DIY Dual 12 inch ported vs Rythmik FV15HP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 01-30-2014, 06:44 AM - Thread Starter
JT78681's Avatar
Quoted: 1509 Post(s)
Liked: 1059
I am currently in a bit of a dilemma. I am running dual Rythmik LV12R's and while they do dig low and sound really clean they don't quite give that hit you in the chest bass. The listening area isn't large roughly 14x16, but ceilings are high and it is open to an upstairs loft and dining area. I can either upgrade to a Rythmik FV15HP for a few hundred or go DIY and build the below for very little money. Thoughts on which choice would be best? Would the DIY 12's provide enough of a jump in performance over my current LV12R's? I'm going to post some links below to the components I would use to build my own.
Enclosures
http://www.diysoundgroup.com/subwoofer-flatpacks-2/ported-subwoofer-flatpacks/4-ported-sub-flat-pack.html
Drivers
http://www.parts-express.com/dayton-audio-um12-22-12-ultimax-dvc-subwoofer-2-ohms-per-coil--295-512
Amps
http://www.parts-express.com/bash-500s-digital-subwoofer-plate-amplifier-500w-rms--300-752?utm_source=google&utm_medium=cpc&utm_campaign=pla
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #2 of 40 Old 01-30-2014, 06:53 AM - Thread Starter
JT78681's Avatar
Liked: 1059
A picture of my room. I have a couch against the wall on the left side another in the middle towards the back against no wall and a huge lazy boy on the right hand side by no wall. If I had more walls I think it would help energize the room more, but unfortunately I don't. The TV, receiver and front speakers are located in front of the window.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #3 of 40 Old 01-30-2014, 07:18 AM
Bill Fitzmaurice's Avatar
Liked: 5767
In the most simple of terms maximum output is limited by driver displacement. If you're comparing drivers of the same size you would compare xmax. Doubling xmax results in a 6dB increase in maximum displacement limited output. Since the Ultimax 12 has 19mm xmax it would potentially beat the LV12R by a worthwhile margin only if the LV12R driver xmax is 15mm or less, though it would have to be 10mm or less for the difference to be major.
As for one fifteen versus two twelves, the displacement rule still applies. For instance, the Ultimax 12 has 932cc of displacement, T/S spec Vd. The Vd of the Ultimax 15 is 1548cc. Obviously one U15 will beat one U12, but at 1864cc two U12 will beat one U15.
Bill Fitzmaurice is offline
post #4 of 40 Old 01-30-2014, 09:06 AM - Thread Starter
JT78681's Avatar
Liked: 1059
So then I guess I would have to somehow find out what the xmax of the LV12R is from Rythmik.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #5 of 40 Old 01-30-2014, 06:51 PM
Tripledub's Avatar
If you're going to go to the trouble of DIY, you might as well go all out and do 2 18's.  The cost wouldn't be that much more...probably about the cost of dual LV12Rs if you use 1 pro amp to drive dual 18s, especially if you get the SI 18s for around $160 ea plus shipping.
Tripledub is offline
post #6 of 40 Old 01-30-2014, 07:14 PM
qguy's Avatar
Quoted: 179 Post(s)
Liked: 104
Why not DIY kits from Rythmik ?
qguy is offline
post #7 of 40 Old 01-31-2014, 05:38 AM - Thread Starter
JT78681's Avatar
Liked: 1059
I was looking at the kits from Rythmik, but I'm lacking tools to build the enclosures. That's why if I was going to go DIY I would just pick up some flat packs. I also tried to search for cabinet builders online who could maybe build me the enclosures, but I was unable to locate anything.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #8 of 40 Old 01-31-2014, 05:48 AM
Liked: 5767
Jerry Caldwell, Austin, Texas. [email protected]
post #9 of 40 Old 01-31-2014, 06:07 AM - Thread Starter
JT78681's Avatar
Liked: 1059
Your the man Bill thanks. Did you find this online or do you know Jerry personally? Just curious!
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #10 of 40 Old 01-31-2014, 06:15 AM
Liked: 5767
He's an authorized builder of my designs, his (and 30 others) name is on the Cabinet Builders page on my website.
post #11 of 40 Old 01-31-2014, 07:00 AM - Thread Starter
JT78681's Avatar
Liked: 1059
I will shoot him an email.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #12 of 40 Old 01-31-2014, 10:42 AM - Thread Starter
JT78681's Avatar
Liked: 1059
I could go the dual SI 18 route and pick up two of these. The reason for the plate amps as opposed to using 1 pro amp is because my receiver doesn't have the 12v trigger to hook up an external amp. Or is there another way I could achieve this?
http://www.parts-express.com/dayton-audio-spa1000-1000w-subwoofer-plate-amplifier--300-809
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #13 of 40 Old 01-31-2014, 10:57 AM
braveheart123's Avatar
Quoted: 337 Post(s)
Liked: 289
If you are looking for hard hitting chest slam bass, even FV15HP won't cut it for you. If you can afford, JTR OS LFU is your ticket. Alternatively, DIY sub(s) with a pro-amp will get you what you want very cost effectively.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #14 of 40 Old 01-31-2014, 11:17 AM - Thread Starter
JT78681's Avatar
Liked: 1059
Any way I could hook up an external amp to the receiver I currently have?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15 of 40 Old 01-31-2014, 11:22 AM
BeeMan458's Avatar
Liked: 813
I know from personal experience, a pair of them will.
