Rythmik FV15HP or PC-13 Ultra - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #31 of 249 Old 10-17-2013, 12:36 PM
brian6751's Avatar
Quoted: 1672 Post(s)
Liked: 1648
Originally Posted by braveheart123 View Post
When you say PB13U had thicker sound compared to FV15HP; what were the settings on FV15HP amp? Where did you set the damping knob (High/Med/Low)?
the rythmik was usually in 12Hz tune with High damping so im sure that contributed to the sound
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is online now
post #32 of 249 Old 10-17-2013, 01:28 PM
basshead81's Avatar
Quoted: 310 Post(s)
Liked: 8734
well that's the difference...for home theatre Brian recommends the low damping setting to thicken the bass.
basshead81 is offline
post #33 of 249 Old 10-17-2013, 02:52 PM - Thread Starter
braveheart123's Avatar
Quoted: 337 Post(s)
Liked: 289
basshead81 is right and that was the reason you found low end on PB13U fatter than the same on FV15HP. In 14hz tune with high damping, FV15HP is giving up 30Hz-60Hz (chest slam) big time anyway to accommodate depth.
Anyone who owns FV15HP and using it in 20Hz tune with low damping pls chime in. Need some subjective input on how this sub performs with those settings
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #34 of 249 Old 10-17-2013, 06:15 PM
steve nn's Avatar
Liked: 433
I think I can interpret what you are saying and the kind of fat low end I want is what SVS has. Rythmiks belt out tight bass; but the dampening can be increased/decreased in Rythmik; how much??? I don't know. I think I read somewhere that dampening switch must not be on low setting coupled with the rumble filter set to off on Rythmik FV15HP in 2 ports open mode or it will void warranty.
I don't know if it's true or not.
Yeah it looks as though you have the reach-out that I would suggest. Like said I never had the opportunityy to use one of Rythmik's amp offerings since there was no Rythmik at the time, although Brian was building a few subs. Have you any better idea on the cost of shipping now?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #35 of 249 Old 10-17-2013, 06:38 PM
brian6751's Avatar
Liked: 1648
I tried it in low damping. I preferred it on high damping. I still preferred the pb13 to the Rythmik in any setting.
FOR SALE:
post #36 of 249 Old 10-17-2013, 06:55 PM
brian6751's Avatar
Liked: 1648
This is being over thought. They are both awesome. Pick the one that interests you most or matches with the rest of your setup or whatever.
alwaller likes this.
FOR SALE:
post #37 of 249 Old 10-17-2013, 09:50 PM
K5/SS's Avatar
Quoted: 75 Post(s)
Liked: 129
I have owned both and really loved both. I really can't compare them side by side though since I had them in different rooms. I am by no means a "audiophile" and have zero equipment to test the two but I thought the Rythmik "felt" deeper than the SVS. If you purchased either, you would be totally happy unless you were one of the bass nutz that frequent these pages. Basically, flip a coin. Both are overkill for 99.98% of the population.
I am also testing a Earthquake Supernova 12" and I think the Rythmik and SVS dug deeper but the mid bass feels more "impact-full" than both. I have also switched receivers since the SVS and the Rythmik though. It never ends...smile.gif
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
K5/SS is offline
post #38 of 249 Old 10-17-2013, 11:07 PM
rcohen's Avatar
Quoted: 1405 Post(s)
Liked: 633
rcohen is offline
post #39 of 249 Old 10-18-2013, 06:21 AM - Thread Starter
Quoted: 337 Post(s)
Liked: 289
After going through features of both subs from A to Z, multiple user/expert reviews, and tons of deep brooding; I think the only two things that significantly set PC13U apart from FV15HP is placement friendliness and $200 extra price tag. While the former is the requirement; the later will be an unwanted sour pill I have to swallow. But, at the same time, I hope those extra $200 that SVS charges for PC13U go in driver and amp quality.
So, I'm finally locked on PC13 Ultra and looking forward to experiencing what all the hype is about when it comes to true subwoofers. I hope it works well for me.
