Completely lost when looking for new sub - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 46 Old 02-21-2014, 07:22 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3015
Originally Posted by shadyJ View Post
I like Winamp, it's simple, it loads fast, and its very customizable. I like the milkdrop visualizer too. I also like that EQ plug in by Nevi, I'm not sure if something like that exists for foobar but I hear good things about foobar. iTunes is horrendous though, that is a nightmare I do not care to relive.
Originally Posted by basshead81 View Post
Winamp is my fav...
Must be the polar vortex. Hell has frozen over. You guys readily agreed on something eek.gifbiggrin.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #32 of 46 Old 02-21-2014, 09:24 PM
basshead81's Avatar
Quoted: 324 Post(s)
Liked: 9281
basshead81 is offline
post #33 of 46 Old 02-22-2014, 12:03 PM - Thread Starter
Opentoe's Avatar
Quoted: 91 Post(s)
Originally Posted by flickhtguru View Post
Ok OP it sounds like your needs are modest, BUT no one asked what size your room is. So what is the total cubic footage of the room and any area open to the room where the sub is? Once we know that we can more accurately give you advice for a sub.
It is a living room. 30 feet x 16 feet. My TV of course is setup at one side of the 30 foot end. I have been looking more closely at the SVS SB-1200 ($699) or the Rythmik F12. The speakers look totally different on each of these subs. The Rythmik says the driver is aluminum, is that why? And of course all through out Rythmik's site all I can see is about their DIRECT SERVO technology. That's plastered on every page and why it is the best. Is that technology proprietary to them only? Anyone here own an F12? So it may be between the Rythmik F12 or the SVS SB-1200.
Rythmik does seem a little odd. Looks like their web site was designed in the 80's and made by a teenager. SVS has a nice 45 day return period also, but I haven't read any of the fine print yet. I really doubt they would allow you to return a "used" subwoofer and give you your money back. There is always a catch. Maybe they give you credit with them only?
And of course ported or sealed. I do like tight, quick bass response so I'm guessing my ears would prefer a sealed sub.
LEAD Technologies Inc. V1.01
Opentoe is offline
post #34 of 46 Old 02-22-2014, 12:07 PM
cel4145's Avatar
Liked: 3015
Both of those subs would be challenged to perform in a room that big. Note that Audioholics, in their extensive review, gives the SB12 a rating as best for rooms 1500 to 3000 cubic feet: http://www.audioholics.com/subwoofer-reviews/sb12-nsd-subwoofer/sb12-nsd-conclusion
My recommendation would be the SVS PB-2000. Of course, you could always order the SB12 from SVS, try it, and see if it makes you happy. Return it and upgrade if not.
flickhtguru likes this.
cel4145 is offline
post #35 of 46 Old 02-22-2014, 01:58 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 44
No catch. If not satisfied with your purchase within 45 days, call them to set up the return. They give you back your money and pay the return shipping as well. Sweet deal if you have doubts.
Randy
ransac is offline
post #36 of 46 Old 02-22-2014, 02:16 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 44
The speakers look totally different on each of these subs. The Rythmik says the driver is aluminum, is that why? LEAD Technologies Inc. V1.01
Don't be concerned with driver appearance. All you want is light weight and rigid material. Some use aluminum, some use treated compressed paper, some even use carbon fiber.
Randy
ransac is offline
post #37 of 46 Old 02-22-2014, 03:37 PM
flickhtguru's Avatar
Quoted: 21 Post(s)
Liked: 129
And of course ported or sealed. I do like tight, quick bass response so I'm guessing my ears would prefer a sealed sub.]
I agree with cel I would go with the SVS PB2000. Honestly I would go for 2 PB2000's if possible. Ported will do way better in your size room than sealed. And for a room that size I'd try to go with duals.
