Official Power Sound Audio Subwoofer Thread - Page 1419 - AVS Forum | Home Theater Discussions And Reviews
 71324Likes
post #42541 of 54532 Old 05-18-2018, 12:37 PM
imureh's Avatar
Quoted: 3225 Post(s)
Liked: 4248
Originally Posted by indebtbassfreak View Post
No, i was refuring to 80Hz on the LFE channel.
Hmmm. Not sure how that will help but doesn’t hurt to try.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #42542 of 54532 Old 05-18-2018, 12:39 PM
Marc Alexander's Avatar
Quoted: 6061 Post(s)
Liked: 5639
I think you will be happy with towers set at 80Hz and LFE 80Hz. (If) there is no localization you can experiment with 90/100Hz. Good luck!
If you experiment with LFE LPF I suggest matching the speaker X-over. 80/80, 90/90, etc. Don't go below 80Hz for LFE LPF.
indebtbassfreak likes this.
Marc Alexander is offline
post #42543 of 54532 Old 05-18-2018, 12:39 PM
indebtbassfreak's Avatar
Quoted: 1527 Post(s)
Liked: 2937
Originally Posted by Marc Alexander View Post
80Hz is a good start but for me 60Hz has been best to eliminate localization when the mains are capable. This is for the speaker crossovers. The LFE LPF is a different topic altogether. It is best to leave that at 120Hz to start.
With near field behind the MLP Marc wont 120Hz be more localized than 80 Hz?
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #42544 of 54532 Old 05-18-2018, 12:41 PM
Liked: 2937
I believe by reducing the higher bass frequencies which are more directional. I think even at 120/140Hz some dialog can come through the sub.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #42545 of 54532 Old 05-18-2018, 01:05 PM
Liked: 5639
Probably, but it will differ room to room and ears to ears. Setting the LFE LPF too low can reduce the mid-bass punch. That is why I recommend leaving it at 120Hz to start. I think it is best to get the sub/speaker blend right before messing with LFE LPF. 60/120 is what I am running downstairs (the mains go down to ~20Hz).
BTW, If one thinks they are just going to measure for day and never need the UMIK-1 again. They are easy to flip quickly on the classifieds. You'll get ~75% of your money back. However, once you enter the rabbit hole you likely won't turn back.
post #42546 of 54532 Old 05-18-2018, 01:25 PM
butie120's Avatar
Quoted: 1124 Post(s)
Liked: 368
So can someone help explain this to me. I'm trying to reduce localization when placing the sub behind me. I might try lowering the crossover to 60hz, but I've also been reading more about reducing the LFE channel to 80hz. Do these differ in the way they reduce localization?
Speakers: Fronts- JBL 230, Center- JBL 235C, Surrounds: Fluance XLBP
Sub: PSA 15V
Processing: Onkyo 676
Video: BenQ 1080ST
butie120 is offline
post #42547 of 54532 Old 05-18-2018, 02:01 PM
Kini62's Avatar
Quoted: 2811 Post(s)
Liked: 2696
I run one sub in the front right corner and one in the rear left corner. I sit around 11' from the front sub and around 4' from the rear sub. I use 120hz crossover when I listen loud and I have no localization issues. Adding another sub will likely cure any localization issues.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #42548 of 54532 Old 05-18-2018, 02:11 PM
Quoted: 1012 Post(s)
Liked: 1263
Oh… I thought you were using amps direct from Speakerpower for the UltraMax 18s. Did I just inagine or were you considering it?
Thats still the plan, a 4kw or 6kw SP plate amp with the um18 tune preloaded but got delayed by an upgrade to diysoundgroup Titan 615lxs for left and right in the meantime.
ahblaza likes this.
Pradeep2 is offline
post #42549 of 54532 Old 05-18-2018, 02:21 PM
butie120's Avatar
Liked: 368
Well I know another sub would help prevent localization. I was speaking more to the idea of the LFE channel reducing localization.
Sub: PSA 15V
Video: BenQ 1080ST
butie120 is offline
post #42550 of 54532 Old 05-18-2018, 02:36 PM
Liked: 2937
My understanding as far as the frequency's been delivered by the sub(s) is 80Hz LPF setting often is refurred as the (safe zone) where many on AVS have suggested for those who may have been experiencing localisation issues with their specific sub placement. As Marc mentioned you will loose some punch in the upper bass with capable subs so a bit of a trade off. Of coarse multiple subs would be a better option.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #42551 of 54532 Old 05-18-2018, 03:10 PM
ereed's Avatar
Quoted: 2404 Post(s)
Liked: 1685
80Hz on your towers will send more of the bass work to your sub, and 80Hz on your LFE channel is a good start
Originally Posted by jgourlie View Post
This could be the solution that I am looking for. Nearfield and minimal localization by lowering the lfe lpf to 80hz.
