SVS PB13 Ultra, worth it? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 103 Old 03-02-2014, 06:38 PM
Reference_head's Avatar
Quoted: 144 Post(s)
Liked: 731
Originally Posted by Luis5150 View Post
Reference_head.... nice looking room, btw. That PB13 right behind your couch must be gut-wrenching smile.gif
To the OP, I would totally recommend you try one of your pb-2000 nearfield before making any further upgrade/purchasing decision.
Thanks. It does have the potential to be really insane if pushed. But I keep it down and level match it with the front subs that are behind the screen. I also xo it at 60hz and 99.99% of the time you don't even know its right behind you. Its also great because its an effortless bass . The sub barley even moves to reach the levels i watch at (pretty loud). I strongly recommend to anyone with a spot and multi subs to give it try.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #92 of 103 Old 03-02-2014, 06:53 PM - Thread Starter
Hockeypucks's Avatar
Quoted: 12 Post(s)
Liked: 51
That would be my only concern with putting a sub (or two) right behind me. I wouldn't want to notice it but I have plenty of room for more placement options.
Hockeypucks is offline
post #93 of 103 Old 03-02-2014, 06:55 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 51
Originally Posted by basshead81 View Post
You're not helping basshead!! Ha if only they were cheaper. Would love to hear 4 of these in my room. Perhaps it's an option in the future.
post #94 of 103 Old 03-02-2014, 07:00 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
See my signature? I have a VTF-3-HO right against my couch and it plays perfectly with the dual PB13's I have. I have 1 PB13 up front between my left main and center speaker, the other PB13 in the back of the room about 30" from the back-left corner along the back wall (about 6ft - 7ft from the main MLP...), AND a Hsu VTF3-HO right against the back of my recliner sofa/2nd row seating/MLP and its just plain awesome, all that tactile sensation. The bass is everywhere in my room = hard hitting when called for, but you can't tell there is a sub right behind that recliner. I've had people sitting there and they couldn't believe there was a sub there.
Granted, it took time on my part to get all 3 subs dialed-in in unison and properly gain-matched to work, but the rewards are just priceless. smile.gif
| Panasonic TC-P65S2 HD Plasma | Oppo BDP-93 | Paradigm Studio 100's v2 (mains) | Paradigm Studio CC-690 v5 (center) | Paradigm ADP-370 v3 (sides surr.) | Paradigm Studio 20's v2 (sides + back surr.) | SVS PB13-Ultra(x3) | Marantz AV-8801 pre/pro | Emotiva XPA-5 (x2) |
Luis5150 is offline
post #95 of 103 Old 03-02-2014, 07:11 PM
basshead81's Avatar
Quoted: 312 Post(s)
Liked: 8756
Here are how mine are setup...nearfield
basshead81 is offline
post #96 of 103 Old 03-02-2014, 07:21 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 51
Thank you Luis, that was quite helpful. I am very much after room enveloping bass and it's good to know it can be done.
post #97 of 103 Old 03-02-2014, 07:24 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 51
Ahh I thought I've recognized that pic, you showed that to me over on HT Shack. I think I'm going to try that, ugh you guys are costing me $ but it's great advice. My subs are currently both on the front wall but I like the idea of having them surround the listening areas. I just don't want to localize any of them.
post #98 of 103 Old 03-02-2014, 07:42 PM
Quoted: 144 Post(s)
Liked: 731
+1 basically the same experience. It gives the ability to reach any level of bass you want without pushing the subs hard. Like anything worth having its not as easy as setting up two upfront. But the rewards are worth it. I would never go back. If you put a 2000 right behind and one upfront you might be good to go. Worth a try
post #99 of 103 Old 03-02-2014, 07:45 PM
Quoted: 144 Post(s)
Liked: 731
Is that a sub in the corner too? Nice room by the way
post #100 of 103 Old 03-02-2014, 07:48 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
Basshead's setup picture tells a thousands words.... You owe it to yourself to experinment, take your time, and come back here to the forum for tips on how to accomplish it. I can tell you this much ... I had dual-subs along the front wall initially and while I liked it, there was a part of me that felt.... hmmm this could be better. In the end after some placement experimentation, I found that deploying the subs in diffenrent location across my room (particularly front and back ... ) worked best.
Luis5150 is offline
post #101 of 103 Old 03-02-2014, 07:54 PM
basshead81's Avatar
Quoted: 312 Post(s)
Liked: 8756
Thx!
Yep...3 subs all placed accordingly.
post #102 of 103 Old 03-02-2014, 07:58 PM
Quoted: 144 Post(s)
Liked: 731
post #103 of 103 Old 03-02-2014, 08:19 PM
bigguyca's Avatar
Quoted: 941 Post(s)
Liked: 762
Originally Posted by Lecter83 View Post
The FV15HP is medium to large sized for a commercial HT subwoofer with two 3" flared ports.
http://www.data-bass.com/data?page=system&id=51
FYI, from the Rythmik thread, post: 13871
Originally Posted by Rythmik View Post
Maybe because Josh at Data-Bass has mistakenly listed our port diameter as 3". The correct size is 3-1/2" smile.gif
bigguyca is online now
Svs Pb2000 , Svs Pb13 Ultra , Fv15hp Subwoofer , Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer
