URGENT - limited offer, Paradigm Servo 15 v1 faulty <$275 shipped? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-16-2013, 05:00 PM - Thread Starter
matt09's Avatar
Hi all,
Would really appreciate any input ASAP as to whether this is a good offer? I am struggling to find the value of this sub in a faulty condition and even in used working condition is quite difficult.
The fix sounds pretty simple, the amp is creating audable hum but works.
I am hoping to get the price down under $200, but either way is this a deal you would jump for?
matt09 is offline
post #2 of 16 Old 06-16-2013, 05:24 PM
eljaycanuck's Avatar
Quoted: 1857 Post(s)
Liked: 2610
IMO, a gently-used Servo-15v1 in working order should sell for ~$500. I wouldn't buy one that's faulty, but if I were to consider it, I wouldn't pay anywhere near $275 for it.
eljaycanuck is offline
post #3 of 16 Old 06-16-2013, 07:37 PM - Thread Starter
matt09's Avatar
Are they really worth so little, one just went here for $700
http://www.ebay.com/itm/Paradigm-Reference-Home-Theater-15-Powered-Subwoofer-Servo-15-/151060343281?pt=Speakers_Subwoofers&hash=item232be5e9f1&autorefresh=true
It's almost certainly a capacitor problem and should be quick, cheap and easy to fix. How much would people value one in such a condition to be?
matt09 is offline
post #4 of 16 Old 06-17-2013, 04:38 AM
Liked: 2610
Are they really worth so little ...
Maybe $600 for a minty-mint unit, maybe, but not more.
That one has a rosenut finish, which is usually (and probably also was) an extra-cost option, so the vendor is likely just trying to recover that additional cost.
post #5 of 16 Old 06-17-2013, 09:20 AM - Thread Starter
matt09's Avatar
Okay so if it doesn't sell within 1 week it is agreed I can have it for $170 shipped. Pretty sure that's a sweet deal now.
matt09 is offline
post #6 of 16 Old 06-17-2013, 10:02 AM
Liked: 2610
If you're sure the problem is one that is fixable for relatively little money, I agree that $170 (shipped) for that sub is a pretty good price.
post #7 of 16 Old 06-17-2013, 10:22 AM - Thread Starter
matt09's Avatar
Convinced the seller to sell now for $170. Thanks alot for the advice on lowering the price.
matt09 is offline
post #8 of 16 Old 06-17-2013, 10:30 AM
Liked: 2610
Cool. cool.gif Once you've got it fixed up and running, please post your thoughts on it. smile.gif
post #9 of 16 Old 06-18-2013, 05:17 AM - Thread Starter
matt09's Avatar
Cheers will do, came in even better in the end at just $155. Will be very interesting to see how it performs compared to my current sub, a 15" Ascendant audio driver in a 300L tube tuned to 15.5Hz.
matt09 is offline
post #10 of 16 Old 06-18-2013, 01:37 PM
Larry L's Avatar
You may have even better luck. The last hum I had with a sub was eliminated by lifting (removing) the safety ground on the power plug.
Larry L is offline
post #11 of 16 Old 06-18-2013, 07:18 PM
Bill Fitzmaurice's Avatar
Liked: 5768
You accomplish the same thing by lifting the ground at one end of the interconnect, except you don't raise the possibility of electrocution should there be an internal fault in the amp.
http://www.rane.com/note110.html
Bill Fitzmaurice is offline
post #12 of 16 Old 06-21-2013, 03:44 PM - Thread Starter
matt09's Avatar
Agreed NEVER disconnect the ground from a power plug or are asking for serious trouble.
matt09 is offline
post #13 of 16 Old 06-26-2013, 05:50 AM - Thread Starter
matt09's Avatar
Ok so this is an interesting one. The amplifier is now working but is not able to put out the 400W continuous power stated and is considerably far off at 270W. This is due to the undersized transformer which is only 420VA. I'm starting to wonder if it has been previously repaired with a smaller sized transformer but the toroid is a paradigm part. If anyone has any info or can confirm is this is the case I'd be grateful to hear as this is quite shocking Paradigm would exaggerate their rated power specs to such a degree.
matt09 is offline
post #14 of 16 Old 09-23-2013, 02:59 AM
Dougofthenorth's Avatar
Liked: 44
Whatever happened about this fix?
Dougofthenorth
www.turtleshelltortue.org RIP
Dougofthenorth is offline
post #15 of 16 Old 10-08-2013, 10:25 AM
dobyblue's Avatar
Quoted: 14 Post(s)
Yeah I'd be interested to know the end result too.
dobyblue is offline
post #16 of 16 Old 03-16-2014, 03:06 AM
Liked: 44
FYI
Mine was fixed by my sending the board to Paradigm in Toronto (in 2013)
They changed the capacitor on the board & the 240V fuse - cost $60
Boards are no longer available
Dougofthenorth