Thanks for the help
I wouldn't go lower than 120hz on the LFE because the LFE takes place 120hz and below. If you set the LFE at 80hz, then you are just limiting LFE content and missing 80-120hz portion. LFE content is the .1 of the system....LFE part only, not the low bass routed from speakers to subs for normal material.
But the sub xover (not LFE part) which you can play between 60 to 120hz but usually 80hz is where its good starting point. But for LFE only, I believe it should be set at 120hz default. Correct me if I'm wrong...but if you set the LFE to 80hz then you are just missing the rest of the .1 content? That has been what manufactures have said in the past.
Also I believe many people get confused between LFE xover and sub/speaker xover sometimes.....I know I did!
MKtheater and hawkeyejw like this.
Theater room: Sony 45es | 120" screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M | Funk Audio subs | MiniDSP 2x4HD | Crowson Tech MAs | Surgex XR 315 | GIK room treatment
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8 |
ereed is offline
post #42552 of 54532 Old 05-18-2018, 03:16 PM
Quoted: 12 Post(s)
Liked: 25
Yes, this is my understanding too. The .1 is a different channel with its own content. The speaker crossover routes signal below the crossover to your subs, which is in addition to the signal from the .1.
hawkeyejw is offline
post #42553 of 54532 Old 05-18-2018, 03:21 PM
SBuger's Avatar
Quoted: 1498 Post(s)
Liked: 5015
I messed with my LPF of LFE quite a bit a while back and settled on 90hz, just like my crossovers to speakers. Set your crossovers where you like, leave LPF of LFE at default of 120hz, then play a variety of your favorite movie bass demos. Change LPF of LFE to one notch lower, 110hz, and replay the clips. Repeat lowering the LFE of LFE each time. This will let you know what you like best and is easy to do. There may not be a best for ALL but should be one that you like for probably 95% of the clips. Then just set it to this and leave it. It can make a real nice difference. I'm sure setup, room, equipment, and of course personal preference will play a big roll in what you like best. Experimentation is key IMHO, and can lead to some wonderful discoveries ...don't be afraid
You can do the same for your crossovers as well, just be aware of what it might be doing to your FR at the crossover points, which can be confirmed easy enough in REW or OMNI and adjustments can be made if necessary.
My 'Blacked Out' Home Theater | Tactile Response for BASS | BassEQ for Filtered Movies
1400cuft Sealed Room | SY Triple Black Velvet Blackout | GIK Treatments | Denon AVR-X6300H - 7.7.4 Atmos | KEF Q Series Speakers | Epson 5040UB | Eyes 6.5' to 120" 16:9 AT Seymour Screen | Oppo 203 | XB1X | ATV4K | 6x 18" Sealed Subs w/3x VNF | HoverBOSS w/6x JBL-12s | Sealed BossBack w/ 1x JBL-12 | 6x Crowson MAs | 4x BK LFEs | MiniDSP 10x10HD
SBuger is offline
post #42554 of 54532 Old 05-18-2018, 03:25 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5767 Post(s)
Liked: 11595
Hi,
I do think it's possible that reducing the LPF of LFE to 80Hz would reduce localization, and I wouldn't be afraid to try it. It was Mark Seaton and Roger Dressler (formerly with Dolby Labs, and one of the creators of Dolby Pro Logic and PLII) who I first heard suggest reducing the LPF to 80Hz. Their analysis indicated that very little content above 80Hz is meaningful. Apparently, a lot of it is just random noise.
And, that is consistent with the original intent of the Low-Frequency Effects channel. It was originally conceived as a way to emphasize low-bass effects more than mid-bass effects. And, it was given an extra 10db to facilitate that. Since that original analysis from Mark and Roger, others such as Marc Fishman, who posts on the forum as FilmMixer, have confirmed the lack of meaningful content above 80Hz in their movies. And, the LPF is just a filter, so it gradually rolls-off content above 80Hz. It doesn't eliminate it.
I have experimented quite a bit with settings ranging from 80Hz up to 120Hz. In my room and with my system, the differences are fairly subtle, but they are distinguishable. 120Hz gives me more bass, but it sounds a little muddier with higher volumes and bass boosts. An 80Hz setting is perceptibly clearer sounding to me. YMMV! But, if I were experiencing localization from a nearfield sub, I would definitely try the lower LPF setting.
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #42555 of 54532 Old 05-18-2018, 04:01 PM
Liked: 2937
I'm unaware of a X-over setting for my subs other than LPF in the LFE unless your refurring to the manual mode in the AVR settings which for my sub's options are 25/40/63/100/160Hz?