Shawn
flickhtguru is offline
post #38 of 46 Old 02-22-2014, 05:34 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1358
I would still go for a VTF3 for control over the bass. SVS doesn't give you any control over the sound unless you buy the Plus or Ultras. The Rythmik F12 would allow you a good deal of control over the sound though. It won't hit very hard in that room though, unless you bought multiples. If you want sealed, an F15HP might do the trick, at least above 35 Hz or so. Check out a Hsu ULS-15 as well for enough output for that room and a tight sealed sound while spending a bit less than the higher powered Rythmik 15"s. If you can do just a little bit of assembly, the Dayton kits would be worth checking out, specifically the Titanic 15" and RS1202k. Thos will give you lots of high quality output for under $1k. Those are also available in assembled versions here and here, but they are $150 more. Since assembly only takes an hour or so and some glue, that is well worth $150 savings, I would get the kits over assembled versions.
shadyJ is offline
post #39 of 46 Old 02-22-2014, 07:06 PM
Gov
Gov's Avatar
Quoted: 139 Post(s)
Liked: 204
PSA
Gov is online now
post #40 of 46 Old 02-22-2014, 08:45 PM
mercury's Avatar
Liked: 102
I also have PSB speakers and although i'm a big fan of svs having owned a few different models in the past I opted for a pair of PSA XS30's.... 18x16x8 open too the rest of the house. so i needed power!!
after watching a movie as my wife was getting ready for bed she said and I quote.... Thomas,+ that's ****ing ridiculous +........ I was grinning as it felt like my walls were gonna cave in;)
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
post #41 of 46 Old 02-23-2014, 07:18 AM - Thread Starter
Opentoe's Avatar
Quoted: 91 Post(s)
I'll be hooking it up to a Denon AVR-X4000 receiver. Wouldn't that be enough control over a subwoofer? I don't want to get too complicated here. I thought the receiver would do all of the handling, excepting the small tweaking with some of the controls later on, which will be difficult since I saw the SVS control panel will be facing the wall and opposite of me. I think that's the way they designed it. Hard to get to those controls, especially when the sub will be behind my entertainment rack, speakers, etc....
I also don't want to build my sub. I'd rather have the pros/company do that. I'll keep building me own media centers, servers and all that, but when it comes to speakers I'll have the company build it. It does seem trivial though. I've done some extensive car audio installations when I was younger and today I'm just more or less lazier and would rather buy something made already.
Now everyone's got me thinking. Do I need dual subs. Do I need a larger sub. Do I need a ported. Ugh. I guess if SVS's 45 day return policy is really true that may be my only path here. The last thing I want to do is drop $1k on a sub, pay for expensive shipping and then it is too small or I don't like it. SVS really though of people buying speakers online. You really can't beat that return policy.
Now, if bitcoin rises up a little more maybe I'll cash out a couple and grab a large SVS sub. I'll just have to decide sealed or ported. Ugh.
Opentoe is offline
post #42 of 46 Old 02-23-2014, 07:50 AM
eljaycanuck's Avatar
Quoted: 1891 Post(s)
Liked: 2651
I have the X4000 and it does a good job of EQ-ing. But you can buy subs that offer more flexibility and/or you can get gear like the miniDSP that will also provide flexibility.
That said, andgiven all the requirements you've stated in this thread, IMO you'll do fine with the SVS PB-2000. At the very least, you should give one a risk-free try.
eljaycanuck is offline
post #43 of 46 Old 02-23-2014, 08:02 AM - Thread Starter
Opentoe's Avatar
Quoted: 91 Post(s)
Thanks, I will probably take your recommendation on the PB-2000. Can't wait!
Opentoe is offline
post #44 of 46 Old 02-23-2014, 08:04 AM
cel4145's Avatar
Liked: 3015
It should be a nice improvement over your Klipsch sub.
Which model Klipsch do you currently have?
cel4145 is offline
post #45 of 46 Old 02-23-2014, 04:56 PM - Thread Starter
Opentoe's Avatar
Quoted: 91 Post(s)
I don't even remember what model it is. It is a ported 12" basic sub from Klipsch and only cost me $300.
Opentoe is offline
post #46 of 46 Old 02-23-2014, 05:31 PM
cel4145's Avatar
Liked: 3015
cel4145 is offline
Denon Avr X4000 7 2 Channel Home Theater Receiver , Hsu Vtf3 Mk4 , Rythmik Audio F15 Subwoofer , Svs Sb2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
