Official Power Sound Audio Subwoofer Thread - Page 1493 - AVS Forum | Home Theater Discussions And Reviews
 65646Likes
post #44761 of 52666 Old 09-22-2018, 01:47 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5540 Post(s)
Liked: 10682
Originally Posted by Hopinater View Post
Good points. But I think its important to keep mind that these big subs are already a very niche market with very few potential customers. They're expensive and in most cases very overwhelming to the decor of a room. They work great in a man cave but not so much in most living rooms. And the lower they get tuned the more expensive they get which only narrows the market potential even further. If you look at the Cap 2400 sure its tuned lower and is more powerful but once you add in shipping its also a lot more expensive than the V3611. That financial hit gets even more painful if you go duals which most of us believe is a good idea.
Having said all that I think the philosophy of the particular companies dictate where they make their compromises. A great example of this is Funk. They do custom work and make awesome subs but the price is far beyond what most can afford.
Hi Hop,
I agree with a lot of what you are saying, and especially with that last part. I thought that I wrote my post pretty carefully, but apparently it is subject to multiple interpretations. David correctly read my post to be suggesting some of the reasons why it may not be as simple to lower the port tune on the V3611 as he had thought. I think that he missed the philosophical reasons why it might not happen, though, and I believe that he minimized the practical ones. I think that they are very real.
Your post is actually lending further weight to what I was saying. If the guys at PSA really wanted to do it, I'm sure that they could, but it would take a lot of effort and perhaps a different driver. And, the additional time spent in R&D, and perhaps on different drivers, would have to be recouped in the price of the subwoofers. But, I think that it would be somewhat alien to the philosophy that they originally started with, and that in itself is an important factor, as you noted at the end of your post.
Personally, I would like to see it, just because. And, I think that if PSA can build and sell something as large and expensive as the S7201, then they could design, build, and sell a perhaps larger, but certainly slightly more expensive, version of their flagship ported subwoofer, with a slightly lower port tune and some additional extension. But, I think it's really all just Monday morning quarterbacking. If there actually were a PSA market for this, because PSA owners genuinely wanted it, I'm sure that Tom and Jim would eventually find a way to make it happen.
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #44762 of 52666 Old 09-22-2018, 03:55 PM
Tom Vodhanel's Avatar
Quoted: 3049 Post(s)
Liked: 10457
Originally Posted by David Charles View Post
Another question I had, purely Hypothetical, but if you let say, stuffed a piece of foam/towel in part of the slot port, And thus reduce its volume, would the tuning frequency change? I’m thinking something along the lines of rhythmik subwoofer or equivalent. I want to know from a science standpoint if this does anything. Yes I know the amplifier is not designed to do this and I’m not going to try it but I would like to know out of principle
The tuning point of a subwoofer cabinet is a simple function of the (effective) cabinet volume versus the air resistance of the vent. Keep the vent size the same but increase the cabinet volume lowers the tuning. Or, increasing the resistance(by say blocking off half a port) also lowers the tune.
There's a number of easy to use "calculators" you can play around with to see this in action.
http://www.mobileinformationlabs.com...0lenth%201.htm
Tom V.
Power Sound Audio
SuperFist, ahblaza and Pradeep2 like this.
The woods are lovely, dark and deep, But I have promises to keep,
Tom Vodhanel is offline
post #44763 of 52666 Old 09-22-2018, 04:06 PM
Liked: 10457
Originally Posted by Ultra_Sound View Post
How far away (or recommended) should a PSA 15V sub be placed away from the back wall corner for maximum performance with minimum to no distortion? Does anyone know?
Optimal placement in room will vary from room to room and also be dependent on the seating placement as well. When I start with corner loading I shove the sub as far "into" the corner as posible without it touching any walls. The only caveat to that is port flow. With widely flared circular porting my rule of thumb is half port diameter for the minimum spacing. So if the 15V has its' port facing directly at a wall, keep 2 to 2.5 inches from port-to-wall and you'll be fine.
Tom V.
Power Sound Audio
SuperFist, ahblaza and Ultra_Sound like this.
post #44764 of 52666 Old 09-22-2018, 04:26 PM
Liked: 10457
the v3601 Are definitely animalistic above 20 cycles But I’d be willing to give up three or 4 dB of mid bass, which is rarely maxed out, for a 14–16hz tuning.
