Crown XLS DriveCore 2 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 42 Old 04-29-2015, 07:46 PM - Thread Starter
coolrda's Avatar
Quoted: 1391 Post(s)
Liked: 1508
Don't know if this has been mentioned but there's a new amp on the horizon which I believe to be noteworthy for a number of reason. As many of us here, I've been waiting on an amp that fits my criteria of a good sub amp, Quiet Fan, High Sensitivity, OnBoard Usable DSP, Remote Turn On and Good Looks. While these don't give us the 12V remote, it has a good many features. First is the switchable sensitivity between 1.4v and .775v which will eliminate the gain stage incompatibility issues that mixing home and pro sound gear bring to the table. Of course the improved onboard DSP eliminates yet another component in the signal chain which is always a good thing. So if the new versions fans remain as quiet as series one's fan, we could have a winner here, especially with the new, much improved looks. Cost appears to be the same.
coolrda is online now
post #2 of 42 Old 04-29-2015, 07:55 PM - Thread Starter
coolrda's Avatar
Liked: 1508
Looking at the back of the amp it could actually have a remote trigger. The brochure says it does but IT could be some type of prosound trigger I'm unfamiliar with. Heres hoping.
post #3 of 42 Old 04-29-2015, 07:58 PM - Thread Starter
coolrda's Avatar
Liked: 1508
post #4 of 42 Old 04-30-2015, 06:17 AM
NWCgrad's Avatar
Quoted: 1283 Post(s)
Liked: 1332
The ability to turn off all the LED's is nice! Looks like they know there customer base is expanding and are responding (trigger, ability to turn off the lights, etc.).
Now I have a conundrum, I just bought a XLS 1500 with plans to buy at least three more. Looks like I may be selling it and getting 4 of the newer models. Would be cool if the expanded DSP has PEQ but the info is pretty scanty so far.
______________________________________
Home Theater:
https://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #5 of 42 Old 04-30-2015, 09:08 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2729
I wonder if the DSP is as powerful as the DSi DSP ?
Mfusick is offline
post #6 of 42 Old 05-01-2015, 08:18 AM
Skylinestar's Avatar
Quoted: 1312 Post(s)
Liked: 268
I doubt there's any PEQ.
Quote from the product page:
Higher DSP capabilities: More control; has band pass filter per channel
...that's all ?
Skylinestar is offline
post #7 of 42 Old 07-09-2015, 04:15 PM
AV Hack's Avatar
Quoted: 146 Post(s)
Liked: 79
HP filter is removable.
Better x-over range and setings.
AV Hack is offline
post #8 of 42 Old 07-09-2015, 05:09 PM
DonH50's Avatar
Quoted: 3311 Post(s)
Liked: 3421
The XLS series to date has included a 20 Hz roll-off so this amp might not be suitable for subwoofers.
YMMV - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #9 of 42 Old 07-09-2015, 09:08 PM
Stereodude's Avatar
Quoted: 4344 Post(s)
Liked: 3085
No it doesn't. This is an internet urban legend started by some clueless Crown employees.
Stereodude is offline
post #10 of 42 Old 07-09-2015, 09:24 PM
DonH50's Avatar
Liked: 3421
Hmmm... The clueless Crown employee I spoke with was Aaron, feel free to call him. He had to check, then followed up because he had the roll-off incorrect (second-order vs. fourth-order depending on whether DSP is used or not).
DonH50 is offline
post #11 of 42 Old 07-11-2015, 08:32 AM
Stereodude's Avatar
Liked: 3085
And a different forum member called and spoke to someone else at Crown and was told there wasn't one. I can't find the post right now though.
I trust my measurements more than I trust some random Crown employee who answers the phone. My measurements when testing the amps for a subsonic impedance dip overload issue clearly demonstrate there is no high pass filter at 20Hz. If there were the problem I measured wouldn't exist. I had to implement a HPF on the input to stop the behavior. Further, I did compare the measured in room frequency response to a QSC amp I measured flat to ~2.5Hz and didn't find any noteworthy differences.
post #12 of 42 Old 07-11-2015, 10:52 AM
Quoted: 1300 Post(s)
Liked: 2118
As stereodude points out--the proof is in the testing
I own a 2014 Crown XTi1002 for my garage speakers and have the limiter set to -2.5dB both for speaker, hearing and not going to jail protection. It drives the mid/highs as I have subwoofer plate amps for the subs.
