calibration? Audyssey asks for it to be set at 50%, I end up with max -12 when i do that. So i turned my gain down to 25% and ran calibration again and ended up at -3. I left the AVR as is and bumped the sub gain up to 50% . I'm only running one sub.
MattRomain is offline
post #31598 of 52991 Old 02-15-2017, 08:53 PM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
There is no set number, set it, run Audyssey...if it is at the max, turn the sub gain down a bit and run audyssey again. Just run a 1 point calibration and adjust the sub gain until you get -6 ~ -10 db, then run a full calibration.
Yamaha RX-A2060 | Outlaw M-2200 (x5) | Oppo UDP-203 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | Amber In-ceiling | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #31599 of 52991 Old 02-15-2017, 08:56 PM
So if you want more bass than the calibration sets to you add it at the AVR or the sub? Or both? Thanks, seems like I'm on the right track, all new to me.
post #31600 of 52991 Old 02-15-2017, 08:58 PM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
Add at the AVR only.
ceh383 is offline
post #31601 of 52991 Old 02-15-2017, 08:59 PM
Liked: 9
Just wanted to chime in and say my new V1801 is up and running strong. Just curious what people think average break in time for new drivers is? I've had the V1801 going for about 5 hours now and it seems to already be opening up a bit. (sorry no pictures of the sub, a bit dark for that now). The speaker stands happen to be milk crates which we were coincidentally just the right height to get the tweeters ear level. Being 27 with speakers that cost this much still seems a little silly sometimes so I'm ok with the milk crates :P
chainwallet likes this.
ianhiggins is offline
post #31602 of 52991 Old 02-15-2017, 10:20 PM
Marc Alexander's Avatar
Quoted: 5639 Post(s)
Liked: 5222
Aren't bass traps another option? I'm currently working with GIK to put together a treatment package.
Marc Alexander is offline
post #31603 of 52991 Old 02-15-2017, 10:24 PM
Quoted: 16 Post(s)
Liked: 65
Talking
After seeing your feet I think a more appropriate username might be "iambaggins"
FullOfVexationComeI is offline
post #31604 of 52991 Old 02-15-2017, 11:04 PM
Mike Butny's Avatar
Quoted: 1126 Post(s)
Liked: 2555
Get a 4th and stack them, 2 in each corner
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7013 Receiver, 3-Marantz Ma700 and 2-Ma6100 monoblocks, 7.4.2 Atmos, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, 2 Volt 6 Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, 2 LaVoce 21inch Neo DIY subs and 2 PSA S3600I'S.
Mike Butny is offline
post #31605 of 52991 Old 02-15-2017, 11:14 PM
Quoted: 87 Post(s)
Liked: 64
haha im trying to see if tang will sell me his!!!!
Mike Butny likes this.
post #31606 of 52991 Old 02-16-2017, 06:20 AM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
bass traps do very little for frequencies below 80 or so hz unless you are going to line the entire room over foot thick.
ahblaza and sunPin like this.
post #31607 of 52991 Old 02-16-2017, 07:51 AM
mrmike_'s Avatar
Quoted: 30 Post(s)
Liked: 27
So heads up for anyone also thinking of upgrading from a 12" sealed sub to the V1801... there is a slight difference in size that you may have underestimated when simply looking at the dimensions online.
I suppose this will be a modest upgrade from the SB-2000.
ID:	1972857   Click image for larger version
ID:	1972865   Click image for larger version
ID:	1972889   Click image for larger version
mrmike_ is offline
post #31608 of 52991 Old 02-16-2017, 08:02 AM
rynomyte's Avatar
Quoted: 69 Post(s)
Liked: 94
Really "ties the room together" if ya ask me!
Cannot wait for mine. Next week can't come soon enough!
Mike Butny and k1n3t1k like this.
Spoiler!
rynomyte is offline
post #31609 of 52991 Old 02-16-2017, 08:04 AM
Just a slight change LOL
JosephTonyStark likes this.
