Sharing subwoofer between home theatre and 2-channel systems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-05-2015, 10:50 PM - Thread Starter
breadvan's Avatar
Hi there,
Is there an effective method of sharing a sub, mine a PC-13 Ultra with the older BASH amp, between a HT system with digital EQ, and a 2-channel system with a preamp having dual balanced output?
breadvan is offline
post #2 of 5 Old 03-06-2015, 05:21 AM
Transmaniacon's Avatar
Quoted: 1788 Post(s)
Liked: 1628
Do you have both systems in the same room?
5.1: Samsung PN60F5300 | Sony BDP-S1700 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
2.0: Oppo DV-980H | Apple Airport Express | Topping D30 | Parasound HCA-1500a | Chane A1.4
Transmaniacon is offline
post #3 of 5 Old 03-07-2015, 06:43 PM
BassThatHz's Avatar
Quoted: 3777 Post(s)
Liked: 4297
Yes. I use one of these:
http://www.parts-express.com/behring...-cros--248-669
It can accept up to 3 inputs (Left, Right, LFE) and outputs up to 6 subs, in any matrixed or summed combination.
It also has 9 independent variable: delay, phase, XO, DEQ/PEQ/Limiter DSP channels. It has everything you need and then some...
For your AVR or processor, you likely need one of these:
http://www.monoprice.com/Product?c_i...seq=1&format=2
Then you'll just need a bunch of XLR cables of various lengths:
https://www.parts-express.com/talent...8-ft--240-9480
https://www.parts-express.com/talent...0-ft--240-9107
https://www.parts-express.com/talent...5-ft--240-9102
This way you can have up to 6 subs. (Any combination of: Left, Right, LFE or bi-summed.)
I use two of them, and I'm buying a 3rd soon (got a lot of subs and speakers.)
Here is about half of the available screens (there are literally a 1000 settings, with a million combinatorial combinations if you use all 9 XLR wires, or in my case... 18+ XLR!!!)
Once you get passed the learning curve it is actually quite simple. and changeable with a flick of the wrist.
BassThatHz is offline
post #4 of 5 Old 03-10-2015, 06:36 PM - Thread Starter
breadvan's Avatar
sorry for the late reply, yes I do, both systems share the same powered speakers.
breadvan is offline
post #5 of 5 Old 03-10-2015, 06:38 PM - Thread Starter
breadvan's Avatar
http://youtu.be/QlykCxSPSSs
Wow thanks for the detail advice, I gotta to study these link to see if I can handle all the new buttons
Much appreciated.
breadvan is offline