Although I own a Crown, I'm not a fanboy as the proof is in the testing. Not feeling positive about this as Crown tends to be better at marketing and not very forthcoming with the specifications. The "DSP" is a bandpass filter which would be great if it could be used as a 15Hz high pass ASSuming the amplifier can put out full power that low.
I'll be in the market for a 300 to 600 WPC PA amp to push two (or four) subs in the next year or two--eagerly await testing of the "new" Crowns.
18Hurts is online now
post #13 of 42 Old 07-11-2015, 12:19 PM
DonH50's Avatar
Liked: 3421
Interesting, and disappointing since I went back and forth several times over a few days to try to get a right answer. We went back and forth on the differences between the DSP settings and such, and he said he had checked with other engineers. Argh. Oh well, proof's in the measurements. I have never owned a QSC amp, and the only Crown XLS I have used are in our church sound system where a separate amp does sub frequencies. I don't have one around to measure. I was told that, while the XLS series had filters (both subsonic and ultrasonic), the XTi series does not. I do not know since I have not measured them.
I have used Crown amps in pro installs and for sound reinforcement work for decades but only rarely had one in my personal stereo (AV, now) system.
My apologies for doubting, but I had read all the same stuff, and thought I had gotten the right answer. - Don
DonH50 is offline
post #14 of 42 Old 07-24-2015, 09:42 AM
mwne2nks's Avatar
Thanks to Musicians Friend, I am the proud owner of 2 XLS 1000. They were on closeout for $ 149.00 each. I plan to power 4 12" subs ohmed down to 4. This should give me about 1100 per side .If I don't like them I'll repurpose them to drive the outside speakers.
mwne2nks is offline
post #15 of 42 Old 08-07-2015, 10:04 AM
worldturning75's Avatar
I've had the new Crown XLS 2502 for several days which has replaced an XLS 2000.
Aesthetically, I do like the overall look, but I find the 2 front blue led's and the lcd screen to be too bright and somewhat annoying in my HTS setup so I have them set to sleep after 5 minutes. I wish they kept the small blue light on the power button from the gen 1 xls series. The signal presence indicators cannot be put to sleep.
worldturning75 is offline
post #16 of 42 Old 08-07-2015, 11:00 AM
DonH50's Avatar
Liked: 3421
Black electrical tape works over the LEDs. You could also cover the display, but in the past my solution for that has been a piece of black construction paper taped across the top like a hinge so I can flip it up if I need to see the display. Otherwise it's hidden behind the cardboard. I make it a little oversize to reduce light bleed from the edges.
You could also use translucent tape or sheets to tone them down without hiding them completely.
HTH - Don
DonH50 is offline
post #17 of 42 Old 08-10-2015, 01:04 AM
Speed Daemon's Avatar
Quoted: 91 Post(s)
Liked: 47
If electrical tape is too extreme, just pick up one of those lighting gel color sample books, cut or punch out some of the appropriately dark colors, and glue or scotch tape them over the LEDs as needed. That's what I do to tone down those obnoxious baby blue lights that every hipster loves and I hate.
You get what you pay for.  For professional advice, pay the professional rate.
Speed Daemon is offline
post #18 of 42 Old 08-10-2015, 12:20 PM
Thanks Don and Speed Daemon.
I do usually go the electrical or masking tape route with the obnoxious blinking lights on my routers/access points.
If you look at the DriveCore 2 pictures from the original post, the lights are much brighter in actuality, imo. The actual signal lights aren't bad, but the two blue solid lights on the front and lcd screen are. I just have the lcd screen set to sleep right now.
post #19 of 42 Old 08-22-2015, 01:39 PM
DotJun's Avatar
Quoted: 598 Post(s)
Liked: 163
Any reason to. It use this series for LCR duty or is there a better series for LCR?
DotJun is offline
post #20 of 42 Old 08-22-2015, 07:17 PM
Liked: 268
If you need RCA consumer level (0.775v) input , I think this is the best so far. All the other models require a pro level (1.4v) input, except the XLi models
post #21 of 42 Old 09-03-2015, 08:09 PM
crimsonblue's Avatar
Quoted: 138 Post(s)
Liked: 89
I am going to be adding in some 18" subs in the near future and I was wondering how people think these new Crown amps compare to the iNuke DSP series? I have the [now]-old version of the Crown XLS series and they are great, but I do want to make sure that there is some DSP on my sub amps.
Does anyone have any thoughts on how they might compare?
