Official Deep Sea Sound Thread - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 2241Likes
post #1981 of 2003 Old 05-21-2019, 06:36 AM
Quoted: 166 Post(s)
Liked: 151
Originally Posted by dgage View Post
I had to order some heavy duty threaded inserts as I didn't like the standard threaded inserts available from my local supplier. With the heavy duty threaded inserts, the 7" feet were rock solid and the cabinet didn't move a bit when we were jamming in the warehouse. So it looks like there are no issues with the feet.
My driver builder knows a painter so he's going to drop some 18" and 24" dustcaps to be painted chrome along with the clamping pieces that go around the 24. So hopefully we'll have some pictures of a chrome accessorized driver soon.
Wow that looks great. I like it off the floor a bit. Very elegant and makes the sub look more expensive too! If you screw in the feet with the sub on it’s side, is it then safe to tip it upright without damaging the feet?
ianrozzano is online now
post #1982 of 2003 Old 05-21-2019, 08:09 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1795 Post(s)
Liked: 1713
No, I don’t think you could tip the sub upright as the legs would probably break. Don’t know for sure as I didn’t try but I wouldn’t trust it. What we did is stack some wood underneath so the sub was 9” off the floor in the same orientation and then installed the feet. Then two of us just lifted the sub and placed it in its final resting place near the wall. We were then able to “skate” it into final position.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #1983 of 2003 Old 05-21-2019, 11:46 AM
Quoted: 166 Post(s)
Liked: 151
Okay that makes sense. I was thinking of using an automotive floor jack. You could roll it around too if you’re careful. I assume you could always swap out the legs for another style if you wanted to. I like the option to customize
post #1984 of 2003 Old 05-21-2019, 12:21 PM
ereed's Avatar
Quoted: 2304 Post(s)
Liked: 1624
You are better off buying large furniture sliders that can slide around. Once you decide the final spot just remove one slider out at a time. If you do swap the legs in future just have someone help you lift and flip and lay on its side and then change feet and then lift and flip back. Like David said....I wouldn't flip the sub on its feet as it can break the thread inserts.
Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1075 | Rotel RMB-1077 | Rotel RSP-1068 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
ereed is offline
post #1985 of 2003 Old 05-21-2019, 12:27 PM
Deep Sea Sound
dgage's Avatar
Liked: 1713
There are threaded inserts in the bottom for standard 5/16-18 threads so as long as the replacement feet had the same screw threads, they’d swap out no problem.
And this is similar to what we used to move the sub around with, again we stacked wood up to get us to 9” so we could easily screw the feet on. Lifting was easy since we just rolled in front of where we wanted to move the sub and then picked up the sub briefly and set it down in place. Easy and no having to twist the enclosure from horizontal to vertical.
https://www.homedepot.com/p/Milwauke...3700/100057209
David Gage
Deep Sea Sound
dgage is offline
post #1986 of 2003 Old 07-09-2019, 12:33 PM
ereed's Avatar
Liked: 1624
Any updates on the chrome sub build?
ereed is offline
post #1987 of 2003 Old 07-11-2019, 05:56 PM
Deep Sea Sound
dgage's Avatar
Liked: 1713
Originally Posted by Molon_Labe View Post
Looks like a fat broad in high heels
Chris - There’s no reason to be jealous. Let me know and I can send out a retrofit kit for your 24s if you’d like.
Molon_Labe likes this.
David Gage
Deep Sea Sound
dgage is offline
post #1988 of 2003 Old 07-11-2019, 06:01 PM
Deep Sea Sound
dgage's Avatar
Liked: 1713
The customer was researching and considering a fall purchase. But I knew if I didn’t test with the feet at the time, it wouldn’t get done in a timely fashion. But we learned that tall feet will work as long as they are leveled to the floor. And if we want the cone silver, it will need to be painted.
ereed likes this.
David Gage
Deep Sea Sound
dgage is offline
post #1989 of 2003 Old 07-12-2019, 05:37 AM
ereed's Avatar
Liked: 1624
Only if they are pink
Careful! David may end up painting them hot pink and send them on your way.....and then you would be FORCED to show off your new sub makeover.
iceatola and Molon_Labe like this.
ereed is offline
post #1990 of 2003 Old 07-12-2019, 06:15 AM
Mocs123's Avatar
Quoted: 218 Post(s)
Liked: 114
I just think it's funny that a 24" sub isn't attention grabbing enough and he needs crome on it. I would think a 24" sub would hit you in the face when you walked in the room. You don't see that every day - most people think an 18" is a huge sub.
7.4.4 Theater Room: JVC-RS46U, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 270’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is online now
post #1991 of 2003 Old 07-12-2019, 07:36 AM
ereed's Avatar
Liked: 1624
One of the posters wanted a chrome finish since he had a specific look in mind. For some reason I thought it was already in the works on being built. Looks like its just speculation at this point. and if David can do what the poster wanted....which he said he can. Now the Poster needs to go forward! Cause I wanna see it!
ereed is offline
post #1992 of 2003 Old 07-12-2019, 11:38 AM
Deep Sea Sound
dgage's Avatar
Liked: 1713
When we were exhibiting the side table version of the Mariana 24 a few years ago at THE Newport Show in LA, there were more than a couple attendees that came in the room, made a disgusted face, and left. It could have been the TV but more than likely it was the 24 that didn’t fit with their audiophile sensibilities. Of course, I’d put my 24 against any 12” sub in an even test of accurate, articulate, and tight bass but some people have their mind made up that a big sub can’t be quick. Physics says a 75lb motor-magnet doesn’t have a problem moving a 1.5lb cone.
