eD sub died - trying to think outside the box! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By WhskyTangoFoxtrt
post #1 of 13 Old 10-28-2014, 11:32 AM - Thread Starter
stream's Avatar
Hi guys - my eD sub's plate amp was recently trashed by our 2-year-old (long story involving the port and a sippy cup). I've looked into replacing the plate amp, but I can't find one with the same cutout size, and I'm not much of a woodworker. I'd absolutely love to just toss the old sub and throw a new PB-1000 in there, but WAF is exceptionally low on a $500 purchase right now. So, I'm trying to think outside the box.
I have a pair of Klipsch RF-7's that each have dual 10's, powered by a Denon x4000. I realized that I have four 10" woofers in my room right now - is there a better way I can drive those to "replace" a sub, at least temporarily? I could probably get away with $200 or $300 for another amp, etc. Or would it make more sense to just re-run Audyssey with a 5.0 setup, and let it adjust accordingly?
Throw some ideas at me!
stream is offline
post #2 of 13 Old 10-28-2014, 12:08 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1359
which ED sub do you have at the moment? You don't really need a plate amp, you can still use an outboard amp.
shadyJ is offline
post #3 of 13 Old 10-28-2014, 02:46 PM
Tom Vodhanel's Avatar
Quoted: 3049 Post(s)
Liked: 10457
Which sub and how big is the amp plate?
Tom V.
Power Sound Audio
Tom Vodhanel is offline
post #4 of 13 Old 10-28-2014, 04:45 PM - Thread Starter
stream's Avatar
The sub is an eD A2-300, and the plate amp was labeled LT-200. The cutout size is 7.25" square - plate amp is 8.25" square.
I've found a couple of plate amps on Parts Express that are close, but I'm not much of a woodworker, and I'm worried I wouldn't get a good seal if I tried to fabricate/modify something.
stream is offline
post #5 of 13 Old 10-28-2014, 04:54 PM
Liked: 10457
I'll check around my house and see if anything matches. You can also consider just modifying the plate amp you have so a pair of the binding posts on the outside just pass the single directly to the sub terminals. Then you can use an outboard amp connected to the old ED amp(still mounted to the sub) with speaker wiring.
Tom V.
Power Sound Audio
post #6 of 13 Old 10-28-2014, 05:31 PM
Hrimnir's Avatar
I've had this same exact sub for the better part of a decade now. Been real happy with it. Hope you find a solution to your problem.
Klipsch RF-62 L/R, RC-62 C, Energy C-100 SL/SR, HSU VTF-15H, Marantz SR7008.
"All speakers sound good when you're on a coke binge in the middle of an orgy." - Heebdawg16
Hrimnir is offline
post #7 of 13 Old 10-29-2014, 07:49 AM
Liked: 10457
Tom V.
Power Sound Audio
Sorry, nothing I have is close. I even checked our PSA amps. I have seen your amp before though. It looks like something stock rebadged. Let me think about this today...I might be able to come up with the exact amp if I can remember where I saw it.
Tom V.
Power Sound Audio
post #8 of 13 Old 10-29-2014, 10:23 AM - Thread Starter
stream's Avatar
Tom V.
Power Sound Audio
Great, thank you!
stream is offline
post #9 of 13 Old 10-29-2014, 10:41 AM
WhskyTangoFoxtrt's Avatar
Quoted: 78 Post(s)
Liked: 58
You might consider contacting @daveds50 about repairing or replacing the amp.
Archaea likes this.
WhskyTangoFoxtrt is offline
post #10 of 13 Old 10-29-2014, 03:11 PM
Liked: 10457
Great, thank you!
Sorry, struck out(so far). One idea is to grab the inuke 1000 ($149) and use one channel(300 watts) to power the sub. But it will have loud cooling fans so you'll want to keep the amp away from the seating positions. Usually you would want some control of the limiters, EQing, etc when replacing a plate amp but from what I have seen the eD stuff wasn't very "fine tuned" in that regard anyway..
Otherwise, check with Dave(as Whiskey just linked). I'll keep looking as time allows too.
Tom V.
Power Sound Audio
post #11 of 13 Old 10-30-2014, 11:01 AM
Archaea's Avatar
Quoted: 3923 Post(s)
Liked: 3733
pull the amp, seal the hole with a board, some caulk, and a binding post plate.
Buy an iNuke DSP 1000.
It'll be a cheap fix, and will perform better than any plate amp you can buy for similar cost. You can use the DSP to protect the driver by limiting voltage (how many watts the sub receives), or by tailoring EQ and HPF.
Archaea's 9.12.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is offline
post #12 of 13 Old 11-11-2014, 07:37 PM - Thread Starter
stream's Avatar
Hi guys - ordered a new SVS PB-1000 today, so this thread is a bit of a moot point now.
However, while I was staring at the disassembled eD in the garage today, wondering what the heck I'd do with it, something struck me. What if I found a decent used sub amp on eBay, patched the cutout, and ran the eD along with the PB-1000 as a pair? Would they totally clash with each other, or might it be worth it? My HT room is very large and could definitely use the extra oomph.
stream is offline
post #13 of 13 Old 11-11-2014, 08:25 PM
flyng_fool's Avatar
Quoted: 190 Post(s)
Liked: 172
You can make different subs play nice with each other, but it requires a bit of work with level and phase matching. Not super hard, but you have to do some research to know what you're doing.
Television: Vizio E70iA3
Processor: Emotiva MC700
Surrounds: AT 2200 LR Sub: Danley DTS-10Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
