The "Official" Crowson Tactile Motion Actuators Thread. - Page 39 - AVS Forum | Home Theater Discussions And Reviews
 1461Likes
post #1141 of 2451 Old 10-23-2017, 09:07 AM
Sekosche's Avatar
Quoted: 1439 Post(s)
Liked: 3634
Originally Posted by Alan P View Post
Finally found my order for those feet I used for the plywood platform experiment:
ButtKicker RI-4-PAK Medium Kinetic Furniture Isolators Set of 5
Will these work with the MAs or do I need to order the ones from Crowson??
Use those, the Crowson sorbothane feet are 10 times the price. I'm using some harder cheap penn elcom feet I got from PE also. Sorbothane feet are great for decoupling, but I keep seeing reports of them disintegrating after heavy use within a year or less so that's a little worrisome, probably a YMMV type of thing.
Alan P likes this.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is offline
post #1142 of 2451 Old 10-23-2017, 09:08 AM
Alan P's Avatar
Quoted: 6367 Post(s)
Liked: 5689
Originally Posted by Sekosche View Post
Woot, halfway there! That's basically it. RCA Y splitter from LFE then an RCA to XLR adapter going into the amp (or two depending on setup). I use a cheap pair of neutrik/speakon cables out that terminates into bare wires from the amp to the subs.
I have no idea what a "neutrik/speakon" cable is.
I've got an RCA>XLR adapter for the amp input, but can someone link me to the cable they are using between the amp and MA please? Sorry, I'm such a needy hand-holder...
Alan P is offline
post #1143 of 2451 Old 10-23-2017, 01:32 PM
Hopinater's Avatar
Quoted: 3506 Post(s)
Liked: 10886
Alan, when you order a single Crowson I believe they will send three of their feet with it. that should be enough. But if you do need more feet then the Buttkicker feet work fine (that's what I'm using for my extra feet).
I'll send you a link for the Speakon connectors.
The cable going from the amp to the Crowsons is simply speaker wire. I'm using 14 gauge.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
post #1144 of 2451 Old 10-23-2017, 02:22 PM
Alan P's Avatar
Liked: 5689
Hmmm...do you think they would give me a discount if I don't need the feet the provide??
Thanks for the links!
Carp! I gotta go check when I get home...I don't think I have ANY speaker wire! Weird for me not to, but I think I gave all I had left to a buddy who was wiring up surrounds.
Alan P is offline
post #1145 of 2451 Old 10-23-2017, 02:50 PM
Hopinater's Avatar
Liked: 10886
FWIW I think the Crowsons feet are much better.
post #1146 of 2451 Old 10-23-2017, 03:09 PM
Alan P's Avatar
Liked: 5689
You've used both? Can you tell me why you think they are better??
Alan P is offline
post #1147 of 2451 Old 10-24-2017, 06:35 AM
Hopinater's Avatar
Liked: 10886
To me they feel like they have a little more movement in them. But I could be wrong and it certainly isn't a huge difference IMO. And I'm still in the experimenting phase so keep that in mind as well, I may change my mind in a few weeks... who knows.
post #1148 of 2451 Old 10-24-2017, 06:36 AM
coolrda's Avatar
Quoted: 1391 Post(s)
Liked: 1506
I actually noticed a slight decrease in TR afterwards, the opposite of most peoples experience. Regardless, now I am ready for the Crowson(s).
And you should have. The fact that it feels that way is correct. When you place isolators on seating your decoupling. That takes away from acoustic coupled TR but increases direct coupled TR which is what you'll have. Lose a little but gain a lot.
Are you using the sorbothane feet from Crowson? Do you have links to the hard rubber and cork stand offs that you mentioned?
I was using those feet. I'm using these now. Penn Elcom 9106 Feet
coolrda is offline
post #1149 of 2451 Old 10-24-2017, 10:05 PM
Sekosche's Avatar
Liked: 3634
Those are the feet I use too, and I think a more firm base helps transmit the direct TR from the Crowson more accurately...maybe I'm wrong, but I love the results. I can see how softer isolation feet would also work well in other situations.
Sekosche is offline
post #1150 of 2451 Old 10-25-2017, 03:14 AM
H Stevens's Avatar
Quoted: 171 Post(s)
Liked: 122
I went from the original rubber feet like the Penn Elcom's to the sorbethane and back to the rubber.
After approximately one year of using the sorbethane, I noticed the sorbethane was tearing which I believed was caused by the opening and closing of the recliner. It appears that the movement of the chair during the reclining and closing motion caused the upper and lower disc of the sorbethane isolator to tear into the sorbethane.
The stiffer rubber feet provide better performance to me, the action is more jarring and abrupt and it appears faster. The sorbethane appear to perform best with very low frequencies and slow motion which enable the chair to quiver and swim a little. Overall, I feel the stiffer rubber feet are preferred for the majority of the action especially if you choose a higher crossover for the transducers.
VideoGrabber, coolrda and Sekosche like this.
