Do subs sound best at 80Hz and under only (crossovers)? - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
post #361 of 426 Old 11-06-2015, 09:56 AM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 2776 Post(s)
Liked: 966
Originally Posted by Alan P View Post
Yes, most auto-EQ does roll off the high end, yours just seems to be a more gradual slope than others I've seen. Yours seems to start dropping at around 600hz. For a quick comparison, here is mine. Pay no attention to that huge dip at 64hz, I've since fixed that.
Well, my roll off is natural since I have auto eq off.
PlasmaPZ80U is online now
post #362 of 426 Old 11-06-2015, 09:57 AM
Alan P's Avatar
Quoted: 6137 Post(s)
Liked: 5349
As long as the high-end doesn't sound too toned downed to you, you're golden.
PlasmaPZ80U likes this.
Alan P is offline
post #363 of 426 Old 11-06-2015, 10:00 AM - Thread Starter
Liked: 966
It's sounds pretty sweet. For the $260 I spent on my LCRs ($390 retail), I'm very satisfied. And they're not overwhelmed by my Rythmik sub.
Alan P likes this.
post #364 of 426 Old 11-06-2015, 12:14 PM - Thread Starter
Liked: 966
Originally Posted by braveheart123 View Post
I've seen you getting blown away many a times in this thread. Your opinion about perfect bass, IOW your preferred bass, would change many times before you finally realize what sounds best in your set up and in your room.
Happy hunting.....
I'm currently giving high extension/damping a try for at least a few days to see if I like it. Do I need to bother with generating a new set of filters based on the high extension/damping frequency response with no EQ applied? Or does this current frequency response (see attached) look suitable (hc1, mid based filters)?
https://www.avsforum.com/forum/attachment.php?attachmentid=1042241&d=1446828537
post #365 of 426 Old 11-06-2015, 07:44 PM
braveheart123's Avatar
Quoted: 337 Post(s)
Liked: 289
High ext/damping alters the FR below 30Hz; it doesn't just control dampening. So, you should apply new filters or at least run YPAO again.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #366 of 426 Old 11-06-2015, 07:52 PM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 65
80Hz seems like a bit of a stretch for most mids, so I would give 90-100Hz a listen before pulling the trigger. Forget 120Hz !
Carrick is offline
post #367 of 426 Old 11-07-2015, 06:06 AM - Thread Starter
Liked: 966
If it's not too much trouble, what is the minimum EQ you can apply that simply gets rid of the 2 peaks and the dip in between them (without any net boost when all filters are summed)? I want to preserve as much of the existing FR as possible (minus the 2 peaks and dip in between them).
Samsung 55" MU8000
Yamaha RX-A2070
KEF Q150 Bookshelf x 5
Rythmik L12 Sealed Subwoofer
post #368 of 426 Old 11-07-2015, 03:43 PM - Thread Starter
Liked: 966
Originally Posted by pviljaka View Post
Are you sure you have your MiniDSP 2x4 unbalanced set as Mono and not Stereo, in its settings? You should not have to use y-cable etc. I believe you have some setup error somewhere. Maybe in your receiver its -10dB for LFE if its not the MiniDSP? If it was the MiniDSP it would lower all bass under XO and not just LFE portion.
Removing all filters in the MiniDSP makes YPAO set the sub trim a whopping 8dB lower. So, I guess that is the price to pay for aggressive cutting of huge peaks.
post #369 of 426 Old 11-08-2015, 05:27 AM - Thread Starter
Liked: 966
For info purposes, here's an overlay of the response differences between low/mid/high without any EQ applied. However, since sub placement and gain knob position did vary (and measures were weeks apart amongst other variables), they are not an exact match past 100Hz to about 200Hz.
Name:	no EQ overlay.png
Samsung 55" MU8000
Yamaha RX-A2070
post #370 of 426 Old 11-08-2015, 11:09 AM
Quoted: 337 Post(s)
Liked: 289
Nothing more can be done with your current placement. Either change the location or change the room or enjoy what you have right now till the time you move your setup in a more acoustically friendly room.
post #371 of 426 Old 11-08-2015, 11:21 AM - Thread Starter
Liked: 966
I decided to experiment a bit with the filters I like best...
Name:	sub EQ capture.PNG
ID:	1046185   Click image for larger version
Name:	before and after sub EQ.png
ID:	1046193   Click image for larger version
ID:	1046201   Click image for larger version
Name:	LCRs full range.png
Samsung 55" MU8000
Yamaha RX-A2070
post #372 of 426 Old 11-08-2015, 11:49 AM - Thread Starter
Liked: 966
I basically removed the first filter to preserve the high damping characteristics and then tweaked the dip filter to avoid any boost (0dB gain at 60Hz). Do you think this should sound good?
Samsung 55" MU8000
Yamaha RX-A2070
post #373 of 426 Old 11-08-2015, 12:15 PM - Thread Starter
Liked: 966
I appreciate all the help you gave with the 5 sets of filters I currently have. At this point, I'd like to learn how to manually create filters myself and perhaps get suggestions from as many AVS members as possible. I think I'll start a new thread in the Audio Theory and Setup section so I can learn how to fish as opposed to asking for fish.
(I really just want to tweak things to my personal preferences at this point and since no one knows exactly what I prefer other than myself, learning how to create filters and what kinds of FR curves to target should be the next step for me.)