One very important consideration is the loss of mid and upper operating bandwidth efficiency. We shouldn't casually dismiss a 2-3dB drop as inaudible since the system may rarely be "maxxed" out in that bandwidth anyway. That would be a mistake.
My end game to all of this would be a V2 on the S7201. Put a large block off plate on the cabinet. Leave the plate on, it's just another quad 18 inch array with both push-pull and mass cancelling engineering...yawn. Remove the plate and secure the patented atmospheric laminizer duct chamber and you have a S7201 tuned to 7hz. Flip one toggle switch on the amp and home damage is back on the menu. If we got our *hit together we could just put in a relay on block off plate. When that is removed and the duct installed the amp auto senses it and goes to ported mode on its own.
But it still won't have a phone amp...
Tom V.
Power Sound Audio
post #44765 of 52666 Old 09-22-2018, 05:08 PM
ahblaza's Avatar
Quoted: 2474 Post(s)
Liked: 3476
Every minute I stay in this room, I get weaker, and every minute Charlie spends in the bush, he gets stronger. Every time I look around the walls move in a little tighter.
Story of my life.....................
ahblaza is offline
post #44766 of 52666 Old 09-22-2018, 05:27 PM
Hopinater's Avatar
Quoted: 3562 Post(s)
Liked: 11203
The reality of it all is I should probably just trade my 1801 in for a second 3 601 and just add Crowsons. That would be the economical way to go and probably actually sound better
I highly recommend this plan. The dual V3601/Crowson combo is by far the best thing going IMO. Atmos runs 2nd.
healthnut likes this.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is online now
post #44767 of 52666 Old 09-22-2018, 05:47 PM
Hopinater's Avatar
Liked: 11203
Originally Posted by mthomas47 View Post
Hi Hop,
Mike
In truth I would like to see it as well but I think it might end up being past my price range. I know that Tom and Jim can design and produce whatever they decide they want so a low tuned ported sub may be in the cards someday. And I know it would sell but how many would sell is the question. Like I said, low tuned ported subs seem to be pricey.
On another note, I think the limiting factor for PSA might be the cabinets. That seems to be the bottle neck that slows things down more often than not and every time they add another sub model that's another cabinet design that has to be ordered and waited on which also pushes some other set of cabinets further back in the queue. However, now that PSA has the amp in house and the cabinet finishing in house maybe the cabinet production isn't far behind. That would be awesome. But as you said, we are just guessing and Monday morning quarterbacking. Only Tom and Jim know the real ins and outs.
post #44768 of 52666 Old 09-22-2018, 05:54 PM
FattyMcButterPants's Avatar
Quoted: 1061 Post(s)
Liked: 1334
Originally Posted by basshead81 View Post
Have you actually brought in a lower tuned sub and did a blind test to see if you actually can tell a difference between 14 and 19hz?
My thought exactly. I think it’s easy to get caught up in spec chasing and REW graphs, and often causes us to forget to ask if the difference is even noticeable on real material, and what percentage of the time. Also, is the source material that goes that low even worth watching (i.e. EOT intro...)?
I think PSA has a really smart balancing act going with their current ported offerings. They extend low enough for what, 99% of the source material out there? And the performance within that 99% is stellar. It is a great place to draw the line IMHO, and it lets them source their parts from places capable of offering the performance, reliability, QC, and volume they need. You can tell this was carefully thought out on many fronts, very smart.
Let’s also not forget, they have not completely abandoned chasing that last 1%. The s3611 and s7201 have that covered in spades!
FattyMcButterPants is offline
post #44769 of 52666 Old 09-22-2018, 05:59 PM
Quoted: 333 Post(s)
Liked: 989
Here is something you don't often see on the PSA website. I wonder if Tom is still celebrating that Browns win.
ahblaza likes this.
Electronics: Denon X4400, Vizio M65
Sub: PSA TV36-iPal
Speakers: 3 x Chane A2.4 LCR, Klipsch Quintet Surrounds
chucks0 is offline
post #44770 of 52666 Old 09-22-2018, 06:03 PM
Liked: 10457
chats are on...
Maybe just a browser hiccup?
Tom V.
Power Sound Audio
Mike Butny and ahblaza like this.
post #44771 of 52666 Old 09-22-2018, 06:51 PM
basshead81's Avatar
Quoted: 327 Post(s)
Liked: 9477
Agreed!! I can say from experience that with out REW I would not be able to tell a difference between reference capable at 16hz compared to 13hz in my room...but not every room is the same.
