Reaction Audio Subs - Page 215 - AVS Forum | Home Theater Discussions And Reviews
 4224Likes
post #6421 of 6445 Old 12-30-2016, 09:45 AM
lz7j's Avatar
Quoted: 695 Post(s)
Liked: 687
Originally Posted by TooPoor View Post
It's a SP1-4000 Torpedo SpeakerPower amp. I thought someone said earlier in the thread that I'd need a passive plate, but I may have misunderstood. That's even better news. The PE flatpack doesn't come with a cutout if I'm not mistaken (or the DIYSG flatpack).
Docethic, the PS18x will always be available to you if you're interested. I really want to start getting into DIY and another sub seemed like a good idea considering the availability of flatpacks, the fact I have a sub amp that can power a slave, and the low cost. I certainly don't need 2 18's in my current listening area...
EDIT: Yup... I get it now. I just need the Speakon Terminal Plate. Makes sense now.
You definitely don't need another amp. If you plug in a second sub, it'll get 2kw rms as long as the amp is seeing a 2ohm load. Your current driver is 4ohm, your second one should be the same - run it parallel and it'll be 2ohm. Aside from the box and driver you'll also need the following:
- 1 x neutrik connector http://www.parts-express.com/neutrik...mount--092-054
- 2 x speakons http://www.parts-express.com/neutrik...mount--092-050
- 12awg wire
- wood screws
- walmart pillow $3 each, you'll need 4 for each box. Go ahead and add them to your other box from Jeremy.
- paint/duratex
Assuming you can get a series 2k 18" driver from Paul Pierce, the entire project should cost you under $700.
I highly suggest you visit the DIY forum and start a thread there.
lz7j is offline
post #6422 of 6445 Old 12-30-2016, 09:48 AM
TooPoor's Avatar
Quoted: 103 Post(s)
lz7j,
I contacted Paul and he knows exactly what I need (and has it). Your list will round out my BOM. I really appreciate the help.
Now about those active CX-10t...
DIYSoundgroup Titan LX 15 (WIP)
Philharmonic Audio BMR
Reaction Audio PS-18x (x2)
Denon X4000 - Schiit Mimby - Monolith 2
TooPoor is offline
post #6423 of 6445 Old 01-19-2017, 10:07 AM
Docethic's Avatar
Quoted: 330 Post(s)
Liked: 281
lz7j,
Have you received the driver yet? Curious how the slave project is shaping up...Have you worked on fine tuning the ps18 any further ?
Docethic is offline
post #6424 of 6445 Old 01-19-2017, 02:37 PM
ahblaza's Avatar
Quoted: 2458 Post(s)
Liked: 3397
lz7j,
TP, if I remember correctly Nikko has the CX-12 active XOs.
ahblaza is offline
post #6425 of 6445 Old 02-02-2017, 07:39 PM
codee's Avatar
Quoted: 68 Post(s)
Liked: 33
Originally Posted by DotJun View Post
Unplug the signal cable going into the amp. Leave the amp on. Let it sit that way for a few days. Does it still pop? If not, your problem lies elsewhere.
Originally Posted by Tom Vodhanel View Post
Also, be sure when you are switching it from OFF to ON 15-20x...you give it enough time for all the relays/DSP. 10 seconds would be plenty of time.
EDIT---for clarity. What I mean is when you switch it to ON you need to wait a bit for all of the relays/DSP before the subwoofer will begin reproducing bass. Give it 10 seconds, that should be plenty.
Tom V. is Power Sound Audio
Sorry I got sidetracked and forgot to post back as it actually started working almost all the time. Unfortunately it doesn't work at all now though. Even if the sub seemingly engages and the power light is green there almost no output. If I play a test tone and turn the sub output on the receiver all the way up and the gain on the amp all the way up there is literally next to no output from the sub.
I got a new receiver from Denon under warranty so the sub was disconnected almost a week and it still doesn't work on the new receiver. At this point i'm not sure if there is anything I can do to repair it. I'm starting to research new subs but am somewhat skeptical of another internet direct sub...I've been burned now by Chase Home Theatre going out of business and now reaction audio seemingly disappearing. Just had some bad luck in picking them I guess.
Blu-Ray - 1229
HD DVD - 57
SD DVD - 1159
I Do Blu.
NEXTEL. Done.|
codee is offline
post #6426 of 6445 Old 02-02-2017, 08:36 PM
basshead81's Avatar
Quoted: 318 Post(s)
Liked: 8981
There are some very reliable ID companies out there such as HSU and SVS which have been around for 20yrs+. Rythmik, PSA, and JTR also have a great track record.