Thanx folks for the valuable input. However, um still expecting more input from people who actually own PC13 Ultra.
post #40 of 249 Old 10-18-2013, 08:07 AM
cfraser's Avatar
Quoted: 285 Post(s)
Liked: 164
^ I have had a PC13U for a few years, my room is ~1950 cu ft. It is a good sub, and I got it for its small footprint and very flexible placement and connection options. To be honest, if Rythmiks were easier to get in Canada, and less expensive to ship, I would have seriously considered one. They were just becoming more available at the time IIRC, and some guys "locally" I think were trying to do a bulk buy to reduce shipping costs (truck). Still a pain to actually get to me. e.g. even the PC13U comes in a huge box that won't fit in a typical car. The other feature of the PC13U I liked and specifically wanted was the option to use it in sealed mode. I like sealed subs for music. And of course, as often happens, things don't go how you thought and the sub seemed plenty tight enough to me for music in vented mode and I have never even tried it sealed... I use the sub far more for movies than music anyway.
Even in a room about our size, or just about any room really, you should consider two (at least!) subs. That is if you want to experience a better overall sound in a larger seating area. You will find a single sub very "node-y", it's physics and you can't do much about it except with more sources (subs) and/or treatments that could easily cost more than a sub and maybe take up even more space. The lower the sub goes (and the source), the more you'll notice the nodes. Two subs is substantially better than one sub, but OTOH quality counts too. The PC13U is pretty good quality. If there are typically only a couple people listening in close proximity, then one sub can be quite adequate. All I'm saying is maybe plan for two subs in the future, and ideally they would be very similar. It is possible, for instance and sticking with SVS, that two PB12-NSDs would give a better overall experience for a family than a single PC13U for roughly the same money (but higher shipping cost I'll guess). OTOH, if I want, a single PC13U can shake my whole room more than I'm comfortable with...
cfraser is offline
post #41 of 249 Old 10-18-2013, 08:33 AM
Skylinestar's Avatar
Quoted: 1308 Post(s)
Liked: 267
Rumble filter must be set to position 2/ON when the sub is in 2 ports mode. Position 2 = 2 ports mode. Simple as that.
Skylinestar is offline
post #42 of 249 Old 10-18-2013, 09:13 AM
basshead81's Avatar
Quoted: 310 Post(s)
Liked: 8734
I think either are a good choice but if I am spending that much coin then I would take the sub that has a 9db advantage at 12hz which is the FV15HP.
post #43 of 249 Old 10-18-2013, 09:36 AM
steve nn's Avatar
Liked: 433
I dig, but that extra extension is coming at more cost than what some might realize. In defense of the OP, this seems to be a concern and quite understandable imo considering the ULTRA has things covered quite well.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #44 of 249 Old 10-18-2013, 09:48 AM
Kini62's Avatar
Quoted: 2657 Post(s)
Liked: 2436
I just upgraded to the PC12+ version in a 1650^3 foot room. It's an incredible experience and my first sub that does < than 20hz. I run it in 16hz mode. It sounds just as good with music as it does with movies.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #45 of 249 Old 10-18-2013, 09:55 AM
morrischestnut60's Avatar
Quoted: 63 Post(s)
Liked: 86
I have never heard the Rythmik but I have owned a few SVS subs. Their bass is not thick. The word I have always used to describe the bass from them is muscular. I had the first generation PB12-Plus so I can only imagine how much more potent the Ultra 13 is.
morrischestnut60 is offline
post #46 of 249 Old 10-18-2013, 12:58 PM - Thread Starter
Quoted: 337 Post(s)
Liked: 289
Thanks folks for the input. I guess I know what I actually want now. As regards depth; I think um comfortable with close to 16-17Hz. PC13U in 20Hz mode has useful output down down to 16Hz. In my room it should be flat till 15-16Hz. I think that's enough. As my DIY sub does hit close to 117dB at 17Hz with useful output down to 13Hz in my room, but I don't want a huge box taking up a lotta space + plus it is terribly heavy.
As regards duals, I will use my current PSB S300 for the time being, which I can't compare with PC13U but it is super clean and loud down to 25Hz. So, it will help smooth out the response till 25Hz.
post #47 of 249 Old 10-18-2013, 02:36 PM
steve nn's Avatar
Liked: 433
Looking forward to your impression of the ULTRA Brave. I’m at the point on this Forum that I only want what works best for you. I’ll argue good versus bad, but the two subs we’re talking about are both very good options as you know.. maybe criteria is the key word here as it plays a big part in all our SW decisions. Anyway good decision (they both are) bass-on forum Bass Dude Junkie . cool.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #48 of 249 Old 10-19-2013, 02:13 AM - Thread Starter
Quoted: 337 Post(s)
Liked: 289
Had a talk with SVS rep and it seems like their payment mode for international sales may be a deal breaker. I've shot an email to rythmik; i'd go with with fv15hp piano gloss if they accept international credit cards online.
