Official Power Sound Audio Subwoofer Thread - Page 1895 - AVS Forum | Home Theater Discussions And Reviews
 78198Likes
post #56821 of 57533 Old 05-31-2020, 10:29 PM
serith's Avatar
Quoted: 927 Post(s)
Liked: 1169
Originally Posted by rhelliott2 View Post
That's easy Play EOT at reference lol
if i remember correctly the test tones in that intro start at 30hz and drop down to 10hz in increments of 5hz five times.
@badtlc this is by far easier to use and you can pick any frequency your heart desires: https://www.szynalski.com/tone-generator/
1800ft³ | 7.1.6 | 157" at/cw | hc2150 | x4300h | mtm-210t | 4000ulf | me650c | av5 | avbp2 | rialto | velvet | plex
serith is offline
post #56822 of 57533 Old 06-01-2020, 05:24 AM
mnc
mnc's Avatar
Quoted: 1023 Post(s)
Liked: 807
I’m still hoping to upgrade to the Neo “sound” but I’m more budget constrained so I’m hoping the Chinese cabinet options will be my answer!
skylarlove1999 likes this.
NHT speakers, Denon x4500h, Stacked PSA XS30SE's, ATV4K, 75X940E, UBPX700
mnc is offline
post #56823 of 57533 Old 06-01-2020, 05:40 AM
badtlc's Avatar
Quoted: 810 Post(s)
Liked: 366
What does EoT stand for?
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
AVR: Denon AVR-X3500H
badtlc is offline
post #56824 of 57533 Old 06-01-2020, 05:45 AM
Hopinater's Avatar
Quoted: 3885 Post(s)
Liked: 13146
Edge of Tomorrow the movie also known as Live, Die, Repeat. Stars Tom Cruise and Emily Blunt.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - PSA MT110's Rear - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Hopinater is offline
post #56825 of 57533 Old 06-01-2020, 05:51 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10954
I wouldn't crank your system to reference and play the EOT intro without knowing your sub(s) capabilities prior.
basshead81 is offline
post #56826 of 57533 Old 06-01-2020, 05:54 AM
badtlc's Avatar
Quoted: 810 Post(s)
Liked: 366
I agree.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
badtlc is offline
post #56827 of 57533 Old 06-01-2020, 08:41 AM
mnc
mnc's Avatar
Liked: 807
Don’t all PSA subs have built in protection?
mnc is offline
post #56828 of 57533 Old 06-01-2020, 09:07 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10954
Yes most subs have some form of limiting. I still recommend having a idea of your systems limits before going HAM and playing test tone sweeps at a level that might be much higher then your sub is capable of. There is a good chance the Subs protection circuits will save it, but I believe you can still damage a PSA sub playing with test tones if the levels are above the subs limits. Tom mentioned it a few years back and said that playing this type of stuff can void the warranty as well.
post #56829 of 57533 Old 06-01-2020, 09:10 AM
Tom Vodhanel's Avatar
Quoted: 3286 Post(s)
Liked: 11821
Define "protection"..
Protection could be a single 50 cent resistor used in a highpass circuit in many non dsp enabled products for example.
Specifically, in this neck of the woods....people discussing sine waves at port tunes and craziness like that...there's not much you can do for bullet proof protection. This is absolute worst case scenario for a voice coil. Max heating, minimum cooling(cooling is dependent on VC movement---at tune there is minimal movement unless the system is unusually lossy).
You can either incorporate something unusual and fairly complex like a temperature monitoring circuit on the VC.
Another option, albeit a very expensive one, is to use woofers with a motor design so over-built that they can handle an extraordinary amount of continuous power---even at "port tune".
At the end of the day, as noted, these "tests" should be avoided or at least limited to short duration.
Tom V.
Team Power.
The woods are lovely, dark and deep, But I have promises to keep,
Tom Vodhanel is offline
post #56830 of 57533 Old 06-01-2020, 09:59 AM
mnc
mnc's Avatar
Liked: 807
Tom V.
Team Power.
So are sealed subs more protected than ported?
mnc is offline
post #56831 of 57533 Old 06-01-2020, 10:04 AM
rhelliott2's Avatar
Quoted: 461 Post(s)
Liked: 872
I agree.
Good idea.
dont do what this guy did.
rhelliott2 is offline
post #56832 of 57533 Old 06-01-2020, 10:04 AM
Quoted: 206 Post(s)
Liked: 233
Do you read this thread with your head in your hands thinking "what are they trying to do to my subs!"
Conrad Nash is offline
post #56833 of 57533 Old 06-01-2020, 10:41 AM
SuperFist's Avatar
Quoted: 1742 Post(s)
Liked: 7563
Dude... I just can't! I can't even... Seriously, WTF!?!
SuperFist is online now
post #56834 of 57533 Old 06-01-2020, 10:46 AM
rhelliott2's Avatar
Quoted: 461 Post(s)
Liked: 872
Yeah like WTF playing a sine wave for THAT long will burn the VC.
post #56835 of 57533 Old 06-01-2020, 10:48 AM
Hopinater's Avatar
Liked: 13146
Originally Posted by Conrad Nash View Post
Do you read this thread with your head in your hands thinking "what are they trying to do do to my subs!"
