Official Funk Audio Thread - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 913Likes
post #931 of 996 Old 06-24-2019, 09:19 AM
indebtbassfreak's Avatar
Quoted: 1345 Post(s)
Liked: 2532
Originally Posted by purplerain View Post
In 1 Gain is set to -5
NO EQ too
Try that to start, report back to what room correction set your trim at.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is online now
post #932 of 996 Old 06-24-2019, 10:31 AM
Liked: 2532
NO EQ too
Been almost an hour and a half,,,,,, did you get side tracked lol? Any updates? There are more setting options once you have a baseline done.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #933 of 996 Old 06-24-2019, 11:07 AM
purplerain's Avatar
Quoted: 207 Post(s)
Liked: 82
Set the Funk sub to NO EQ and -5
Ran YAPO and that set my sub level in the Yamaha to -8.5
Then manually set all to "small" and 80Hz's - Parametric EQ was set to flat in Yamaha already
***That's where I set as of now***
Not the best pics, but you get the point of amazing
toddct, ereed, Darian97 and 8 others like this.
*ENTERTAINMENT PURPOSES ONLY*
*TV: Sony XBR65Z9D* - *BD Player: Pioneer UDP-LX 500* - *AVR: Yamaha RX-A3070* - *Audio System: (2) Funk Audio 6.1P’s towers - (2) Funk Audio 3.4D’s surrounds - (1) Funk 18.0C sub*
purplerain is offline
post #934 of 996 Old 06-24-2019, 11:53 AM
Liked: 2532
Thats a good result already. I would bump the avr trim from -8.5 to -5 or -4. Then when listening to music set your Funk to the "music" preset, for movies, set the Funk preset to "home Theater", see if you like the results.
If you havent done it set your AVR volume readout to "relative" this will then make 0.0MV your reference volume. Your pictures make your mains look like there is no toe in, you may want to play with that. Looking good!!
Edit
Jon before you set your surround's to 80Hz what did room correction set them at? If room correction set the higher than 80Hz then 80Hz is not a good setting because manually setting X-overs lower than room correction can cause some information to be lost. Its ok to manually increase the X-over above room correction settings but not blow. Cheers!!
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #935 of 996 Old 06-24-2019, 12:51 PM
purplerain's Avatar
Quoted: 207 Post(s)
Liked: 82
Edit
I just did a redue...YAPO set the towers to 40Hz and the surrounds to 110Hz
indebtbassfreak likes this.
post #936 of 996 Old 06-24-2019, 12:56 PM
Liked: 2532
OK, set all to "small" leave surrounds at 110Hz put mains at 80Hz.
purplerain likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #937 of 996 Old 06-24-2019, 07:08 PM
Billy p's Avatar
Quoted: 352 Post(s)
Liked: 725
My media room only being <1.5^3....my Anthem &#115;et the initial &#115;ub gain at -10....I a&#115;ked Nathan a&#115;&#115;i&#115;tance in turing down &#115;ub&#115; volume. With &#115;ome tweak&#115;...and deciding on flat EQ...I wa&#115; able to re-run ARC...and get to within .5db&#115; of my main and &#115;ub gain &#115;et at~3.5. &#83;ound wi&#115;e...I'm in a very good place....but that KOA.... veneer look&#115; awe&#115;ome...your &#115;et up look&#115; tantalizing...well done.
Ascend Acoustics: Towers, STC w RAAL & 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo 103D,
Sub: Funk Audio 18: (Santos Rosewood)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
post #938 of 996 Old 06-24-2019, 07:25 PM
Liked: 2532
I'm seeing a lot of posts lately like above with "&#115" messing up the ability to understand whats been written. Is this an AVS glitch??
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #939 of 996 Old 06-25-2019, 12:17 AM
drh3b's Avatar
Quoted: 1866 Post(s)
Liked: 3381
Yes.
Something to do with Android and the mobile version of the site.
https://www.avsforum.com/forum/43-fo...l#post58192316
Spoiler!
drh3b is offline
post #940 of 996 Old 06-25-2019, 06:47 AM
Liked: 2532
Originally Posted by drh3b View Post
Yes.
Thanks drh3b, obviously a still unresolved issue. Cheers!!
drh3b likes this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #941 of 996 Old 06-25-2019, 07:18 AM
purplerain's Avatar
Quoted: 207 Post(s)
Liked: 82
Question Material care method
As for cleaning these Funk pieces, do you recommend a feather duster or some other polish for the wood (non gloss finish). I noticed some finger prints on the cone of the sub (my OCD). I took a clean cloth that was just slightly damp and gently rubbed the cone (I believe the cone is carbon/paper based?). Only thing that did was leave tiny fibers of the cloth stuck to the cone.