(not trying to be argumentative, just saying, he commented about the LV12R and you commented about the FV15HP.....)
(okay, there it is in the thread's title)
BeeMan458 is offline
post #16 of 40 Old 01-31-2014, 11:25 AM - Thread Starter
JT78681's Avatar
Liked: 1059
The best I could do for right now is pick up one, but even after selling my LV12R's it would cost me a few hundred. I then would have to save up for a long time if I wanted to add a second. Brian did say that I could audition one at my house if I wanted.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #17 of 40 Old 01-31-2014, 11:29 AM
Quoted: 337 Post(s)
Liked: 289
Yeah he did mention LV12R and was also thinking of upgrading to FV15HP to find better chest slam. As regards performance in the chest slam region and room pressurization; my room is a tad over 1700 cu ft. So, a single FV15HP in my sealed room pressurizes more than your duals in over 3000 cu ft open room. But Rythmiks lack that hard hitting chest slam feeling even in 2 ports open/14Hz extension mode.
post #18 of 40 Old 01-31-2014, 11:30 AM
BeeMan458's Avatar
Liked: 813
(my bad)
In our 3300^3 room, open to other large spaces, two FV15HPs, one port open, EQ'd flat +/-3dB to 11Hz, at +/-0dB MVC, causes the room, floor, seating, everything to rumble and roll in the 115dB range.
post #19 of 40 Old 01-31-2014, 11:31 AM
Quoted: 337 Post(s)
Liked: 289
Brian has a great CS and I reckon u must audition FV15HP and know it yourself.
post #20 of 40 Old 01-31-2014, 11:33 AM
Quoted: 337 Post(s)
Liked: 289
Almost all the modern day AVRs can drive a pro amp to its optimum level. You just need to gain match it with CE gear.
post #21 of 40 Old 01-31-2014, 12:10 PM
Tripledub's Avatar
Which AVR do you have? It's my understanding that you run a RCA cable from your subwoofer out on your AVR to the pro amp. For the Behringer iNuke you'd have to have an RCA to XLR cable I think, although some pro amps have RCA inputs. Someone correct me if I'm wrong. That is what I'm considering doing as well, so I would like clarification also
post #22 of 40 Old 01-31-2014, 12:22 PM
Quoted: 337 Post(s)
Liked: 289
You only require an rca female to XLR male adaptor or an rca male to xlr male cable. It will be an unbalanced connection between your AVR and the pro amp.
post #23 of 40 Old 01-31-2014, 12:45 PM - Thread Starter
JT78681's Avatar
Liked: 1059
Meaning I will need an external EQ device to fine tune the sub? Trying to understand what unbalanced means exactly.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #24 of 40 Old 01-31-2014, 12:59 PM
Quoted: 337 Post(s)
Liked: 289
Well if you go for an amp with built-in DSP e.g. iNuke DSP models, you do not need an external EQ device. Unbalanced means the potential difference in resistance between both ends of an unbalanced cable is not fixed. For small runs (up to 50 feet), there is no difference between balanced and unbalanced cable in terms of signal transfer.
post #25 of 40 Old 01-31-2014, 01:05 PM - Thread Starter
JT78681's Avatar
Liked: 1059
Thank you for the insight.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #26 of 40 Old 01-31-2014, 01:07 PM
Liked: 5767
Read this:
http://www.rane.com/note110.html
It also may help with the next issue that could arise, ground loop noise.
Not a true pro amp, which runs at +4db, as opposed to -10dB consumer level. Some lower end pro amps have sufficient gain to work with consumer level sources. There are level matching devices available if necessary.
post #27 of 40 Old 01-31-2014, 01:09 PM
Quoted: 337 Post(s)
Liked: 289
Um sure they do Bee, but I found FV15HP to be a tad mellower in chest slam region. A flat FR is half the battle won and does not give a correct reflection of listening experience, IMO.
post #28 of 40 Old 01-31-2014, 01:13 PM
Quoted: 337 Post(s)
Liked: 289
I've used Crown XLS-1000 and iNuke 6000 DSP with Yamaha RX-V3900, Onkyo 809, Denon 3313, Cambridge Audio Azur 751R, and Onkyo 5010. All pushed both the amps into clipping when gain matched.
post #29 of 40 Old 01-31-2014, 01:16 PM
BeeMan458's Avatar
Liked: 813
Not arguing or disagreeing, but if the whole room is rumbling and rolling with the floor vibrating, chairs being thumped about with tactile sensation and the whole area crashing about at 110dB to 115dB, leaving the viewer with that butt-kicked, rode hard and put away wet feeling, than I'm clueless what real "chest slam" is.
post #30 of 40 Old 01-31-2014, 01:22 PM
Quoted: 337 Post(s)
Liked: 289
Rumbling and tactile sensations have more to do with sub 30Hz region. That's the area where, IMO, Rythmik FV15HP has staggering amount of power in 2 ports/14Hz extension/rumble filter on/ low damping. I just couldn't get that hard hitting chest slam, which is in 30Hz-60Hz region.
Fv15hp Subwoofer , Rythmik Audio Lv12r
