Official Power Sound Audio Subwoofer Thread - Page 917 - AVS Forum | Home Theater Discussions And Reviews
 61945Likes
post #27481 of 51212 Old 07-15-2016, 07:49 AM
Sekosche's Avatar
Quoted: 1417 Post(s)
Liked: 3570
Am I boosted too much below 50Hz or is my response too low from 50-100Hz, and what's the best way to tell, SPL meter and test tones? I tested a few frequencies below 50Hz and from 60 and up and there does seems to be a 3-6dB increase below 50 at my MLP. I might get around to playing with a miniDSP in the next few weeks to pull down some of those peaks, although I do like a slight house curve. I tried the Audyssey Room Size tweak on the V1800's, setting them to medium/50% before calibrating, and then back to large after. There's not a substantial difference, but that may be my 3rd sub that wasn't attenuated throwing it off...come to think of it, the cylider does have a room gain adjustment on it too, doh. Perhaps the room size needed to be set even smaller. Happy Friday!
Scott
Sekosche is online now
post #27482 of 51212 Old 07-15-2016, 12:44 PM
zeus33's Avatar
Quoted: 1794 Post(s)
Liked: 1802
Originally Posted by Hakka View Post
No, i got the unbalanced, the balanced one would have been a better fit.
Yep. The unbalanced version is limited to 0.9 volts. The balanced is 4 volts. Some have even measured higher.
zeus33 is offline
post #27483 of 51212 Old 07-15-2016, 02:05 PM
Greg Samples's Avatar
Quoted: 27 Post(s)
Liked: 48
LOL well my early birthday present arrived this afternoon so I am trying to get it dialed in and setup. Plays way deeper bass than my old Pardigm PW 2200. Exactly what I was looking for. Of course going from a 12" sub to an 18" sub should be quite a difference.
Sent from my SM-G935T using Tapatalk
Greg Samples is offline
post #27484 of 51212 Old 07-15-2016, 03:10 PM
Hopinater's Avatar
Quoted: 3390 Post(s)
Liked: 10304
Originally Posted by Cal68 View Post
I took a very preliminary reading using REW after I calibrated the system with Audyssey, and the new sub definitely filled in a huge dip that I was seeing in the 25Hz range and another smaller dip in the 80Hz range. But I still have a dip at the 150Hz range and the curve did not look flat at all. Because the V3600i is such a huge monster(), there are not many choices as to where it can be placed in my HT. But I'll try a couple of different locations and see what readings I get on REW.
I plan to fire it up this evening and watch a few "bass heavy" movies. I'm looking forward to being blown away!
What are you crossing over at? The 150 Hz range is a bit high up on the scale to be your subs. That sounds more like your speakers are experiencing some room issues.
Congrats on your new subwoofer, have fun dialing it in.
ahblaza and Oledurt like this.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
post #27485 of 51212 Old 07-15-2016, 04:42 PM
Cal68's Avatar
Quoted: 346 Post(s)
Liked: 341
My V3600i arrived last week and the first reaction I had was that it is huge! In fact my family were wondering whether I had bought another set of floor standing speakers instead of just one sub! I was glad that my sister and family were visiting me over the weekend because I got my nephew to help me unpack the sub and get it into place. It would have been tough for me to do that by myself. However, because I had to play host over the weekend, I could not get it hooked up and calibrated until yesterday evening. I took a very preliminary reading using REW after I calibrated the system with Audyssey, and the new sub definitely filled in a huge dip that I was seeing in the 25Hz range and another smaller dip in the 80Hz range. But I still have a dip at the 150Hz range and the curve did not look flat at all. Because the V3600i is such a huge monster(), there are not many choices as to where it can be placed in my HT. But I'll try a couple of different locations and see what readings I get on REW.
Originally Posted by lizrussspike View Post
Cal68,
You will be blown away, as once I received the V3600, I watched movies over again that I had watched before, knowing that I was going to be amazed with the new addition. Enjoy your sub and all the benefits it brings to you in your home.!
Thanks guys. Just getting ready to go downstairs and watch a few movies tonight. Will post my impressions tomorrow.
Cal68
Cal68 is offline
post #27486 of 51212 Old 07-15-2016, 04:50 PM
Cal68's Avatar
Quoted: 346 Post(s)
Liked: 341
I am crossing over at 80 Hz and all my speakers are set as "Small". Audyssey set all my speakers as "Large" and set the crossover at 40 Hz. I changed them to be "Small" and the crossover to be 80Hz. I hope that I did the right thing.
Cal68
Cal68 is offline
post #27487 of 51212 Old 07-15-2016, 05:14 PM
Hopinater's Avatar
Liked: 10304
Yep that's exactly what is usually recommended to do.