I was surprised to hear from SVS rep that FV15HP was in the league of PB-12 Plus and PC13-U was superior to FV15HP in terms of output above 20Hz. I think this is not true.
post #49 of 249 Old 10-19-2013, 04:17 AM
Quoted: 93 Post(s)
Liked: 122
Depending on which measurements you look at, it is true in some cases, but definitely not across the board.
Projector: LG PF1500W; Receiver: Sony STR-DN1080; Speakers: Monitor Audio Controlled Performance Inwalls and Inceilings; Subwoofer(s): SVS PC-2000; Bluray Player: Sony BDP-S6500; Remote: Roomie Remote; Cables: Monoprice
rnatalli is offline
post #50 of 249 Old 10-19-2013, 05:38 AM
steve nn's Avatar
Liked: 433
Yeah it seems like I remember a certain thread the PLUS measurement issue coming up. smile.gif The Plus is quite a substantial sub in it’s own right that’s for sure.
Brave..Had a talk with SVS rep and it seems like their payment mode for international sales may be a deal breaker. I've shot an email to rythmik; i'd go with with fv15hp piano gloss if they accept international credit cards online.
Maybe the HP is your destiny then? Lets hope it’s not the same case with Rythmik?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #51 of 249 Old 10-25-2013, 03:18 PM - Thread Starter
Quoted: 337 Post(s)
Liked: 289
Ordered FV15HP in piano black today. Will be out for shipment on its long journey to Pakistan. Can't wait.
SaviorMachine likes this.
post #52 of 249 Old 10-25-2013, 03:44 PM
basshead81's Avatar
Quoted: 310 Post(s)
Liked: 8734
post #53 of 249 Old 10-25-2013, 05:01 PM
newc33's Avatar
Quoted: 1169 Post(s)
Liked: 1771
I would have loved to get the piano black. I'd even have black matte over the black oak. But oh well when it comes down to it I care more about performance al then looks so I'm happy with the Black oak
Are u going to get duals?
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s rear surround
Quad PSA T18s!!!!!!
Funk audio 12.2 HP mains powered by/funk audio 6x500 watt amp
newc33 is offline
post #54 of 249 Old 10-25-2013, 06:39 PM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #55 of 249 Old 10-25-2013, 08:50 PM - Thread Starter
Quoted: 337 Post(s)
Liked: 289
Though I don't have the room for duals considering the size of fv15hp; but I think I will order the second one. But it won't be before a year.
post #56 of 249 Old 10-26-2013, 03:03 PM
newc33's Avatar
Liked: 1771
That's cool, hey ya never know..aybe one fv15hp will be ebough anyway:cool:
denon x4100
Quad PSA T18s!!!!!!
newc33 is offline
post #57 of 249 Old 10-31-2013, 10:00 AM - Thread Starter
Quoted: 337 Post(s)
Liked: 289
Finally Elvis has left the building. Can't wait.......
post #58 of 249 Old 10-31-2013, 10:06 AM
steve nn's Avatar
Liked: 433
cool!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #59 of 249 Old 12-06-2013, 06:05 AM - Thread Starter
Quoted: 337 Post(s)
Liked: 289
The sad news is that I'll have to wait another week till I get FV15HP mad.gif. Anyway I was getting bored, so thought let's try some new thing for other's info, so, I integrated two ported subs tuned to different frequencies (PSB S300 (27Hz) and Alpine DIY (21Hz)). Subs are placed diagonally. Alpine in the front right corner and PSB in the rear left corner.
Here is the subs-only response without any EQ;
Sounds great and enjoying natural 7dB house curve till the time FV15HP arrives wink.gif
post #60 of 249 Old 12-06-2013, 07:08 AM
rcohen's Avatar
Liked: 633
Wow!
rcohen is offline
Fv15hp Subwoofer , Svs Pc12 Ultra , Svs Pb13 Ultra , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs , Rythmik Audio , Rythmik