Samsung 55" MU8000
Yamaha RX-A2070
post #374 of 426 Old 11-08-2015, 12:38 PM
checker9's Avatar
Quoted: 1482 Post(s)
Liked: 352
What about the auto EQ that REW creates?
checker9 is online now
post #375 of 426 Old 11-08-2015, 12:44 PM - Thread Starter
Liked: 966
I can't seem to get it to target the kind of house curve I want (or even close for that matter)... perhaps the house curve feature in the preferences window might be the answer...
Samsung 55" MU8000
Yamaha RX-A2070
post #376 of 426 Old 11-08-2015, 01:12 PM - Thread Starter
Liked: 966
I must have done something right, because right now watching previews before the start of my BD movie sounds very tactile and punchy for high damping. Not too weak like in the past. Getting rid of that 30Hz filter must be why.
post #377 of 426 Old 11-08-2015, 01:46 PM
DotJun's Avatar
Quoted: 597 Post(s)
Liked: 163
Can I ask why you are taking measurements and doing eq from 1m vs your MLP or is the distance just coincidence?
DotJun is offline
post #378 of 426 Old 11-08-2015, 02:25 PM - Thread Starter
Liked: 966
1M sweep is measurement quality in REW, not distance between mic and sub.
Mic is in MLP (exactly)
Samsung 55" MU8000
Yamaha RX-A2070
post #379 of 426 Old 11-17-2015, 05:10 PM - Thread Starter
Liked: 966
I gave higher crossovers a try with the LV12R and after a day...
Went back to 80Hz crossover and simply cranked up sw trim to compensate. It seems each 10Hz step from 120Hz to 80Hz resulted in cleaner, clearer, more tight and precise bass. 120Hz and 110Hz were quite bad sounding, whereas 100Hz and 90Hz were a lot better but still noticeably off.
yanks1 likes this.
post #380 of 426 Old 11-17-2015, 09:24 PM
Quoted: 337 Post(s)
Liked: 289
That's coz the sub ends up playing upper harmonics as well above the fundamental xo frequency. The higher you set the xo; the higher the upper harmonics seep into sub response, which sounds awful. That's the reason wall linings are used inside the sub to attenuate upper harmonics should you decide to use higher xo. But that can only do so much.
One alternative is to cascade two LPFs i.e. engage LPF on AVR and sub as well. The net effect of two LPF will cut upper harmonics and you may be able to get away with higher xo setting.
post #381 of 426 Old 11-17-2015, 11:30 PM
Skylinestar's Avatar
Quoted: 1308 Post(s)
Liked: 267
But what's up with Rythmik subs can go as high as 200Hz? Is it ok to use 200Hz if I have dual subs next to my fronts?
http://www.rythmikaudio.com/FV15HP_specs.html
Frequency Response 12 - 200 Hz (-2 dB @ 17 Hz, [email protected]) with LFE input
Skylinestar is offline
post #382 of 426 Old 11-18-2015, 02:15 AM
Quoted: 337 Post(s)
Liked: 289
That's too high an xo. I wouldn't do that. Even the weakest and cheapest of bookshelves can play down to 120Hz. With an xo of 120Hz fundamental frequency, the sub would end up playing till 240Hz (2nd harmonic). You can even hear 360Hz (3rd harmonic) if LPF has shallow slope.
Most of the male and some of the female voices will be bloated and directional. Now it is a separate case, if one has trained ears to discern the difference. But I guess mostly would.
In your case, you may get away with it if you place your subs next to mains.
post #383 of 426 Old 11-18-2015, 06:39 AM - Thread Starter
Liked: 966
Interesting, so using the 24dB/octave setting on LV12R and/or lower crossover/lpf frequency could allow higher crossovers without sound quality suffering?
Or using the crossover feature in the MiniDSP to apply exactly the lpf I want?
Though I wonder if it's worth the trouble over sticking with 80Hz crossovers...
post #384 of 426 Old 11-18-2015, 07:29 AM - Thread Starter
Liked: 966
I'm going to try 24dB/octave lpf slope on the LV12R while sticking with a 80Hz crossover to see if that sounds even better than 12dB/octave on the LV12R. It's only one flip of a switch so easy enough to try. Though I might need to redo the sw distance tweak...
post #385 of 426 Old 11-18-2015, 08:23 AM - Thread Starter
Liked: 966
Initial impressions are more articulate but weaker... will do REW measures and sw distance tweak later I'm curious what the sub only measure will look like.
post #386 of 426 Old 11-18-2015, 09:37 AM - Thread Starter
Liked: 966
results (sw trim was already optimal for CC+sub):
Name:	80Hz Crossover and sub trim 4dB hot.png
Samsung 55" MU8000
Yamaha RX-A2070
post #387 of 426 Old 11-18-2015, 09:47 AM - Thread Starter
Liked: 966
oddly enough, sub only comparison is exactly the same:
Samsung 55" MU8000
Yamaha RX-A2070
post #388 of 426 Old 11-18-2015, 10:11 AM - Thread Starter
Liked: 966
Samsung 55" MU8000
Yamaha RX-A2070
post #389 of 426 Old 11-18-2015, 10:12 AM - Thread Starter
Liked: 966
^ looks pretty similar especially when you consider the 12dB/oct measure was with sw trim 2.5dB hot and 24dB/oct measure was with sw trim 4dB hot
Samsung 55" MU8000
Yamaha RX-A2070
post #390 of 426 Old 11-19-2015, 12:38 PM - Thread Starter
Liked: 966
@braveheart123 , do you know why my measures look the same between 12 and 24dB per octave on the LV12R? Am I measuring the wrong thing? Because I can definitely hear a difference and since the sw distance remained at 11.2ft between both lpf slopes, the only reason it should sound different is due to the sub's lfp slope setting.
