Official Power Sound Audio Subwoofer Thread - Page 1418 - AVS Forum | Home Theater Discussions And Reviews
 71439Likes
post #42511 of 54580 Old 05-18-2018, 05:37 AM
healthnut's Avatar
Quoted: 985 Post(s)
Liked: 988
Originally Posted by ironcobra View Post
Expecting a 15v today with a boom stand and a miniDSP UMIK-1. Going head first into my first serious subwoofer. Its replacing a elemental a2-300. Hoping its a nice upgrade and i'm sure it will be. Cant wait to crawl around on the floor all night and learn REW. Could anyone point me in the right direction for a intro into REW.
AustinJerry’s guide, linked in his signature and on the MiniDSP site is the definitive guide. I found it best to print it out and put it on a binder for ease of use. Best of luck!
ironcobra likes this.
healthnut is offline
post #42512 of 54580 Old 05-18-2018, 07:21 AM
lizrussspike's Avatar
Quoted: 1389 Post(s)
Liked: 2080
Look at Alan P post and in his signature is a few links to keep you busy all weekend! Good Luck.
lizrussspike is offline
post #42513 of 54580 Old 05-18-2018, 08:50 AM
butie120's Avatar
Quoted: 1124 Post(s)
Liked: 368
Originally Posted by mdameron View Post
There aren't a lot of 15V owners here. Glad to see another one!
So, I am curious how you know you added 8db on the sub amp. My 15Vs are just dots. Did you just count dots, or something? It would be news to me if you are able to convert the dots to db. Based on my experience with two separate 15V setups in my house, I recommend you try this:
1) Use only 1 RCA input on the sub (do not use a Y connector to use both inputs). Gain knob between noon and 1pm. Delay set to minimum. Crossover set to maximum. Room size set to maximum.
2) Run audyssey. Hopefully it sets the sub trim between -11.5 and -6. Honestly, no big deal if it comes back -12 (or whatever max negative is in your AVR). Set speaker crossovers no higher than 80. I also prefer to lower the LPF for LFE down a bit.
3) Turn on DEQ. Turn off DVOL (actually I like DVOL for tv watching).
4) Test it. Add heat to the sub trim to your liking. You may only have to come up a couple db if audyssey brought back max negative. I go 6-8db hot with DEQ on, depending on content, typically watching at -20mv at most. The sub just pounds. Can't imagine watching any louder than that in my ~1980 cubic foot sealed movie space. I played MMFR through it for the first time the other day and it was awesome.
Also, with DEQ on, make sure your reference level offset is 0. That is the default, so it probably is.
I used an SPL meter and REW to determine the Db increase using the gain on the sub. I just placed the mic at the MLP and turned up the gain until it increased by 8db. I'm trying some various settings to get a better experience with seating distance at the moment. I don't use DEQ because this boosts the subs too much and increases surround activity that I find distracting. And, it's best to stay below -12db on Audyssey because then you don't know what it's setting the sub at, so I shoot for around -10db.
I need to use a Y connector when running two subs because I don't have two sub preouts. A "Y" adapter worked great when I was able to audition two subs.
Speakers: Fronts- JBL 230, Center- JBL 235C, Surrounds: Fluance XLBP
Sub: PSA 15V
Processing: Onkyo 676
Video: BenQ 1080ST
butie120 is offline
post #42514 of 54580 Old 05-18-2018, 08:52 AM
butie120's Avatar
Liked: 368
REW has been a great tool and I was intimidated initially with it, but after I got all the initial setup stuff out of the way, I find it pretty user friendly. And, you can always hop on here if you have any questions.
I have the 15V and really like it. Will be curious to hear your impressions.
