Thoughts on Polk Audio DSWmicroPRO 3000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-23-2014, 11:13 AM - Thread Starter
Acousticality's Avatar
Quoted: 18 Post(s)
Hello,
I have been thinking about getting a new subwoofer for my HT Set-up. I have noticed the DSWmicroPRO 3000 at 1200W continuous (RMS), 2400W Peak for under $1000. I also see it only has a 10" woofer, which seems odd to me.
Has anyone had any experience with these subs?
Compared to other subs in the $1000 price range does it compete?
Acousticality is offline
post #2 of 6 Old 02-23-2014, 11:34 AM
spyboy's Avatar
Quoted: 216 Post(s)
Liked: 158
At about $1,000 you have a number of choices. Going the internet direct route can save you money. Take a look at this:
http://www.hsuresearch.com/products/uls-15.html
The ULS 15 has a very good 15 inch driver. The difference between 1200 watts and 600 watts on the HSU doesn't make a whole lot of difference.
You could buy 2 subs from SVS namely the PB-1000.
There also other choices.
spyboy is offline
post #3 of 6 Old 02-23-2014, 01:04 PM - Thread Starter
Quoted: 18 Post(s)
Kinda looking to stay below $1000. I've heard about the PB-1000 before, as well as the PB12-NSD. Those are 300 Watt continuous though.
post #4 of 6 Old 02-23-2014, 02:11 PM
jwtallguy's Avatar
Quoted: 119 Post(s)
Liked: 57
Originally Posted by Acousticality View Post
Hello,
Hello just thought I'd say that the polk sub is really only around 600-700 watts rms max! And getting 2 pb1000s would crush it in lfe for a lot less
current setup: marantz 7011 avr, PSA 210t L/R, PSA 210, 4 volt 10's in slant box style, 4 svs pc13 ultras, epson 5030ub with 100" AT screen diy spandex cloth
jwtallguy is offline
post #5 of 6 Old 02-23-2014, 02:34 PM
spyboy's Avatar
Quoted: 216 Post(s)
Liked: 158
I realize that the number of watts isn't unimportant, however, savvy sub designers have to balance wattage along with other factors, like cabinet size and driver excursion. You will be surprised by how much output a mere 300 watts can get you.
http://www.svsound.com/
45 day no risk try out. (it doesn't get any better than that). Try to look at the SVS Bill of Rights.
spyboy is offline
post #6 of 6 Old 02-23-2014, 06:14 PM
basshead81's Avatar
Quoted: 325 Post(s)
Liked: 9399
You can get away with less power when the enclosure is bigger. Also power does not mean alot when determining subwoofer performance. The micro pro3000 is a decent sub, but for its price, Internet Direct will stomp a mud hole in its arse. smile.gif
Look at the SVS PB2000, PSA XV-15, or Hsu VTF-3...these options will easily outperform the polk for less money.
basshead81 is offline
