DIY Dual 12 inch ported vs Rythmik FV15HP - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 01-31-2014, 01:27 PM
BeeMan458's Avatar
Liked: 813
Originally Posted by braveheart123 View Post
Rumbling and tactile sensations have more to do with sub 30Hz region. That's the area where, IMO, dual Rythmik FV15HP have staggering amount of power in 2 ports/14Hz extension/rumble filter on/ low damping. I just couldn't get that hard hitting chest slam, which is in 30Hz-60Hz region.
I know you know this, in the 30hz to 60hz octave, according to Data-Bass, a single FV15HP is 115dB to 118dB capable. With a second FV15HP, co-location, cabin gain and anything else one wants to throw into the pot, a pair of FV15HPs is more than capable.
What's your room measurement graph like in this region? IIRC, you're running a single as opposed to a pair of FV15HPs?
(for EQ purposes we have XT32/SubEQ HT, using REW for room measuring and running the FV15HPs in one port mode, rumble filter on in 14/hi mode)
BeeMan458 is offline
post #32 of 40 Old 01-31-2014, 01:35 PM
braveheart123's Avatar
Quoted: 337 Post(s)
Liked: 289
The FR is roughly the same compared to my DIY alpine car sub in the same spot in my room. Rythmik of course has more power 25Hz and below but alpine hits much harder in the chest slam region.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #33 of 40 Old 01-31-2014, 01:38 PM
BeeMan458's Avatar
Liked: 813
Do you have a measurement graph of your room that you can post?
The reason I ask, it reads as if your sub's output is being killed by the acoustics in your room in the 30Hz to 60Hz range.
post #34 of 40 Old 02-03-2014, 08:04 AM - Thread Starter
JT78681's Avatar
Quoted: 1510 Post(s)
Liked: 1059
Well if you go for an amp with built-in DSP e.g. iNuke DSP models, you do not need an external EQ device. Unbalanced means the potential difference in resistance between both ends of an unbalanced cable is not fixed. For small runs (up to 50 feet), there is no difference between balanced and unbalanced cable in terms of signal transfer.
So I could pick up an iNuke1000DSP along with either rca female to XLR male adaptor or an rca male to xlr male cable adaptor? I currently have a Y splitter from the sub out on my receiver, so I would hook up the two adapters to the Y splitter to get the signal sent to the external amp? Then I would just need to EQ the subs using the external amp and not Audyssey in the Denon? Am I on the right track?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #35 of 40 Old 02-03-2014, 08:32 AM - Thread Starter
JT78681's Avatar
Liked: 1059
Also, since my receiver does not have a 12v trigger am I going to have manually turn on and off the iNuke when it's not in use? Sorry for all the questions. I actually am trying to look this stuff up online as well.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #36 of 40 Old 02-03-2014, 11:58 AM
Quoted: 337 Post(s)
Liked: 289
Yes
Yes, if you are running two subs.
That is personal preference. I like to keep things in my hand when it comes to subs. You let audyssey do its thing then tame the sub response using PEQ filters in iNuke. Or do it the other way around, which Audyssey recommends. See which yields better results for your ears.
post #37 of 40 Old 02-03-2014, 12:02 PM
Quoted: 337 Post(s)
Liked: 289
Yes. I manually switch it on and off. Though there is thread on this forum to DIY auto on/off a pro amp.
post #38 of 40 Old 02-03-2014, 12:10 PM - Thread Starter
JT78681's Avatar
Liked: 1059
Thank you for clearing up some of these things.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #39 of 40 Old 02-03-2014, 12:26 PM
Quoted: 337 Post(s)
Liked: 289
Make sure your iNuke is the last unit to turn on when you switch on your system and it should be the first to switch off when you turn off the system or else you will hear a loud pop, which may damage your driver.
It's LIFO - Last In First Out
post #40 of 40 Old 02-03-2014, 12:36 PM - Thread Starter
JT78681's Avatar
Liked: 1059
Whoa very good to know. I would probably have cried if I went this route and that happened to my driver.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Fv15hp Subwoofer , Rythmik Audio Lv12r