Sub: PSA 15V
Video: BenQ 1080ST
butie120 is offline
post #42515 of 54580 Old 05-18-2018, 09:31 AM
jgourlie's Avatar
Quoted: 61 Post(s)
Liked: 37
I just ordered a y adapter for my 15v and I am curious why you are saying not to use it?
jgourlie is offline
post #42516 of 54580 Old 05-18-2018, 09:36 AM
ironcobra's Avatar
Quoted: 26 Post(s)
Thanks guy's that's more than enough to fill a couple weekends. I will was initially intimidated by auddessy as well but the gains were tremendous. Will REW also help with mains and surrounds after auddessy or is it more focused on subs?
ironcobra is offline
post #42517 of 54580 Old 05-18-2018, 09:38 AM
jgourlie's Avatar
Quoted: 61 Post(s)
Liked: 37
All of you 15v owners that seem to have popped up, especially those with REW my room is 3200ft3 and open to the rest of my basement on concrete slab. I am totally considering just going near field behind my couch as I am not quite sure that a 15v is going to be able to pressurize that room at all, and if I put it at the front of the room it would be 17ft away from my couch, if I put it at the back of the room in the corner opposite the entrance it would only be 6ft away.
What do you 15v owners think I should do?
jgourlie is offline
post #42518 of 54580 Old 05-18-2018, 09:38 AM
imureh's Avatar
Quoted: 3226 Post(s)
Liked: 4254
It will help with both. It will allow you to see your FR with and without mains as well as play with the crossover to make improvements.
ahblaza likes this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #42519 of 54580 Old 05-18-2018, 09:40 AM
imureh's Avatar
Liked: 4254
I am not a 15V owner but I agree that is a large space for one 15 inch sub to fill in. You would be better off having it near field if you are not able to add another.
post #42520 of 54580 Old 05-18-2018, 09:43 AM
butie120's Avatar
Liked: 368
3,200 cubic feet is a good sized room, so near field might be your best bet for more tactile response. The 15V won't be able to pressurize that space very well. 17 Feet away is quite a distance away as well. You can try the sub in the back of the room which would be closer, but you might run into localization issues depending on how the sub interacts with your room and how sensitive you are to directional sound. I recently tried putting my sub in the back middle of the room and it tends to feel like the bass is coming from behind me and it's about 8 feet away. Testing is free!
Sub: PSA 15V
Video: BenQ 1080ST
butie120 is offline
post #42521 of 54580 Old 05-18-2018, 09:44 AM
David Charles's Avatar
Quoted: 1109 Post(s)
Liked: 1888
I think you’ll be disappointed with that speaker in that large of a room. The only alternative is if you really put it close to you and then you might run into localization issues. Best bet is to add one for now and put it near you and then add one in the future and put it on the front soundstage
David Charles is offline
post #42522 of 54580 Old 05-18-2018, 10:41 AM
Liked: 2080
jgourlie, That is a large room. Go near field until you can get a second one. That is what I did when I started with my XV15SE, as my room is 2600ft 3.
post #42523 of 54580 Old 05-18-2018, 10:41 AM
jgourlie's Avatar
Quoted: 61 Post(s)
Liked: 37
Thanks for all the quick responses. I am not a super loud listener for a lot of reasons including WAF and I mentioned that to Tom when I made the purchase and he said I would be happy with the 15v. My room isn't built yet, but I have hooked the 15v up in my unfinished basement to just test it out and it sounds great and can pound in my wide open basement.
I guess I just want to get the most out of it with my situation (dual subs isn't going to happen for many years, probably never), I only ever listen upto -10mv max as I put a limiter on my denon in case my kids get a hold of the remote.
So it seems that nearfield is going to give me localization issues?
In the owner's manual it says to put the sub in the corner opposite the room opening, which in my room would be behind the couch about 6ft away. So this could also cause localization?
I am going to do basstraps in at least 2 of the 3 corners of my room as the 4th corner is open/no door so I will only have 3 corners. If I put the sub in 1 corner then I would only put basstraps in 2 corners.
The more I type the more I realize I am going to have to get REW and a Umik, which kind of sucks cause I live in Canada and it adds so much extra cost for everything for something I will use once and then put in a closet.
jgourlie is offline
post #42524 of 54580 Old 05-18-2018, 10:44 AM
butie120's Avatar
Liked: 368
You might not have localization issues. Only one way to find out...
Sub: PSA 15V
Video: BenQ 1080ST
butie120 is offline
post #42525 of 54580 Old 05-18-2018, 10:47 AM
jgourlie's Avatar
Quoted: 61 Post(s)
Liked: 37
Does REW work good with MAC and apple?
I haven't really looked into it at all as I was just going to go without it put up some sound treatments and bass traps and hope for the best.
