Official Power Sound Audio Subwoofer Thread - Page 602 - AVS Forum | Home Theater Discussions And Reviews
 67062Likes
post #18031 of 53135 Old 03-26-2015, 11:02 AM
Hopinater's Avatar
Quoted: 3594 Post(s)
Liked: 11472
Originally Posted by ahblaza View Post
Some one please help me to post my graphs from REW, I tried everything and don'y know what I'm doing.
Hey that's great Jeff you got your first graphs with REW. As the other guys pointed out now the work begins as you can now see what you need to fix (But your speakers look pretty darn good). Once you figure out what's causing that dip you should be great.
ahblaza likes this.
Hopinater is offline
post #18032 of 53135 Old 03-26-2015, 11:02 AM
Tom Vodhanel's Avatar
Quoted: 3051 Post(s)
Liked: 10484
Originally Posted by Alan P View Post
Nothing against Tom, but with all the issues you and I (and many others) have had with the MiniDSP and then ended up not using it, I think Tom is asking for a lot of headaches from customer issues by including the MiniDSP....just my 2 cents.
Actually I just refer them to you and basshead..
Seriously though, thanks to everyone who spends time in this thread helping out others. There is *no* way I would have the time to answer all of the questions that pop up here.
Also, we're going to evaluate the anti-modes too. It may not work quite as well as a optimized miniDSP setup but I'd guess 95% of our customers would prefer a plug-play solution that gives them most of what the miniDSP+REW5 does.
Tom V.
Power Sound Audio
Tom Vodhanel is offline
post #18033 of 53135 Old 03-26-2015, 11:17 AM
Blaine Morrissey's Avatar
Quoted: 61 Post(s)
Liked: 36
Tom V.
Power Sound Audio
To me those looked like they had potential for those of us who just want to push a button Actually now that I feel like I can take measurements ok it is kinda fun...even though my room sucks.
Pioneer Elite SC-63 | OPPO BDP-103D | PSA v1500 | SVS PB 12 NSD/v | SVS AS-EQ1 | GR Research A/V-3 | VOLT 10LX Edition (build in progress) | Onix Rocket ELT DPA | Epson 3020 | Dragonfly 120 Screen | APC H15BLK
Blaine Morrissey is offline
post #18034 of 53135 Old 03-26-2015, 11:18 AM
Alan P's Avatar
Quoted: 6608 Post(s)
Liked: 6023
Tom V.
Power Sound Audio
I think the Antimode would cause you less headaches, that's for sure.
ahblaza likes this.
Alan P is offline
post #18035 of 53135 Old 03-26-2015, 11:20 AM
Liked: 10484
Being able to take accurate audio measurements in your system will prove invaluable over the years. And REW5 is very powerful for free software too.
Tom V.
Power Sound Audio
ahblaza likes this.
post #18036 of 53135 Old 03-26-2015, 11:25 AM
Liked: 10484
Here is the electrical of our "Room Size" control.
The top curve(virtually flat) is the control set to LARGE.
The bottom curve(with the greatest attenuation) is the control set to SMALL.
Everything in-between is everything in-between on the dial..
Tom V.
Power Sound Audio
mnc, ahblaza and jhughy2010 like this.
post #18037 of 53135 Old 03-26-2015, 11:50 AM
jhughy2010's Avatar
Quoted: 906 Post(s)
Liked: 288
I had originally thought that Audyssey XT32 did all the sub EQing and correction?
jhughy2010 is offline
post #18038 of 53135 Old 03-26-2015, 12:01 PM
Alan P's Avatar
Liked: 6023
Well, it does some EQing of the sub...but some folks need more, hence the MiniDSP (and other EQ solutions).
jhughy2010 likes this.
Alan P is offline
post #18039 of 53135 Old 03-26-2015, 01:23 PM
nalthien's Avatar
Quoted: 485 Post(s)
Liked: 538
I imagine it makes sense to take multiple measurements: go with un-EQ'd and then go with post-Audyssey. Once you've done that, you'll see the differences Audyssey was able to make. Depending on your room, you'll see whether or not that was "enough." My understanding is that the MiniDSP can help tame really nasty modes in which certain frequencies are lifted way too high. But, much like Audyssey, it can't really help a null; you'll need to explore different positions for that.
