Official Power Sound Audio Subwoofer Thread - Page 825 - AVS Forum | Home Theater Discussions And Reviews
 63670Likes
post #24721 of 51950 Old 01-03-2016, 07:58 PM
jbrown15's Avatar
Quoted: 2524 Post(s)
Liked: 1997
Originally Posted by k1n3t1k View Post
What size room at you working with and what are your listening habits like? I have the Antimode 8033S-II like you, running two subs and it was able to calibrate them pretty easily. To say I'm pleased is such an understatement! The Antimode dual core can apply a different correction per channel, which could yield better results, but like you said, it's a big level to jump and there's a good cost increase as well. "How much better could it be?" is a question I've asked even myself a thousand times.
Since you have a USB mic on the way already, I would do some measuring with REW first and see where you're at before laying down some more cash. I think most would agree with me when I say that two smaller subs (dual S1500) placed in good positions that are EQed well will have a better response and desired effect than a single bigger sub.
I believe Tom told me that the S3000i (1700W RMS) has a max of around 5700W peak, which places the 725W RMS around the 2400W peak mark when I run the numbers, but I'm sure he'll chime in shortly with exact numbers for you.
Travis
All of the amps are based on the 700watt and 1400watt ICEpower modules, there's several other sub manufactures also using them sourced from SpeakerPower. From what I understand SpeakerPower never likes to give peak output numbers, they base everything off of RMS.
jbrown15 is offline
post #24722 of 51950 Old 01-03-2016, 08:23 PM
k1n3t1k's Avatar
Quoted: 228 Post(s)
Liked: 437
Originally Posted by ceh383 View Post
It's not a big deal, I was just wondering if would be in the same ballpark as my SVS...By your numbers, it is
Oh my - I would not compare numbers like that, especially cross-vendor. It's just a number on the box; it has absolutely no bearing on what's inside or how it was calibrated, which is far more important than an insignificant number as that. That's like comparing 100W RMS from Sony to 100W RMS from Krell or Integra. Plus, there are many ways to take measurements, which is why watt ratings can be so misleading from vendor to vendor.
Oh for sure! I believe, Brian was it? at Speaker Power had posted something about power delivery output at all levels. I remember a detailed post a few months ago - I think Tom may have even written it. But yes, you are definitely correct as I wrote above, there are many, many factors that are involved and was just trying to give an estimation!
Sorry for any confusion.
Travis
k1n3t1k is offline
post #24723 of 51950 Old 01-03-2016, 08:56 PM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
True, but we're not talking Sony here either. Both PSA and SVS show FR graphs, both PSA and SVS give RMS power levels, but then SVS shows peak power and PSA shows SPL levels. We have two quality subs that show different data on their sites, given the similar RMS and FR specs, I was wondering if SPL would be close. If peak power is similar, they should be...But the PSA is a 15" where the SVS is a 12".
Just trying to occupy my brain until I get the PSA here to test and compare...
Yamaha RX-A2060 | Outlaw M-2200 (x5) | Oppo UDP-203 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | Amber In-ceiling | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #24724 of 51950 Old 01-03-2016, 09:16 PM
jbrown15's Avatar
Liked: 1997
PSA is using a much better amp than what SVS is using. It's one of the best sub plate amps on the market and it's the same reason why other great ID companies such as JTR, Seaton Sound and Reaction Audio are also using them.
jbrown15 is offline
post #24725 of 51950 Old 01-03-2016, 09:45 PM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9200
to get a idea of all level comparison...go to www.data-bass.com/systems. refer to the PB13 sealed mode, subtract 3db. Now go to the PSA XS15se and add 1db. That should get you close.
oneeyeblind and ahblaza like this.
basshead81 is offline
post #24726 of 51950 Old 01-04-2016, 06:33 AM
Hopinater's Avatar
Quoted: 3441 Post(s)
Liked: 10585
That's what I was going to mention. The amps used by PSA and SVS amp are not an apples to apples comparison. The Speaker Power amps used by PSA are on a different level (meaning much better) compared to the amps used by SVS. And if that fact was ever in question all one has to do is take a look around and see who else is implementing the use of Speaker Power amps in their line up.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is online now
post #24727 of 51950 Old 01-04-2016, 06:47 AM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
Good information, thanks for it!