H Stevens is offline
post #1151 of 2451 Old 10-27-2017, 10:38 AM
Alan P's Avatar
Liked: 5689
Where are you guys mounting the amp? Since I will be splitting the signal from one of my rear subs to feed it, I was thinking somewhere in the back of the room (under the chair even?). But, I could just as easily split off of one of the front subs, put the amp in the equipment rack (really just a TV stand) and run speaker wire the 35' or so to the MA.
What say you?
Alan P is offline
post #1152 of 2451 Old 10-27-2017, 01:25 PM
coolrda's Avatar
Liked: 1506
What say you?
Mines rack mounted.
coolrda is offline
post #1153 of 2451 Old 10-27-2017, 02:44 PM
Alan P's Avatar
Liked: 5689
Do the iNukes tend to run hot, or are they relatively cool running units? Asking because my available rack space is a bit tight, but could add a couple cooling fans if need be.
Alan P is offline
post #1154 of 2451 Old 10-27-2017, 02:58 PM
Nalleh's Avatar
Quoted: 2569 Post(s)
Liked: 3458
Inukes are PA amps, so they are ment to be stacked. They have cooling fans in the rear blowing to the front.
The fans are noisy however, so if used in same room, they need a fan mod.
Alan P likes this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is offline
post #1155 of 2451 Old 10-28-2017, 11:26 PM
MassiveG's Avatar
Quoted: 36 Post(s)
Liked: 9
Question
So the 2 Crowsons came in a couple days ago and I'm terrible at setting these up!
I've got them wired properly to the iNuke 3000dsp amp and receiver, they seem to work okay? But I'm honestly kinda unimpressed. I'm sure that's due to my settings within the iNuke app...but what settings are you all using? If anyone could post screenshots of their equalizer graphs, db stuff. Anything really :P
I've tried messing around with it and I've gone from just a general constant vibrating happening all the time to what almost feels like I thought it would? I'm now getting somewhat punchy jolts with guns for instance but it's still hit or miss and feels sorta loose.
LG OLED65B7P | AVR-X6300H | 7.1.4 - Klipsch RF 7II, RC-64II, RS-62II, RP 260f, 4x CDT-5800-CII, JTR Cap 1400 | OPPO 203 | XB1X | PS4 Pro | PC (i9-7900x, 1080ti)
MassiveG is offline
post #1156 of 2451 Old 10-29-2017, 08:03 PM
FriscoDTM's Avatar
Quoted: 432 Post(s)
Liked: 391
I don't have my exact settings handy, but as a rough starter, turn the attenuator knobs on the front all the way clockwise so your AVR is sending the full signal to the amp. Give it a 3rd order BW low pass filter at 30-40Hz (gain=0) to eliminate the high frequency signals going to the transducers. Then if you listen at low volume, you can add DEQ so the amp automatically applies additional gain at low volume levels - as an example you can try a LP12 @ 20Hz, max gain, threshold = -50. That will amplify the low frequency signals at low volume and automatically turn it down as you raise the volume. You will need to adjust to suit your situation and taste but that should get you started.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #1157 of 2451 Old 10-29-2017, 09:31 PM
coolrda's Avatar
Liked: 1506
For starters you should run the Crowson flat with no eq.
coolrda is offline
post #1158 of 2451 Old 10-30-2017, 12:49 PM
ahmedreda's Avatar
Quoted: 363 Post(s)
Liked: 382
I started with an unequalized signal going to a minidsp 2x4. I had the best results by reducing the frequencies around 50 hertz by about 4 db and using a fairly wide Q so it gradually reduced the frequencies between 30 and 70hertz which were the most annoying with my seating. I like to keep the frequencies 80hz and higher on because they make the speech in movies more impactful. I would try youtube test tones between 10 and 100 hertz and see which ones are desirable with your seating and start from there.
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is offline
post #1159 of 2451 Old 10-30-2017, 02:06 PM
VideoGrabber's Avatar
Quoted: 522 Post(s)
Liked: 324
Why would you want that? (Just curious.)
VideoGrabber is offline
post #1160 of 2451 Old 10-31-2017, 10:38 AM
ahmedreda's Avatar
Quoted: 363 Post(s)
Liked: 382
Personal preference. Works well IMO at lower volumes and remember it is a very small range of frequencies under the center crossover.
My home theater
Display: JVC RS400
post #1161 of 2451 Old 11-03-2017, 03:55 PM
Hopinater's Avatar
Liked: 10886
I can confirm this. For convenience sake I split my Crowsons off my NF sub (Audyssey settings and all) and ran it like that for awhile. I really liked it a lot. But SBuger had mentioned he was running his off his OPPO sub out for a pure signal. Tonight I decided to do the same. WOW! Definitely a noticeable difference.
SBuger likes this.
post #1162 of 2451 Old 11-03-2017, 05:00 PM
Quoted: 522 Post(s)
Liked: 324
What do people do, who don't have an OPPO?
post #1163 of 2451 Old 11-03-2017, 11:29 PM
SBuger's Avatar
Quoted: 1249 Post(s)
Liked: 4037
Nice, I'm glad you tried it.