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #42556 of 54532 Old 05-18-2018, 05:31 PM
ironcobra's Avatar
Quoted: 26 Post(s)
Just received my 15v and wanted to double check some settings before I begin my sub crawl and auddessy. Should I turn auddessy off before the crawl as it's calibrated from the old sub. And my back plate settings are
crossover 80
Roomsize large?
Gain 10:00 I understand adjusting this
But what do I do with delay?
ironcobra is offline
post #42557 of 54532 Old 05-18-2018, 05:41 PM
cannga's Avatar
Quoted: 1909 Post(s)
Liked: 1864
Hello @indebtbassfreak , long time no see. AFAIK/IMHO
LFE is essentially 0-120: you do not set this frequency, and you don't want to as it is creator's intent, part of the "rule" of the Dolby and DTS codec, etc. It includes low, mid, and part of upper bass. You run the subwoofer full range (turn its crossover off) and let the processor sends the (already limited) 0-120 signal to it.
Crossover Setting is a different issue altogether. There are two crossover settings: one on your subwoofer, and multiple on your receiver (which for example has 11 of them for each of the 7+4=11 speakers in a 7.1.4 system). The crossover setting is used for example when a typically small surround speaker can't cover the bass range, since it has tiny bass drivers. The receiver's crossover setting sends 20-80 Hz to subwoof and 80-20k to the small speaker. In my system, I again turn off the crossover on the subwoofer, and let the receiver sets/determines the limited 20-80 signal to go to subwoofer.
LFE you leave at 120 (don't touch). Crossover you could use 60, 80, 120, etc. depending on the surround speaker's low bass capability. 80 Hz and below is desirable since above 80 some people start to be able to localize the sound. ie Left surround bass now appears to come from the subwoofer behind you. For this reason, it's a good idea to get a "competent" surround speaker. For example you would like the mid/bass driver of the surround speaker to be 5-6 inches, as opposed to 4 inches. Just trying to help and hope I haven't repeated material you know well.
Regards, Can
My System & Theta Casablanca Mini-Review Uncontrolled passion for music, and sound.
Casablanca IVa Dirac Set Up Help HERE And some interesting audio diagrams.
JTR Subwoofer Thread I don't always listen to subwoofers, but when I do, it's JTR :-).
cannga is offline
post #42558 of 54532 Old 05-18-2018, 06:06 PM
imureh's Avatar
Liked: 4248
crossover 80
Roomsize large?
What size was your room again? You would want to find the ideal position for the sub before EQ so yes Audyssey off.
imureh is offline
post #42559 of 54532 Old 05-18-2018, 06:14 PM
Liked: 2937
Hey cannga good to hear from you. My AVR does not have a second X-over setting for my sub. In the Configuration menu where i can set each individual speakers X-over,,,,, when i get to the sub the (only) option is the low pass on the LFE. The only other adjustment in my AVR that i have ever seen is in the equalizer setting menu. I have audyssey setting,,, and manual,,, thats it. In the manual setting i can manipulate the five option frequency's 25/40/63/100/160Hz. Other than that i see no other adjustment in my older AVR. If there is one then i've been in a long coma.
As for my subs,,, they have a DSP that is way beyond my pay grade and maybe this adjustment can be done there but most subs have the same low pass on the back with the option that most use by turning it all the way to (LFE) setting letting the AVR to do the work.
Is it possible my AVR just doesn't have the extra X-over setting been discussed?
In the case of jgourlie who's only option at this time is one sub behind his MLP away from his front sound stage ,,,,reducing the upper bass either by LPF at 80Hz or this other X-over sub setting seems to be a good start. At the end of the day (sub placement is #1 )
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #42560 of 54532 Old 05-18-2018, 06:22 PM
ahblaza's Avatar
Quoted: 2523 Post(s)
Liked: 3746
crossover 80
Roomsize large?
Yes turn Audy off,
Crossover, turn all the way to 150Hz highest setting.
Gain 10-11:00
Room Size large is fine.
Delay leave at lowest setting 0ms
Will you be using a SPL meter?
ahblaza is offline
post #42561 of 54532 Old 05-18-2018, 06:34 PM
Quoted: 1006 Post(s)
Liked: 1146
I coulda sworn we had this LPF LFE talk about 2 to 3 weeks ago. It was very helpful. Like most are saying, experimenting is free!
CallingMrBenzo and subacabra like this.
GeoJustGeo is offline
post #42562 of 54532 Old 05-18-2018, 06:37 PM
ironcobra's Avatar
Quoted: 26 Post(s)
crossover 80
Roomsize large?
