Help picking a sub for a 6000 cubic foot basement - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By orion2001
  • 1 Post By bear123
post #1 of 22 Old 10-09-2014, 08:51 AM - Thread Starter
ohioratrodder's Avatar
Quoted: 23 Post(s)
Liked: 0
I would like to stay under $1500 for a sub or dual subs. Right now i have a andrew jones 7 speaker setup(2 towers 4 bookshelf and a center) and a denon x4000 avr. Will be used for movies and games only. Was looking at getting 2 pb2000 but after tax because i live in ohio its right over what i wanted to spend(but not a deal breaker). Was wondering if there is other subs that are comparable cheaper or if the pb2000 or over kill for the speakers i currently have. I dont listen loud and never had a sub before so no idea what to expect or look for Also not against diy but i would have to buy a box as my wood skills are not great lol.(parts express is only 20 mins from my work but dont know if they have a store front) .
ohioratrodder is offline
post #2 of 22 Old 10-09-2014, 10:13 AM
Batman61405's Avatar
Quoted: 208 Post(s)
Liked: 205
6000 cubic feet is a pretty large space to fill. I would strongly suggest going ported as you were currently thinking. Duals would be the proper way to go IMO, and you can take advantage of the dual sub eq your denon x4000 has. Dual PB-2000s would be a great option for your budget. Is it possible to buy one sub for $1500 now and add a second later when you get the funds together? If that is an option I'd look at the Rythmik FV15 HP and then add a second later. Dual PSA XV15 SEs would be a great option too.
Dual setup if your stuck on $1500- SVS PB-2000s
Dual Setup for a little more money-Dual PSA XV15 SEs
Single sub and adding a second later- Rythmik FV15HP
Hopefully others chime in with other options as well. Good luck. I have a PB-2000 and I love it. It rocks! SVS and PSA offer free trials and free shipping both ways so Id order both and see what u like best and send back the other if you decide to spend a little more and go PSA.
Polk CS20Polk Tsi 500'sPolk Tsi 200'sDenon AVR 3300WSilver Ticket 92'' 16;9 White ScreenBenq HT2050 ProjectorXbox OneWii UPanasonic DMP-BDT 210SVS PB-4000Auralex MoPAD Paragon 4oz Theater Pop Popcorn MachineLogitech Harmony Elite
Batman61405 is offline
post #3 of 22 Old 10-09-2014, 10:23 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1358
At 1500, I would be looking at either dual Reaction V-15s or Hsu VTF3 mk4s. Either one should be at least as powerful as a PB2000 if not more so.
shadyJ is offline
post #4 of 22 Old 10-09-2014, 10:39 AM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 711
Gotta second these options. I'd go with dual Reaction Audio V-15's
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #5 of 22 Old 10-09-2014, 11:52 AM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
I would also look into building two ported Dayton 18 Ultimax. It should fit in budget and work great for a large basement. I have 2 of them in a 5300 cu ft. basement. Basement are tough and require multiple subs to get good ULF.
derrickdj1 is offline
post #6 of 22 Old 10-10-2014, 04:06 AM
Quoted: 95 Post(s)
Liked: 122
Dual PB-2000 gets my vote, but HSU and Reaction Audio are excellent options too.
Projector: LG PF1500W; Receiver: Sony STR-DN1080; Speakers: Monitor Audio Controlled Performance Inwalls and Inceilings; Subwoofer(s): SVS PC-2000; Bluray Player: Sony BDP-S6500; Remote: Roomie Remote; Cables: Monoprice
rnatalli is online now
post #7 of 22 Old 10-10-2014, 08:03 AM
orion2001's Avatar
Quoted: 462 Post(s)
Liked: 313
I hadn't noticed this till recently, but it looks like the PB-2000 drops off quite a bit slower than the VTF3 (seems like a 2X factor) below ~20Hz with both ports open for max output. It would seem that with in-room gain, the PB-2000 would likely be able to dig deeper. Would that be correct?