Stompbox is offline
post #31610 of 52991 Old 02-16-2017, 08:06 AM
rdb1276's Avatar
Quoted: 76 Post(s)
Liked: 56
Hey guys,
Anyone on here go from 2 subs to 4? Was wondering if there is a huge improvement in bass or is it more for smoothing and making the subs work less? I have 2 PSA 3600I's and was thinking of getting 2 more and putting one in each corner
rdb1276 is offline
post #31611 of 52991 Old 02-16-2017, 08:09 AM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
4 subs can effectively smooth all room modes with no EQ when properly placed. So yes 4 subs are better then 2, just like 2 subs are better then 1. However, Once you get past 4 subs diminishing returns starts setting in fast. I only have 3 subs, but 3 was better then 2 for smoothing out the response.
ahblaza likes this.
post #31612 of 52991 Old 02-16-2017, 08:41 AM
newc33's Avatar
Quoted: 1190 Post(s)
Liked: 1818
I don't know if you guys play videos games much (I rarely do) but I found some crazy low content in the game fallout 4 on ps4. Any time your wearing "power armor" and you jump off something kinda high the results are crazy! There has to be powerful 10hz ish stuff there if I had to guess. The fun part is you can just do it over and over lol
Anyway for all you guys with those new "01" toys you should try it out if you have the game
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s rear surround
Quad PSA T18s!!!!!!
Funk audio 12.2 HP mains powered by/funk audio 6x500 watt amp
newc33 is offline
post #31613 of 52991 Old 02-16-2017, 09:11 AM
sb1
sb1's Avatar
Quoted: 445 Post(s)
Liked: 393
Multiple subs can indeed smooth the frequency response, but a smooth response won't always mean less ringing. I've done exactly that before trying to integrate two dissimilar subs (ported and sealed). Achieved a great looking spl response but terrible looking waterfall.
Stephen.
Chances are very good that I was drinking when I posted the above.
sb1 is offline
post #31614 of 52991 Old 02-16-2017, 09:42 AM
Quoted: 87 Post(s)
Liked: 64
hell yeah just ordered my 4th s3000i this morning to further balance out my room. 3 was such a odd number anyway
post #31615 of 52991 Old 02-16-2017, 09:43 AM
Quoted: 87 Post(s)
Liked: 64
cause war.war never changes
post #31616 of 52991 Old 02-16-2017, 10:04 AM
rdb1276's Avatar
Quoted: 76 Post(s)
Liked: 56
I will be using 4 of the same subs PSA S3600I's Is corner locations for the subs best when you are using 4 subs?
rdb1276 is offline
post #31617 of 52991 Old 02-16-2017, 10:27 AM
Pulloutchamp's Avatar
Quoted: 381 Post(s)
Liked: 559
I know its probably better to have all 4 of the same subs correct? Im thinking of running a pair of V1500's with a pair of SVS PC-12+ if I end up with enough room .... I may be able to sell the PC's and get another pair of V15's..
Pulloutchamp is offline
post #31618 of 52991 Old 02-16-2017, 10:30 AM
Quoted: 381 Post(s)
Liked: 559
lol....I used to do that all the time!!! Havent played that game lately and havent tried with my latest subs , might be time to pop that back in....... Battlefield1 has some pretty good sound effects , the cannons are pretty impressive...
newc33 likes this.
post #31619 of 52991 Old 02-16-2017, 12:55 PM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
Post
Well obviously you need to start with quality subs that are the same alignment...Thought that was a given.
ahblaza and newc33 like this.
post #31620 of 52991 Old 02-16-2017, 02:15 PM
chainwallet's Avatar
Quoted: 38 Post(s)
Liked: 69
I definitely suggest checking out Titanfall 2. I'm almost scared to fire it up with the S1801.
newc33 and Pulloutchamp like this.
Samsung UN55JS8500
Sony UBP-X800
Denon X3300
Energy RC-50, Energy RC-LCR, Mirage OMD-5
PSA S1801
chainwallet is offline
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s7201 , tv36 , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