Mike Butny, ahblaza and Hopinater like this.
basshead81 is offline
post #44772 of 52666 Old 09-22-2018, 06:55 PM
David Charles's Avatar
Quoted: 1106 Post(s)
Liked: 1848
Yes but a big, lower tuned ported sub trumps them both in the sub bass SPL. Let’s put our drinks down for a sec and come to reality.... we all appreciate subterranean bass . Midbass is cool and all but....
David Charles is offline
post #44773 of 52666 Old 09-22-2018, 06:56 PM
imureh's Avatar
Quoted: 2949 Post(s)
Liked: 3772
Originally Posted by Tom Vodhanel View Post
chats are on...
Tom V.
Power Sound Audio
Outstanding, I mean leave the chat alone, the man is on the forums responding on a Sat night! Hats off Tom to your service and availability!
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #44774 of 52666 Old 09-22-2018, 07:03 PM
Liked: 10457
It's always fun to discuss what ifs and speculation like this.. I wish we all lived close enough to just sit and shoot the breeze at the local Slaughtered Lamb. Well, minus the full moon of course. We could just put two 21" cutouts on the back side of the S7201 too. Dual IPAL 21s. 4000 watts. With four high mass 18" PRs(where the active 18s are now) tuning the whole thing to whatever...10hz?
We've gotten things running pretty smoothly now in the spray shop and with amplifier production.
We're adding another new employee who starts on Monday I believe.
All domestic orders are 100% caught up now. We're not quite back to "same day shipping" but we're not far off. 2-3 business days right now I'd say. What has been tripping us up a little has been international orders. We just shipped a big order to the UK a couple of weeks ago. Now we have another couple-few pallets heading to Singapore(see picture) this week. And we've just signed on a dealer for China too. You read that right.. Made in USA, sold in china. That's another pretty big order(bigger than Singapore for sure). And I think we have Hong Kong, Macau and Taiwan coming up soon as well.
And its not like things are ever boring in my office
Tom V.
Power Sound Audio
ID:	2458792   Click image for larger version
post #44775 of 52666 Old 09-22-2018, 07:19 PM
ahblaza's Avatar
Liked: 3476
Ray, any news about your receiver, repair again or replacing with newer 4400, I hope the latter my friend......
ahblaza is offline
post #44776 of 52666 Old 09-22-2018, 07:30 PM
imureh's Avatar
Liked: 3772
Hi Jeffrey, it has to be sent in to the repair center one more time before they entertain replacement. I have sent it in yet as I am in midst of hosting a GTG with Todd and have a bunch some subs sitting in my house which I wanted to listen to as well. Plan to send it in first week of October.
imureh is offline
post #44777 of 52666 Old 09-22-2018, 07:54 PM
pmeintel's Avatar
Quoted: 149 Post(s)
Liked: 83
Tom V.
Power Sound Audio
"Slaughtered Lamb" that brings back some fun memories... I remember being 13 and sneaking in to see that one at the 2 screen theater in upstate NY. The effects had me mesmerized....
"These go to eleven." - Great words from Nigel Tufnel.
pmeintel is online now
post #44778 of 52666 Old 09-22-2018, 07:57 PM
Liked: 1848
Tom... explain
post #44779 of 52666 Old 09-22-2018, 07:57 PM
Quoted: 114 Post(s)
Liked: 55
Dual S1510 hooked up and ran through Audyssey XT32 and man, I am impressed. I came from a single Hsu VTF3 MK5 and then dual Rythmik F12SE. I like these best, and it's not even close. Thank you very much for all your time and help Tom, it's greatly appreciated.
BTW, the TV is NOT as high as it looks 🙂
Kirkobangz is offline
post #44780 of 52666 Old 09-22-2018, 08:21 PM
Hopinater's Avatar
Liked: 11203
Tom V.