Recommended calibration settings for Samsung PN60F5300B
orion2001 is offline
post #8 of 22 Old 10-10-2014, 08:31 AM
orion2001's Avatar
Quoted: 462 Post(s)
Liked: 313
Maybe pick up 3, PC12-NSDs for $1500 while stock lasts (won't last very long at this price!) - http://www.svsound.com/subwoofers/cylinder/pc12-nsd
nashou66 likes this.
post #9 of 22 Old 10-10-2014, 01:22 PM
shadyJ's Avatar
Liked: 1358
They will both drop off at roughly a 24/dB octave slope. On the VTF3 that can be mitigated somewhat with the Q control. I think the VTF3 would be able to dig slightly deeper as it can be used with a 16 hz tuning point whereas the PB2000 has a 17 or 18 Hz tuning point if I remember right.
shadyJ is offline
post #10 of 22 Old 10-10-2014, 01:26 PM
bear123's Avatar
Quoted: 2651 Post(s)
Liked: 4147
For that large of a space, I would start with the Rythmik FV15-HP. It could end up being all the sub you could ever want. If not, buy another some day. If I were in your shoes, that is the sub I would start with.
dsrussell likes this.
bear123 is online now
post #11 of 22 Old 10-10-2014, 01:34 PM
saevox's Avatar
lil mike cinema f20! build 2 or 3 or 4 for that budget
saevox is offline
post #12 of 22 Old 10-10-2014, 01:35 PM
orion2001's Avatar
Quoted: 462 Post(s)
Liked: 313
Looks like the PB2000 drops off at ~24dB/octave. Maybe I am misreading, but doesn't it look like the VTF3 drops off a lot quicker?
post #13 of 22 Old 10-10-2014, 01:47 PM
shadyJ's Avatar
Liked: 1358
It looks like the VTF3 drops off at a 48 dB octave slope in that chart. I may have been wrong in assuming all the ported Hsu subs dropped off at a 24 dB slope, but there could be other factors involved in that chart. Best to drop Hsu a message to ask them I suppose. The mk3 and mk2 dropped off at a 24 dB octave slope, and I assumed, perhaps erroneously, that the mk4 model does as well. Either way, a lower tuning point will get you more deep bass than a more gradual rolloff.
shadyJ is offline
post #14 of 22 Old 10-10-2014, 05:53 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 0
thanks everyone know i have a lot more to look at. how would dual pc12-nsd be.? they on sale right now for $950. i know pb2000 are better but are they $500 better or any other sub current suggested in this thread
post #15 of 22 Old 10-10-2014, 07:59 PM
shadyJ's Avatar
Liked: 1358
Two PC12 NSD for 950 has to be the best bang for the buck at the moment. I would grab them while the getting is good. There are better subwoofers out there, but not for that price, as far a I know. Not even two will come close to a Rythmik FV15HP in output and extension though, but a FV15HP costs a lot more. On the other hand, with careful placement, two PC12 NSDs should be able to do more to smooth out the frequency response, and two will take greater advantage of Audyssey's SubEQ which is onboard your Denon X4000.
shadyJ is offline
post #16 of 22 Old 10-12-2014, 03:19 PM
primetimeguy's Avatar
Quoted: 715 Post(s)
Liked: 465
ohioratrodder, I'm in the same boat with same size room and was looking at dual PB-2000's. Did you make a decision yet?
primetimeguy is offline
post #17 of 22 Old 10-12-2014, 04:07 PM
bgtighe23's Avatar
Quoted: 1846 Post(s)
Liked: 1231
Dual outlaw lfms. Wait til the season when they go on sale for $499 shipping. And save $500. Or buy 3
bgtighe23 is offline
post #18 of 22 Old 10-12-2014, 04:41 PM
bear123's Avatar
Liked: 4147
You posted the VTF-3.4 in max output, or two port mode. Here it is in one port mode:
Looks to me like both subs dig pretty low. I have had the PB2000 in my room and it was quite flat down to almost 15 Hz.
post #19 of 22 Old 10-12-2014, 06:17 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 0
no not yet. hard to decided
post #20 of 22 Old 10-12-2014, 06:19 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 0
whats the diffence bewteen pb2000 and xv15se?
post #21 of 22 Old 10-13-2014, 05:11 AM
orion2001's Avatar
Quoted: 462 Post(s)
Liked: 313
I thought the two port mode would be the apples to apples comparison as both subs are at max output mode (with max output on the VTF being likely higher than what the PB2000 can achieve). In either mode, the fall off slope looks to be 48dB/octave as opposed to 24dB/octave on the PB2000. That being said, if 1 port mode provides enough output for someone's room, then it is quite impressive and digs a bit deeper than the PB2000.
post #22 of 22 Old 10-13-2014, 07:04 AM
pennynike1's Avatar
Quoted: 652 Post(s)
Liked: 26
6000 cubic feet is a lot of space to fill. Have you considered the Pro Version of the JTR Orbit Shifter? It is tuned for 37 hz, but retails for $1,799 passively. Cross it over at 32 hz and get an inexpensive 2nd sub to handle the low-end until you can afford something better. Just a thought.
pennynike1 is online now