If that's the case that dip at 150 Hz isn't the subs, it's your speakers and how they are interacting with the room and it's fairly common to see dips like that. When you get a chance post a shot of your REW graph so the guys here can give you some feedback.
post #27488 of 51212 Old 07-15-2016, 06:28 PM
ahblaza's Avatar
Quoted: 2458 Post(s)
Liked: 3397
That's the general settings to use, as Hop said it may be room induced from your speakers, try a 1 meter close mic sweep of your left and right speakers and post the graphs, use the 0 degree cal file and see what you get. Make sure you put the mic at the same distance from each speaker, this will give you a good idea what's happening before the sound reaches your LP.
ahblaza is offline
post #27489 of 51212 Old 07-15-2016, 06:39 PM
Oledurt's Avatar
Quoted: 437 Post(s)
Liked: 571
try to pull the sub out from wall 6 inches see what happens
Oledurt is offline
post #27490 of 51212 Old 07-15-2016, 07:11 PM
ahblaza's Avatar
Liked: 3397
I just wanted to comment on the movie Allegiance or whatever it's called, that movie has some moments of serious LFE going on, my V1800s which are on carpet over concrete sent such tactile force waves through the floor from the bottom of my feet and slammed me in the chest. I never really opened the 1800s up till last night as I haven't been doing much movie or music listening as of late and the 1800s on the carpet/concrete made a real impression on me. I believe the V1800 is the perfect sub for most situations and is the diamond in the rough which says a lot for the V3600, I think one of those may be in order as a very high end table....
ahblaza is offline
post #27491 of 51212 Old 07-15-2016, 07:22 PM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 582
congrats on the new v3600. it's a beast for sure. it's funny how you can get the measurements, imagine it with a tape measure and think you know the size. then you see it in real life and go, "oh, sh**........this is AWESOME! " i thought for sure i had a grasp of its size and wouldn't be surprised, but nope. and one thing that just doesn't get pointed out quite enough around here is how articulate the v3600 is. sure, it can pound the windows out of their frames and crack your foundation with the pod emergence scene, but when you experience how quick and accurate it hits with more subtle music and movie effects....well, that's where it impressed me quite a bit. don't get me wrong, i love the boom, but it's all the other subtle things it does that make it such a special behemoth.
ahblaza, Oledurt, Cal68 and 2 others like this.
digler84 is offline
post #27492 of 51212 Old 07-15-2016, 07:34 PM
Marc Alexander's Avatar
Quoted: 5347 Post(s)
Liked: 4845
Just moving your mains a foot in or out from the walls can make all the difference. My owner's manual advises a minimum of 3' of distance from any wall. Every speaker and room are different. Start with the manufacturer's recommendations then tweak from there.
Sent from my SM-G935V using Tapatalk
Marc Alexander is online now
post #27493 of 51212 Old 07-16-2016, 12:33 AM
shepdog's Avatar
Quoted: 125 Post(s)
Liked: 142
Originally Posted by zeuspaul View Post
There are plenty of budget subs on the market. PSA can't be all things to all people. Let someone else make $700 subs.
I have to sell my audio purchases to my wife and she understands Made in America and not much else when it comes to audio components. PSA is quality from beginning to end and you have to expect to pay a little more for that. My JBL towers of five years ago arrived in flimsy packaging. One of the plastic grill pins was broken and it still bothers me today. PSA components arrive in second to none thick cardboard packaging well protected with foam inserts. There would have to be serious mishandling to damage them in shipping. And that is just the beginning. Pull the grill and you will find steel pins instead of plastic. And best of all they sound great.
My vote is to stick with uncompromised quality made in USA including the cabinets.
I'm a new proud owner of S1500 and the made in America was the final nail that allowed me to pull the trigger.
shepdog is offline
post #27494 of 51212 Old 07-16-2016, 06:44 AM
lizrussspike's Avatar
Quoted: 1138 Post(s)
Liked: 1685
Well said digler84!
Oledurt likes this.
lizrussspike is offline
post #27495 of 51212 Old 07-16-2016, 01:54 PM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 582
thanks man. i just think so many people get caught up in graphs and tech specs rather than what the sub actually sounds like. it's hard enough to put into words how good the v3600 is, let alone trying to express finess and high quality sound as a max output spec on some spreadsheet. if it were all about max output, there is no doubt in my mind that tom and jim could produce that in spades. they are much more concerned about quality sound from top to bottom and that is what they have achieved. after all, they did name the company power SOUND audio, not power MAX OUTPUT audio.
ahblaza, Oledurt, gbreda and 2 others like this.
digler84 is offline
post #27496 of 51212 Old 07-16-2016, 05:43 PM
newc33's Avatar
Quoted: 1173 Post(s)
Liked: 1779
Hey guys I have an intresting announcement to bring to the table.
I just ordered 2 3600is that are expected to be here Thursday.
Can anyone say 3600 vs g21 throw down?
Looking forward to it!
