Official Power Sound Audio Subwoofer Thread - Page 1767 - AVS Forum | Home Theater Discussions And Reviews
 69387Likes
post #52981 of 53924 Old 12-07-2019, 10:51 AM
Kini62's Avatar
Quoted: 2795 Post(s)
Liked: 2671
Originally Posted by Dave Ol View Post
It's interesting that zambine stated this in his review of his new S3012".......In my sealed 2000ft^3 HT the ULF this thing puts out definitely outdoes the FV18 and the mid-bass seems to be a bit stronger too."
On paper the Rythmiks may have a lower tune, but it sounds like zambine feels the ULF is stronger on the PSA's. I guess we'll have to wait for someone to take some measurements to be sure.
Small room, lots of low end room gain, more driver area, shallow roll off all adds up to more pressurization and the feeling of more ULF would be my guess.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #52982 of 53924 Old 12-07-2019, 11:17 AM
zambine's Avatar
Quoted: 196 Post(s)
Liked: 219
Thanks for the recommendations on the humming. I have found that when I turn the crossover slightly below 150Hz the humming goes away. I am using this as a near field sub and also an end table for my second row seating so having the hum was not a good thing. The humming is there when nothing is plugged into the sub and it slightly increases when I plug my RCA cable in. I will continue to experiment with the settings and I will also message Tom on it but this may turn out to be a non-issue thanks to your help.
zeuspaul, DOC1963 and Hopinater like this.
zambine is online now
post #52983 of 53924 Old 12-07-2019, 11:22 AM
zambine's Avatar
Quoted: 196 Post(s)
Liked: 219
Originally Posted by Soulburner View Post
I think we need to give him a week or two to get a more complete feel of the subs.
Absolutely, everyone please take my impressions so far with a grain of salt. I will provide some more feedback after I have lived with them for a bit and been able to measure some with REW. I will also be performing a head to head test of dual S3012s vs dual FV18 paper cones next week just because I can.
BTW the room size dial was set to small for my initial impressions.
CallingMrBenzo, drh3b and GatoGoat like this.
post #52984 of 53924 Old 12-07-2019, 11:29 AM
ratbuddy's Avatar
Quoted: 900 Post(s)
Liked: 1291
I think I might have been the first to report mild hum from the neo stuff, having TV36ipals that shipped day one along with Hop's. It's only noticeable if you are standing 1-2 feet from the sub, and I actually only hear it at all from one of them. I didn't think to mess with the gain knobs, but that could definitely be the difference. When Audyssey had me set the gain levels of the subs, one needed a little more on the knob, and that's the one that I can hear mildly humming. The sub with a lower gain setting and no hum just happens to be in a corner, so that would explain why it needed less gain than the other one.
If I was planning to keep the subs long term, I would definitely lower the gain knob a bit, even if it means Audyssey coming back at -5 instead of my preferred -10ish. I can always boost in the miniDSP if I want to, and losing the hum would be good for peace of mind, even though it's not audible farther than a few feet away from the sub.
It looks like this on Spectroid - I turned the receiver on about halfway up the graph, you can see it on the ~-70 db line or so.
It also sounds the same whether there is a signal cable connected or not, and each sub is on a fully dedicated circuit, so I don't think it's anything related to a ground loop, even though the hum is centered around 59 Hz. I think it's just the nature of the drivers and the amp gain setup.
I'll reiterate, since I know there are some weirdos out there who love to hate PSA and will run with this like they ran with the false rumors of chuffing from an abused V1801: The hum is completely inaudible from any reasonable distance from the sub, and can probably be completely eliminated by lowering the gain on the amp. It's also literally the ONLY small issue I've had with the TV36ipals. Their actual performance has been nothing short of astonishing, both in quality and quantity of bass. I really wish I could keep them, and I'll 100% pick up another pair down the road when I move to a bigger house.
ratbuddy is online now
post #52985 of 53924 Old 12-07-2019, 11:36 AM
imureh's Avatar
Quoted: 3131 Post(s)
Liked: 4055
I used to have submersives in my room and was flat down to 5hz and you can see I am using ported subs. A sealed sub will have shallower roll off especially in room. So I would not put too much faith in the FR but could use it with that in mind. Now if we take them outside then it’s a different story as the room gain is out of the question. This is all quite interesting and fun.
drh3b likes this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #52986 of 53924 Old 12-07-2019, 12:14 PM
zambine's Avatar
Quoted: 196 Post(s)
Liked: 219
For me the humming was probably more noticeable since the sub is near field. I assume that lots of people thinking of purchasing an S3012 may be looking to use them the same way. The dual opposed drivers and size make it a perfect end table sub. In addition, 50% of my HT use is video games which can have very quiet moments that I do not want interrupted by a humming sub.