________________________________________________
Home theater build 1 | Black & Grey Theater 2 | Yet Unnamed Theater 3
Marantz AV7702mkII | Epson 5040 | 7.2.4 Elusive 1099 LCR + Volt 8 Atmos & Surrounds + Dual UM18 Subs
crimsonblue is offline
post #22 of 42 Old 09-04-2015, 12:16 PM
Liked: 2118
From the information I have gathered...
The amp sections are the same, they added a bandpass function for the crossover, added 12V turn on, added 0.775V RCA level inputs, can switch off the output lights and made it black. It would be a GREAT amp for mains as long as DSP and below 20Hz does not matter.
It is fine as a PA amp but is lacking in two things for HT use: true DSP and ability to go below 20Hz without limiting. The proof of what it can do will come out when it's bench tested--maybe it can do infrasound--maybe. Still, no DSP to adjust for sealed EQ or protect ported subs down in the teens.
This might change in the future with the continued march of EDM--after all, Harmon is more concerned with the needs of the PA market over some nut cases trying to put IMAX in the basement.
post #23 of 42 Old 10-10-2015, 07:31 PM
biliam1982's Avatar
Quoted: 735 Post(s)
Liked: 396
Anyone figure out how to use the auto-on feature?
biliam1982 is offline
post #24 of 42 Old 10-20-2015, 01:14 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4797
Originally Posted by CBdicX View Post
Hello, i will use the XLS1000 to drive the woofers of a Klipsch RP280FA (no subwoofer in use), tweeters will be done by a Denon X7200WA, so it will be a Bi-amp setup.
Can anyone tell me what Crossover mode i must select on the XLS, and what frequency ?
Are you taking the passive crossover components out of the speakers?
ps What happened to your subs you made?
lovinthehd is offline
post #25 of 42 Old 10-20-2015, 02:39 AM
lovinthehd's Avatar
Liked: 4797
You're giving your speakers full range signal now if you bi-amp them as you're leaving the passive components in the speakers, so continue to give them a full range signal. I suppose you could try and put a low pass setting on the Crown to limit the range for additional power via upping the gain on the Crown, but how are you sure you will get enough signal to be able to significantly raise the gain to act in the range you want? Seems like a waste of time to me.
ps You shouldn't hijack threads, particularly when you aren't even talking the same model range as this thread. Start one.
post #26 of 42 Old 11-15-2015, 03:27 PM
wse
wse's Avatar
Quoted: 2207 Post(s)
Liked: 814
Originally Posted by worldturning75 View Post
I've had the new Crown XLS 2502 for several days which has replaced an XLS 2000. Aesthetically, I do like the overall look, but I find the 2 front blue led's and the lcd screen to be too bright and somewhat annoying in my HTS setup so I have them set to sleep after 5 minutes. I wish they kept the small blue light on the power button from the gen 1 xls series. The signal presence indicators cannot be put to sleep.
Do they sound different? What speakers and pre/pro do you have?
wse is offline
post #27 of 42 Old 11-20-2015, 02:18 PM
In my opinion, no difference in sound between the DriveCore 1 & 2's and I guess there really shouldn't be any difference.
Currently using a pair of PSA MTM-210 speakers for L/R. I also have a pair of Paradigm Signature S8's that I used to run with a Crown XLS-2000.
post #28 of 42 Old 12-02-2015, 12:31 PM
kschmit2's Avatar
Wow, haven't logged in here for years.
Can anyone who owns a XLS DriveCore 2 series amp please do me a favor and look what the lowest frequencies are that can be selected in bandpass mode.
I'm converting Klipsch KSP-400 speakers to external amplification for the bass section and therefore I'm looking for an amp that can set to a bandpass filter to allow around 20 Hz - 100 Hz to feed my 15 inch subs.
If there is no way to select a lower limit in the 20 Hz range, I can just as well go with the 1500 instead of the 1502 and mate it with something like a Reckhorn B-1.
Any help would be appreciated.
kschmit2 is offline
post #29 of 42 Old 12-02-2015, 01:38 PM
lovinthehd's Avatar
Liked: 4797
It will be in the manual just like it is for the 1500, wouldn't it?
post #30 of 42 Old 12-02-2015, 01:57 PM
kschmit2's Avatar
For the record: I checked the manual before posting, and unlike the manual for the XLS DriveCore 1 series, the manual for the XLS DriveCore 2 series does not contain the relevant information.
(http://rdn.harmanpro.com/product_doc...5_original.pdf)
I wouldn't have asked here if the information was readily available.
kschmit2 is offline