Sent from my SAMSUNG-SM-G920A using Tapatalk
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s rear surround
Quad PSA T18s!!!!!!
Funk audio 12.2 HP mains powered by/funk audio 6x500 watt amp
newc33 is offline
post #27497 of 51212 Old 07-16-2016, 06:08 PM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 582
see, this thread does have some sort of mystical voodoo that causes one to order expensive audio equipment. it also causes you to keep upgrading until you can upgrade no further....newc33 is just the latest victim. see guys....there's just no stopping it and we were doomed from day 1. i suddenly feel compelled to save no further and just go purchase a second v3600...right.....now!
ahblaza, Oledurt, gbreda and 1 others like this.
digler84 is offline
post #27498 of 51212 Old 07-16-2016, 06:21 PM
newc33's Avatar
Liked: 1779
Do it! I would
denon x4100
Quad PSA T18s!!!!!!
newc33 is offline
post #27499 of 51212 Old 07-16-2016, 06:43 PM
Quoted: 27 Post(s)
Liked: 48
LOL this thread made me order a V1800. It was originally a v15 but I have been following it for a year or so now. LOL I though a 15 would be too small after reading all this time.
post #27500 of 51212 Old 07-16-2016, 06:56 PM
ahblaza's Avatar
Liked: 3397
Wait till you get the second......
Kevin Grimm likes this.
ahblaza is offline
post #27501 of 51212 Old 07-16-2016, 07:01 PM
Quoted: 27 Post(s)
Liked: 48
Yeah it's in the plans before this time next year so I can still get the discount.
ahblaza likes this.
post #27502 of 51212 Old 07-16-2016, 07:04 PM
ahblaza's Avatar
Liked: 3397
Congrats on the purchase, you'll have tracking Monday and delivery Thursday, that in it itself should be a rewarding experience for you, I think it will be a real throw down..........
Have you ever seen the build quality of a PSA subwoofer, I think you're going to be very impressed before you even plug it in, that's about all the break in time it will need.......
Congrats again...
Hopinater likes this.
ahblaza is offline
post #27503 of 51212 Old 07-16-2016, 07:20 PM
newc33's Avatar
Liked: 1779
Congrats again...
I haven't seen the build quality of Psa in person no. I'm sure it is of top notch material and crafmanship.
So far I'd say my jtrs are the most solid built while RA has the most appealing looks and finish.
denon x4100
Quad PSA T18s!!!!!!
newc33 is offline
post #27504 of 51212 Old 07-16-2016, 07:22 PM
newc33's Avatar
Liked: 1779
Basically it should be close. I believe the cone area of dual 18s is approximately 24 inches if I am correct. The gamma subjectively has the better amp with more power on tap. Beefier driver for the RA but only one of them.... Should be good...
denon x4100
Quad PSA T18s!!!!!!
newc33 is offline
post #27505 of 51212 Old 07-16-2016, 07:27 PM
ahblaza's Avatar
Liked: 3397
I'm glad to hear you like the RA finish as I thought that was one of the main complaints, faded and uneven finish, I'm not trying to be smart seriously, I just read many posts about the finish of the subs.
ahblaza is offline
post #27506 of 51212 Old 07-16-2016, 07:31 PM
newc33's Avatar
Liked: 1779
Ya I'm really suprised about that. Unless it was a cosmetic flaw I can't belive someone would feel that way.
But hey to each there own...
denon x4100
Quad PSA T18s!!!!!!
newc33 is offline
post #27507 of 51212 Old 07-16-2016, 07:33 PM
ahblaza's Avatar
Liked: 3397
I don't want to sound forward or anything but I don't think it's going to be that close of a throw down just because the driver is "beefier" and has more power on tap, I'll leave you to your own conclusions........have fun.
ahblaza is offline
post #27508 of 51212 Old 07-16-2016, 08:03 PM
newc33's Avatar
Liked: 1779
No I'm not choosing sides at all. You may be right. I'm just glad I have the opportunity two play around with both of them. It's gonna be fun and that's all that matters...
ahblaza and dashpuppy like this.
denon x4100
Quad PSA T18s!!!!!!
newc33 is offline
post #27509 of 51212 Old 07-16-2016, 08:32 PM
Liked: 4845
What's the ultimate plan? Run all 4 together? Sell/return the loser? Return the PSAs if its a wash?
post #27510 of 51212 Old 07-16-2016, 08:39 PM
Oledurt's Avatar
Quoted: 437 Post(s)
Liked: 571
if you do we can be sub brothers
Oledurt is offline
chuffitychuffchuff , chuffmaster , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , hr chuff'n'stuff , Power Sound Audio , Power Sound Audio Triax , psa , Room Equilizer Wizard Rew , s3000i , s7201 , tv36 , v1500 , V1800 , v1801 , V3600i , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Xs30 , Xv15
