Speaker Wire to RCA? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By flyng_fool
  • 1 Post By piening2150
  • 1 Post By bobknavs
post #1 of 5 Old 02-18-2012, 11:05 AM - Thread Starter
sdalton37's Avatar
So I've been looking around a bit and it looks like this typically is not a good idea as an RCA is a line level and speaker wire is not and a couple of other reasons. Well, I have an older (8 years) Sony SS-WS12 that was a part of the Sony DAV-FR1 that I want to hook up to a newer receiver that does not have a speaker wire input for the sub, but only the RCA type connector. Any way I can continue to use this subwoofer?
The speaker wire from the sub is actually hardwired to the sub and it has 4 wires that went into two connectors in the previous system. Do I need to get a new sub, or can I do some homebrewed solution? I'd rather the latter as I don't really want to buy a new sub when the old one works fine. Experts, I am asking you, am I screwed?
sdalton37 is offline
post #2 of 5 Old 02-18-2012, 11:14 AM
flyng_fool's Avatar
Quoted: 190 Post(s)
Liked: 173
The sub is passive. It means that it doesn't have it's own dedicated amplifier. If you tried to do as you suggested, you would get nothing. The rca out on your receiver is only a line level signal with no power. If you got an amp to place between the receiver and your sub it would work but money wise and performance wise you're probably better off buying a new sub.
scottiemon likes this.
Television: Vizio E70iA3
Processor: Emotiva MC700
Surrounds: AT 2200 LR Sub: Danley DTS-10Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #3 of 5 Old 02-18-2012, 11:53 AM
piening2150's Avatar
^^^^ this.
Time for a new sub.
piening2150 is offline
post #4 of 5 Old 06-29-2020, 04:09 AM
Liked: 0
Did you find a solution?
Hi. I also have the SS-WS12. I understand from Sony that it is an active speaker, so I assume that 2 of the 4 wires is for power and the other 2 are for speaker(s). I wondered if you had found out which wire was for what ? Thanks
Andrew Nicholls is offline
post #5 of 5 Old 06-29-2020, 11:15 AM
bobknavs's Avatar
Quoted: 2891 Post(s)
Liked: 2092
It's a passive sub. It has two drivers, each of which has its own connection. https://www.manualscenter.com/manual...l#.XvovVF-SkuV
I doubt that it'd be worth the trouble of getting it to operate with an external amplifier.
bobknavs is offline
