Official Funk Audio Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 730Likes
post #331 of 895 Old 11-01-2015, 06:49 AM
arsMatrix's Avatar
Originally Posted by Funky Waves View Post
As I mentioned in previous posts the new software still has some issues. Please continue with the current version. When the new version is ready I will let everyone know they can update to it.
Hi Nathan.
Any update on upgrading to the latest version of ALLdsp?
arsMatrix is offline
post #332 of 895 Old 11-01-2015, 08:50 AM
Funk Audio's Avatar
Quoted: 123 Post(s)
Liked: 275
The new firmware is done and it looks like all the issues have been resolved, just need to finish the sofware for it and test it. Shouldn't be too much longer now.
Also in case anyone is wondering why we have not done the instructional video yet is because we decided to wait until this new version was done.
henrich3 and arsMatrix like this.
Funk Audio is offline
post #333 of 895 Old 11-01-2015, 10:15 AM
Hopinater's Avatar
Quoted: 3230 Post(s)
Liked: 9513
I just visited the Funk Audio website. I hadn't been there in a while and had forgotten just how beautiful the Funk audio gear is. The craftsmanship is really 2nd to none, it's absolutely gorgeous (as is the sound quality, I'm sure of this even though I've never been blessed enough to hear it).
If I had the funds I would definitely love to own one of these beautiful subwoofers. Oh well…I can always window shop, they're fun to look at.
Great work.
smurraybhm and dsrussell like this.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
post #334 of 895 Old 11-19-2015, 02:35 AM
Quoted: 36 Post(s)
Liked: 0
Is the new Firmware ready and perfect ?
Is Problem solved , autom. switch in Stand by , when Subwoofer long out ???
Filou6901 is offline
post #335 of 895 Old 11-19-2015, 08:46 AM
Funk Audio's Avatar
Quoted: 123 Post(s)
Liked: 275
Unfortunatly it is not ready yet. I will post here when it is.
post #336 of 895 Old 11-20-2015, 04:56 AM
pbc
pbc's Avatar
Quoted: 437 Post(s)
Liked: 217
Are there any particular reasons to upgrade to the latest firmware once it is tested? Most of the updates the last little while seem to have been for functions that aren't really used in our applications? Maybe the LED dimming.
Nathan - ever figure out the occasional loss of signal/reboot that happens on the external amps btw? Seems to be happening much less, but did occur the other day on mine again.
My DIY Subs ... https://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #337 of 895 Old 11-24-2015, 05:05 AM
Quoted: 36 Post(s)
Liked: 0
I hope so of new Software !!!
1. Is the Sub long Time out , he goes not automatic on !
2. Yesterday have suspended , the Sub was up all Night on !?
- little Problems , they very bother me !
post #338 of 895 Old 12-01-2015, 11:30 AM
Funk Audio's Avatar
Quoted: 123 Post(s)
Liked: 275
We are working on that issue. The AllDSP system we use is quite powerful(64bit 96kHz processing, compared to most DSP systems that run at 24 bit 48kHz or lower), and like any computer system the more powerful it is the more prone it is to developing a glitch after being on for extended periods. This glitch does not happen very often, and simply turning if off and back on reboots the system and clears the glitch.
This issue is even less frequent if you set it to be on all the time, and not enter standby, set standby delay setting to 0 to deactivate. The idle draw when the unit is not in standby is still only ~13watts, this is well within the standby draw of many home appliances, TV's etc.
Nathan Funk
Funk Audio
post #339 of 895 Old 12-02-2015, 01:21 PM
Quoted: 36 Post(s)
Liked: 0
Standby Delay Setting to 0 ? Now set is 15 min. ?
Then alway go out by Film , or what ?
post #340 of 895 Old 12-18-2015, 01:32 PM
Quoted: 36 Post(s)
Liked: 0
I have Windows Upgrade 10 , before 7 !
Now AllDSP is not work , Menu does not go on ?
I can the EQ Flat and HomeCinema u.s.w change on the back Side , but NOT the Volume !?
Can anybody help ?
post #341 of 895 Old 12-18-2015, 03:14 PM
Funk Audio's Avatar
Quoted: 123 Post(s)
Liked: 275
Can anybody help ?