Looking at the data-bass numbers, it seems as the PSA will push slightly more SPL than the SVS does. I think they may actually play well together. Hopefully it will show up this week so I can play this weekend
ceh383 is offline
post #24728 of 51950 Old 01-04-2016, 06:51 AM
smurraybhm's Avatar
Quoted: 2304 Post(s)
Liked: 3155
They will play well together with a little tweaking, but I promise you that once you hear the difference the PSA sub makes you will wonder why you bought the SVS sub - I speak from experience
No comparison in the output department, Tom has come up with products that kick his former company's xxx.
ahblaza likes this.
There is no perfect display, quit looking for faults and enjoy
LG OLED 65” B7 and 55” C8
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 and other stuff
smurraybhm is offline
post #24729 of 51950 Old 01-04-2016, 07:06 AM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9200
The SVS subs still sound really good imo. However, The PSA stuff definitely offers better performance for the dollar. I think CEH383 will find that both subs will work well together. If not I am sure he can sell the Plus for another S1500 .
post #24730 of 51950 Old 01-04-2016, 08:19 AM
dabrick7's Avatar
Quoted: 21 Post(s)
Liked: 31
Have time to play as their was an issue at work today. Forgot how much I like doing this.
Initial measurements with the AntiMode:
Red - Naked
Green - Flat
Blue - Lift25
Purple - Lift35
dabrick7 is offline
post #24731 of 51950 Old 01-04-2016, 09:10 AM
k1n3t1k's Avatar
Quoted: 228 Post(s)
Liked: 437
Red - Naked
Green - Flat
Blue - Lift25
Purple - Lift35
Green is looking good! Don't forget to tweak the sub distance to mesh the 80Hz crossover point null with your speakers.
Travis
k1n3t1k is offline
post #24732 of 51950 Old 01-04-2016, 11:32 AM
Alan P's Avatar
Quoted: 6297 Post(s)
Liked: 5627
Today I placed an order for a S1500 to pair with my SVS PC12Plus(I run it in sealed mode).
I hope I can get them to play well together. I have only one place I can put the new sub, and it's going to be a bit of work to get it going.
I plan on putting in in the hole above the closet...
I demand that you have someone take video when you try to lift the S1500 into that cubby hole, then post it here. I really hope you got a couple very strong (and tall) friends!
BTW, I hope the sub sounds good once you get it up there....cause you ain't gonna want to take it down again if it doesn't.
Mike Butny and ahblaza like this.
Alan P is offline
post #24733 of 51950 Old 01-04-2016, 12:28 PM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
Well, at the listed weight of 63lbs, it shouldn't be that hard to get up there
ceh383 is offline
post #24734 of 51950 Old 01-04-2016, 12:29 PM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9200
I could toss it right up there like a atlas stone...might not look so good afterwards!
post #24735 of 51950 Old 01-04-2016, 01:30 PM
Alan P's Avatar
Liked: 5627
Ahhh...didn't realize the S1500 was such a light-weight. I'm used to PSA subs being much heavier.
My CC only weighs 55lbs and it was no picnic getting that on the shelf above my TV....I was alone though.
Alan P is offline
post #24736 of 51950 Old 01-04-2016, 01:58 PM
dabrick7's Avatar
Quoted: 21 Post(s)
Liked: 31
Switched to a Windows laptop and I have a quick REW question; how do I measure CC+subs? I need it spelled out, because I couldn't figure out which pull down menu is 3 and which is 4.
Or if that is even right?
Tried a search but there's way too many posts to wade through.
dabrick7 is offline
post #24737 of 51950 Old 01-04-2016, 02:19 PM
k1n3t1k's Avatar
Quoted: 228 Post(s)
Liked: 437
Taken from: https://www.minidsp.com/applications...dmi-on-windows
o check all channels, change the Output drop-down selector in the REW Preferences window. (You can leave the Preferences window open to make output channel selection easier.) Here is a typical mapping of HDMI channel numbers:
  • Channel 1: Front Left
  • Channel 2: Front Right
  • Channel 3: Center
  • Channel 4: Subwoofer
  • Channel 5: Surround Left
  • Channel 6: Surround Right
  • Channel 7: Surround Back Left
  • Channel 8: Surround Back Right
Good luck!
Travis
Alan P and ahblaza like this.
k1n3t1k is offline
post #24738 of 51950 Old 01-04-2016, 03:11 PM
Alan P's Avatar
Liked: 5627
While Travis was kind enough to tell you which HDMI channel is which, you only need to output to CH3 (CC) with bass management on (CC set to "small") to measure CC+subs. Do NOT select CH3 in the Output dropdown and CH4 in the Timing Reference Output dropdown.