Luckily the previous advice given seems to have worked to eliminate the hum when I quickly checked. When I test with REW later I'll see if the settings changes to remove the hum alter the subs performance at all.
Sent from my SM-G965U1 using Tapatalk
post #52987 of 53924 Old 12-07-2019, 01:30 PM
MKtheater's Avatar
Quoted: 2606 Post(s)
Liked: 2843
It is about the response, but not the response at 75-80 dB which many people post. It is the response at the levels they listen to. Based on science the louder response wins.
ahblaza likes this.
Building the room, speakers, and subs.
MKtheater is online now
post #52988 of 53924 Old 12-07-2019, 06:19 PM
gbreda's Avatar
Quoted: 594 Post(s)
Liked: 1102
Been away for quite a while as life stuff went in the crapper on several fronts. Missed out on the pre sales as I really had no interest in doing anything here but coming out of it now and the mind is thinking again.
Using dual S3000i and the fact that I really dont listen to music as much any more at home (especially loud music) I start thinking vented subs for movies. My subs are also my L/R speaker stands and I really like the inert characteristic of dual opposed.
So, questions here is do I wait for upgrades to start being sold for the S3000's (I think I am leaning this way) and save the hassle of boxing and shipping or look into dual V1502/V1802. S3612 is a very slight possibility but will also cost the most $$. TV36 is definitely out here.
I am liking the first impressions of the S3012 in comparison to the S3010 while also paying attention to what @basshead81 and @bear123 and others have been talking about last few days of what the new 15's can potentially provide.
Will the S3012, like the S3000/10 remain the sleeper of the lineup? Time will tell on that question.
gbreda is offline
post #52989 of 53924 Old 12-07-2019, 06:25 PM
Just bought a pre-owned XS30SE and lost my mind bringing it up to my 3rd floor! Nonetheless top notch subs.
From those who switched to the ICE amp, was there a massive difference to warrant the price?
ramon banaag is offline
post #52990 of 53924 Old 12-07-2019, 06:25 PM
bear123's Avatar
Quoted: 2935 Post(s)
Liked: 4483
Looks like a Monoprice subwoofer cable. I'd swap it out for a good quality, well constructed cable like Blue Jeans Cable LC1....*lots* of folks have eliminated noise issues by replacing junk Monoprice cables with better quality like BJC. Any slight noise that might be getting into poorly constructed cables is going to be amplified by the very high sensitivity pro audio drivers.
bear123 is offline
post #52991 of 53924 Old 12-07-2019, 06:42 PM
rhelliott2's Avatar
Quoted: 251 Post(s)
Liked: 437
I noticed a slight hum with my V1512 over my V1510 (that had ZERO hum.) One thing I found out was, my power cord from my AVR was super close to my Sub RCA cable(Amazon basics) and I re-organized my cable and upgraded to a Blue jeans Sub RCA cable and the hum is gone!
Living Room: 5.1.2 PSA MT110L/R | PSA MTM210C | Polk TSi100 S/R | Atmos in-ceiling Mag6R
SUB: PSA V1512
RECEIVER: Denon X3400H
DISPLAY: Vizio P65-C1
SOURCES, MISC, & 2ch: Xbox One X, Harmony Elite, Aircom T10, Chane A1.5 & AD18
rhelliott2 is online now
post #52992 of 53924 Old 12-07-2019, 07:05 PM
soundofrockets's Avatar
Quoted: 25 Post(s)
Liked: 41
Ordered the mic from cross spectrum web site. Let’s see how deep I run into the hole!!!
MKtheater, ahblaza and rhelliott2 like this.
soundofrockets is offline
post #52993 of 53924 Old 12-07-2019, 07:14 PM
Quoted: 26 Post(s)
Liked: 44
I have little experience with this stuff but i have 2 tv36 ipals and can chime in a bit on the humming some people hear.