Music: McIntosh C1100T/C | McIntosh MC452 | Revel Salon 2 | PSA S3000i x2 | VPI Traveler | Parasound ZDac | AppleTV
Movies Add: Marantz AV7702 | Revel Voice 2 | Emotiva UPA-1 | Sony Ps4 | Custom HTPC
Ordered: VPI Prime
nalthien is offline
post #18040 of 53135 Old 03-26-2015, 01:31 PM
ggallaway's Avatar
A few things. I performed the following to dial in my subs:
1) connect both subs to the MiniDSP and subwoofer output on my Onkyo 705 Reciever
2) bring up calibration tones on onkyo and set sub to 0db
3) Mute one sub and calibrate using amp gain and minidsp to 75db
3) Mute other sub and calibrate to 75db
4) Run Audysey (which brought combined sub output cut to -6db at the onkyo) also it set the sub to 8ft (even though subs are placed in opposing corners across the room, one in back and one up front)
5) Run REW and see crazy dips just below and above 80hz
6) Play with delay on V1500 until REW shows "relatively flat" response with just one big bump at 100hz, export MiniDSP file to tame the bump
7) import file into MiniDSP (luckly saved my settings from before didn't know it would wipe them out if I hadn't )
8)verify with REW that graph looks smooth without the 100hz bump
Anything I missed here? should I have done things in a different order? also, slightly unrelated what kind of power draw does the V1500 have when idle? I know it has the "auto" setting but I have never really cared for how they operate (sometimes shutting off if there is not sufficient bass in the movie) anyone have thoughts on that?
Thanks Much!
G
ggallaway is offline
post #18041 of 53135 Old 03-26-2015, 01:36 PM
nalthien's Avatar
Quoted: 485 Post(s)
Liked: 538
This is one area with which I am entirely unfamiliar. I'm not sure what measurements are going to correspond to needing to change the delay and how to accurately dial that in. Would love to hear from people more knowledgable--I understand the purpose of the control; just, nothing about how to use it.
Ordered: VPI Prime
nalthien is offline
post #18042 of 53135 Old 03-26-2015, 02:36 PM
Alan P's Avatar
Liked: 6023
Thanks Much!
G
To properly time-align multiple subs with the MiniDSP, all you need is a tape measure and a calculator.
Measure the the distance from MLP to furthest sub, measure the distance from MLP to closest sub. Calculate the difference (sub1 is 15', sub 2 is 5', difference = 10'). Use MiniDSP to add 10' of delay to closer sub.
This will get you in the ballpark, you can fine tune while measuring with REW for the smoothest response.
After you get the subs time-aligned with each other, you then run Audyssey (or whatever auto-EQ you have) then perform the sub distance tweak to get the sub "system" in-phase with the CC/main speakers.
Alan P is offline
post #18043 of 53135 Old 03-26-2015, 02:43 PM
nalthien's Avatar
Quoted: 485 Post(s)
Liked: 538
If I'm running Audyssey XT32 on a Marantz AV7702 (which has two, independent subwoofer outs), I believe it can calculate distance for each sub independently--should I still need to go through this step?
Also, these steps make sense for time-aligning the subwoofers with each other; I'm also concerned with time-aligning the subwoofers with my mains. My understanding was that Audyssey does a pretty good job of that on its own and that the physical delay control on the subwoofer could be used to tweak. Am I in line with reality here or just confused?
Ordered: VPI Prime
nalthien is offline
post #18044 of 53135 Old 03-26-2015, 02:52 PM
Alan P's Avatar
Liked: 6023
Yes, if you have XT32 with SubEQ HT (edit: and only TWO subs) there is no need to time-align with the MiniDSP.
In order to "time-align" the subs with the mains you would use the sub distance tweak (as I mentioned above). The distance tweak uses the AVR's sub distance setting, "moving" the entire sub system as one.
EDIT: Oh, and Audyssey typically does NOT do a good job at getting your mains (FL/R & CC) in-phase with the subs...it never measures them together so it does not have the information to do so.
ahblaza likes this.
Alan P is offline
post #18045 of 53135 Old 03-26-2015, 02:55 PM
tvuong's Avatar
Quoted: 2740 Post(s)
Liked: 2570
Aud measures each channel separately and applies eq to each of those channels separately. It does not measure your main with sub or any other channel with sub; therefore, it is good to adjust the sub distances (if needed) to have the sub(s) in phase with your main and/or center channel. This can easily be seen with REW or any measurement program at the crossover point.
Edit: Alan beats me to it.
tvuong is offline
post #18046 of 53135 Old 03-26-2015, 03:02 PM
Hopinater's Avatar
Liked: 11472
Amen to that!
post #18047 of 53135 Old 03-26-2015, 03:52 PM
basshead81's Avatar
Quoted: 343 Post(s)
Liked: 9769
Audyssey can do more harm then good when it comes to sub eq in some situations. The best option is again to download Rew, get a measuring mic, and measure pre and post eq no matter what form of eq it is....I would get the sub placement and response set up the best your room and waf will allow then run Audyssey or whatever form of sub eq you have. THE LESS EQ NEEDED THE BETTER!!
basshead81 is offline
post #18048 of 53135 Old 03-26-2015, 04:12 PM
Hopinater's Avatar
Liked: 11472
I have read in some threads that some people who got Antimode ended up disconnecting it because they felt like it neutered the sub. Has anyone used it at all? I'm curious to hear their thoughts.
post #18049 of 53135 Old 03-26-2015, 04:15 PM
jhughy2010's Avatar
Quoted: 906 Post(s)
Liked: 288
Do you need to time align the subs if they are equidistant from the MLP?
post #18050 of 53135 Old 03-26-2015, 04:15 PM
Alan P's Avatar
Liked: 6023
Alan P is offline
post #18051 of 53135 Old 03-26-2015, 04:16 PM
Alan P's Avatar
Liked: 6023
If they are identical, no.
Alan P is offline
post #18052 of 53135 Old 03-26-2015, 04:20 PM
cesar123's Avatar
Quoted: 390 Post(s)
Liked: 579
Not exactly the same, but I introduced a SVS EQ1 into my system a week or so ago and it definitely smoothed out the FR. No overpowering slam anymore.
Sounds are "cleaner" (for lack of a better word), but I did feel like it tamed a tad too much my XS30se.
Maybe I was just used to not so clean bass?... Nevertheless, adding another one should make things better.
Yippee-ki-yay...
cesar123 is offline
post #18053 of 53135 Old 03-26-2015, 04:50 PM
Alan P's Avatar
Liked: 6023
Alan P is offline
post #18054 of 53135 Old 03-26-2015, 05:11 PM
mnc
mnc's Avatar
Quoted: 877 Post(s)
Liked: 628
Tom V.
Power Sound Audio
Oh wow I didn't realize it started so high. I thought it only affected around 30Hz and under. I think I'm going to try Audyssey again with it set to Large. Doesn't make any sense why I would have deeper, more powerful bass when setting it ti Small.
NHT speakers, Denon 4520, DUAL PSA XS30SE's, ATV4K, 75X940E, UBPX700
mnc is offline
post #18055 of 53135 Old 03-26-2015, 05:45 PM
satfam's Avatar
Quoted: 75 Post(s)
Liked: 64
Well I've got my V1500s setup using XT32. Haven't really had a chance to really check these out but my based on my initial listening is deep, clean bass. I tried various locations from mid-side walls to corner placement but finally wound up with front stage. Seemed the best there but I'm sure I will tinker some more.
Very impressive subs Tom!
mnc, oneeyeblind, ahblaza and 4 others like this.
H/T: Marantz 7702MK II, MM8077, MM7055, Triton 2s, SCXL, SL/SR-S50s, BL/BR-S50s, H/W-4 Sat3s, dual SB16 Ultras, JVC DLA-RS2000, Stewart Cima Neve 110", Tivo Bolt, PS-3, Apple 4K TV, GIK Acoustics treatments, Panasonic UB820
Gameroom: Denon AVR-X4500H, Emotiva 2-T1’s, C1, 2 B2’s, 4 NHT ceiling speakers, 2 Velo SPL-1000R, Sony XBR85X900F, PS4 Pro, Tivo Bolt,Oppo 203
satfam is offline
post #18056 of 53135 Old 03-27-2015, 08:57 AM
cesar123's Avatar
Quoted: 390 Post(s)
Liked: 579
Have you measured your response with the EQ1 Cesar?
Yes, I did. I have a mac at home but used my work computer over the weekend to set it all up. Didn't have a chance to actually save the graphs, but I believe I ran the whole calibration process three times, and ended up running my sub hot with the last one.
Didn't have that much time, but remember using REW and being very satisfied with my graph - but my ears didn't like it that much. Hence, my thought about me getting used to "clean" bass?
Who knows, man. I am, indeed, enjoying the system a lot more. And when I add a second sub (and going through those shenanigans again), I'm sure it'll improve things. I want to know what everybody talks about with duals and stuff...
Yippee-ki-yay...
cesar123 is offline
post #18057 of 53135 Old 03-27-2015, 09:12 AM
Alan P's Avatar
Liked: 6023
When you implemented the EQ1, did your overall SPL from the sub drop?
With a flat response, most folks like to bump up the sub trim a few db to bring the whole bottom end back up, essentially creating a "house curve".
Alan P is offline
post #18058 of 53135 Old 03-27-2015, 11:30 AM
bwilberg266's Avatar
Quoted: 33 Post(s)
Liked: 55
This is going to make for a nice little work desk sub
Hopinater, jhughy2010 and Pawee like this.
Epson 8350 | Silver Ticket 100" 16:9 Fixed Screen | Marantz 6011 | Emotiva XPA-5 | Elan z660 x 2 | Energy RC-LCR x 3 FL/C/FR | Monoprice Alpha 8" In Wall SLB/SRB | Monoprice Alpha 8" In Ceiling SL/SR |Monoprice Caliber 6.5" x 4 In Ceiling Atmos | PSA S3000i | SVS PB12 Ultra | Apple TV | miniDSP | Samsung K8500 | Synology DS213j Media Server
bwilberg266 is offline
post #18059 of 53135 Old 03-27-2015, 11:40 AM
nalthien's Avatar
Quoted: 485 Post(s)
Liked: 538
Well, well! That looks like our first s3000i action shot. Congrats!
bwilberg266 likes this.
Ordered: VPI Prime
nalthien is offline
post #18060 of 53135 Old 03-27-2015, 11:53 AM
jhughy2010's Avatar
Quoted: 906 Post(s)
Liked: 288
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , Power Sound Audio , Power Sound Audio Triax , Room Equilizer Wizard Rew , s7201 , tv36 , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