The Timing Reference Output dropdown is where you would select your second output channel....I know, not very intuitive...but if you select the subwoofer channel here (really the LFE channel) your sub(s) will be outputting 10dB higher than the CC.
ahblaza likes this.
Alan P is offline
post #24739 of 51950 Old 01-04-2016, 03:11 PM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
The weight was a huge consideration when picking this sub, I figured 75 ~ 80lbs would be the max weight as I will more than likely will have to do it myself.
ceh383 is offline
post #24740 of 51950 Old 01-04-2016, 04:59 PM
dabrick7's Avatar
Quoted: 21 Post(s)
Liked: 31
Okay, that makes sense. I imagine its the same for all speakers and to measure each individually, I'd just switch the subs off.
Thank you and Travis for the help.
dabrick7 is offline
post #24741 of 51950 Old 01-04-2016, 05:37 PM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9200
Hey CEH, do you shoot trap? I was just looking at your avatar and noticed that it looks like you are at a range.
post #24742 of 51950 Old 01-04-2016, 05:56 PM
Hopinater's Avatar
Liked: 10585
LOL…spoken like someone 6' 8" tall. Only someone that tall can say they could put that up there like an Atlas stone.
I'm 5'10''… I guess I could throw it up there but there's NO DOUBT that the sub wouldn't look so good afterwards.
basshead81 likes this.
post #24743 of 51950 Old 01-04-2016, 06:34 PM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
Not to much, I mainly shoot Skeet and Sporting Clays...The avatar is from a Skeet tournament...
ceh383 is offline
post #24744 of 51950 Old 01-04-2016, 07:28 PM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9200
ahh ok cool. I shoot Trap 2 nights a week. Also sporting clays from time to time.
post #24745 of 51950 Old 01-04-2016, 07:45 PM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
So, there's someone else like me with 2 money sucking hobbies I find it to be a great stress reliever, and a lot of fun
basshead81 and k1n3t1k like this.
ceh383 is offline
post #24746 of 51950 Old 01-04-2016, 08:57 PM
climber07's Avatar
Quoted: 804 Post(s)
Liked: 2594
Yeah, ammo isn't cheap and I'm too lazy to reload...
Power Sound Audio S7201 Quad 18" 4000W Sealed Subwoofer - Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Epson 5030UB Projector - Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - - XBox One S - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #24747 of 51950 Old 01-04-2016, 09:03 PM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
When talking 12 and 20ga, there's not much savings in reloading. Now if you are talking 28 & .410, it's a different story...
And now back to subs...
I've got everything I need for the install on order or waiting for me at the local hardware store. Everything should be here on Friday, including the sub. Looking forward to getting it all set up
ceh383 is offline
post #24748 of 51950 Old 01-04-2016, 09:13 PM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9200
Yep..It's a blast!!
post #24749 of 51950 Old 01-05-2016, 06:54 AM
k1n3t1k's Avatar
Quoted: 228 Post(s)
Liked: 437
TWO money sucking hobbies?!?! I wish it was just two! Please, try RC cars, quads, and helicopters, photography (Canon 300mm F2.8L IS and Canon 400mm F/2.8L IS and 1-series bodies anyone?), audio/video, and guns. I also like cars, but I don't have enough time, cash flow, and large enough garage to be truly serious about them. Thankfully! Why can't I enjoy something less expensive, such as knitting or being quick with a Rubick's cube?
/sigh
climber07, you're not kidding about reloading! That also takes a ton of time and a moderate amount of trial and error, despite reload specs from a book, since not all guns like the same mixture of ingredients. Then you have to use a chronometer to verify your speeds to make sure you're not too hot, listening to a tumbler in your basement for 2 days at a time. Bleh! Unless you have your class 3 FFL and emptying hundreds or thousands of rounds a time, it's not worth it for most. At least, in my experience. But reloads can be more accurate if you're that good or using a lead sled.
Back on the topics of subwoofers, ceh383,what are you going to use to run power and signal up to the sub? Dayton wireless RCA kit? Is power already up in your cubby?
Travis
k1n3t1k is offline
post #24750 of 51950 Old 01-05-2016, 07:03 AM
ceh383's Avatar
Quoted: 531 Post(s)
Liked: 3329
Travis
There's a power outlet next to the closet, so I'll replace the subs power cord with a 12' cord and that should be good. For signal, I'm going to make one out of RG-6U like I did for the other sub, I'm on a raised foundation so running it will be easy...but dirty
ceh383 is offline
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , Power Sound Audio , Power Sound Audio Triax , psa , Room Equilizer Wizard Rew , s3000i , s7201 , tv36 , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