Yes turn Audy off,
Gain 10-11:00
Yes I just got a umik 1 and plan on REW calibration this weekend. I used your settings and believe I found the 2nd best spot I can use, the first failed the girlfriend test but they were very close.
ahblaza likes this.
post #42563 of 54532 Old 05-18-2018, 06:38 PM
Liked: 5639
Originally Posted by mthomas47 View Post
It was Mark Seaton and Roger Dressler (formerly with Dolby Labs and the creator of Dolby Pro Logic and PLII) who I first heard suggest reducing the LPF to 80Hz. Their analysis indicated that very little content above 80Hz is meaningful. Apparently, a lot of it is just random noise.
@Mark Seaton and @Roger Dressler are both amazing and humble. But I don't think Roger wants credit as the creator of DPL and DPLII (Jim Fosgate). Roger should eventually jump in and clarify his involvement in the creation of Dolby codecs (like DD+ and True HD).
post #42564 of 54532 Old 05-18-2018, 06:53 PM
ahblaza's Avatar
Liked: 3746
You need to verify both the second and first best locations with REW, hopefully they will be close enough that either spot will work well in your space and you can keep the GF happy, if not, threaten to buy another sub and I bet the first best spot will pass the GF test............. enjoy...........
ironcobra likes this.
ahblaza is offline
post #42565 of 54532 Old 05-18-2018, 07:23 PM
basshead81's Avatar
Quoted: 353 Post(s)
Liked: 10245
Good lord, I just read the last few pages of the JTR thread...what a train wreck! Now I know why I see some members posting here that use to frequent that thread. At least there is a good group of guys here in this thread.
basshead81 is offline
post #42566 of 54532 Old 05-18-2018, 07:28 PM
ereed's Avatar
Liked: 1685
This is exactly what I'm saying. I think people are confusing LFE .1 content with the speaker/sub xover rolloff. Or maybe they are not confused and set it lower such as 80hz for LFE, but if you do that then what will play 80-120hz? Definitely not the other speakers since its .1 LFE only which goes to subs and nothing else. So that is content they are missing IMO.
My prepro doesn't have LFE setting and its set 120hz from factory which is a good thing....but I do have sub/speaker xover settings separately.
ereed is offline
post #42567 of 54532 Old 05-18-2018, 07:48 PM
Hopinater's Avatar
Quoted: 3667 Post(s)
Liked: 11966
Originally Posted by basshead81 View Post
sounds about right...going from 11-12 on my sub amps increased levels +3db
I got about +4dB going from 10 to 11 on mine so that's about right in line.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
post #42568 of 54532 Old 05-18-2018, 07:51 PM
imureh's Avatar
Liked: 4248
Sorry guys. That was part my doing. I just could not understand the whole numbers between the subs being compared. That has been an issue as you all know for some time.
imureh is offline
post #42569 of 54532 Old 05-18-2018, 07:55 PM
Mark Seaton's Avatar
Quoted: 930 Post(s)
Liked: 2600
Hi,
Mike
Quick clarification on my own recommendation on this. It is less about if content above 80Hz is meaningful, rather that most of us will have the subwoofer overall set higher than the main speakers. When we set the sub higher its effect with the main speakers is limited to taper off with the low pass setting of your main speakers. As such frequencies at and above the crossover frequency taper into the response of the main speakers as frequency rises. Since the LFE channel and bass from the mains are all part of the "sub" output, such a setting boosts the entire LFE channel frequency range up to the LFE low pass frequency; 120Hz typically by default. The more you boost the level of the subwoofer channel rather than just tilting up the lowest frequencies, the more you raise the content above ~80Hz. Since a large majority of you cross your speakers at 80Hz or lower, this can make the LFE channel a bit strong in the top end of it's range. The low pass is a slope, not a cliff, and lowering the frequency simply tilts down the highest frequencies more vs the 120Hz setting.
Think of this as the opposite of tilting up the low frequencies of your subwoofer by using PSA's room size control or my LF Adjust. This tilts down the upper range if you have it set a bit hot. Since this is only on the LFE channel, you won't hear it on music, and possibly less so on some scenes you demo. In short, the more you raise the subwoofer level from a calibrated flat energy, the more I would suggest lowering the LFE low pass might sound preferable. Despite how many portray such adjustments as wrong or deviation from accurate, we're simply saying this is an entirely justifiable and warranted adjustment you can use to get the best result in your room, just as we often tell you not to be afraid to raise the subwoofer to get the balance you prefer.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #42570 of 54532 Old 05-18-2018, 08:01 PM
butie120's Avatar
Liked: 368
Thanks for the clarification. Would you believe that lowering the LFE to 80hz would help with localization problems as well when running a sub near field?
Sub: PSA 15V
Video: BenQ 1080ST
butie120 is offline
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , ipal , neo , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s1512 , s3000i , S3600i , s7201 , tv36 , tv42 , v1500 , v1512 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