I am not sure about Windows 10, but for windows 8 you need to follow the instructions available here http://www.funkaudio.ca/how-to-use-alldsp.html , Windows 10 could be the same. Changing your operating system should not change the functioning of the interface display panel on the subwoofer itself unless you changed the firmware via ALLDSP. As I mentioned before please continue using the version available from our page linked above until I am happy with the newer version available from ALLDSP. If you have gone to the new version and then back you will need to go into the settings with the password and change the user rights to have the display panel function as it did. If you need help doing this please contact me direct via email or phone.
Nathan Funk
Funk Audio
post #342 of 895 Old 12-24-2015, 12:24 AM - Thread Starter
crackhead2k's Avatar
Quoted: 84 Post(s)
Liked: 43
Can anybody help ?
Try to run it in compatibility mode for Windows 7 under administrator.
Right click -> Properties -> compatibility "tab"
Also check "Run this program as administrator"
Hopefully that works.
Equipment List: Preamp/Processor: Sherbourn PT-7030 [] Speakers: Funk Audio - Line Array(2kW),18.2 Subwoofer (9.6kW)[]Projector: Epson 5020ub []Screen: Elunevision Reference 150"
PC/HTPC: Intel Q6600 [] GTX670 [] 4 GB Ram [] Windows 8.1 x64
Cabling: Interconnects: HDMI - Redmere Cable 50 ft
Audio Cable: XLR - From Orange County Speaker - 50ft
crackhead2k is offline
post #343 of 895 Old 12-24-2015, 02:07 AM
Quoted: 36 Post(s)
Liked: 0
I have the new Software from FunkAudio Hompepage download , ok again !
When make the Subwoofer out , without electric Power , then on , my Settings deleted !?
How can safe it ?
Best Regards from Germany !
post #344 of 895 Old 12-24-2015, 07:45 PM
Funk Audio's Avatar
Quoted: 123 Post(s)
Liked: 275
How can safe it ?
Please email me so I can send you the factory presets via email so you can reload them.
post #345 of 895 Old 01-02-2016, 01:58 PM
Red99's Avatar
Quoted: 776 Post(s)
Liked: 418
This is the time of the year the sun is very low. So at about 1:00 if I open the curtains it shines on this sub. The bright sun shine really brings the detail out in the Veneer.
This one of the pair of 18.0 subs Nathan built for me last spring done in a Mahogany Crotch.
ID:	1157658   Click image for larger version
Name:	Angled Side Pic.jpg
chucky7, jbrown15, Billy p and 5 others like this.
Red99 is offline
post #346 of 895 Old 04-12-2016, 05:15 PM
Majister's Avatar
Liked: 60
Is this thread still alive? I've been missing the activity in this thread. If you have recently enjoyed a Funk product, post your experiences here!
atabea likes this.
Majister is offline
post #347 of 895 Old 04-13-2016, 11:34 AM
Billy p's Avatar
Quoted: 352 Post(s)
Liked: 725
Damn....that veneer has got me hooked....absolutely love it!
Ascend Acoustics: Towers, STC w RAAL & 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo 103D,
Sub: Funk Audio 18: (Santos Rosewood)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
post #348 of 895 Old 04-13-2016, 02:56 PM
atabea's Avatar
Quoted: 747 Post(s)
Liked: 636
So, has anyone had any hands-on experience with the Funk 15Hs?
https://www.avsforum.com/forum/458-fu...l#post43234370
atabea is online now
post #349 of 895 Old 04-15-2016, 02:53 AM
Majister's Avatar
Liked: 60
It's amazing the kind of woods he gets. I have a 21.0 coming with a Bog Sequoia Burl with a polished finish. The wood itself can be hundreds (or more years old) and is undergoing the first stages of petrification. It's not petrified yet, but the process begins. The oxygen free, acidic environment of Bogs/muskeg does some serious magic to woods. In Nathan's words, he said a it's evil to work with because it want so crumble, but the effort and the end results are worth it. Obviously a very different look from the mahogany crotch in that photo (stunning) but staggering what he can and does work with. His main pic on his site for the 21.0 is done in santos rosewood - it has to be one of the most beautiful finishes I've seen. Just gorgeous. Someone on the forums here was the lucky one to snag that.