Power Sound Audio
I agree. I think it would be absolutely awesome if all of us who hang out in this thread lived close enough so we could get together and relax with some ribs and beer. We could talk about everything from subwoofers to movies to all the other crazy topics we introduce into this thread and just have a great time. This thread is a lot like a family... its a tight group of guys so I'm sure we would have a blast. I'd even bring a keg of home-brew... perhaps a nice IPA.
post #44781 of 52666 Old 09-22-2018, 08:24 PM
ahblaza's Avatar
Liked: 3476
Tom... explain
That's a prototype PR (passive radiator) design that the guys were working on, same (similar) size box as the V18 with output capabilities of the V36, active driver and passive radiators instead of ports, if ever finished it won't look like that with the radiators (drivers) inverted........
MentatYP likes this.
ahblaza is offline
post #44782 of 52666 Old 09-22-2018, 08:27 PM
darthray's Avatar
Quoted: 2299 Post(s)
Liked: 3368
Tom V.
Power Sound Audio
While I was a previous customer of yours, but not for PSA.
I find this news to very exciting
Great news indeed.
Wishing you the best!!!
Ray
Hopinater likes this.
darthray is offline
post #44783 of 52666 Old 09-22-2018, 08:33 PM
ahblaza's Avatar
Liked: 3476
Great news indeed.
Ray
I just got there last week when Tom was speaking to someone in China about a big order being placed but payment wasn't received yet, I guess that and a few other deals have transpired since last week, that didn't take long to happen, I think Tom was speaking Chinese as well.......... Great news indeed Ray.
Cheers Jeffrey
Mike Butny and darthray like this.
ahblaza is offline
post #44784 of 52666 Old 09-22-2018, 08:36 PM
ahblaza's Avatar
Liked: 3476
Have a good GTG and hope you share the experience.............
imureh likes this.
ahblaza is offline
post #44785 of 52666 Old 09-22-2018, 08:44 PM
darthray's Avatar
Liked: 3368
Cheers Jeffrey
A language hard to get by
Also, I see that you added a few links to your Signature, since we last chat on these forums.
Glad to see, you have master-it
Ray
ahblaza likes this.
darthray is offline
post #44786 of 52666 Old 09-22-2018, 10:13 PM
lizrussspike's Avatar
Quoted: 1266 Post(s)
Liked: 1901
I'd even bring a keg of home-brew... perhaps a nice IPA.[/QUOTE]
@Hopinater said that as I am drinking a two hearted ale(IPA)! Made my heart skip a beat, that and the volcano explosion in the JP Fallen Kingdom. Man that movie has some great bass for PSA subs!!!!!!!!!!!!!
lizrussspike is offline
post #44787 of 52666 Old 09-22-2018, 11:57 PM
butie120's Avatar
Quoted: 1122 Post(s)
Liked: 364
Saw Jurassic World fallen kingdom tonight from Redbox and was pretty dissapointed. Pretty standard affair and didn’t offer much in the way of story, although not like I should have expected much. In these situations I at least hope for some nice bass but it was pretty non existent for the most part. The previous Jurassic world had better bass. Saw Adrift and that was so sweet with bass.
Any new Redbox movies you guys have seen where the bass was impressive? Just amazes me how great one movie is with bass and feel totally satisfied and then the nest film has me questioning if I need a bigger sub
Speakers: Fronts- JBL 230, Center- JBL 235C, Surrounds: Fluance XLBP
Sub: PSA 15V
Processing: Onkyo 676
Video: BenQ 1080ST
butie120 is offline
post #44788 of 52666 Old 09-23-2018, 05:56 AM
jamiebosco's Avatar
Quoted: 799 Post(s)
Liked: 1974
Maybe the Redbox copy is filtered?, I thought JW:FK had pretty good bass actually. What about the intro? and the
Spoiler!
TV: Panasonic P65ST60 AVR: Denon X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is offline
post #44789 of 52666 Old 09-23-2018, 06:03 AM
Quoted: 333 Post(s)
Liked: 989
To be clear, I wasn't complaining that the chat wasn't online. Sometimes I wonder when Tom sleeps.
Sub: PSA TV36-iPal
chucks0 is offline
post #44790 of 52666 Old 09-23-2018, 06:39 AM
butie120's Avatar
Liked: 364
Spoiler!
I guess I shouldn’t say it was non existent. I take that back. Just less potent than the first Jurassic world if going off memory. The Redbox is a lossless version.
Sub: PSA 15V
Video: BenQ 1080ST
butie120 is offline
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , Power Sound Audio , Power Sound Audio Triax , psa , Room Equilizer Wizard Rew , s3000i , s7201 , tv36 , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