If i put my ear right to the driver i can hear a very quiet fan noice. Wouldn't call it a hum exactly and I literally can only hear it with my ear to the drivers. Happens with both subs.
I did have a hum i could hear from the MLP from one sub. It was pretty quiet and could only be heard with nothing playing. I did manage to remove it 100% by rerunning audyssey set up and it has never come back. I tried everything to remove it before that and nothing worked.
Im really curious Why audyssey was causing this and if this will fix the problem for any of you.
ahblaza likes this.
moviefiend420 is offline
post #52994 of 53924 Old 12-08-2019, 04:03 PM
maxkolonko123's Avatar
Quoted: 31 Post(s)
Liked: 32
so im reading and reading and it makes we want to add more bass to my setup got one question guys for you, basically i own 1x S3010 which im really happy of, my room is mega small something 3m x 4m sq,but yet i want more bass and db so im lately parted between ported vs sealed, after reading here that ported will hit lower and louder which is what i want, im curious if u can run ported and sealed combo in one setup? for example if in future i would like to go with ported one subs would be an issue for me to try integrate them together ?
maxkolonko123 is offline
post #52995 of 53924 Old 12-08-2019, 04:30 PM
imureh's Avatar
Liked: 4055
Not typically not recommended to mix sealed and ported but if one has the right tools and knows what to do then it can be done.
maxkolonko123 likes this.
post #52996 of 53924 Old 12-08-2019, 05:53 PM
basshead81's Avatar
Quoted: 349 Post(s)
Liked: 10045
Going by Zambine's post I would add a S3012 and some "oh ****" handles to your seat and hang on.
Mike Butny, SuperFist and drh3b like this.
basshead81 is offline
post #52997 of 53924 Old 12-08-2019, 07:15 PM
banyar's Avatar
Quoted: 229 Post(s)
Liked: 92
I am struck by the performance of the S3012 compared to the Rithmik FV18. I have a V1801 and a V1811, I have been thinking of trade in for dual V1512s, with the new drivers maybe they should be on par (or maybe exceed) my current subs. I don't want to take the dual drivers route. My use is 100% HT, do you think it would be an upgrade to trade in by dual V1512s? Or maybe dual S3012 could outperform my subs for 100% HT?
CallingMrBenzo likes this.
banyar is offline
post #52998 of 53924 Old 12-09-2019, 04:35 AM
Quoted: 31 Post(s)
Liked: 32
It wont be more cost efficient to upgrade drivers in your V18's to Ipal ?
Dave Ol likes this.
post #52999 of 53924 Old 12-09-2019, 08:21 AM
basshead81's Avatar
Quoted: 349 Post(s)
Liked: 10045
Not really because the cost of the just the NEO upgrades is like 450.00 for the 15". I am sure the IPAL 18" would quite a bit more(900.00 if I had to guess). Then you have to factor down time for sending amps out for recalibration and you don't get a new warranty with the upgrade. If you trade-in then you get brand new subs with full warranty. So Let's say you get 1000.00 trade-in credit each for V1801/1811, it would cost him roughly 1614.00 to upgrade to new V1812 IPAL subs or about the same to upgrade his current subs to 18" Ipal. Or he could switch to V1512's for about 470.00.
ahblaza, Hopinater and rhelliott2 like this.
post #53000 of 53924 Old 12-09-2019, 08:53 AM
Quoted: 31 Post(s)
Liked: 32
Ok gotcha, and make sense, when you saing you dont get new warranty " does it mean you dont get any ? or the warranty time is left from your original purchase? And switching to 15' from 18' it wont be a downgrade in that situation?
I'm based in UK so i doubt for us here trade-in is an option though
post #53001 of 53924 Old 12-09-2019, 09:53 AM
Quoted: 193 Post(s)
Liked: 574
There are probably plenty of people in the UK looking for USA I.D. subs , you will probably get more $$ if you try and sell locally and use that $$ towards a new purchase...Shipping eats up a lot of the value in trade-in..