Sorry for going on, but I'm a sucker for rare woods (mahogany among them) and Funk Audio really scratches an itch for me.
Billy p, Hopinater and Red99 like this.
Majister is offline
post #350 of 895 Old 04-15-2016, 04:28 PM
Hopinater's Avatar
Liked: 9513
That's sounds incredible. Please post pics once you get your sub delivered... I'm sure there are many here who would love to see it (I know I do).
Majister likes this.
post #351 of 895 Old 04-15-2016, 04:44 PM
Majister's Avatar
Liked: 60
Will do!
Majister is offline
post #352 of 895 Old 04-17-2016, 02:44 PM
Red99's Avatar
Quoted: 776 Post(s)
Liked: 418
Nathan is an artist when it comes to Veneers. And the fit and finish is perfect and flawless.
But the looks are only part of the story. They sound incredible. I have tested mine crossed as high as 250 Hz and they still sound incredible. Very clean bass.
Billy p likes this.
Red99 is offline
post #353 of 895 Old 04-17-2016, 05:13 PM
Billy p's Avatar
Quoted: 352 Post(s)
Liked: 725
Yea...I've contacted Nathan and discussed some formal design plans at minimum with a 18.0C in Santos or Mahogany crotch. I can't commit on a build for this scheduling period. Once we settle into our new home...I'll be fully on board...maybe even the 18.0.
One of the things I would really like to experiment again is using a higher x-over....did some with my last subs but ran into some localization issues... new place will be a dedicated room so placement will be more flexible as well.
Billy p is offline
post #354 of 895 Old 04-17-2016, 07:16 PM
Red99's Avatar
Quoted: 776 Post(s)
Liked: 418
I am lucky and the best spots for my subs are near my front L/R speakers. So for me localization isn't a problem.
Red99 is offline
post #355 of 895 Old 04-18-2016, 11:05 PM
Majister's Avatar
Liked: 60
Wooo, well Nathan sent me a couple photos of my new 21.0 freshly veneered. Lots of work to go yet. But it's great to get an update like that. You can't get Bog Sequoia Burl in chunks or strips, so the corner inlays look like they will be santos rosewood. Nathan has a great eye for this stuff, so I certainly trust him! 2 of my Favorite woods, magically blended together. 👍 Should be a looker!
Majister is offline
post #356 of 895 Old 04-28-2016, 08:03 PM
Majister's Avatar
Liked: 60
Thread Bump! I'm hoping for more updates on your experiences! Love to hear more. I'm jonesing for my 21.0, alas I must be patient, which in some ways makes it more exciting! Pretty breathtaking performance from the sub. The driver is staggeringly well designed. I can hardly wait.
Majister is offline
post #357 of 895 Old 05-11-2016, 11:09 AM
Funk Audio's Avatar
Quoted: 123 Post(s)
Liked: 275
Thought you might be interested in the test/review just posted on Data-Bass http://www.data-bass.com/data?page=system&id=127
DS-21, Majister, audiofan1 and 4 others like this.
Nathan Funk
Funk Audio
post #358 of 895 Old 05-13-2016, 01:40 AM
Majister's Avatar
Liked: 60
Release the Kraken!!!
It is a beast
Majister is offline
post #359 of 895 Old 05-26-2016, 02:36 PM
Majister's Avatar
Liked: 60
Well, my 21.0 is getting close to completion...
Anyone else enjoying their new 21.0?
Majister is offline
post #360 of 895 Old 06-11-2016, 12:44 PM
Billy p's Avatar
Quoted: 352 Post(s)
Liked: 725
Ordered a FA 18.0C is Santos Rosewood the other day... Will be several weeks before I get my sub but no worries here.
Decision wasn't easy but at the end of the day it comes down to aesthetics(size, fit and finish) and with Funk Audio I believe I get overall package so to speak.
Countdown has begun but it's a ways away....as I told Nathan there is no rush since were just getting settled into our new home...
Billy p is offline
bass , funk audio , high-end , nathan funk , speaker , speakers , subwoofer