That being said you should be able to send that ICE amp to Brian at Speaker Power(manufacturer) and he might repair it for free. I would assume that amp should still have some sort of warranty even though RA is no longer. JTR and PSA both are using those ICE amps in their products.
basshead81 is offline
post #6427 of 6445 Old 02-02-2017, 08:48 PM
codee's Avatar
Quoted: 68 Post(s)
Liked: 33
I will check out that option, thank you very much! i had actually researched HSU the first time around and HSU and PSA the second time around. No real good reason I didn't pick one of those 2 companies, but I will definetly keep them in mind in the future - even if I can get this amp repaired I would like to add a second sub to the mix again.
Thank you very much!
Blu-Ray - 1229
HD DVD - 57
SD DVD - 1159
I Do Blu.
NEXTEL. Done.|
codee is offline
post #6428 of 6445 Old 02-03-2017, 10:11 AM
Tom Vodhanel's Avatar
Quoted: 2992 Post(s)
Liked: 9924
Could you remind me of the product we were discussing? Which model ra do you have? ICE powered?
The newer klipch 15 slot port sub is a very good "big name" product at $699-749(?) if you go that route. Also, remember that hsu has been at this since 1990(?)...which is *much* longer than the majority of non ID companies..
Tom V.
Power Sound Audio
The woods are lovely, dark and deep, But I have promises to keep,
Tom Vodhanel is offline
post #6429 of 6445 Old 02-03-2017, 10:21 AM
codee's Avatar
Quoted: 68 Post(s)
Liked: 33
Tom V.
Power Sound Audio
I have a Echo 18 that is seemingly dead at this point in time. I feel I can get much more "bang for my buck" going ID vs a brand sold at b&m stores primarily.
I looked at PSA and hsu in the past and they would be my leading contenders at this point in time I'd say.
codee is offline
post #6430 of 6445 Old 02-03-2017, 11:30 AM
Liked: 9924
Before anything, I'd pop out the driver AND amp. Take all of 5 minutes with a power screw driver. This will let you check internal connections, and you can test the driver and possibly the amp too. Do you happen to have a good DMM?
When removing the driver be careful. One slip of the screw driver and you can easily put a hole in the surround. That is often an easy fix but best not to get to that point of course..
Tom V.
Power Sound Audio
chucky7 likes this.
post #6431 of 6445 Old 02-03-2017, 11:38 AM
basshead81's Avatar
Quoted: 318 Post(s)
Liked: 8981
Tom makes a good point here...Could be a simple connection issues because many of RA products were poorly assembled.
post #6432 of 6445 Old 02-03-2017, 12:07 PM
Warmacblu's Avatar
Quoted: 180 Post(s)
Liked: 85
I have some RA products and can verify that the assembly varies wildly from product to product. If I were to do it over again I would go with PSA. Once my RA gear decides to die or if I can sell it for a decent price locally then I will be looking at PSA.
When I was looking, Tom wasn't offering any tower speakers and Jeremy was so that's all it took for me. Now that Tom is offering them I would definitely be interested in those.
ahblaza likes this.
Warmacblu is offline
post #6433 of 6445 Old 02-03-2017, 12:51 PM
Mark Seaton's Avatar
Quoted: 909 Post(s)
Liked: 2541
Please reach out to Brian or Carol at SpeakerPower, as they supplied and can most certainly service the amplifier in your subwoofer. Let them know you purchased the subwoofer from Reaction Audio which uses the 700W amplifier (that's what SpeakerPower labels it) and you need it serviced. I'm sure they will take care of you. @SpeakerPower
chucky7, jamiebosco and Molon_Labe like this.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #6434 of 6445 Old 02-03-2017, 02:49 PM
Gorilla Killa's Avatar
Quoted: 1360 Post(s)
Liked: 1920
lz7j,
Since it doesnt matter and RA is defunct, ask Paul to give you the TS parameters after the driver is built and before shipping. It would be good to know if the enclosure is a match for the driver. Ive had Pierce do a few builds for me, and I feel that IB is his strong point and being a car audio guy thats fine.
@tuxedocivic commented on a driver someone local bought and he helped with a box that was large and should have been larger. Im quite happy with the IB specific 18's he made. The 12's we're supposed to go a in a 2cuft box and need closer to a 12cuft box so I spent quite a bit of time with dsp to get it where I wanted it.
Gorilla Killa is offline
post #6435 of 6445 Old 02-05-2017, 01:36 PM
codee's Avatar
Quoted: 68 Post(s)
Liked: 33
Tom V.
Power Sound Audio
I will try to take it apart tomorrow after work, I have a DMM that I use for work - not sure if I would consider it "good" though" It's about a $80 unit
Blu-Ray - 1229
HD DVD - 57
SD DVD - 1159
I Do Blu.
NEXTEL. Done.|
codee is offline
post #6436 of 6445 Old 02-11-2017, 04:22 PM
ahblaza's Avatar
Liked: 3397
That will work just fine for what you need, it could very possibly be what Tom said, I would physically check all wiring and connections and you may get lucky. Like BH and others have said who knows how the unit was assembled or if the DSP was done properly. Good luck.
ahblaza is offline
post #6437 of 6445 Old 02-27-2017, 07:42 PM
codee's Avatar
Quoted: 68 Post(s)
Liked: 33
Just got around to this finally, have to say I'm surprised at how small the amp actually is. It's very light, I guess the majority of the weight in this unit is the box.
All visible connections were tight but i repeated them anyways. No luck, I contacted the amp manufacturer and they said to ship it to them and they would repair it under warranty.
I got a SVS ultra 16 or whatever it's called to accompany this currently broken sub so once I get the amp back I should be in great shape!
Thanks for all the help guys -
Cody
ID:	1997257   Click image for larger version
ID:	1997265   Click image for larger version
codee is offline
post #6438 of 6445 Old 02-28-2017, 12:05 AM
laserjock II's Avatar
Quoted: 1219 Post(s)
Liked: 684
Cody
Did you ohm out the speaker coil?
Fuse if any?
laserjock II is offline
post #6439 of 6445 Old 08-22-2018, 10:11 PM
Liked: 4
I hate to resurrect an old thread, but........ I have an Echo 18 that the woofer went out shortly after receiving the unit, back in 2016. After Jeremy bailed and I couldn't get a replacement under warranty, it sat for awhile. I moved and just now got around to replacing the woofer. I pulled the defective unit out and there isn't an ounce of poly-fill in the cabinet. Has anyone else done maintenance on their sub and come across the same thing, is this the way all were built or is mine one of the last units out the door and no one cared? I discovered that Paul Pierce built the woofers for Reaction and he was extremely helpful in building another HT unit to meet the specs of the original.
jamiebosco likes this.
N173MM is offline
post #6440 of 6445 Old 08-23-2018, 04:22 AM
djreef's Avatar
Quoted: 207 Post(s)
Liked: 269
There should be some polyfill in the box. I’m thinking at least a couple of pounds. If you could contact Paul I’m sure he could tell you how much.
DJ
2kW fully active, fully balanced 2 channel Vaders
Overkill IS my middle name.
djreef is offline
post #6441 of 6445 Old 08-23-2018, 06:53 AM
Liked: 4
DJ
djreef,
Thanks for the response. That was my thinking on the polyfill too. I have an email in to Paul but wanted to see if this was a common build practice on the RA subs. I`m looking forward to getting my HT set back up and I`m hoping this new woofer will last much longer than the last.
N173MM is offline
post #6442 of 6445 Old 08-23-2018, 07:00 AM
Liked: 9924
If the picture right above (post on 2-27) is indicative of ra's "polyfill" you're better off polyfill-less.
There's not a whole lot of variance with sub lining. Some quality brands don't use anything. Some use a thin layer, some use a thick layer. If the idea is to try to increase the effective enclosure volume thicker home insulation is always a common goto.
Tom V.
Power Sound Audio
ahblaza, BufordTJustice and N173MM like this.
post #6443 of 6445 Old 08-23-2018, 07:30 AM
basshead81's Avatar
Quoted: 318 Post(s)
Liked: 8981
Yea if I remember correctly the whole idea of filling the box with poly-fill is to simulate the internal volume of the enclosure being larger then what it is. Often times large enclosures have nothing. I think it can also help with cab resonance too if the panels used are not very thick?
ahblaza and N173MM like this.
post #6444 of 6445 Old 08-27-2018, 10:12 AM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2171 Post(s)
Liked: 3283
Paul is actually a good choice for info about RA subs as he helped design them (Jeremy wasn't an engineer nor did he have any practical experience so Paul handled a lot of those chores). He was instrumental with things like cabinet volume, drive parameters, etc. He likely helped with the amount of the acoustic damping as well.
BufordTJustice likes this.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #6445 of 6445 Old 09-02-2018, 11:04 AM
bgtighe23's Avatar
Quoted: 1846 Post(s)
Liked: 1231
Internal damping and resonance
.707 qtc alignment
Receiver : Denon x5200
Front Stage : L/R - Statements by Jim Holtz
Surround Speakers : Klipsch RF-82II x 4 / RP-280F x 2
Subwooferage : 6 UM18/4 HT18 Subwoofer Log
bgtighe23 is offline