GatoGoat is offline
post #53002 of 53924 Old 12-09-2019, 10:13 AM
banyar's Avatar
Quoted: 229 Post(s)
Liked: 92
Thanks for the reply guys, would it be a good idea to trade in my V18s for dual S3012s or maybe dual V1512s for 100% HT?
banyar is offline
post #53003 of 53924 Old 12-09-2019, 10:19 AM
Quoted: 31 Post(s)
Liked: 32
We have here a distributor of PSA subs but i doubt he does trade ins
post #53004 of 53924 Old 12-09-2019, 10:22 AM
Quoted: 31 Post(s)
Liked: 32
i would go fro s3012s u can afford it or 2x V18 IPAL
post #53005 of 53924 Old 12-09-2019, 11:45 AM
Spidacat's Avatar
Quoted: 310 Post(s)
Liked: 425
FYI - the pricing for the 18" models - this was Tom's original post, so things could have changed. It looks like the 15" (Neo?) and 18" Neo are the same price? Ipal for the 18" only?
All models with a *01* and *11* suffix are eligible.
S1801
S1811
S3601
S3611
V1801
V1811
V3601
V3611
The following is for the lower 48 (USA) states only.
Single woofer models.
Neo upgrade $625 with a $200 core credit (so 425 after we get the old woofer back)
Ipal upgrade $1000 with a $200 core credit (800 after we get the old woofer back)
Dual woofer models.
Neo upgrade $1250 with a $400 core credit (850 after we get both old woofers back)
Ipal upgrade $2000 with a $400 core credit (1600 after we get both old woofers back)
Pricing includes all associated costs including the amp reprogram, and all shipping involved.
basshead81 likes this.
Spidacat is online now
post #53006 of 53924 Old 12-09-2019, 01:30 PM
basshead81's Avatar
Quoted: 349 Post(s)
Liked: 10045
What I meant was the warranty isn't reset from the upgrade purchase date. You still however have the remaining warranty left from original purchase. I made a point to mention that because back when the ICE upgrade was offered, it gave you a new 5yr bumper to bumper warranty which adds a lot of incentive to the "upgrade" imo.
Either will be a solid choice but I think the V1512 a ringer at it's price point. With the Neo woofer you are getting sealed quality sound signature with added low end output from the port. That being said, dual opposed NEO's is probably a force to be reckoned with. Zambine's post is pretty informative. Sorry I am not of much help...I just don't think you can make a bad choice. Larger room dual V1812's, small to medium room dual S3012's since they will have the ability to make use of that low end room gain and net some really deep extension.
S1801
S1811
S3601
S3611
V1801
V1811
V3601
V3611
Dual woofer models.
I don't believe anything has changed...Neo 15 & 18 are same price. B&C only makes 18 & 21" IPAL.
Mike Butny likes this.
post #53007 of 53924 Old 12-09-2019, 01:32 PM
gutcheck2001's Avatar
Quoted: 232 Post(s)
Liked: 180
So after discussing things with a contractor i believe it may be possible to get a single TV42 on its side under my TV. I’d have to move my Amps and I would forever be limited to a single sub. That’s gotta be ok though no? I mean my god.
Dave Ol, rhelliott2 and GatoGoat like this.
gutcheck2001 is offline
post #53008 of 53924 Old 12-09-2019, 02:24 PM
Quoted: 232 Post(s)
Liked: 180
Also for those of you experiencing a hum have you tried these? They silenced my JTR’s which both had obnoxious ground loop issues:
https://www.amazon.com/Transformer-Eliminator-Blue-Jeans-Cable/dp/B00GG1PK5W/ref=asc_df_B00GG1PK5W/?tag=hyprod-20&linkCode=df0&hvadid=309809835998&hvpos=1o2&hvne tw=g&hvrand=13651403297839530141&hvpone=&hvptwo=&h vqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9031317 &hvtargid=pla-761120909432&psc=1
SuperFist likes this.
post #53009 of 53924 Old 12-09-2019, 02:48 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1925
I'm really looking forward to what he has to say, but I'm sorry, he has only posted initial impressions. He hasn't done a proper comparison yet, has not shared any measurements or posted longer term impressions. And, the Rythmik was set to low damping, which is going to give a high Q value like other subs.
We should not be jumping to conclusions just yet. Let's give him some time.
Soulburner is online now
post #53010 of 53924 Old 12-09-2019, 03:03 PM
ratbuddy's Avatar
Quoted: 900 Post(s)
Liked: 1291
https://www.amazon.com/Transformer-E...20909432&psc=1
Since mine still does it with everything unplugged but the power cable, I don't think that would help.
ahblaza likes this.
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s1512 , s7201 , tv36 , v1500 , v1512 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