I have a rescue cat too with massive claws, but she is damn cool and never bothers my furniture and hopefully not my Funk's sub cone
post #942 of 996 Old 06-25-2019, 09:51 AM
Todeseng3l's Avatar
Quoted: 263 Post(s)
Liked: 426
Nathan's test measurements are looking good on the ULF Vented Beast ~112dB 10Hz 2m ground plane. Looks like we have a Cap killer on our hands
It really isn't a fair fight though, the Cap 4000 = 19.21ft3 The Beast = 31.59ft3
Todeseng3l is online now
post #943 of 996 Old 06-25-2019, 09:58 AM
imureh's Avatar
Quoted: 2676 Post(s)
Liked: 3206
And potentially more than twice the cost?
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #944 of 996 Old 06-25-2019, 12:01 PM
Hopinater's Avatar
Quoted: 3330 Post(s)
Liked: 10009
Now that's a huge subwoofer! Beautiful... but huge.
Todeseng3l and flat4 like this.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
post #945 of 996 Old 06-25-2019, 12:22 PM
Quoted: 1012 Post(s)
Liked: 1261
I'm thinking he'd prefer to sink his claws into that beautiful chunk of wood that you have bestowed upon him, as opposed to the driver side.
Sent from my SM-N920V using Tapatalk
Pradeep2 is offline
post #946 of 996 Old 06-25-2019, 12:43 PM
Liked: 2532
Understatement of the year I suspect triple, but worth it if one can afford, as quality difference are worlds apart.
Todeseng3l, iceatola and flat4 like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #947 of 996 Old 06-25-2019, 02:39 PM
Todeseng3l's Avatar
Quoted: 263 Post(s)
Liked: 426
That's like a Corvette guy posting in a Ferrari forum telling them that they aren't getting good value lol "My Z06 has 650HP, I can't believe you paid 4x more for an additional 60HP on your 488GTB".
Different strokes for different folks
flat4 and indebtbassfreak like this.
post #948 of 996 Old 06-25-2019, 03:03 PM
imureh's Avatar
Liked: 3206
That was not a knock I hope you know. You said it was not a fair fight so added on that it should not be a fair fight based on cost as well.
post #949 of 996 Old 06-25-2019, 03:40 PM
Todeseng3l's Avatar
Quoted: 263 Post(s)
Liked: 426
I didn't take it to be inflammatory, just offering a different perspective such as there is more to cars than HP just as there is more to subs than dB. I'm sure Nathan could slap together something to compete with the Cap 4000 at its price point and still beat it in raw output but it probably wouldn't live up to his standard of what a Funk sub is/have his name associated with it.
purplerain and flat4 like this.
post #950 of 996 Old 06-25-2019, 04:17 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2155 Post(s)
Liked: 3237
+1
Numbers are great, and I use them as much as the next guy, but it's only part of the story. 0-60 times give no clue as to how a car feels when making the run, so they should be used as reference only. Total output when something is pushed to the limit doesn't indicate what the subwoofer actually sounds like, only what it can measure. There is more to the equation than that.
Either way, I certainly wouldn't want to move around the Cap4000 or your Beast. I'm getting too old for that stuff...
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
post #951 of 996 Old 06-25-2019, 05:40 PM
ratbuddy's Avatar
Quoted: 647 Post(s)
Liked: 884
ROFL, what are the dimensions and weight of that thing???
ratbuddy is online now
post #952 of 996 Old 06-25-2019, 07:37 PM
Marc Alexander's Avatar
Quoted: 5270 Post(s)
Liked: 4794
And that is with a ~12Hz tune!
Todeseng3l likes this.
Marc Alexander is online now
post #953 of 996 Old 06-25-2019, 08:32 PM
Liked: 2532
I think 13.5Hz
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #954 of 996 Old 06-25-2019, 09:19 PM
Liked: 4794
I think 13.5Hz
I got that number from Nathan. PSA TV36x are 13.5Hz.
post #955 of 996 Old 06-25-2019, 09:37 PM
Liked: 2532
I'm amazed i can find my way home from the grocery store at times,,,,,, thanks for the correction Jim!!
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #956 of 996 Old 06-26-2019, 05:19 AM
Writer & Reviewer
JimWilson's Avatar
Liked: 3237
Jim? How did I get involved?
MaxTemp likes this.
post #957 of 996 Old 06-26-2019, 06:05 AM
Todeseng3l's Avatar
Quoted: 263 Post(s)
Liked: 426
To be exact it is 11.5Hz haha every tenth of a Hz counts!
26” wide 35” deep 60” high, don't know the weight yet- heavy
post #958 of 996 Old 06-26-2019, 06:34 AM
Liked: 2532
Lol,,,,, had company over "few beverages" a little distracted. Sorry Jim!!
Thanks for the correction Marc!!
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #959 of 996 Old 06-26-2019, 07:10 AM
imureh's Avatar
Liked: 3206
Thanks for the correction Mark!!
Mark? You mean Marc...keeps getting better.
post #960 of 996 Old 06-26-2019, 07:20 AM
Liked: 2532
Thanks imureh,,,,,, must go have coffee. Good god.
jamiebosco and JimWilson like this.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
bass , funk audio , high-end , nathan funk , speaker , speakers , subwoofer