I don't know if he did but I can tell you I've been reading some posts and shaking my head wondering what people are trying to do. I thought it was common knowledge if you want to kill a sub, any sub... play sine waves at loud volumes. I know it can be done for short durations but why take the risk? And how long is "short"?
Basshead gave some good advice a few posts back, don't go crazy before you understand what you're doing and what your subs can handle.
post #56836 of 57533 Old 06-01-2020, 11:41 AM
badtlc's Avatar
Quoted: 810 Post(s)
Liked: 366
I don't know how short is short but when I'm goofing off testing different things with pure sine waves I won't typically do it more than about 5 seconds and I usually keep it to a very low volume.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
badtlc is offline
post #56837 of 57533 Old 06-01-2020, 12:10 PM
Hopinater's Avatar
Liked: 13146
Yep, that should be fine.
LOL... when I watched that video posted above I actually felt my self getting more and more nervous as he kept turning the volume up. He literally cooked that subwoofer, and I bet there may be damage to the others as well.
post #56838 of 57533 Old 06-01-2020, 12:34 PM
Quoted: 102 Post(s)
Liked: 557
Talked my into it! Ordered the blu ray.
PSA MTM 210T's, MTM 210C, MT 110SR, V-1800, V-1801
65" LG 4K, Denon AVR-X4300H, EAT B Sharp Turntable, Xbox One X
ss nimrod is offline
post #56839 of 57533 Old 06-01-2020, 02:52 PM
Liked: 11821
www.youtube.com/watch?v=AZynRC-2Wp0
Tom V.
Team Power.
post #56840 of 57533 Old 06-01-2020, 02:58 PM
Liked: 11821
It depends. Even with the VC moving, sealed = interior heat build up. And the you have VC movement varying with frequency as well.
I've been trying to talk Bennett into testing their coils in Mt. Vesuvius. I mean, it's right there.
Maybe we'll soon see a new AES standardization...
Tom V.
Tom Vodhanel
post #56841 of 57533 Old 06-01-2020, 03:05 PM
Liked: 11821
tv18ipal_r3
S2410(first poc)
Tom V.
Team Power.
ID:	2735834   Click image for larger version
ID:	2735836   Click image for larger version
post #56842 of 57533 Old 06-01-2020, 05:41 PM
zora's Avatar
Quoted: 135 Post(s)
Liked: 161
tv18ipal_r3
S2410(first poc)
Tom V.
Team Power.
Me likey👍 Can’t wait for the pair to come.
zora is offline
post #56843 of 57533 Old 06-01-2020, 06:50 PM
Quoted: 370 Post(s)
Liked: 962
tv18ipal_r3
S2410(first poc)
Tom V.
Team Power.
Multiple typos or something new and special?
ahblaza likes this.
7.3.4 Setup---TV: LG OLED 65B7A, Receiver: Marantz SR-6012, External 2-channel amplifier: Marantz MM7025 (Front Towers), Blu-Ray Player: LG UBK90, Fronts: JBL S312, Center: JBL S-Center, Surrounds: JBL S38, Surround Backs: JBL S36 ,Top: JBL S36 (4), Subwoofer: 2 PSA S3000i and one PSA XS-30se
http://www.blu-ray.com/community/col...&action=hybrid
Joshua Chmiel is offline
post #56844 of 57533 Old 06-01-2020, 07:04 PM
Nalleh's Avatar
Quoted: 3291 Post(s)
Liked: 5121
Sealed 2x12" dual opposed "proof of concept"?
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 6x Crowsons - 4xBK-LFE - 2x12"BB - 2x "4DX" fans- 6xNU6K - Minidsp 10x10HD-Vertex2-Oppo UDP203-XB1X-ATV4K-JVC RS600-Dreamscreen V2 120"-Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is online now
post #56845 of 57533 Old 06-01-2020, 07:27 PM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10954
Pretty sure the S2410 is in the 3rd pic unfinished next to the TV18's.
Tom Riddle and Joshua Chmiel like this.
post #56846 of 57533 Old 06-01-2020, 08:45 PM
rhelliott2's Avatar
Quoted: 461 Post(s)
Liked: 872
IIRC it had a Passive radiator.
post #56847 of 57533 Old 06-01-2020, 09:18 PM
Tyborg's Avatar
Quoted: 105 Post(s)
Liked: 75
You got me Tom, was looking all over for the sealed SI 24” driver, little 12” is a little too small for my current needs, but I know a guy
Tyborg is offline
post #56848 of 57533 Old 06-01-2020, 10:27 PM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10954
Passive radiator is a Vented alignment.
post #56849 of 57533 Old 06-02-2020, 05:25 PM
Tom Riddle's Avatar
Quoted: 1103 Post(s)
Liked: 1354
I just ordered a TV3612 that I’m going to pair with my V3600I! I’m ready to make my theater seat float!
Routh Family Theater - My Dedicated Home Theater Build - 7.2.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I & TV3612 Subwoofers
Marantz AV7705 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #56850 of 57533 Old 06-02-2020, 06:04 PM
rhelliott2's Avatar
Quoted: 461 Post(s)
Liked: 872
Congratulations! They will make an awesome pair!
Tom Riddle likes this.
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , ipal , neo , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s1512 , s3000i , S3600i , s7201 , tv36 , tv42 , v1500 , v1512 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