David Gage
Deep Sea Sound
dgage is offline
post #1993 of 2003 Old 07-12-2019, 12:46 PM
Quoted: 166 Post(s)
Liked: 151
If you saw the eclectic and flashy vibe at my place you might understand why I prefer the sub to have some shine on it too. Hitting someone in the face with a 24” sub isn’t enough for me. I want jaws dropped and bowels loosened. Figuratively of course.
That being said, I will push forward on this thing when the moment is right. Unfortunately Trump screwed us transportation workers pretty hard with his new tax laws. Usually we get to write off a ton of traveling expenses but these standard deductions are a b*tch. Went from an $8-10k return to owing $3k. That cost you a sale, Dave. F*ck it. It’s only money and I can always make more. I drive freight trains for a living so I’d like to think I’ve personally moved some DSS subs at some point. Maybe I will be hauling my own soon enough. Or maybe it stays on the truck the whole way?
Frohlich likes this.
post #1994 of 2003 Old 07-12-2019, 04:44 PM
Frohlich's Avatar
Quoted: 2053 Post(s)
Liked: 2258
David is building me a couple of subs that I am picking up in early August. I figure I can put "Buckeyes rule!!!" on one and "UT Sucks" on the other.
Is that wrong????
Frohlich is offline
post #1995 of 2003 Old 07-12-2019, 05:39 PM
Quoted: 166 Post(s)
Liked: 151
Originally Posted by Frohlich View Post
David is building me a couple of subs that I am picking up in early August. I figure I can "Buckeyes rule!!!" on one and "UT Sucks" on the other.
Is that wrong????
If it is wrong, I don’t wanna be right.
post #1996 of 2003 Old 07-12-2019, 06:23 PM
Deep Sea Sound
dgage's Avatar
Liked: 1713
The subs ship to you via freight truck but I’m sure some of the parts, while assembled in the US (enclosures, amps, drivers), the parts came from around the world and I’m sure some traveled by ship and by train. So thanks for helping transport some of our components. I’m ready to send you the fully assembled sub whenever you’re ready. The test sub is still in the same place with the feet and we play it periodically so no rush.
David Gage
Deep Sea Sound
dgage is offline
post #1997 of 2003 Old 07-12-2019, 06:27 PM
Deep Sea Sound
dgage's Avatar
Liked: 1713
Is that wrong????
That is absolutely wrong, first by defacing the beautiful subs and secondly by knocking my alma mater. But as long as you cover up the foul wording when I visit, you may do what you want with them. Not sure how such defacing will affect the warranty though.
Frohlich and grtuck like this.
David Gage
Deep Sea Sound
dgage is offline
post #1998 of 2003 Old 07-12-2019, 07:02 PM
Quoted: 166 Post(s)
Liked: 151
That is absolutely wrong, first be defacing the beautiful subs and secondly by knocking my alma mater. But as long as you cover up the foul wording when I visit, you may do what you want with them. Not sure how such defacing will affect the warranty though.
If you consider that foul wording then I’m thoroughly embarrassed for my language earlier. Please excuse me.
dgage likes this.
post #1999 of 2003 Old 07-12-2019, 07:06 PM
Frohlich's Avatar
Liked: 2258
Doth taketh David too seriously. We are friends and have met each other in person multiple times. It was all in good fun. Your language was fine. We are meeting up in person in August to do some exchanges and hopefully enjoy a good meal together. You don't need me to tell you, but David is good people
Frohlich is offline
post #2000 of 2003 Old 07-12-2019, 07:34 PM
Deep Sea Sound
dgage's Avatar
Liked: 1713
I’m pretty sure “UT Sucks” is much, much worse than what you wrote but I think I’m biased.
David Gage
Deep Sea Sound
dgage is offline
post #2001 of 2003 Old 07-12-2019, 08:57 PM
Quoted: 166 Post(s)
Liked: 151
It’s all good, brothers. I should have added a “haha” in there somewhere. I curse like Al Swearengen but I have manners like Seth Bullock, that f*cking c*cksucker.
post #2002 of 2003 Old 07-13-2019, 05:10 AM
madhuski's Avatar
Quoted: 1334 Post(s)
Liked: 865
Is that wrong????
Seems acceptable. I’m still not over the 1995 season citrus bowl.
What subs are you going with??
madhuski is online now
post #2003 of 2003 Old 07-13-2019, 10:32 AM
Frohlich's Avatar
Liked: 2258
Dual 18 singles. I had JTS s2 subs in my current basement set-up that was an open space on concrete and it was more than I ever needed. I am moving to a new house with an enclosed 18 by 14 room above a garage with wood floors. I will have triple JBL M2s up front that create plenty of bass in their own right, the Deep Sea subs will be icing (very nice icing ) on the cake.
Frohlich is offline