Dang it, the theatre budget just went up!!
jgourlie is offline
post #42526 of 54580 Old 05-18-2018, 10:55 AM
imureh's Avatar
Liked: 4254
Yes it does. You need to look into the link for Mac set up in the REW guide
post #42527 of 54580 Old 05-18-2018, 11:08 AM
mdameron's Avatar
Quoted: 107 Post(s)
Liked: 112
I preferred the sound and performance with 1 input & mid-range gain setting than 2 inputs and a low gain setting.
You should certainly try both and report back.
Denon, Polk, Parasound, PSA
mdameron is offline
post #42528 of 54580 Old 05-18-2018, 11:10 AM
jgourlie's Avatar
Quoted: 61 Post(s)
Liked: 37
ok I see what you are saying. Makes sense.
It does seem intuitive to get into the higher gain settings of the subwoofer amplifier power in order to get the most out of the sub after audyssey.
jgourlie is offline
post #42529 of 54580 Old 05-18-2018, 12:06 PM
indebtbassfreak's Avatar
Quoted: 1529 Post(s)
Liked: 2944
What can help reduce localisation is an 80Hz crossover. Above that can be more challenging.
ahblaza likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #42530 of 54580 Old 05-18-2018, 12:07 PM
Quoted: 1012 Post(s)
Liked: 1263
Originally Posted by Marc Alexander View Post
Thanks Mark! Can DIYers request either? @Pradeep2 ?
Mine are all OEM: 4kw and two 700W icepowers from PSA, two 2400w from Reaction Audio with PSA dsp tuning
Maybe @MKtheater can assist I think he bought a 4kw direct from Brian.
Pradeep2 is offline
post #42531 of 54580 Old 05-18-2018, 12:09 PM
jgourlie's Avatar
Quoted: 61 Post(s)
Liked: 37
Is that 80hz on the lpf lfe? rather than the standard 120hz?
jgourlie is offline
post #42532 of 54580 Old 05-18-2018, 12:13 PM
imureh's Avatar
Liked: 4254
No, it’s the speaker crossover
post #42533 of 54580 Old 05-18-2018, 12:22 PM
Liked: 2944
Correct. That been said it depends on the capability of one's mains (if) 80Hz will work best but above 80Hz seems to be where localisation can be more easily heard.
jgourlie likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #42534 of 54580 Old 05-18-2018, 12:22 PM
jgourlie's Avatar
Quoted: 61 Post(s)
Liked: 37
My towers will probably end up at 40hz but I would move it to 80hz in my denon as standard practice probably anyways.
@indebtbassfreak ok that will be something I will look into
jgourlie is offline
post #42535 of 54580 Old 05-18-2018, 12:24 PM
Liked: 2944
No, i was refuring to 80Hz on the LFE channel.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #42536 of 54580 Old 05-18-2018, 12:26 PM
Liked: 2944
80Hz on your towers will send more of the bass work to your sub, and 80Hz on your LFE channel is a good start
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #42537 of 54580 Old 05-18-2018, 12:28 PM
Marc Alexander's Avatar
Quoted: 6069 Post(s)
Liked: 5647
Oh… I thought you were using amps direct from Speakerpower for the UltraMax 18s. Did I just inagine or were you considering it?
Marc Alexander is online now
post #42538 of 54580 Old 05-18-2018, 12:29 PM
jgourlie's Avatar
Quoted: 61 Post(s)
Liked: 37
This could be the solution that I am looking for. Nearfield and minimal localization by lowering the lfe lpf to 80hz.
Thanks for the help
jgourlie is offline
post #42539 of 54580 Old 05-18-2018, 12:35 PM
Liked: 2944
Thanks for the help
I think you will be happy with towers set at 80Hz and LFE 80Hz. (If) there is no localization you can experiment with 90/100Hz. Good luck!
Marc Alexander and ahblaza like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #42540 of 54580 Old 05-18-2018, 12:36 PM
Liked: 5647
80Hz is a good start but for me 60Hz has been best to eliminate localization when the mains are capable. This is for the speaker crossovers. The LFE LPF is a different topic altogether. It is best to leave that at 120Hz to start.
Pradeep2 likes this.
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , ipal , neo , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s1512 , s3000i , S3600i , s7201 , tv36 , tv42 , v1500 , v1512 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