I've done both. I've mainly used the OPPO, then one of the AVR subouts for a while, and currently and for the last 6 months or so I'm back to the OPPO. I just prefer the OPPO after experimenting with it quite a bit. Pro's and Con's to both, but I think I ultimately liked the OPPO method better because it just feels cleaner and more detailed to me, even though I set it up real similar to the way coolrda does so that Audy didn't EQ it much at all and have all subs on one subout and the MAs/TT's on the other. It looked great in VS (combined great with subs), maybe a little better than using the OPPO (almost looks as good though), but just felt better subjectively. IDK, maybe I was doing something wrong and may try it again at some point, but for now I love the OPPO method and am very used to it.
If you don't want to use your AVR and don't have an OPPO, you just need a player with an Analog Subout, then go into speaker setup and set your crossovers and delays for bass management within the player. Intensity can be controlled with the volume control on the remote (set to variable on the OPPO, probably something similar with a different player).
My 'Blacked Out' Home Theater | Tactile Response for BASS | BassEQ for Filtered Movies
1400cuft Sealed Room on Suspended Floor | SY Triple Black Velvet Blackout | GIK Treatments | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | Epson 5040UB 4K | Eyes 6.5' to 120" AT Seymour Screen | Oppo 203 | Xbox One X | Apple TV 4K | 6x 18" Sealed DIY Subs | 6x Crowson MAs | 4x BK LFEs | BOSS 'Sub Riser' w/ 6x JBL-12s | MiniDSP 10x10HD
SBuger is offline
post #1164 of 2451 Old 11-04-2017, 03:49 PM
darrellh44's Avatar
Quoted: 1058 Post(s)
Liked: 517
What about the difference in delay between direct from the player vs the added processing delay through the AVR's sub outs? Admittedly we're talking about really low frequencies, but if the AVR's delay also includes additional delay for video lip sync, then we can be talking well over 100 msec of AVR delay. If the upper end of the TT is 40 Hz, then one cycle of that is only around 25 msec.
darrellh44's Home Theater
"Faith is not about everything turning out OK, Faith is being OK no matter how things turn out".
darrellh44 is offline
post #1165 of 2451 Old 11-04-2017, 04:55 PM
SBuger's Avatar
Liked: 4037
Yeah it can be kind of tricky, especially when throwing lip sync in there. I had to mess with delays for lip sync and time alignment with the subs from the AVR and MA's/TT's from the OPPO . VibSensor really helps with TA of the Crowsons and Subs. If its off, they can cancel each other out at certain frequencies kind of like two subs out of phase can (a little or a lot). If it's off a fair amount, it can really be felt subjectively. Craig John (thread starter) had a couple of good explanations somewhere around here on how to get the timing close for starters when using the OPPO.
SBuger is offline
post #1166 of 2451 Old 11-04-2017, 09:25 PM
darrellh44's Avatar
Liked: 517
Looks like you can compensate for quite a bit of delay if you're using an iNuke DSP to drive Crowsons. I just looked in my iNuke manual, and it shows you can add '100 m' of delay between speakers which I take to mean 100 meters, or more than 300 msec. It makes sense they can add this much delay since they're designed for outdoor concerts with large distances between speakers.
post #1167 of 2451 Old 11-05-2017, 06:07 AM
coolrda's Avatar
Liked: 1506
Yep. I know its been written that even TA thats 30ms off isn't an issue with subs such as front rear array. I can easily hear the difference that change in delay does to the magnitude response. But i guess its not terribly objectionable. I found though, that when it comes to TR, theres a considerable difference with 3ms, like huge, when the MA's are put in play. Even 1ms can be felt. I've found that to be the big problem guys are having with integrating the Crowsons in their system, far more so than having an EQ issue. It really does cancel/null your TR and robs one of performance. Thats why I run all subs off one channel after REQ and setup is done. While I can feel the difference, VS does back that up. Best way to describe it is when properly setup, ULF transients have a razor sharp, defined quality to them.
VideoGrabber and SBuger like this.
coolrda is offline
post #1168 of 2451 Old 11-05-2017, 06:39 AM
darrellh44's Avatar
Liked: 517
It would be nice if AVR manufacturers started giving us separate outputs for TTs vs subs. It seems very clusmy to get the optimal settings for both LF device types any other way. Another issue with using your BluRay player's output is you can't get the same TT optimizations for other sources without going thru another set of source switches into the TT path (and then having to remember to switch everything properly every time you change sources). I'm not looking to patent this idea, so any AVR manufacturers out there, please feel free.
SBuger likes this.
post #1169 of 2451 Old 11-05-2017, 06:50 AM
darrellh44's Avatar
Liked: 517
If they were still alive today, there's probably several famous French mathematicians that would agree whole-heartedly that phase is every bit as important as magnitude.
post #1170 of 2451 Old 11-05-2017, 08:15 AM
coolrda's Avatar
Liked: 1506
Yep. I think it was Not that has a preamp with 3 subouts so he has a dedicated output.
coolrda is offline
