Sub to aid Paradigm Cinema 400 LCR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-19-2013, 06:10 PM - Thread Starter
PapaPhive's Avatar
I am looking for a recommendation on the purchase of a new sub in a dedicated home theater project I am working on. The room is approx 25' x 19' x 10'. The room will be used 80% movies and 20% games.
I will be using three Paradigm Cinema 400s for the LCR with four Inwalltech Pro Gold M65s for the rear and side surrounds. I plan on powering them on my Yamaha RX-V673. I am aware that the on wall Cinema 400s lack in low end frequency response lower than 115hz and that has me a bit concerned. I am by no means an audiophile, but don't want to miss out either.
Can anyone provide a good sub that can adequately take over where the Cinema 400s fall behind? I am working with a $600 budget and would like to stick to just one sub for the time being.
I have been looking at other recommendations here and are considering:
Rythmik LV 12R
Outlaw LFM-1 EX
HSU VTF-2
All recommendations are greatly appreciated. Thank you!
PapaPhive is offline
post #2 of 6 Old 11-20-2013, 11:30 AM - Thread Starter
PapaPhive's Avatar
Well, I just bit the bullet on a HSU VTF-3 MK4 and hope that was a good choice. I am not very "in tune" with this audio stuff, but am looking forward to putting it all together!
post #3 of 6 Old 11-20-2013, 11:43 AM
eljaycanuck's Avatar
Quoted: 1891 Post(s)
Liked: 2651
The VTF-3 MK4 is a well-regarded sub and it should perform well. But, at ~4,750 cu.ft., your room is quite large, so don't be surprised if, after a while, you find yourself thinking about adding a second sub... wink.gifsmile.gif
eljaycanuck is offline
post #4 of 6 Old 11-20-2013, 11:53 AM
spyboy's Avatar
Quoted: 216 Post(s)
Liked: 158
In a space the size of yours, I suggest that you use the VTF-3 MK4 in Maximum Output mode, (both ports open), rather than in Maximum Extension mode, (one port plugged).
spyboy is online now
post #5 of 6 Old 11-20-2013, 12:45 PM - Thread Starter
PapaPhive's Avatar
Will do! And, I am not opposed to eventually picking up a second; however, for the time being and in an effort to manage available funds, I will now be looking into acoustics.
post #6 of 6 Old 11-18-2016, 10:54 PM
splat10's Avatar
PapaPhive, not sure if you are still around but how have your cinema 400 LCR with the HSU worked out for you. I got some cinema 400's and haven't chosen a sub yet. The speakers leave a lot without one so i'm worried about their performance. I'm looking at an SVS PB2000. How have the highs on your 400's been?
splat10 is offline
Yamaha Rx V673 Receiver , Rythmik Audio Lv12r , Hsu Vtf2 Mk4 , Hsu Vtf3 Mk4
