Which Sub???? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-31-2014, 02:53 PM - Thread Starter
Cocahoe's Avatar
My home theater system consists of 2 Polk Monitor 60s, a Polk CS1 Center speaker, and 2 Polk OWM3 rear speakers. They are driven by an Onkyo TX-SR604. My current sub was a Polk PSW-110. It blew the amp several days ago after about 2 years of moderate use. I am on the fence about the following 2 subs
JBL-ES250P and a BIC F-12. Need some advice as to which one I should go with. I like to watch movies and listen to Rock in Roll. Any help would be great.
Cocahoe is offline
post #2 of 7 Old 01-31-2014, 04:36 PM
eljaycanuck's Avatar
Quoted: 1983 Post(s)
Liked: 2803
You don't mention a budget, so I'll suggest you put your money into an SVS PB-1000.
eljaycanuck is online now
post #3 of 7 Old 01-31-2014, 05:30 PM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 85
The more expensive of the two subs he's asking about is $250, so I'm guessing that's his price range.
What size is your room? Is the budget a preference or a necessity? The PB1000 is pretty much the least expensive sub that gets an unqualified recommendation around here. Barring that, you could get a Dayton SUB1200 or SUB1500, with not a lot of reason to spend more than that until you're looking to spend the $449-500 on the SVS. If you can deal with $300+, look to a pair of the Daytons, or a Bic PL200. $370 shipped gets you a Hsu STF-2, which doesn't seem like a terrible idea either (in a small to mid sized room).
ermghoti is offline
post #4 of 7 Old 02-01-2014, 02:25 PM - Thread Starter
Cocahoe's Avatar
Thanks for the reply. My room size is 24 by 20. Would like to keep the price less than $400.00.
Cocahoe is offline
post #5 of 7 Old 02-01-2014, 07:10 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3016
That's a pretty big room. I wouldn't be surprised if your PSW-110 died because it was having to work too hard in that room. A 100 watt 10" sub is not not enough for that size space.
My recommendation would be the Premier Acoustics PA-150. It's a 15" with plenty of output for that size room, more than any other sub in your budget range. Acoustic Sound Design will generally take an offer under $400--try $350 and see what they come back with.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #6 of 7 Old 02-01-2014, 10:27 PM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
Dittos on the PA 150 subwoofer!
derrickdj1 is offline
post #7 of 7 Old 02-01-2014, 10:52 PM
mark62's Avatar
Quoted: 25 Post(s)
Liked: 104
mark62 is offline
Polk Audio Psw110 10 Inch Powered Subwoofer Single Black , Jbl Es250pbk 12 Inch Subwoofer Black , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer , Onkyo Tx Sr604 7 1 Channel A V Receiver Black , Polk Audio Monitor 60 Am6025 A 2 Way Floorstanding Speaker Single Black , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Black
